[General] Pass Guaranteed Quiz 2026 UiPath UiPath-ADPv1: UiPath (ADPv1) Automation Develop
57
General Pass Guaranteed Quiz 2026 UiPath UiPath-ADPv1: UiPath (ADPv1) Automation Develop
Posted at 1/30/2026 21:07:44      View269 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsActual UiPath-ADPv1 PDF Dumps and UiPath-ADPv1 Exam Engine Free Share: https://drive.google.com/open?id=1fvb7TYTo_kQgFTU-5tk3rql2xdy2dGi0
DumpsActual is a leading platform that has been helping the UiPath-ADPv1 exam candidates for many years. Over this long time period, countless UiPath UiPath-ADPv1 exam candidates have passed their dream UiPath (ADPv1) Automation Developer Professional (UiPath-ADPv1) certification and they all got help from valid, updated, and Real UiPath-ADPv1 Exam Questions. So you can also trust the top standard of UiPath-ADPv1 exam dumps and start UiPath-ADPv1 practice questions preparation without wasting further time.
UiPath UiPath-ADPv1 Exam Syllabus Topics:
  • Design and Development: This section covers designing workflows using sequences, flowcharts, and state machines, building reusable components with libraries, exception handling and debugging techniques, etc.
  • UiPath Studio Fundamentals: In this section, the focus is given to the understanding of Robotic Process Automation (RPA) concepts; it covers UiPath Studio and its components, Working with the UiPath user interface, project creation, management, and version control.
  • UiPath Activities: In this section, the discussion is related to various UiPath activities for UI interaction, data manipulation, control flow, and more.
  • Debugging and Testing: This section is about utilizing logging and debugging tools and adopting unit testing and test automation strategies.
UiPath-ADPv1 Pass4sure Study Materials & UiPath-ADPv1 Download DemoWe update our UiPath-ADPv1 Test Prep within one year and you will download free which you need. After one year, we provide the client 50% discount benefit if buyers want to extend their service warranty so you can save much money. If you are the old client, you can enjoy some certain discount when buying UiPath-ADPv1 exam torrent so you can enjoy more service and more benefits. Our update can provide the latest and most useful UiPath (ADPv1) Automation Developer Professional prep torrent to you and you can learn more and master more. Because we update frequently, the client can understand the latest change and trend in the theory and the practice. So you will benefit from the update a lot.
UiPath (ADPv1) Automation Developer Professional Sample Questions (Q86-Q91):NEW QUESTION # 86
"Process A" is scheduled to run at 2:00 PM using a time trigger with the Schedule ending of Job execution feature configured to stop the job after 20 minutes. Assuming that the robots are busy and "Process A" is queued until 2:05 PM. at what time will "Process A* be stopped?
  • A. 2:25 PM
  • B. 2:20 PM
  • C. 2:05 PM
  • D. 2:28 PM
"Process A":
* The process is scheduled to run at 2:00 PM, but due to busy robots, it starts at 2:05 PM.
* The Schedule ending of Job execution feature is configured to stop the job after 20 minutes.
* Therefore, "Process A" will be stopped 20 minutes after it started, which is at 2:25 PM.
NEW QUESTION # 87
What actions must be manually selected in the App/Web Recorder before recording a step?
  • A. Click on buttons, links, and other clickable elements such as icons or images.
    Type text in a text area such as a text box.
    Select or clear a check box.
    Send keyboard shortcuts using your keyboard.
    Select an item from a drop-down.
  • B. Copy text using the Get Text activity.
    Hover over an element using the Hover activity.
    Highlight an element using the Highlight activity.
  • C. Copy text using the Get Text activity.
  • D. Select or clear a check box.
In UiPath's App/Web Recorder, certain actions need to be selected or indicated before they can be recorded.
These include:
*Clicking on buttons, links, and other interactive elements.
*Typing text into input fields.
*Selecting or clearing checkboxes.
*Sending keyboard shortcuts.
*Selecting items from drop-down menus.
Based on these common actions that are typically used in UiPath recording, the answer that best fits is:
A: Click on buttons, links, and other clickable elements such as icons or images. Type text in a text area such as a text box. Select or clear a check box. Send keyboard shortcuts using your keyboard. Select an item from a drop-down.
These are the actions that you would manually select or perform during the recording process to automate interactions with a UI.
NEW QUESTION # 88
Suppose you have the following workflow that verifies if the text value of an element is equal to "Work Items":
The configuration for the Verify Control Attribute and Get Text activities is shown below:
The element and its selector are highlighted in the image below:
Taking into consideration that the page shown above will be present on screen at execution time, what will be the result of the Verify Control Attribute activity?
  • A. Verification will be passed.
  • B. Verification will be failed because the actual value is different than expected value.
  • C. An exception will be thrown because there is no variable set in the Save to property of the Get text activity.
  • D. Verification will not be executed.
The workflow in question uses a 'Verify Control Attribute' activity to check if the text value of a UI element is equal to "Work Items". The Get Text activity is used to retrieve the text from the specified UI element, and the result of this activity is compared against the expected value "Work Items".
From the provided information, the 'Verify Control Attribute' activity has been set up with the Expression
"Work Items" and the Operator set to Equality. The 'Get Text' activity is configured to extract the text from the UI element with the visible text "Work Items", as indicated by the selector shown in the image.
Since the actual value of the UI element's text is "Work Items" (which matches the expected value in the
'Verify Control Attribute' activity), and provided that the 'Get Text' activity successfully retrieves this value, the verification will pass. The configuration indicates that the activity should take a screenshot only if the verification fails (TakeScreenshotIfFailed is set to True), which will not be the case here.
Therefore, assuming that there are no other issues such as incorrect selectors or unexpected changes to the UI element at execution time, the result of the 'Verify Control Attribute' activity will be a pass.
* UiPath Documentation: Verify Control Attribute Activity
NEW QUESTION # 89
What is the default polling interval set for an event trigger?
  • A. 10 minutes
  • B. 15 minutes
  • C. 5 minutes
  • D. 1 minute
NEW QUESTION # 90
What is the use of job priorities in unattended automations within UiPath Orchestrator?
  • A. To create job dependencies that must be completed before new job execution.
  • B. To sort and organize tasks within a folder.
  • C. To determine machine resource allocation among processes.
  • D. To determine which processes should be executed first when dealing with multiple jobs.
The use of job priorities in unattended automations within UiPath Orchestrator is to determine which processes should be executed first when dealing with multiple jobs. Job priorities are values that can be assigned to jobs or triggers when they are created or edited. The possible values are High, Normal, and Low. Job priorities affect the order in which the jobs are executed by the robots, with higher priority jobs being executed before lower priority jobs. Job priorities can help you to optimize the execution of your unattended automations, especially when you have limited resources or time-sensitive processes. You can also use job priorities to create job dependencies that must be completed before new job execution, by using the Start Job activity with the Wait for completion option and setting the priority of the child job to High. References: [Job Priority],
[Start Job]
NEW QUESTION # 91
Our UiPath-ADPv1 guide torrent boosts 98-100% passing rate and high hit rate. Our UiPath (ADPv1) Automation Developer Professional test torrent use the certificated experts and our questions and answers are chosen elaborately and based on the real exam according to the past years exam papers and the popular trend in the industry. The language of our UiPath-ADPv1 study torrent is easy to be understood and the content has simplified the important information. Our product boosts the function to simulate the exam, the timing function and the self-learning and the self-assessment functions to make the learners master the UiPath-ADPv1 Guide Torrent easily and in a convenient way. Based on the plenty advantages of our product, you have little possibility to fail in the exam.
UiPath-ADPv1 Pass4sure Study Materials: https://www.dumpsactual.com/UiPath-ADPv1-actualtests-dumps.html
BTW, DOWNLOAD part of DumpsActual UiPath-ADPv1 dumps from Cloud Storage: https://drive.google.com/open?id=1fvb7TYTo_kQgFTU-5tk3rql2xdy2dGi0
Posted at 2/15/2026 19:06:29        Only Author  2#
Thank you for your article, it really opened my eyes! The HPE6-A86 test cram exam questions are freeyour key to a brighter career and higher salary!
Posted at 2/19/2026 12:19:49        Only Author  3#
Great content; my like is locked in. Free Reliable study questions KCNA free download to boost your IT skills. Best wishes for success!
