[Hardware] C_CPI_2506 Study Center, Test C_CPI_2506 Score Report
93
【Hardware】 C_CPI_2506 Study Center, Test C_CPI_2506 Score Report
Posted at 1/30/2026 22:40:14      View:145 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New C_CPI_2506 dumps are available on Google Drive shared by Actual4Cert: https://drive.google.com/open?id=1P3OfWgaxiFT2VdXY_6HeWBCsK3F6ecmN
The simulation of the actual C_CPI_2506 test helps you feel the real C_CPI_2506 exam scenario, so you don't face anxiety while giving the final examination. You can even access your last test results, which help to realize your mistakes and try to avoid them while taking the SAP Certified Associate - Integration Developer (C_CPI_2506) certification test.
SAP C_CPI_2506 Exam Syllabus Topics:
  • SAP Integration Suite Overview: This section of the exam measures the skills of Integration Consultants and covers the foundational concepts of the SAP Integration Suite. It provides an understanding of the suite’s capabilities, its role in connecting applications, and its relevance in modern cloud-based integration scenarios.
  • Managing APIs: This section of the exam measures the skills of Solution Architects and focuses on managing APIs within the SAP ecosystem. It covers topics such as API provisioning, lifecycle management, security policies, and monitoring, ensuring candidates can handle APIs effectively for enterprise integration needs.
  • Implementing Cloud Integration: This section of the exam measures the skills of Integration Consultants and examines how cloud integration flows are designed and deployed. It emphasizes creating integration scenarios, handling connectivity, and applying best practices to build efficient, secure, and reliable integration processes in SAP’s cloud environment.
  • SAP Event Mesh: This section of the exam measures the skills of Solution Architects and centers on using SAP Event Mesh to support event-driven integration. It highlights the importance of asynchronous communication, event publishing, and subscription models, allowing organizations to build scalable and decoupled systems.
Test C_CPI_2506 Score Report | C_CPI_2506 Practice EngineOur company has become the front-runner of this career and help exam candidates around the world win in valuable time. With years of experience dealing with C_CPI_2506 exam, they have thorough grasp of knowledge which appears clearly in our C_CPI_2506 Exam Questions. All C_CPI_2506 study materials you should know are written in them with three versions to choose from: the PDF, Software and APP online versions.
SAP Certified Associate - Integration Developer Sample Questions (Q38-Q43):NEW QUESTION # 38
You want to set up Exchange Properties in an integration flow. Besides a Con-tent Modifier, what can you use?
  • A. XML scripting
  • B. Batch scripting
  • C. Groovy SDK scripting
  • D. Python scripting
The Groovy SDK scripting can be used to set up Exchange Properties in an integration flow. The Groovy SDK scripting allows you to access and manipulate message headers, properties, and payloads using Groovy scripts. You can use the setProperty method to set an Exchange Property with a name and a value. Reference: Modernize Integration with SAP Integration Suite | openSAP
NEW QUESTION # 39
Which log level must you use to examine the payload at specific processing steps in an integration flow?
  • A. Info
  • B. Error
  • C. Trace
  • D. Debug
To examine the payload at specific processing steps in an integration flow, you must use the Trace log level. The Trace log level provides the most detailed information about the message processing, including the payload content and the headers at each step. You can use the Message Processing Log to view the trace logs for a specific message. Reference: Modernize Integration with SAP Integration Suite | openSAP
NEW QUESTION # 40
What must you do to find out which entity sets are available in the OData V2.0 interface?
  • A. Retrieve the service document from the interface.
  • B. Contact the OData interface manufacturer
  • C. Search in the Global Directory of all available OData interfaces.
  • D. Retrieve the metadata document form the interface.
To find out which entity sets are available in the OData V2.0 interface, you must retrieve the metadata document from the interface. The metadata document is an XML document that describes the data model of the OData service, including the entity types, entity sets, associations, functions, and actions. The metadata document can be accessed by appending $metadata to the service root URL of the OData service. For example, if the service root URL is https://services.odata.org/OData/OData.svc/, then the metadata document URL is https://services.odata.org/OData/OData.svc/$metadata. The metadata document can be used to discover the structure and capabilities of the OData service and to generate client code or proxies. Reference: Overview (OData Version 2.0) | OData - The Best Way to REST, OData API v2 Reference | SAP Help Portal
NEW QUESTION # 41
You configured a content modifier as follows: Action: Create | Name: ProductID | Source Type: XPath Source Value: //ProductID | Data Type: java.lang.string. After testing the content modifier, you receive an error message that contains the following fragment: "Java.lang.ClassNotFoundException: java.lang.string..." What caused the error message?
  • A. Incorrect source type
  • B. Incorrect name
  • C. Incorrect source value
  • D. Incorrect data type
In SAP Cloud Integration, when defining Content Modifier properties, the Java data type names are case- sensitive.
Correct type # java.lang.String
In the configuration, java.lang.string was used (lowercase "s"), which causes a ClassNotFoundException, since Java cannot find the class.
Other options are correct in form:
Source Type = XPath # Valid.
Source Value = //ProductID # Valid XPath.
Name = ProductID # Valid.
Thus, the error occurred because of incorrect data type specification.
NEW QUESTION # 42
To activate the Event Mesh (EMIS) capability in the SAP Integration Suite, which role collections must be assigned to the user performing the activation?
  • A. Integration_Administrator and Security_Auditor
  • B. Integration_Provisioner and Subaccount Administrator
  • C. Process_orchestrator and Subaccount_Viewer
  • D. API_Manager and Monitoring-Viewer
To activate Event Mesh (EMIS) capability in SAP Integration Suite, the required role collections are:
Integration_Provisioner # Allows provisioning of new capabilities (including Event Mesh) in Integration Suite.
Subaccount Administrator # Grants permission to manage and configure subaccount-level entitlements and service activations.
Other options:
Integration_Administrator, API_Manager, Monitoring_Viewer # Used for operational tasks, not provisioning.
Process_orchestrator # Refers to on-premise PI/PO, not BTP roles.
Security_Auditor # Auditing role, not activation.
Thus, the correct roles are Integration_Provisioner and Subaccount Administrator.
NEW QUESTION # 43
Free update for 365 days is available for C_CPI_2506 study guide, so that you can have a better understanding of what you are going to buy. Through free demo, you can also know what the complete version is like. In addition, with experienced experts to compile the C_CPI_2506 Exam Dumps, quality can be guaranteed. Therefore, if you choose us, you can use them at ease. We have online and offline chat service stuff, who are quite familiar with C_CPI_2506 study guide, if you have any questions, you can consult us.
Test C_CPI_2506 Score Report: https://www.actual4cert.com/C_CPI_2506-real-questions.html
BONUS!!! Download part of Actual4Cert C_CPI_2506 dumps for free: https://drive.google.com/open?id=1P3OfWgaxiFT2VdXY_6HeWBCsK3F6ecmN
Posted at 2/4/2026 19:29:21        Only Author  2#
This article has helped me answer many questions, and it's really great. Thanks to the Test AIP-210 discount, I received a promotion and raise. It's now free to all. Hope your promotions come soon!
