[Hardware] ANS-C01 Top Dumps, ANS-C01 Brain Exam
91
Hardware ANS-C01 Top Dumps, ANS-C01 Brain Exam
Posted at 1/31/2026 03:55:35      View727 | Replies7        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassTestking ANS-C01 dumps from Cloud Storage: https://drive.google.com/open?id=1d1sbMLhOSfCgvZg1OYWoy61EsxnBJMSG
Our Amazon ANS-C01 dumps assists the candidates of the test with its three formats to advance their preparation as per various learning needs. A team of experts at PassTestking has designed the ANS-C01 Pdf Format to help applicants who are too busy to prepare intensively for the Amazon ANS-C01 certification exam on the first go.
The service of ANS-C01 test guide is very prominent. It always considers the needs of customers in the development process. There are three versions of our ANS-C01 learning question, PDF, PC and APP. Each version has its own advantages. You can choose according to your needs. Of course, you can use the trial version of ANS-C01 Exam Training in advance. After you use it, you will have a more profound experience. You can choose your favorite our study materials version according to your feelings. When you use ANS-C01 test guide, you can also get our services at any time.
ANS-C01 Brain Exam, ANS-C01 Reliable Test CramSome candidates may want to get the ANS-C01 exam braindumps as soonas possible after they buying it, if you also want to get the ANS-C01 exam braindumps quickly, we can do it for you. You pay for the ANS-C01 exam dumps, we will send you the downloading link and password to you about five to ten minutes by email. Whats more our ANS-C01 Exam Braindumps is of high quality, it will help you to pass the exam successfully.
Amazon AWS Certified Advanced Networking Specialty Exam Sample Questions (Q239-Q244):NEW QUESTION # 239
A company has deployed a software-defined WAN (SD-WAN) solution to interconnect all of its offices. The company is migrating workloads to AWS and needs to extend its SD-WAN solution to support connectivity to these workloads.
A network engineer plans to deploy AWS Transit Gateway Connect and two SD-WAN virtual appliances to provide this connectivity. According to company policies, only a single SD-WAN virtual appliance can handle traffic from AWS workloads at a given time.
How should the network engineer configure routing to meet these requirements?
  • A. Disable equal-cost multi-path (ECMP) routing on the transit gateway for Transit Gateway Connect.
  • B. Configure the BGP community tag 7224:7300 on the primary SD-WAN virtual appliance for BGP routes toward the transit gateway.
  • C. Configure the AS_PATH prepend attribute on the secondary SD-WAN virtual appliance for BGP routes toward the transit gateway.
  • D. Add a static default route in the transit gateway route table to point to the secondary SD-WAN virtual appliance. Add routes that are more specific to point to the primary SD-WAN virtual appliance.
NEW QUESTION # 240
A company is migrating an application from on premises to AWS. The company will host the application on Amazon EC2 instances that are deployed in a single VPC. During the migration period, DNS queries from the EC2 instances must be able to resolve names of on-premises servers. The migration is expected to take 3 months After the 3-month migration period, the resolution of on-premises servers will no longer be needed.
What should a network engineer do to meet these requirements with the LEAST amount of configuration?
  • A. Set up an AWS Client VPN connection between on premises and AWS. Deploy an Amazon Route 53 Resolver inbound endpoint in the VPC.
  • B. Set up an AWS Direct Connect connection with a public VIF. Deploy an Amazon Route 53 Resolver inbound endpoint in the Region that is hosting the VPC. Use the IP address that is assigned to the endpoint for connectivity to the on-premises DNS servers.
  • C. Set up an AWS Direct Connect connection with a private VIF. Deploy an Amazon Route 53 Resolver inbound endpoint and a Route 53 Resolver outbound endpoint in the Region that is hosting the VPC.
  • D. Set up an AWS Site-to-Site VPN connection between on premises and AWS. Deploy an Amazon Route 53 Resolver outbound endpoint in the Region that is hosting the VPC.
Setting up an AWS Site-to-Site VPN connection between on premises and AWS would enable a secure and encrypted connection over the public internet1. Deploying an Amazon Route 53 Resolver outbound endpoint in the Region that is hosting the VPC would enable forwarding of DNS queries for on-premises servers to the on-premises DNS servers2. This would allow EC2 instances in the VPC to resolve names of on-premises servers during the migration period. After the migration period, the Route 53 Resolver outbound endpoint can be deleted with minimal configuration changes.
NEW QUESTION # 241
A company wants to analyze TCP internet traffic. The traffic originates from Amazon EC2 instances in the company's VPC. The EC2 instances initiate connections through a NAT gateway.
The company wants to capture data about the traffic including source and destination IP addresses ports, and the first 8 bytes of the TCP segments of the traffic. The company needs to collect, store, and analyze all the required data points.
Which solution will meet these requirements?
  • A. Configure the NAT gateway to be a VPC traffic mirror source. Deploy software on the traffic mirror target to forward the data to an Amazon S3 bucket. Analyze the data by using Amazon Athena.
  • B. Turn on VPC Flow Logs for the EC2 instances. Specify a custom format and set Amazon S3 as the log destination. Analyze the flow log data by using Amazon Athena.
  • C. Turn on VPC Flow Logs for the EC2 instances. Specify the default format and set Amazon CloudWatch Logs as the log destination. Analyze the flow log data by using CloudWatch Logs Insights.
  • D. Configure the EC2 instances to be VPC traffic mirror sources. Deploy software on the traffic mirror target to forward the data to Amazon CloudWatch Logs. Analyze the data by using CloudWatch Logs Insights
This solution meets the requirements for capturing detailed TCP internet traffic, including source and destination IP addresses, ports, and the first 8 bytes of TCP segments. By configuring the EC2 instances as traffic mirror sources and deploying a software solution on the target to forward the captured traffic to CloudWatch Logs, you can analyze the traffic in-depth using CloudWatch Logs Insights. VPC traffic mirroring is ideal for capturing low-level network traffic, providing the necessary data points for analysis.
NEW QUESTION # 242
Why is referencing the Application Load Balancer or Classic Load Balancer by its DNS CNAME recommended?
Response:
  • A. IP addresses are public and open to the Internet.
  • B. DNS CNAMEs provide a lower latency than IP addresses.
  • C. You want to preserve the source IP of the client.
  • D. IP addresses may change as the load balancers scale
NEW QUESTION # 243
You need to create a subnet in a VPC that supports 1000 hosts. You need to be as accurate as possible since you run a very large company. What CIDR should you use?
Note: Answers to this question are not verified by our experts, please study yourself and select the appropriate answers.
Contribute: Please send the correct answers with reference text/link on feedback@VMexam.com to get up to 50% cashback.
Response:
  • A. /22
  • B. /16
  • C. /24
  • D. /7
NEW QUESTION # 244
Amazon ANS-C01 certification exam is a very difficult test. Even if the exam is very hard, many people still choose to sign up for the exam. As to the cause, ANS-C01 exam is a very important test. For IT staff, not having got the certificate has a bad effect on their job. Amazon ANS-C01 certificate will bring you many good helps and also help you get promoted. In a word, this is a test that will bring great influence on your career. Such important exam, you also want to attend the exam.
ANS-C01 Brain Exam: https://www.passtestking.com/Amazon/ANS-C01-practice-exam-dumps.html
Whats more, the ANS-C01 questions and answers are the best valid and latest, which can ensure 100% pass, And we offer you free updates for ANS-C01 learning guide for one year, Amazon ANS-C01 Top Dumps You can mark the important knowledge points on your paper, which is a very effective way to understand the difficult points, Now you can trust ANS-C01 practice questions and start preparation without wasting further time.
Writing queries, including joins, functions, and subqueries, Working with Text Flow, Whats more, the ANS-C01 Questions and answers are the best valid and latest, which can ensure 100% pass.
ANS-C01 test questions, ANS-C01 dumps torrent, ANS-C01 pdfAnd we offer you free updates for ANS-C01 learning guide for one year, You can mark the important knowledge points on your paper, which is a very effective way to understand the difficult points.
Now you can trust ANS-C01 practice questions and start preparation without wasting further time, Now it is your chance.
DOWNLOAD the newest PassTestking ANS-C01 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1d1sbMLhOSfCgvZg1OYWoy61EsxnBJMSG
Posted at 2/8/2026 01:22:31        Only Author  2#
Your article is truly inspiring, Im so grateful for your sharing! The 1z0-1065-25 reliable test sims materials are excellent, and you can access them for free.
Posted at 2/13/2026 22:47:03        Only Author  3#
ҡϤʤṩΤ¤һȫĤCisco300-745}ǡⰲȫُ뱣Ϥǡ⥿`Cisco300-745ԇYΥեȥθ¤ǤoϥǥϤʤ˰Ĥُ뤷ơُ뤷1gΟoCisco300-745ԇYθ¤Ϥʤ˰ĤԇYʂ䤹뤳ȤǤޤʤϴ_gُݤޤ뤳ȤǤޤ˽ΥեȥԇƤߤƤҡϤʤһĤΤҡ_kयY˺ϸ񤵤Cisco300-745ԇYΥեȥǤ
Posted at 2/14/2026 05:21:19        Only Author  4#
Thank you for your brilliant article; it truly shocked me! Im giving you the exact 77202T latest test cram review questions that helped me get promoted and earn more todayfor free!
Posted at 2/20/2026 04:18:36        Only Author  5#
This article really resonated with me, thank you for sharing! Enhance your IT expertisefree Valid INSTC_V8 practice materials available now! Best wishes for success!
Posted at 2/21/2026 00:32:13        Only Author  6#
Your article really made an impact on me, Im truly grateful. Get your hands on the free Valid PMI-PMOCP exam collection pdf exam questions. Wishing you the best of luck!
Posted at 3/6/2026 02:43:14        Only Author  7#
No question, this content is getting a like. Sharing HPE7-A08 customizable exam mode exam content with you for freegood luck!
Posted at 3/6/2026 04:29:14        Only Author  8#
After reading this article, my understanding of the field has become more comprehensive. This is the Test PA-Life-Accident-and-Health voucher exam I passed for my promotion and salary raise. Its free for you todayhope you reach your career milestones!
