[General] High-quality Exam SK0-005 Papers - Find Shortcut to Pass SK0-005 Exam
110
General High-quality Exam SK0-005 Papers - Find Shortcut to Pass SK0-005 Exam
Posted at 1/31/2026 06:00:57      View108 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that GetValidTest SK0-005 dumps now are free: https://drive.google.com/open?id=1yIrhfH41XoJ3IjZziQh_OiwFrBDF0eb4
As we all know that if you can obtain the SK0-005 certification, your life will change from now on. There will be various opportunities waiting for you. You take the initiative. It is up to you to make a decision. We only live once. Dont postpone your purpose and dreams. Our SK0-005 Real Exam will escort your dreams. You will get better jobs as well as higher salaries to lead a better life. Come to fight for your bright future and buy our SK0-005 practice braindumps right now!
The CompTIA SK0-005 Exam covers topics such as server architecture, virtualization, storage, security, network infrastructure, disaster recovery, and troubleshooting. Candidates are required to have a solid understanding of these topics before attempting the exam.
Official CompTIA SK0-005 Practice Test & Reliable SK0-005 Braindumps PptGetValidTest SK0-005 exam training materials can help you save a lot of time and energy, and make you yield twice the result with half effort to pass SK0-005 certification exam. After you purchase our SK0-005 exam dumps, we will also provide one year free renewal service for you. If there's any quality problem in SK0-005 Exam Dumps you buy or you fail SK0-005 certification exam, we promise to give you a full refund unconditionally.
CompTIA SK0-005 Certification Exam is a globally recognized certification that is highly valued by employers. It is an industry-standard certification that demonstrates the candidate's expertise in server administration. CompTIA Server+ Certification Exam certification is vendor-neutral, which means it is not tied to any specific hardware or software vendor. This makes it an ideal certification for IT professionals who work with different types of servers and vendors.
CompTIA Server+ Certification Exam Sample Questions (Q409-Q414):NEW QUESTION # 409
Which of the following if properly configured would prevent a user from installing an OS on a server? (Select TWO).
  • A. Group Policy Object
  • B. BIOS/UEFI password
  • C. Administrator password
  • D. Bootloader password
  • E. Root password
  • F. SELInux
Requiring a boot password upon execution of the boot loader will prevent an unauthorized user from entering boot parameters or changing the boot partition. This prevents users from weakening security (e.g. turning off SELinux at boot time).
What is a UEFI password?
A UEFI, or BIOS, password is a password that must be entered when the machine is powered on or rebooted in order to continue. Without the password the machine cannot be booted at all - even from external media - and no configuration changes to the UEFI or BIOS settings can be made.
https://www.tenable.com/audits/i ... G.audit:1ee8630516d a75be0fabf64c11ab70c6
https://askleo.com/how_do_i_remove_a_bios_password/#
NEW QUESTION # 410
A server administrator purchased a single license key to use for all the new servers that will be imaged this year. Which of the following MOST likely refers to the licensing type that will be used?
  • A. Per socket
  • B. Open-source
  • C. Per concurrent user
  • D. Volume
This is the most likely licensing type that will be used because volume licensing allows a single license key to be used for multiple installations of a software product. Volume licensing is typically used by organizations that need to deploy software to a large number of devices or users. References:
https://www.microsoft.com/en-us/ ... -licensing-programs
NEW QUESTION # 411
Users report that the FinanceApp software is not running, and they need immediate access. Issues with the FinanceApp software occur every week after the IT team completes server system updates. The users, however, do not want to contact the help desk every time the issue occurs. The users also report the new MarketApp software is not usable when it crashes, which can cause significant downtime. The technician who restarted the MarketApp software noticed it is running under a test account, which is a likely cause of the crashes.
INSTRUCTIONS
Using the Services menu provided, modify the appropriate application services to remedy the stated issues.
See the solution in explanation.
FinanceApp software is running as a service named "FinanceApp Service". The service description says
"rovides financial data and calculations for the FinanceApp software". The service status is "Stopped", which means that the service is not running and the software is not functional. The service startup type is
"Manual", which means that the service needs to be started manually by the user or the administrator. The service log on as is "Local System", which means that the service runs under a predefined local account that has extensive privileges on the local computer.
To fix the issue with the FinanceApp software, you need to do two things:
* First, you need to start the service, so that the software can run. To do this, you can right-click on the service name and select "Start" from the menu. Alternatively, you can select the service name and click on the "Start" button on the toolbar. You should see a message saying that the service has started successfully.
* Second, you need to change the service startup type, so that the service can start automatically every time the server boots up. This way,you don't have to contact the help desk every time the issue occurs.
To do this, you can right-click on the service name and select "roperties" from the menu.
Alternatively, you can select the service name and click on the "roperties" button on the toolbar. You should see a window with several tabs and options. On the "General" tab, under "Startup type", you can select "Automatic" from the drop-down list. Then, click on "OK" to save your changes.
By doing these two steps, you should be able to use the FinanceApp software without any problems.
The MarketApp software is running as a service named "MarketApp Service". The service description says
"rovides market data and analysis for the MarketApp software". The service status is "Running", which means that the service is running and the software is functional. However, as you reported, the software may crash sometimes, which can cause significant downtime. The service startup type is "Automatic", which means that the service starts automatically every time the server boots up. The service log on as is
"TestAccount", which is a test account that was probably used for development or testing purposes.
To fix the issue with the MarketApp software, you need to do one thing:
* You need to change the service log on as, so that the service runs under a proper account that has sufficient permissions and security settings for production use. To do this, you can right-click on the service name and select "roperties" from the menu. Alternatively, you can select the service name and click on the "roperties" button on the toolbar. You should see a window with several tabs and options.
On the "Log On" tab, under "Log on as", you can select either "Local System account" or "This account". If you choose "Local System account", then the service will run under a predefined local account that has extensive privileges on the local computer. If you choose "This account", then you will need to enter a valid username and password for an account that has appropriate permissions and security settings for running the service. You may need to consult with your IT team or your software vendor to determine which option is best for your situation. Then, click on "OK" to save your changes.
NEW QUESTION # 412
A technician is attempting to update a server's firmware. After inserting the media for the firmware and restarting the server, the machine starts normally into the OS. Which of the following should the technician do NEXT to install the firmware?
  • A. Enable HIDS on the server
  • B. Boot from the media
  • C. Press F8 to enter safe mode
  • D. Log in with an administrative account
Firmware updates (such as BIOS or the Unified Extensible Firmware Interface [UEFI]) may be required prior to installation, even for indirect reasons, such as network Preboot Execution Environment (PXE) boot, USB device boot support, and so on. If you plan on installing the hypervisor from a DVD or USB, you may also have to change the boot order configuration on your machine.
NEW QUESTION # 413
IDS alerts indicate abnormal traffic patterns are coming from a specific server in a data center that hosts sensitive data. Upon further investigation, the server administrator notices this server has been infected with a virus due to an exploit of a known vulnerability from its database software. Which of the following should the administrator perform after removing the virus to mitigate this issue from reoccurring and to maintain high availability? (Select three).
  • A. Update the antivirus software.
  • B. Air gap the server from the network.
  • C. Reformat the OS on the server.
  • D. Remove the database software.
  • E. Repartition the hard drive that houses the database.
  • F. Patch the vulnerability.
  • G. Enable a host firewall.
  • H. Run a vulnerability scanner on the server.
Answer: A,F,H
After removing the virus from the server, the administrator should perform the following actions to mitigate the issue from reoccurring and to maintain high availability:
Run a vulnerability scanner on the server to identify any other potential weaknesses or exposures that could be exploited by attackers.
Patch the vulnerability that allowed the virus to infect the server in the first place, using the latest updates from the database software vendor or a trusted source.
Update the antivirus software on the server to ensure it has the most recent virus definitions and can detect and prevent future infections. The other options are either unnecessary or counterproductive for this scenario. Repartitioning the hard drive, reformatting the OS, removing the database software, or air gapping the server from the network would cause downtime and data loss, while enabling a host firewall would not prevent a virus infection from within the network. References: CompTIA Server+ Certification Exam Objectives, Domain 5.0: Security, Objective 5.2: Given a scenario involving a security threat/vulnerability/risk, implement appropriate mitigation techniques.
NEW QUESTION # 414
Official SK0-005 Practice Test: https://www.getvalidtest.com/SK0-005-exam.html
