100% Pass 2026 Realistic Best AZ-104 Preparation Materials - Microsoft Azure Adm
Posted at 1/31/2026 06:16:33
2026 Latest RealExamFree AZ-104 PDF Dumps and AZ-104 Exam Engine Free Share: https://drive.google.com/open?id=1HhX4aKu3qr4oDO53RuIXt6Wt1CY6F6a_
Our AZ-104 learn materials include all the qualification tests in recent years, as well as corresponding supporting materials. Such a huge amount of database can greatly satisfy users' learning needs. Not enough valid AZ-104 test preparation materials, will bring many inconvenience to the user, such as delay learning progress, these are not conducive to the user pass exam, therefore, in order to solve these problems, our AZ-104 Certification material will do a complete summarize and precision of summary analysis to help you pass the AZ-104 exam with ease.
Microsoft AZ-104 exam, also known as the Microsoft Azure Administrator exam, is designed to test an individual's knowledge and skills in managing and monitoring Microsoft Azure services. AZ-104 Exam is intended for individuals who are responsible for implementing, managing, and monitoring Azure resources and services.
Best AZ-104 Preparation Materials | Microsoft AZ-104 Minimum Pass Score: Microsoft Azure Administrator Pass CertainlyFinally, it is important to stay up-to-date with the latest RealExamFree developments in the field of AZ-104 certification exams. To prepare for the exam, it is important to study the Microsoft Azure Administrator (AZ-104) exam questions and practice using the practice test software. The RealExamFree is a leading platform that has been assisting the Microsoft Azure Administrator (AZ-104) exam candidates for many years. Over this long time period countless AZ-104 Exam candidates have passed their Microsoft AZ-104 certification exam. They got success in AZ-104 exam with flying colors and did a job in top world companies. It is important to mention here that the AZ-104 practice questions played important role in their Microsoft Certification Exams preparation and their success.
Module 3: Azure Compute Resources Deployment and ManagementAfter explaining about Azure implementation and storage, the test moves to Azure resource management. In this domain, the candidates have to learn about different ways to configure VMs for scalability as well as high availability. The concepts of creating and setting up Azure Kubernetes Service along with Azure Container Service (ACS) will be observed in detail in this section too. Finally, pay attention to the automation of configurations and deployment processes.
Microsoft Azure Administrator Sample Questions (Q294-Q299):NEW QUESTION # 294
You have an Azure subscription.
You need to deploy a virtual machine by using an Azure Resource Manager (ARM) template.
How should you complete the template? To answer, select the appropriate options in the answer area.
NEW QUESTION # 295
You plan to deploy five virtual machines to a virtual network subnet.
Each virtual machine will have a public IP address and a private IP address.
Each virtual machine requires the same inbound and outbound security rules.
What is the minimum number of network interfaces and network security groups that you require? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... interface-addresses
NEW QUESTION # 296
You need to configure the Device settings to meet the technical requirements and the user requirements.
Which two settings should you modify? To answer, select the appropriate settings in the answer area.
Topic 4, Contoso Ltd (Consulting Company)Case study
Overview
This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
SegmentTo start the case study
To display the first question in this case study, click the Next button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirements, existing environment, and problem statements. If the case study has an All Information tab, note that the information displayed is identical to the information displayed on the subsequent tabs. When you are ready to answer a question, click the Question button to return to the question.
Overview
General Overview
Contoso, Ltd. is a consulting company that has a main office in Montreal and branch offices in Seattle and New York.
Environment
Existing Environment
Contoso has an Azure subscription named Sub1 that is linked to an Azure Active Directory (Azure AD) tenant. The network contains an on-premises Active Directory domain that syncs to the Azure AD tenant.
The Azure AD tenant contains the users shown in the following table.
Sub1 contains two resource groups named RG1 and RG2 and the virtual networks shown in the following table.
User1 manages the resources in RG1. User4 manages the resources in RG2.
Sub1 contains virtual machines that run Windows Server 2019 as shown in the following table
No network security groups (NSGs) are associated to the network interfaces or the subnets.
Sub1 contains the storage accounts shown in the following table.
Requirements
Planned Changes
Contoso plans to implement the following changes:
Create a blob container named container1 and a file share named share1 that will use the Cool storage tier.
Create a storage account named storage5 and configure storage replication for the Blob service.
Create an NSG named NSG1 that will have the custom inbound security rules shown in the following table.
Associate NSG1 to the network interface of VM1.
Create an NSG named NSG2 that will have the custom outbound security rules shown in the following table.
Associate NSG2 to VNET1/Subnet2.
Technical Requirements
Contoso must meet the following technical requirements:
Create container1 and share1.
Use the principle of least privilege.
Create an Azure AD security group named Group4.
Back up the Azure file shares and virtual machines by using Azure Backup.
Trigger an alert if VM1 or VM2 has less than 20 GB of free space on volume C.
Enable User1 to create Azure policy definitions and User2 to assign Azure policies to RG1.
Create an internal Basic Azure Load Balancer named LB1 and connect the load balancer to VNET1/Subnet1 Enable flow logging for IP traffic from VM5 and retain the flow logs for a period of eight months.
Whenever possible, grant Group4 Azure role-based access control (Azure RBAC) read-only permissions to the Azure file shares.
NEW QUESTION # 297
You need to configure the alerts for VM1 and VM2 to meet the technical requirements.
Which three actions should you perform in sequence? To answer, move all actions from the list of actions to the answer area and arrange them in the correct order.
Topic 4, Humongous InsuranceOverview
Huongous Insurance is an insurance company that has three offices in Miami, Tokoyo, and Bankok. Each has
5000 users.
Active Directory Environment
Humongous Insurance has a single-domain Active Directory forest named humongousinsurance.com. The functional level of the forest is Windows Server 2012.
You recently provisioned an Azure Active Directory (Azure AD) tenant.
Network Infrastructure
Each office has a local data center that contains all the servers for that office. Each office has a dedicated connection to the Internet.
Each office has several link load balancers that provide access to the servers.
Active Directory Issue
Several users in humongousinsurance.com have UPNs that contain special characters.
You suspect that some of the characters are unsupported in Azure AD.
Licensing Issue
You attempt to assign a license in Azure to several users and receive the following error message: "Licenses not assigned. License agreement failed for one user." You verify that the Azure subscription has the available licenses.
Requirements
Planned Changes
Humongous Insurance plans to open a new office in Paris. The Paris office will contain 1,000 users who will be hired during the next 12 months. All the resources used by the Paris office users will be hosted in Azure.
Planned Azure AD Infrastructure
The on-premises Active Directory domain will be synchronized to Azure AD.
All client computers in the Paris office will be joined to an Azure AD domain.
Planned Azure Networking Infrastructure
You plan to create the following networking resources in a resource group named All_Resources:
Default Azure system routes that will be the only routes used to route traffic A virtual network named Paris-VNet that will contain two subnets named Subnet1 and Subnet2 A virtual network named ClientResources-VNet that will contain one subnet named ClientSubnet A virtual network named AllOffices-VNet that will contain two subnets named Subnet3 and Subnet4 You plan to enable peering between Paris-VNet and AllOffices-VNet. You will enable the Use remote gateways setting for the Paris-VNet peerings.
You plan to create a private DNS zone named humongousinsurance.local and set the registration network to the ClientResources-VNet virtual network.
Planned Azure Computer Infrastructure
Each subnet will contain several virtual machines that will run either Windows Server 2012 R2, Windows Server 2016, or Red Hat Linux.
Department Requirements
Humongous Insurance identifies the following requirements for the company's departments:
Web administrators will deploy Azure web apps for the marketing department. Each web app will be added to a separate resource group. The initial configuration of the web apps will be identical. The web administrators have permission to deploy web apps to resource groups.
During the testing phase, auditors in the finance department must be able to review all Azure costs from the past week.
Authentication Requirements
Users in the Miami office must use Azure Active Directory Seamless Single Sign-on (Azure AD Seamless SSO) when accessing resources in Azure.
NEW QUESTION # 298
You need to resolve the Active Directory issue.
What should you do?
- A. From Azure AD Connect, modify the outbound synchronization rule.
- B. From Active Directory Users and Computers, select the user accounts, and then modify the User Principal Name value.
- C. Run idfix.exe, and then use the Edit action.
- D. From Active Directory Domains and Trusts, modify the list of UPN suffixes.
IdFix is used to perform discovery and remediation of identity objects and their attributes in an on-premises Active Directory environment in preparation for migration to Azure Active Directory. IdFix is intended for the Active Directory administrators responsible for directory synchronization with Azure Active Directory.
Scenario: Active Directory Issue
Topic 2, Contoso Ltd
Currently, Contoso uses multiple types of servers for business operations, including the following:
File servers
Domain controllers
Microsoft SQL Server servers
Your network contains an Active Directory forest named contoso.com. All servers and client computers are joined to Active Directory.
You have a public-facing application named App1. App1 is comprised of the following three tiers:
A SQL database
A web front end
A processing middle tier
Each tier is comprised of five virtual machines. Users access the web front end by using HTTPS only.
Requirements
Planned Changes
Contoso plans to implement the following changes to the infrastructure:
Move all the tiers of App1 to Azure.
Move the existing product blueprint files to Azure Blob storage.
Create a hybrid directory to support an upcoming Microsoft Office 365 migration project.
Move all the virtual machines for App1 to Azure.
Minimize the number of open ports between the App1 tiers.
Ensure that all the virtual machines for App1 are protected by backups.
Copy the blueprint files to Azure over the Internet.
Ensure that the blueprint files are stored in the archive storage tier.
Ensure that partner access to the blueprint files is secured and temporary.
Prevent user passwords or hashes of passwords from being stored in Azure.
Use unmanaged standard storage for the hard disks of the virtual machines.
Ensure that when users join devices to Azure Active Directory (Azure AD), the users use a mobile phone to verify their identity.
Minimize administrative effort whenever possible.
User Requirements
Contoso identifies the following requirements for users:
Ensure that only users who are part of a group named Pilot can join devices to Azure AD.
Designate a new user named Admin1 as the service administrator of the Azure subscription.
Admin1 must receive email alerts regarding service outages.
Ensure that a new user named User3 can create network objects for the Azure subscription.
NEW QUESTION # 299
AZ-104 Minimum Pass Score: https://www.realexamfree.com/AZ-104-real-exam-dumps.html
- Microsoft AZ-104 Exam Questions in Convenient PDF Format 🌻 Search for ⇛ AZ-104 ⇚ and obtain a free download on ⮆ [url]www.torrentvce.com ⮄ ‼AZ-104 Exam Outline[/url]
- Microsoft - Trustable Best AZ-104 Preparation Materials ⏺ Open ▛ [url]www.pdfvce.com ▟ and search for [ AZ-104 ] to download exam materials for free 👫New AZ-104 Exam Format[/url]
- Test AZ-104 Study Guide 🥅 AZ-104 Latest Real Test ↙ Pdf AZ-104 Dumps 🚇 Download ☀ AZ-104 ️☀️ for free by simply entering ( [url]www.practicevce.com ) website 🚏Reliable AZ-104 Test Experience[/url]
- Valid Best AZ-104 Preparation Materials - Leader in Qualification Exams - Fantastic Microsoft Microsoft Azure Administrator 🔏 Immediately open ⇛ [url]www.pdfvce.com ⇚ and search for ☀ AZ-104 ️☀️ to obtain a free download 🗽AZ-104 Authorized Pdf[/url]
- Microsoft AZ-104 Exam Questions in Convenient PDF Format 🍳 Easily obtain ▷ AZ-104 ◁ for free download through “ [url]www.testkingpass.com ” 🍭AZ-104 Exam Outline[/url]
- Valid Best AZ-104 Preparation Materials - Leader in Qualification Exams - Fantastic Microsoft Microsoft Azure Administrator 📼 ➥ [url]www.pdfvce.com 🡄 is best website to obtain { AZ-104 } for free download 🙅AZ-104 Latest Real Test[/url]
- Valid AZ-104 Exam Experience 🚨 AZ-104 Latest Exam Book 🐩 New AZ-104 Exam Format 🚋 Search for ⇛ AZ-104 ⇚ and download it for free immediately on 【 [url]www.examdiscuss.com 】 🥜Test AZ-104 Study Guide[/url]
- Microsoft AZ-104 Exam Questions in Convenient PDF Format 🦊 Search on ▛ [url]www.pdfvce.com ▟ for ➥ AZ-104 🡄 to obtain exam materials for free download 🕤Simulation AZ-104 Questions[/url]
- New AZ-104 Practice Questions 🍢 Valid AZ-104 Exam Experience 🦹 AZ-104 Answers Real Questions 🚹 Search on 「 [url]www.practicevce.com 」 for ➥ AZ-104 🡄 to obtain exam materials for free download 🥰Latest AZ-104 Test Online[/url]
- Microsoft - Trustable Best AZ-104 Preparation Materials 🥈 Open website 《 [url]www.pdfvce.com 》 and search for 【 AZ-104 】 for free download ☂New AZ-104 Practice Questions[/url]
- Microsoft - Trustable Best AZ-104 Preparation Materials 👞 Search for 《 AZ-104 》 and easily obtain a free download on “ [url]www.verifieddumps.com ” 🥜AZ-104 Authorized Pdf[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, zenwriting.net, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
P.S. Free & New AZ-104 dumps are available on Google Drive shared by RealExamFree: https://drive.google.com/open?id=1HhX4aKu3qr4oDO53RuIXt6Wt1CY6F6a_
