[General] Palo Alto Networks Cybersecurity-Practitioner Latest Test Guide - Cybersecurity-
105
【General】 Palo Alto Networks Cybersecurity-Practitioner Latest Test Guide - Cybersecurity-
Posted at 1/31/2026 08:52:03      View:101 | Replies:1        Print      Only Author   [Copy Link] 1#
We boost professional expert team to organize and compile the Cybersecurity-Practitioner training materials diligently and provide the great service which include the service before and after the sale, the 24-hours online customer service. So you can not only get the first-class Cybersecurity-Practitioner Exam Questions but also get the first-class services. If you have any question, you can just contact us online or via email at any time you like. And you can free download the demos of our Cybersecurity-Practitioner study guide before your payment.
Palo Alto Networks Cybersecurity-Practitioner Exam Syllabus Topics:
  • Network Security: This domain addresses network protection through Zero Trust Network Access, firewalls, microsegmentation, and security technologies like IPS, URL filtering, DNS security, VPN, and SSL
  • TLS decryption, plus OT
  • IoT concerns, NGFW deployments, Cloud-Delivered Security Services, and Precision AI.
  • Secure Access: This domain examines SASE and SSE architectures, security challenges for data and applications including AI tools, and technologies like Secure Web Gateway, CASB, DLP, Remote Browser Isolation, SD-WAN, and Prisma SASE solutions.
  • Cybersecurity: This domain covers foundational security concepts including AAA framework, MITRE ATT&CK techniques, Zero Trust principles, advanced persistent threats, and common security technologies like IAM, MFA, mobile device management, and secure email gateways.
  • Security Operations: This domain focuses on security operations including threat hunting, incident response, SIEM and SOAR platforms, Attack Surface Management, and Cortex solutions including XSOAR, Xpanse, and XSIAM.
Pass Guaranteed 2026 The Best Cybersecurity-Practitioner: Palo Alto Networks Cybersecurity Practitioner Latest Test GuideTo some extent, to pass the Cybersecurity-Practitioner exam means that you can get a good job. The Cybersecurity-Practitioner exam materials you master will be applied to your job. The possibility to enter in big and famous companies is also raised because they need outstanding talents to serve for them. Our Cybersecurity-Practitioner Test Prep is compiled elaborately and will help the client get the Cybersecurity-Practitioner certification. To get a better and full understanding of our Cybersecurity-Practitioner quiz torrent, you can just free download the demo of our Cybersecurity-Practitioner exam questions.
Palo Alto Networks Cybersecurity Practitioner Sample Questions (Q80-Q85):NEW QUESTION # 80
Which component of the AAA framework verifies user identities so they may access the network?
  • A. Accounting
  • B. Allowance
  • C. Authorization
  • D. Authentication
Authentication is the component of the AAA (Authentication, Authorization, and Accounting) framework that verifies user identities (e.g., via passwords, certificates, or biometrics) before granting access to network resources.
NEW QUESTION # 81
An Administrator wants to maximize the use of a network address. The network is 192.168.6.0/24 and there are three subnets that need to be created that can not overlap. Which subnet would you use for the network with 120 hosts?
Requirements for the three subnets: Subnet 1: 3 host addresses
Subnet 2: 25 host addresses
Subnet 3: 120 host addresses
  • A. 192.168.6.128/27
  • B. 192.168.6.0/25
  • C. 192.168.6.160/29
  • D. 192.168.6.168/30
To maximize the use of a network address, the administrator should use the subnet that can accommodate the required number of hosts with the least amount of wasted IP addresses. The subnet mask determines how many bits are used for the network portion and the host portion of the IP address. The more bits are used for the network portion, the more subnets can be created, but the fewer hosts can be assigned to each subnet. The formula to calculate the number of hosts per subnet is
2(32-n)-2
, where
n
is the number of bits in the network portion of the subnet mask. For example, a /30 subnet mask has 30 bits in the network portion, so the number of hosts per subnet is
2(32-30)-2=2
A /25 subnet mask has 25 bits in the network portion, so the number of hosts per subnet is
2(32-25)-2=126
The subnet 192.168.6.0/25 can accommodate 126 hosts, which is enough for the network with 120 hosts. The subnet 192.168.6.168/30 can only accommodate 2 hosts, which is not enough. The subnet 192.168.6.160/29 can accommodate 6 hosts, which is also not enough. The subnet 192.168.6.128/27 can accommodate 30 hosts, which is enough, but it wastes more IP addresses than the /25 subnet. Therefore, the best option is B. 192.168.6.0/25. Reference:
Getting Started: Layer 3 Subinterfaces - Palo Alto Networks Knowledge Base DotW: Multiple IP Addresses on an Interface - Palo Alto Networks Knowledge Base Configure NAT - Palo Alto Networks | TechDocs
NEW QUESTION # 82
What is the recommended method for collecting security logs from multiple endpoints?
  • A. Build a script that pulls down the logs from all endpoints.
  • B. Connect to the endpoints remotely and download the logs.
  • C. Leverage an EDR solution to request the logs from endpoints.
  • D. Configure endpoints to forward logs to a SIEM.
A SIEM (Security Information and Event Management) is a system that collects, analyzes, and correlates security logs from multiple sources, such as endpoints, firewalls, servers, etc. A SIEM can provide a centralized and comprehensive view of the security posture of an organization, as well as detect and respond to threats. Configuring endpoints to forward logs to a SIEM is the recommended method for collecting security logs from multiple endpoints, as it reduces the network bandwidth and storage requirements, simplifies the log management process, and enables faster and more effective security analysis. Leveraging an EDR (Endpoint Detection and Response) solution to request the logs from endpoints is not recommended, as it may cause performance issues on the endpoints, increase the network traffic, and create a dependency on the EDR solution. Connecting to the endpoints remotely and downloading the logs is not recommended, as it is a manual and time-consuming process, prone to errors and inconsistencies, and may expose the endpoints to unauthorized access. Building a script that pulls down the logs from all endpoints is not recommended, as it requires technical skills and maintenance, may not be compatible with different endpoint platforms, and may introduce security risks if the script is compromised or misconfigured. Reference:
Palo Alto Networks Certified Cybersecurity Entry-level Technician (PCCET) - Palo Alto Networks Fundamentals of Security Operations Center (SOC)
10 Palo Alto Networks PCCET Exam Practice Questions - CBT Nuggets
NEW QUESTION # 83
Which of the following is a service that allows you to control permissions assigned to users in order for them to access and utilize cloud resources?
  • A. Lightweight Directory Access Protocol (LDAP)
  • B. User and Entity Behavior Analytics (UEBA)
  • C. User-ID
  • D. Identity and Access Management (IAM)
Identity and access management (IAM) is a software service or framework that allows organizations to define user or group identities within software environments, then associate permissions with them. The identities and permissions are usually spelled out in a text file, which is referred to as an IAM policy.
NEW QUESTION # 84
What type of address translation does a NAT perform?
  • A. Logical to physical
  • B. Public to private
  • C. Private to public
  • D. Physical Io logical
NAT stands for Network Address Translation, which is a process that allows devices on a private network to communicate with devices on a public network, such as the Internet. NAT translates the private IP addresses of the devices on the private network to public IP addresses that can be routed on the public network. This way, multiple devices on the private network can share a single public IP address and access the Internet. NAT also provides security benefits, as it hides the internal network structure and IP addresses from the outside world. Reference: Palo Alto Networks Certified Cybersecurity Entry-level Technician (PCCET), Fundamentals of Network Security, Network Address Translation (NAT)
NEW QUESTION # 85
There are other several Palo Alto Networks Cybersecurity-Practitioner certification exam benefits that you can gain after passing the Palo Alto Networks Cybersecurity-Practitioner certification exam. However, you should keep in mind that passing the Palo Alto Networks Cybersecurity Practitioner certification exam is not a simple and easiest task. It is a challenging job that you can make simple and successful with the complete Cybersecurity-Practitioner Exam Preparation.
Cybersecurity-Practitioner Questions Pdf: https://www.exam4docs.com/Cybersecurity-Practitioner-study-questions.html
Posted at 2/18/2026 02:37:23        Only Author  2#
This is a truly extraordinary piece of work, thank you for sharing. Sharing Cost effective 400-007 dumps materials for free—good luck on your exams!
