[General] Best 1Z0-082 Study Material, 1Z0-082 Valid Exam Experience
103
【General】 Best 1Z0-082 Study Material, 1Z0-082 Valid Exam Experience
Posted at 1/31/2026 11:05:27      View:113 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest FreeCram 1Z0-082 PDF Dumps and 1Z0-082 Exam Engine Free Share: https://drive.google.com/open?id=1GMqz2kaksFGpCkpLJfxsM0h_VGUhS5p4
They check each Oracle 1Z0-082 practice test question and ensure the top standard of Oracle Database Administration I (1Z0-082) exam questions all the time. So you can trust FreeCram Oracle 1Z0-082 practice test questions and start Oracle 1Z0-082 exam preparation with confidence. The FreeCram is a leading platform committed to making entire Oracle Database Administration I (1Z0-082) exam preparation simple, quick, and easy for everyone. To fulfill this objective the FreeCram are offering top-rated and real Oracle Database Administration I (1Z0-082) practice test questions in three different formats.
Oracle 1Z0-082 Certification Exam is a multiple-choice exam that consists of 80 questions. Candidates have two hours to complete the exam and must score at least 64% to pass. 1Z0-082 exam is available in English and Japanese and can be taken at any Pearson VUE testing center around the world. Successful completion of the exam provides candidates with a recognized credential that demonstrates their expertise in Oracle Database Administration I. Oracle Database Administration I certification is particularly valuable for individuals who are seeking to advance their careers in database administration or who are looking to validate their skills and knowledge in the field.
To be eligible to take the Oracle 1Z1-082 exam, candidates must have a basic understanding of SQL, a solid understanding of the Oracle database architecture, and the ability to perform common administrative tasks on an Oracle database. Candidates should also be familiar with the Oracle database management tools and be able to use them effectively to manage and maintain an Oracle database.
Oracle 1Z0-082 Valid Exam Experience - Valid Test 1Z0-082 TipsIt is necessary to strictly plan the reasonable allocation of 1Z0-082 test time in advance. Many students did not pay attention to the strict control of time during normal practice, which led to panic during the process of examination, and even some of them are not able to finish all the questions. If you purchased 1Z0-082 learning dumps, each of your mock exams is timed automatically by the system. 1Z0-082 learning dumps provide you with an exam environment that is exactly the same as the actual exam. It forces you to learn how to allocate exam time so that the best level can be achieved in the examination room. At the same time, 1Z0-082 Test Question will also generate a report based on your practice performance to make you aware of the deficiencies in your learning process and help you develop a follow-up study plan so that you can use the limited energy where you need it most. So with 1Z0-082 study tool you can easily pass the exam.
Oracle Database Administration I Sample Questions (Q48-Q53):NEW QUESTION # 48
Which two statements are true about the PMON background process? (Choose two.)
  • A. It registers database services with all local and remote listeners known to the database instance
  • B. It frees resources held by abnormally terminated processes
  • C. It frees unused temporary segments
  • D. It records checkpoint information in the control file
  • E. It kills sessions that exceed idle time
Explanation/Reference: https://docs.oracle.com/cd/B1930 ... /b14220/process.htm
NEW QUESTION # 49
Which two statements are true about the Oracle Data Dictionary?
  • A. Data dictionary views are always created with queries that join two or more base tables.
  • B. All data dictionary view joins base tables to dynamic performance views.
  • C. Data dictionary base tables can be queried directly.
  • D. It is owned by the system user.
  • E. It is owned by the sys user.
Answer: C,E
NEW QUESTION # 50
Which two statements are true about the Automatic Diagnostic Repository (ADR)? (Choose two.)
  • A. The ADR base defaults to $ORACLE_HOME/dbs if the DIAGNOSTIC_DEST parameter and the ORACLE_BASE environment variable are not set
  • B. It supports diagnostics for Oracle Clusterware
  • C. The ADR base defaults to $ORACLE_HOME/rdbms/admin ifneither DIAGNOSTIC_DEST nor ORACLE_BASE is set
  • D. It is held inside an Oracle database schema
  • E. It supports diagnostics for Automatic Storage Management (ASM)
Answer: B,E
The database, Oracle Automatic Storage Management (Oracle ASM), the listener, Oracle Clusterware, and other Oracle products or components store all diagnostic data in the ADR. https://docs.oracle.com/database/121/ADMIN/diag.htm#ADMIN11260
NEW QUESTION # 51
Which two statements are true about the rules of precedence for operators? (Choose two.)
  • A. The + binary operator has the highest precedence in an expression in a SQL statement
  • B. NULLS influence the precedence of operators in an expression
  • C. Multiple parentheses can be used to override the default precedence of operators in an expression
  • D. The concatenation operator | | is always evaluated before addition and subtraction in an expression
  • E. Arithmetic operators with equal precedence are evaluated from left to right within an expression
Answer: C,E
https://docs.oracle.com/cd/A8786 ... a85397/operator.htm Precedence is the order in which Oracle evaluates different operators in the same expression. When evaluating an expression containing multiple operators, Oracle evaluates operators with higher precedence before evaluating those with lower precedence. Oracle evaluates operators with equal precedence from left to right within an expression.
NEW QUESTION # 52
Which two are true about shrinking a segment online? (Choose two.)
  • A. It is not possible to shrink either indexes or Index Organized Tables (IOTs)
  • B. To shrink a table it must have row movement enabled
  • C. It always eliminates all migrated rows if any exist in the table
  • D. To shrink a table it must have a PRIMARY KEY constraint
  • E. To shrink a table it must have a UNIQUE KEY constraint
  • F. It must be in a tablespace that uses Automatic Segment Space Management (ASSM)
Answer: B,F
NEW QUESTION # 53
We provide a guarantee on all of our 1Z0-082 test products, and you will be able to get your money back if we fail to deliver the results as advertised. We provide 100% money back guarantee for all of us 1Z0-082 test questions products, and we are always available to provide you top notch support and new 1Z0-082 Questions. If you are facing issues in downloading the 1Z0-082 study guides, then all you have to do is to contact our support professional, and they will be able to help you out with 1Z0-082 answers.
1Z0-082 Valid Exam Experience: https://www.freecram.com/Oracle-certification/1Z0-082-exam-dumps.html
DOWNLOAD the newest FreeCram 1Z0-082 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1GMqz2kaksFGpCkpLJfxsM0h_VGUhS5p4
