[General] Realistic FCSS_SDW_AR-7.4 Exam Questions Covers the Entire Syllabus of FCSS_SDW_
75
General Realistic FCSS_SDW_AR-7.4 Exam Questions Covers the Entire Syllabus of FCSS_SDW_
Posted at 1/31/2026 11:44:11      View151 | Replies2        Print      Only Author   [Copy Link] 1#
What's more, part of that TestPassed FCSS_SDW_AR-7.4 dumps now are free: https://drive.google.com/open?id=1FOCb-Tf4uMvb65bAsWMdnX8sVtV4Cf0h
Just as I have just mentioned, almost all of our customers have passed the exam as well as getting the related certification easily with the help of our FCSS_SDW_AR-7.4 Exam Torrent, we strongly believe that it is impossible for you to be the exception. So choosing our FCSS - SD-WAN 7.4 Architect exam question actually means that you will have more opportunities to get promotion in the near future, at the same time, needless to say that you will get a raise in pay accompanied with the promotion. Whats more, when you have shown your talent with FCSS - SD-WAN 7.4 Architect certification in relating field, naturally, you will have the chance to enlarge your friends circle with a lot of distinguished persons who may influence you career life profoundly.
Fortinet FCSS_SDW_AR-7.4 Exam Syllabus Topics:
  • Configure Performances SLAs: Designed for network administrators, this part focuses on setting up performance Service Level Agreements (SLAs) within SD-WAN environments. Candidates must show proficiency in defining criteria to monitor and maintain network performance and reliability.
  • Advanced IPsec: Intended for security engineers, this section covers the deployment of advanced IPsec topologies for SD-WAN, including hub-and-spoke models, ADVPN configurations, and complex multi-hub or multi-region deployments. Candidates need to demonstrate expertise in securing wide-area networks using IPsec technologies.
  • Rules and Routing: Targeted at network engineers, this section assesses the ability to configure SD-WAN rules and routing policies. Candidates will be tested on managing traffic flow and prioritization across the SD-WAN infrastructure.
  • SD-WAN Troubleshooting: This part assesses the troubleshooting skills of network support specialists. Candidates should be able to diagnose and resolve issues related to SD-WAN rules, session behaviors, routing inconsistencies, and ADVPN connectivity problems to maintain seamless network operations.
FCSS_SDW_AR-7.4 Reliable Test Braindumps | FCSS_SDW_AR-7.4 Frequent UpdatesWe have been developing our FCSS_SDW_AR-7.4 practice engine for many years. We have no doubt about our quality of the FCSS_SDW_AR-7.4 exam braindumps. Our experience is definitely what you need. And especially our professional experts have been devoting in this field for over ten years. I believe no one can know the FCSS_SDW_AR-7.4 training guide than them. To combine many factors, FCSS_SDW_AR-7.4 real exam must be your best choice.
Fortinet FCSS - SD-WAN 7.4 Architect Sample Questions (Q24-Q29):NEW QUESTION # 24
Refer to the exhibit that shows an SD-WAN zone configuration on the FortiManager GUI.
Based on the exhibit, how will the FortiGate device behave after it receives this configuration?
  • A. The configuration instructs FortiGate to allow ADVPN shortcuts for the tunnels of this SD-WAN zone.
  • B. The configuration instructs FortiGate to choose an ADVPN shortcut based on SD-WAN information.
  • C. The configuration instructs FortiGate to establish shortcuts only when at least two members meet the SLA target.
  • D. The configuration instructs FortiGate to establish shortcuts only for overlay interfaces that meet the SLA target HUB1_HC.
This is because the setting minimum-sla-meet-members = 2 requires at least two SD-WAN zone members (in this case, HUB2-VPN1, HUB2-VPN2, and HUB2-VPN3) to pass the defined SLA health check (HUB1_HC) before the FortiGate will establish ADVPN shortcuts. If fewer than two members meet the SLA, shortcuts will not be created.
NEW QUESTION # 25
Refer to the exhibit. Which two conclusions can you draw from the output shown? (Choose two.)
  • A. UDP traffic destined to the subnet 10.22.0.0/24 matches a manual SD-WAN rule.
  • B. UDP traffic destined to the subnet 10.22.0.0/24 matches a policy route.
  • C. One SD-WAN rule allows traffic load balancing.
  • D. One SD-WAN rule is defined with application categories as the destination.
One SD-WAN rule is defined with application categories as the destination The diagnose output shows application control matches such as Microsoft.Portal, Operational.Technology, and Social.Media, confirming that SD-WAN rules are using application categories as destinations.
UDP traffic destined to the subnet 10.22.0.0/24 matches a policy route The first entry (id=1) shows protocol=17 (UDP) with destination 10.22.0.0/24, confirming this traffic is handled by a policy route instead of an SD-WAN rule.
NEW QUESTION # 26
You manage an SD-WAN topology. You will soon deploy 50 new branches.
Which three tasks can you do in advance to simplify this deployment? (Choose three.)
  • A. Define metadata variables value for each device.
  • B. Create policy blueprint.
  • C. Create a ZTP template.
  • D. Update the DHCP server configuration.
  • E. Create model devices.
Answer: B,C,E
Creating a ZTP (Zero Touch Provisioning) template automates onboarding of new branches.
Policy blueprints allow predefining consistent configurations for security and SD-WAN rules.
Model devices help preconfigure settings tied to device models, speeding up deployment.
NEW QUESTION # 27
Refer to the exhibit. An administrator is troubleshooting SD-WAN on FortiGate. A device behind branch1_fgt generates traffic to the 10.0.0.0/8 network.
The administrator expects the traffic to match SD-WAN rule ID 1 and be routed over HUB1- VPN1.
However, the traffic is routed over HUB1-VPN3.
Based on the output shown in the exhibit, which two reasons, individually or together, could explain the observed behavior? (Choose two.)
  • A. HUB1-VPN1 does not have a valid route to the destination
  • B. HUB1-VPN3 has a lower route priority value (higher priority) than HUB1-VPN1.
  • C. HUB1-VPN3 has a higher member configuration priority than HUB1-VPN1
  • D. The traffic matches a regular policy route configured with HUB1-VPN3 as the outgoing device
NEW QUESTION # 28
Refer to the exhibit. You configure SD-WAN on a standalone FortiGate device. You want to create an SD-WAN rule that steers Facebook and Linkedin traffic through the less costly internet link. The FortiGate GUI page appears as shown in the exhibit.
What should you do to set Facebook and LinkedIn as destinations?
  • A. Install a license to allow applications as destinations of SD-WAN rules.
  • B. You cannot configure applications as destinations of an SD-WAN rule on a standalone FortiGate device.
  • C. Enable the applications as destinations of the SD-WAN rule feature visibility.
  • D. In the Internet service field, select Facebook and LinkedIn.
In an SD-WAN rule, you can steer application traffic by using Internet Service Database (ISDB) entries. Facebook and LinkedIn are predefined ISDB objects in FortiGate, so the correct way is to select them in the Internet service field under Destination. This ensures that all traffic to these applications is matched and routed through the chosen (less costly) link.
NEW QUESTION # 29
The high quality and high efficiency of our FCSS_SDW_AR-7.4 exam materials has helped many people pass exams quickly. After they get a FCSS_SDW_AR-7.4 certificate, they now have more job opportunities. And you can just look at the feedbacks from our worthy customrs on the website thanking for our FCSS_SDW_AR-7.4 learning guide. The current situation is very serious. Selecting our FCSS_SDW_AR-7.4 training guide is your best decision.
FCSS_SDW_AR-7.4 Reliable Test Braindumps: https://www.testpassed.com/FCSS_SDW_AR-7.4-still-valid-exam.html
DOWNLOAD the newest TestPassed FCSS_SDW_AR-7.4 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1FOCb-Tf4uMvb65bAsWMdnX8sVtV4Cf0h
Posted at 2/1/2026 19:52:42        Only Author  2#
I really appreciate your article, it has been an eye-opening experience. We offer free access to MB-335 valid test practice, filled with material meant to help you succeed.
Posted at 2/13/2026 13:54:49        Only Author  3#
Your article is truly outstanding, thank you for sharing it with us! The N16291GC10 hottest certification material is very useful, and its available at no charge.
