WGU Operations-Management Practice Exam Questions (Desktop & Web-based)
Posted at 1/31/2026 12:01:43
Success in the WGU Operations-Management exam paves the way toward high-paying jobs, promotions, and skills verification. Hundreds of WGU Operations-Management test takers do not get success because of using WGU Operations-Management outdated dumps. Due to failure, they lose money, time, and confidence. All these losses can be prevented by using updated and real Operations-Management exam.
Unlike other Operations-Management study materials, there is only one version and it is not easy to carry. Our Operations-Management exam questions mainly have three versions which are PDF, Software and APP online, and for their different advantafes, you can learn anywhere at any time. And the prices of our Operations-Management training engine are reasonable for even students to afford and according to the version that you want to buy.
Latest Study Operations-Management Questions, Operations-Management Exam Vce FormatIn the case of studying with outdated WGU Operations Management (C215, VDC2) (Operations-Management) practice questions, you will fail and lose your resources. ActualTestsQuiz made an Operations-Management Questions for the students so that they don't get confused to prepare for Operations-Management Certification Exam successfully in a short time. ActualTestsQuiz has designed the real Operations-Management exam dumps after consulting many professionals and receiving positive feedback.
WGU Operations Management (C215, VDC2) Sample Questions (Q67-Q72):NEW QUESTION # 67
Which concept of variation measures the central tendency of a set of data?
- A. Standard deviation
- B. Variable
- C. Mean
- D. Range
Comprehensive and Detailed Explanation (#250 words):
Themeanis the statistical measure that represents thecentral tendencyof a set of data.
In quality management and statistical process control (SPC), the mean indicates theaverage performance level of a process. It is calculated by summing all observed values and dividing by the number of observations.
In Operations Management, understanding central tendency is essential because:
* It defines the process target or expected output
* It serves as the reference point for evaluating variation
* It is used to establish control limits in control charts
Other options measure different aspects of variation:
* Rangemeasures dispersion between the highest and lowest values
* Standard deviationmeasures variability around the mean
* Variableis a generic term, not a measurement
TQM emphasizes not only achieving a desired mean but alsoreducing variability around it. A process can have the correct average output yet still produce defects if variation is excessive.
The mean is therefore foundational in quality analysis, process capability assessment, and continuous improvement initiatives. It helps managers understand whether processes are centered on customer specifications.
NEW QUESTION # 68
Which term means to schedule a job that starts immediately, regardless of the due date?
- A. Forward scheduling
- B. Finite loading
- C. Backward scheduling
- D. Infinite loading
Forward schedulingmeans scheduling workas soon as resources are available, regardless of the job's due date.
In Operations Management:
* Forward scheduling starts at the current time
* Jobs are scheduled sequentially into the future
* Completion dates are determined after scheduling
This method is commonly used when:
* Capacity utilization is the priority
* Due dates are flexible
* Make-to-stock environments exist
In contrast:
* Backward schedulingstarts from the due date and works backward
* Finite loadingrespects capacity limits
* Infinite loadingignores capacity constraints
Forward scheduling ensures continuous resource use but may result in early job completion and higher inventory levels.
NEW QUESTION # 69
Which formula would compute process velocity?
- A. Time a resource is used / time a resource is available
- B. Output / input
- C. Actual output / standard output
- D. Throughput time / value-added time
Process velocityis computed using the ratio:
Process Velocity = Throughput Time / Value-Added Time
This metric measures how efficiently time is used within a process. A high ratio indicates excessivenon- value-added time, such as waiting, moving, or rework.
Operations Management focuses on reducing throughput time while maximizing value-added activities.
Process velocity highlights inefficiencies that are often invisible in traditional productivity measures.
The other formulas measure different concepts:
* Resource utilization (A)
* Performance efficiency (B)
* Productivity (D)
A low process velocity (closer to 1) indicates a lean, efficient process, while high values suggest opportunities for improvement.
NEW QUESTION # 70
How does inventory management differ for manufacturing organizations compared to service organizations?
- A. Manufacturing organizations must keep large amounts of product on hand at all times, regardless of demand.
- B. Manufacturing organizations must maintain tangible inventory.
- C. Service organizations must maintain work-in-progress types of inventory.
- D. Service organizations are concerned with managing idle time due to material and component shortages.
Manufacturing organizations differ from service organizations because they mustmaintain tangible inventory
In manufacturing, inventory includes:
* Raw materials
* Work-in-progress
* Finished goods
These physical items require storage, handling, tracking, and capital investment. Inventory management is therefore a central operational concern in manufacturing.
Service organizations, by contrast, typically do not produce tangible goods. Their primary "inventory" consists of:
* Labor availability
* Time
* Capacity
Idle capacity in services cannot be stored for future use, making demand management more critical than inventory storage.
The incorrect options misrepresent service and manufacturing realities:
* Services do not maintain physical WIP
* Manufacturers do not hold inventory regardless of demand
* Idle time in services is not caused by material shortages
Operations Management highlights inventory as afundamental structural differencebetween manufacturing and service systems.
NEW QUESTION # 71
How do just-in-time (JIT) and lean systems add value?
- A. By enhancing responsibility
- B. By reducing waste
- C. By improving lighting
- D. By increasing simplicity
Just-in-time (JIT) and lean systems add valueby reducing wasteacross all operational processes.
Lean Operations define value strictly from thecustomer's perspective. Any activity that does not add value to the product or service is considered waste (muda). JIT and lean systems systematically identify and eliminate this waste to improve efficiency, quality, and responsiveness.
Common types of waste targeted include:
* Overproduction
* Waiting time
* Excess inventory
* Unnecessary motion
* Transportation
* Defects and rework
* Overprocessing
By reducing waste, organizations achieve:
* Shorter lead times
* Lower costs
* Improved quality
* Greater flexibility
Options such as improving lighting or enhancing responsibility may support efficiency indirectly but do not define the core value mechanism of JIT and lean systems. Increasing simplicity is a result of waste reduction, not the primary method.
Operations Management emphasizes waste elimination as the foundation of sustainable operational excellence, making optionCthe correct answer.
NEW QUESTION # 72
Many exam candidates feel hampered by the shortage of effective Operations-Management preparation quiz, and the thick books and similar materials causing burden for you. Serving as indispensable choices on your way of achieving success especially during this Operations-Management Exam, more than 98 percent of candidates pass the exam with our Operations-Management training guide and all of former candidates made measurable advance and improvement.
Latest Study Operations-Management Questions: https://www.actualtestsquiz.com/Operations-Management-test-torrent.html
With our professional Operations-Management exam software, you will be at ease about your Operations-Management exam, and you will be satisfied with our after-sale service after you have purchased our Operations-Management exam software, Our Operations-Management exam dumps materials completely satisfy your demands, You will have the chance to learn about the demo for if you decide to use our Operations-Management Materials quiz prep, We are dedicated to your accomplishment, hence pledges you victory in Latest Study Operations-Management Questions - WGU Operations Management (C215, VDC2) Exam Certification exam in a single attempt.
In summary, choose our exam materials will be the best method to defeat Operations-Management the exam, Antonio Manriquez is the video production teacher for the New Media Academy at Hollywood High School in Los Angeles, California.
WGU Operations-Management Questions Tips For Better PreparationWith our professional Operations-Management Exam software, you will be at ease about your Operations-Management exam, and you will be satisfied with our after-sale service after you have purchased our Operations-Management exam software.
Our Operations-Management exam dumps materials completely satisfy your demands, You will have the chance to learn about the demo for if you decide to use our Operations-Management Materials quiz prep.
We are dedicated to your accomplishment, hence Free Operations-Management Learning Cram pledges you victory in WGU Operations Management (C215, VDC2) Exam Certification exam in a single attempt, In order tostrengthen your confidence for the Operations-Management exam braindumps, we are pass guarantee and money back guarantee if you fail to pass the exam.
- Actual Operations-Management Test 🛹 Pass4sure Operations-Management Study Materials 🚄 New Operations-Management Test Camp 😏 Open website ☀ [url]www.prepawayete.com ️☀️ and search for ( Operations-Management ) for free download ⛺Actual Operations-Management Test[/url]
- Exam Dumps Operations-Management Provider 🕍 Operations-Management Latest Exam Notes ▶ Actual Operations-Management Test 🥂 Search for ▷ Operations-Management ◁ on ➠ [url]www.pdfvce.com 🠰 immediately to obtain a free download 🏘Operations-Management Brain Exam[/url]
- Operations-Management PDF Dumps Format Desktop Practice Test Software 📌 Easily obtain ➡ Operations-Management ️⬅️ for free download through ⇛ [url]www.pdfdumps.com ⇚ 😕Operations-Management New Study Materials[/url]
- Updated Operations-Management - WGU Operations Management (C215, VDC2) Reliable Test Voucher 💐 Easily obtain free download of 「 Operations-Management 」 by searching on ▷ [url]www.pdfvce.com ◁ 🧳Reliable Operations-Management Test Cost[/url]
- Quiz Updated Operations-Management - WGU Operations Management (C215, VDC2) Reliable Test Voucher 🔁 Easily obtain free download of ▛ Operations-Management ▟ by searching on ▶ [url]www.testkingpass.com ◀ 🎹Operations-Management Test Lab Questions[/url]
- Operations-Management Exam Prep 🍨 Reliable Operations-Management Real Exam 🙉 Operations-Management Exam Registration 🎩 The page for free download of 【 Operations-Management 】 on { [url]www.pdfvce.com } will open immediately 🔙Operations-Management Valid Guide Files[/url]
- Operations-Management New Dumps Book 🤘 Operations-Management Valid Guide Files 👐 Operations-Management Brain Exam 🥶 Easily obtain free download of ( Operations-Management ) by searching on ☀ [url]www.prep4away.com ️☀️ 👪Operations-Management New Dumps Book[/url]
- Operations-Management Exam Bootcamp 🏯 Operations-Management Exam Bootcamp 🤘 Exam Dumps Operations-Management Provider ☘ Go to website ▶ [url]www.pdfvce.com ◀ open and search for 「 Operations-Management 」 to download for free 🥝Operations-Management Valid Guide Files[/url]
- The Key to Success: Proper Planning and the Right WGU Operations-Management Exam Questions 🗻 Search for { Operations-Management } and easily obtain a free download on ⏩ [url]www.practicevce.com ⏪ 🛒Operations-Management Latest Exam Notes[/url]
- [url=https://rdougwicker.com/?s=Your%20Ultimate%20Resource%20Actual%20of%20WGU%20Operations-Management%20Questions%20%f0%9f%97%b3%20Open%20%e2%9e%a5%20www.pdfvce.com%20%f0%9f%a1%84%20enter%20[%20Operations-Management%20]%20and%20obtain%20a%20free%20download%20%f0%9f%9f%a6New%20Operations-Management%20Test%20Camp]Your Ultimate Resource Actual of WGU Operations-Management Questions 🗳 Open ➥ www.pdfvce.com 🡄 enter [ Operations-Management ] and obtain a free download 🟦New Operations-Management Test Camp[/url]
- Pass4sure Operations-Management Study Materials 😲 Reliable Operations-Management Test Cost 🛰 Reliable Operations-Management Test Cost 🦈 Enter “ [url]www.torrentvce.com ” and search for ⮆ Operations-Management ⮄ to download for free 🔣
ractice Operations-Management Test[/url] - faithlife.com, learn.csisafety.com.au, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.fanart-central.net, wjhsd.instructure.com, bbs.t-firefly.com, www.quora.com, bbs.t-firefly.com, Disposable vapes
