[New Launch] Oracle 1z0-1054-25 Dumps (Practice Test) with Newly 1z0-1054-25 Exa
76
Posted at 1/31/2026 12:15:51      View128 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Oracle 1z0-1054-25 dumps are available on Google Drive shared by RealValidExam: https://drive.google.com/open?id=1p3nXVmbW0Q9cGnjiD9zQ6vi5yuWYacwd
All the contents in 1z0-1054-25 training materials have three versions of APP, PC, and PDF. Buying 1z0-1054-25 exam torrent is equivalent to purchasing three books at the same time. That is other materials on the market that cannot satisfy you. If you buy a paper version of the material, it is difficult for you to create a test environment that is the same as the real test when you take a mock test, but 1z0-1054-25 exam questions provide you with a mock test system with timing and scoring functions, so that you will have the same feeling with that when you are sitting in the examination room. And if you buy the electronic version of the materials, it is difficult to draw marks on them, but 1z0-1054-25 Exam Questions provide you with a PDF version, so that you can print out the information, not only conducive to your mark, but also conducive to your memory of important knowledge. At the same time, any version of 1z0-1054-25 training materials will not limit the number of downloads simultaneous online users. You can study according to your personal habits and time schedules regardless of where and when.
Oracle 1z0-1054-25 Exam Syllabus Topics:
  • Implementing Enterprise and Financial Reporting Structures: This section of the exam measures skills of Oracle ERP Implementation Consultants and covers the core components used in setting up enterprise structures and reporting configurations. It assesses knowledge in defining legal entities, jurisdictions, and geographies, as well as the design and configuration of Chart of Accounts. Candidates must also demonstrate how to set up and secure chart structures and manage reporting calendars and currencies.
  • Using AI
  • ML
  • Mobile and Other Automation Features: This final section assesses Finance Transformation Architects and focuses on the business value derived from incorporating AI, machine learning, and mobile capabilities in Oracle Financials. Candidates are expected to understand automation use cases and the practical benefits these modern features offer in streamlining financial operations.
  • Implementing and Managing Journals: This section targets Oracle General Ledger Consultants and covers the full cycle of journal processingfrom creation through approval to management. It includes configuration of journal-related objects and understanding how journals are sourced, tracked, and approved using predefined rules and workflows.
Free PDF Quiz Oracle - 1z0-1054-25 - Updated Oracle Financials Cloud: General Ledger 2025 Implementation Professional Test DumpTo get respected jobs in tech companies around the globe, hundreds of people take the Oracle certification exam every year. Once they clear Oracle 1z0-1054-25 Exam, they easily get jobs and promotions. Hundreds of applicants who appear in the Oracle 1z0-1054-25 Exam don't get a passing score. The major reason behind their failure in the Oracle 1z0-1054-25 Exam is studying the material which is not the latest. So, to save your resources, you must prepare with Oracle 1z0-1054-25 Dumps which has real and updated exam material.
Oracle Financials Cloud: General Ledger 2025 Implementation Professional Sample Questions (Q26-Q31):NEW QUESTION # 26
You are creating values for thechart of account value setthat you are planning to use for theaccount segment within yourChart of Accounts. You are not able to assign anAccount Type.
What is the reason for this?
  • A. You have not set the Allow Budgeting attribute for the value set.
  • B. You have not set the Allow Posting attribute for the value set.
  • C. You are creating values before assigning the value set to the structure.
  • D. The Account Type qualifier has not been enabled when defining the value set.
NEW QUESTION # 27
When will Intercompany processing balance a journal using the accounts identified here for the UK Ledger?
  • A. when the journal is balanced by the primary BSV but not by second or third BSV
  • B. when there is a many-to-many journal and you want to use a clearing company
  • C. when the journal is not balanced by the primary balancing segment value (BSV)
  • D. when the journal is balanced by second balancing segment value
Intercompany processing will balance a journal using the accounts identified here for the UK Ledger when the journal is balanced by the primary balancing segment value (BSV) but not by second or third BSV. A BSV is a segment in the chart of accounts that identifies a legal entity or business unit for which financial statements are prepared and balanced. A primary BSV is required for every ledger and is used to balance journal entries within a ledger. A secondary or tertiary BSV is optional and is used to balance journal entries across different dimensions other than the primary BSV, such as fund or region. Intercompany processing is a feature that enables intercompany transactions between different legal entities or business units within the same enterprise. Intercompany processing uses intercompany balancing rules to generate intercompany receivables and payables accounts for cross-ledger or cross-BSV journals. Intercompany processing will balance a journal using the accounts identified here for the UK Ledger when the journal is balanced by the primary BSV but not by second or third BSV, as this indicates that there is an intercompany transaction between different legal entities or business units within the UK Ledger that requires intercompany balancing.
Intercompany processing will not balance a journal using the accounts identified here for the UK Ledger when there is a many-to-many journal and you want to use a clearing company, as this is a scenario that involves multiple legal entities or business units across different ledgers that requires a separate clearing company ledger to perform intercompany balancing. Intercompany processing will not balance a journal using the accounts identified here for the UK Ledger when the journal is not balanced by the primary BSV, as this is an invalid scenario that violates the accounting rules and prevents posting of the journal. Intercompany processing will not balance a journal using the accounts identified here for the UK Ledger when the journal is balanced by second balancing segment value, as this is an incomplete scenario that does not specify whether the journal is also balanced by primary and third BSV. Reference: Oracle Financials Cloud: General Ledger
2022 Implementation Professional Objectives - Configure and Process Intercompany 12
NEW QUESTION # 28
You want to create an Ad Hoc Analysis in Smart View; you enter the following dimensions for the report and click Refresh in the POV.
You get #Missing instead of a balance. What value did you not specify, which resulted in this?
  • A. Product
  • B. A particular currency
  • C. Intercompany
  • D. Cost Center
NEW QUESTION # 29
You want your sales representatives to be able to find points of interest, such as customers, while out on business. What should you enable to achieve this?
  • A. HZ_GEO_IDENTIFIER_SUBTYPE Lookup
  • B. Address Cleansing
  • C. Geocoding
  • D. Validation
According to Oracle documentation1, you should enable geocoding to achieve the requirement of finding points of interest, such as customers, while out on business. Geocoding is the process of assigning geographic coordinates to a physical address. Geocoding enables you to use maps and location-based services to find and visualize points of interest. Therefore, option B is correct. Option A is incorrect because HZ_GEO_IDENTIFIER_SUBTYPE Lookup is not a feature that enables finding points of interest. Option C is incorrect because validation is not a feature that enables finding points of interest. Option D is incorrect because address cleansing is not a feature that enables finding points of interest.
NEW QUESTION # 30
You are capturing rental costs for a building in a corporate cost center. At month end, you want to allocate those costs to the cost centers in the building based on the floor area occupied. A statistical journal has been entered to record the floor area. You use Calculation Manager to create the allocation.
Where do you reference the statistical balance within the allocation component?
  • A. Allocation Range
  • B. Offset
  • C. Basis
  • D. Source
  • E. Target
The source is where you specify the amount to be allocated. You can use various sources, such as account balances, fixed amounts, or statistical balances. In this case, you want to use the statistical balance of the floor area as the source of the allocation. The basis is where you specify the driver or factor that determines how the source amount is distributed among the targets. The target is where you specify the destination accounts that receive the allocated amount. The offset is where you specify the account that records the opposite side of the allocation entry. The allocation range is where you specify the scope of the allocation, such as the ledger, balancing segment, or legal entity. References:
Oracle Financials Cloud Implementing Enterprise Structures and General Ledger, Chapter 3: Allocations and Periodic Entries, Allocation Components Oracle Financials Cloud Using General Ledger, Chapter 3: Allocations and Periodic Entries, Overview
NEW QUESTION # 31
As we all know that, first-class quality always comes with the first-class service. There are also good-natured considerate after sales services offering help on our 1z0-1054-25 study materials. All your questions about our 1z0-1054-25 practice braindumps are deemed as prior tasks to handle. So if you have any question about our 1z0-1054-25 Exam Quiz, just contact with us and we will help you immediately. That is why our 1z0-1054-25 learning questions gain a majority of praise around the world.
Official 1z0-1054-25 Practice Test: https://www.realvalidexam.com/1z0-1054-25-real-exam-dumps.html
2026 Latest RealValidExam 1z0-1054-25 PDF Dumps and 1z0-1054-25 Exam Engine Free Share: https://drive.google.com/open?id=1p3nXVmbW0Q9cGnjiD9zQ6vi5yuWYacwd
Posted at 2/3/2026 17:47:06        Only Author  2#
Instant like for this incredible content. This is the Valid RVT_ELEC_01101 test question exam that played a role in my promotion and pay raise, now shared with you for free today. Best wishes on your career development!
Posted at 2/4/2026 11:13:58        Only Author  3#
Im so thankful for your article, its truly eye-opening. Reliable exam C11 questions explanations test questions are now free. Good luck with your exams!
Posted at 2/7/2026 09:27:29        Only Author  4#
Im really grateful for your article, it left an indelible mark. Wishing you all the best on your exams! Free 350-801 valid exam review questions available now!
