Salesforce Plat-Dev-301 High Quality, Plat-Dev-301 Reliable Test Tutorial
Posted at 1/31/2026 13:30:13
Considering that different customers have various needs, we provide three versions of Plat-Dev-301 test torrent available--- PDF version, PC Test Engine and Online Test Engine versions. One of the most favorable demo--- PDF version, in the form of Q&A, can be downloaded for free. This kind of Plat-Dev-301 exam prep is printable and has instant access to download, which means you can study at any place at any time. PC version of Plat-Dev-301 exam question stimulates real exam environment and supports MS operating system, which is a more practical way to study for the exam. In addition, the online test engine of the Plat-Dev-301 Exam Prep seems to get a higher expectation among most candidates, on account that almost every user is accustomed to studying or working with APP in their portable phones or tablet PC. We assure you that each version has the same study materials, just choose one you like.
Do you feel Salesforce Plat-Dev-301 exam preparation is tough? LatestCram desktop and web-based online Salesforce Plat-Dev-301 practice test software will give you a clear idea about the final Plat-Dev-301 Test Pattern. Practicing with the Salesforce Plat-Dev-301 practice test, you can evaluate your Salesforce Plat-Dev-301 exam preparation.
Plat-Dev-301 Reliable Test Tutorial, Plat-Dev-301 Latest Exam PdfLatestCram offers the best self-assessment software for the Plat-Dev-301 exam. This desktop-based practice exam provides valid and up-to-date Plat-Dev-301 practice test questions. You can customize the software by adjusting the time and number of Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) questions to your preferences. Additionally, you can try a free demo of the Plat-Dev-301 Practice Test. This software keeps track of all your Plat-Dev-301 practice exam attempts, allowing you to monitor your progress and improve your Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) exam preparation.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q69-Q74):NEW QUESTION # 69
A developer is working on an integration between Salestorce and an external system. The integration requires sending a large amount of data to the external systern, which can cause long response times and timeouts.
To optimize the performance and avoid timeouts, which technique should be used?
- A. Use the @future annotation to make the callout asynchronous.
- B. Increase the timeout limit in the callout options,
- C. Implement an asynchronous callout using the Continuation class,
- D. Use a chained batch Apex to split the data into smaller batches.
Implementing an asynchronous callout using the Continuation class is the optimal solution to handle long response times and avoid timeouts in Salesforce. It allows the Apex code to make a long-running request to an external service and free up the thread to serve other requests.
NEW QUESTION # 70
Which two best practices should the developer implement to optimize this code? Choose 2 answers
- A. Use a collection for the DML statement.
- B. Query the Driving-Structure_C records outside of the loop
- C. Remove the DML statement.
- D. Change the trigger context to after update, after insert
To optimize the code in question, it's important to follow best practices that reduce the number of SOQL queries and DML statements within loops, as these can quickly consume governor limits and lead to inefficiencies. Option C is correct because using a collection to hold records and performing a single DML operation outside of loops reduces the number of DML operations, which is a best practice for bulkifying code in Salesforce. Option D is also correct because querying records outside of a loop prevents hitting SOQL governor limits and makes the code more efficient. Options A and B are not correct in the context provided, as there isn't enough information to determine if changing the trigger context is necessary, and removing the DML statement altogether may not be feasible if the logic requires data to be persisted.
Reference
Apex Best Practices: Apex Developer Guide Best Practices
NEW QUESTION # 71
An environment has two Apex triggers: an after-update trigger on Account and an after-update trigger on Contact.
The Account after-update trigger fires whenever an Account's address is updated, and it updates every associated Contact with that address. The Contact after-update trigger fires on every edit, and it updates every Campaign Member record related to the Contact with the Contact's state.
Consider the following: A mass update of 200 Account records' addresses, where each Account has 50 Contacts. Each Contact has one Campaign Member. This means there are 10,000 Contact records across the Accounts and 10,000 Campaign Member records across the contacts.
What will happen when the mass update occurs?
- A. There will be no error and all updates will succeed, since the limit on the number of records processed by DML statements was not exceeded.
- B. There will be no error, since each trigger fires within its own context and each trigger does not exceed the limit of the number of records processed by DML statements.
- C. The mass update will fail, since the two triggers fire in the same context, thus exceeding the number of records processed by DML statements.
- D. The mass update of Account address will succeed, but the Contact address updates will fail due to exceeding number of records processed by DML statements.
In this scenario, the governor limit for DML statements (150 DML operations and 10,000 DML rows per transaction) will be exceeded because the updates will cascade across related objects, significantly multiplying the number of records processed.
NEW QUESTION # 72
Consider the queries in the options below and the following Information:
* For these queries, assume that there are more than 200,000 Account records.
* These records Include soft-deleted records; that is, deleted records that are still in the Recycle Bin.
* There are two fields that are marked as External Id on the
Account. These fields are customer_Number_c and ERR_Key_ s.
Which two queries are optimized for large data volumes?
Choose 2 answers
- A. SELECT Id FROM Account WHERE Name !- NULL
- B. SELECT Id FROM Account WHERE Name != ' 'AND IsDeleted = false
- C. SELECT 1d FROM Accounts WHERE Name != 'AND Customer_Number_c- "ValueA'
- D. SELECT ID FROM Account WHRE id IN :aListVariable
For optimizing queries, especially on large data volumes, it's recommended to use indexed fields such as External ID fields, which will make the queries selective. Among the options given:
B) is optimized because it is using the Customer_Number__c field, which is an External ID and hence indexed.
D) is also optimized because it filters out deleted records with IsDeleted = false and uses Name != ' ', which is likely to be selective.
Using indexed fields and filtering out unnecessary records helps in faster query execution on large data volumes.
Make SOQL Query Selective
Working with Very Large SOQL Queries
NEW QUESTION # 73
A developer built an Aura component for guests to self-register upon arrival at a front desk kiosk. Now the developer needs to create a component for the utility tray to alert users whenever a guest arrives at the front desk.
What should be used?
- A. DML Operation
- B. Changelog
- C. Application Event
- D. Component Event
Application Events in Aura components are used for communication between components that are not in the same containment hierarchy. An application event to alert users about the arrival of a guest at the front desk is appropriate because it allows any component within the app to listen and respond to the event, regardless of where it is located in the component hierarchy.
NEW QUESTION # 74
With our Plat-Dev-301 pdf torrent, you will minimize your cost on the exam preparation and be ready to pass your Plat-Dev-301 actual test on your first try. LatestCram will provide you the easiest and quickest way to get the Plat-Dev-301 certification without headache. We will offer the update service for one year. In addition, you will instantly download the Plat-Dev-301 PDF VCE after you complete the payment. With the help of Plat-Dev-301 study dumps, you can just spend 20-30 hours for the preparation. Then you will be confident in the actual test.
Plat-Dev-301 Reliable Test Tutorial: https://www.latestcram.com/Plat-Dev-301-exam-cram-questions.html
After purchase of the New Plat-Dev-301 training vce pdf, you can instant download the Plat-Dev-301 latest study dumps and start your study with no time wasted, Do you still worry about passing Salesforce certification Plat-Dev-301 exam, For on one hand, they are busy with their work, they have to get the Plat-Dev-301 certification by the little spread time, LatestCram Plat-Dev-301 Reliable Test Tutorial will be the one.
I spent a month thinking and relaxing, then decided Plat-Dev-301 to take a sabbatical, You can see our reviews and testimonials to make sure how genuine is our company, After purchase of the New Plat-Dev-301 training vce pdf, you can instant download the Plat-Dev-301 latest study dumps and start your study with no time wasted.
Pass Guaranteed Quiz Salesforce - Accurate Plat-Dev-301 - Salesforce Certified Platform Developer II - Multiple Choice High QualityDo you still worry about passing Salesforce certification Plat-Dev-301 exam, For on one hand, they are busy with their work, they have to get the Plat-Dev-301 certification by the little spread time.
LatestCram will be the one, How to tell if a company can provide you reliable Plat-Dev-301 practice questions?
- Reliable Plat-Dev-301 Test Guide 👋 Exam Plat-Dev-301 Fees 🌠 Exam Plat-Dev-301 Fees 🌌 ⮆ [url]www.exam4labs.com ⮄ is best website to obtain ( Plat-Dev-301 ) for free download 🛐
lat-Dev-301 Study Plan[/url] - Plat-Dev-301 High Quality - Free PDF Salesforce Salesforce Certified Platform Developer II - Multiple Choice Realistic Reliable Test Tutorial 🤶 Search for { Plat-Dev-301 } and download exam materials for free through ⇛ [url]www.pdfvce.com ⇚ 🌳
lat-Dev-301 Valid Test Papers[/url] - Plat-Dev-301 Pass Exam 👏 Fresh Plat-Dev-301 Dumps 😜 Plat-Dev-301 Questions Answers 🔮 Easily obtain free download of ▶ Plat-Dev-301 ◀ by searching on ✔ [url]www.testkingpass.com ️✔️ 🐆Exam Plat-Dev-301 Fees[/url]
- 2026 Plat-Dev-301 High Quality | Reliable 100% Free Salesforce Certified Platform Developer II - Multiple Choice Reliable Test Tutorial 🔌 Easily obtain free download of ▶ Plat-Dev-301 ◀ by searching on ⏩ [url]www.pdfvce.com ⏪ 🤗
lat-Dev-301 Trustworthy Practice[/url] - Plat-Dev-301 Pass Exam 🩳 Plat-Dev-301 Pass Leader Dumps 💇 Popular Plat-Dev-301 Exams 🕙 Immediately open ⇛ [url]www.prep4away.com ⇚ and search for ➤ Plat-Dev-301 ⮘ to obtain a free download 👉
lat-Dev-301 Pass Leader Dumps[/url] - Popular Plat-Dev-301 Exams 📣 Exam Plat-Dev-301 Answers 🤜 Reliable Plat-Dev-301 Test Guide ✈ Go to website { [url]www.pdfvce.com } open and search for ▛ Plat-Dev-301 ▟ to download for free 🌆Valid Plat-Dev-301 Test Book[/url]
- Reliable Plat-Dev-301 Braindumps 🧯 Plat-Dev-301 Pass Leader Dumps 🌀 Popular Plat-Dev-301 Exams ⚡ Open ☀ [url]www.exam4labs.com ️☀️ enter 「 Plat-Dev-301 」 and obtain a free download 🧜
opular Plat-Dev-301 Exams[/url] - Plat-Dev-301 Actual Real Questions: Salesforce Certified Platform Developer II - Multiple Choice - Plat-Dev-301 Practice Questions 🐬 ( [url]www.pdfvce.com ) is best website to obtain ☀ Plat-Dev-301 ️☀️ for free download ⚽Exam Plat-Dev-301 Fees[/url]
- Plat-Dev-301 VCE Exam Simulator 🕞 Plat-Dev-301 VCE Exam Simulator 📨 Plat-Dev-301 VCE Exam Simulator 🤴 Search for ☀ Plat-Dev-301 ️☀️ and obtain a free download on ⏩ [url]www.troytecdumps.com ⏪ 🔛Reliable Plat-Dev-301 Test Guide[/url]
- Exam Plat-Dev-301 Answers 😂 Reliable Plat-Dev-301 Test Guide 🐧 Plat-Dev-301 Pass Exam 🍓 Download ➡ Plat-Dev-301 ️⬅️ for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🚍
opular Plat-Dev-301 Exams[/url] - Plat-Dev-301 Valid Exam Practice 🔟 Reliable Plat-Dev-301 Braindumps 🚹 Plat-Dev-301 VCE Exam Simulator 😢 Go to website 《 [url]www.prepawaypdf.com 》 open and search for ⮆ Plat-Dev-301 ⮄ to download for free 🌁
lat-Dev-301 VCE Exam Simulator[/url] - www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, k12.instructure.com, www.stes.tyc.edu.tw, notefolio.net, www.stes.tyc.edu.tw, www.kickstarter.com, www.stes.tyc.edu.tw, Disposable vapes
