Salesforce Advanced-Administrator New Dumps Questions - Hot Advanced-Administrat
Posted at 1/31/2026 15:11:37
BONUS!!! Download part of ActualTorrent Advanced-Administrator dumps for free: https://drive.google.com/open?id=1-44k6NfGR5Gkies6jaXwsFHQyYVuTalH
Created on the exact pattern of the Actual Advanced-Administrator Tests, ActualTorrent’s dumps comprise questions and answers and provide all important information in easy to grasp and simplified content. The easy language does not pose any barrier for any learner. The complex portions of the certification syllabus have been explained with the help of simulations and real-life based instances. The best part of ActualTorrent’s dumps is their relevance, comprehensiveness and precision. You need not to try any other source for exam preparation. The innovatively crafted dumps will serve you the best; imparting you information in fewer number of questions and answers.
Salesforce is a leading customer relationship management (CRM) software that helps businesses manage their customer interactions and streamline their sales and marketing processes. Salesforce offers a range of certifications that enable professionals to validate their skills and expertise in using the platform. One such certification is the Salesforce Advanced-Administrator certification.
Salesforce Advanced-Administrator certification is highly valued by employers as it demonstrates that the professional has a deep understanding of the Salesforce platform and can perform advanced tasks that are critical to the success of their business. Professionals who earn this certification can expect to have a higher earning potential and more job opportunities in the Salesforce ecosystem.
Salesforce Advanced-Administrator Exam covers a range of topics, including managing and configuring Salesforce, data management, security and access, automation, and reporting. Candidates are expected to have a strong understanding of these areas, as well as the ability to apply them to real-world scenarios. Advanced-Administrator exam consists of 60 multiple-choice questions, and candidates have 105 minutes to complete it. A passing score of 65% or higher is required to earn the certification. With the Salesforce Advanced-Administrator certification, individuals can demonstrate their advanced knowledge and skills in Salesforce administration, and stand out to potential employers as a highly qualified and competent professional in this field.
Hot Salesforce Advanced-Administrator Spot Questions & Exam Advanced-Administrator QuizzesThe ActualTorrent is one of the leading brands that have been helping Salesforce Advanced-Administrator Certification aspirants for many years. Hundreds of Salesforce Salesforce Certified Advanced Administrator exam applicants have achieved the Salesforce Certified Advanced Administrator in Procurement and Supply Salesforce certification. All these successful Salesforce test candidates have prepared with real and updated Salesforce Certified Advanced Administrator in Procurement and Supply Salesforce Questions of ActualTorrent. If you also want to become Salesforce Certified Advanced Administrator in Procurement and Supply Salesforce certified, you should also prepare with our Salesforce Salesforce Certified Advanced Administrator actual exam questions.
Salesforce Certified Advanced Administrator Sample Questions (Q100-Q105):NEW QUESTION # 100
When a lookup relationship is created between two objects, which three options can the administrator select to help manage situations when a lookup record is deleted?
Choose 3 answers.
- A. Notify the record owner.
- B. Do not allow deletion of a lookup record that is part of a lookup relationship.
- C. Prompt the user to enter another record to resolve the lookup relationship.
- D. Delete the related record also.
- E. Clear the value of the lookup field.
Answer: B,D,E
NEW QUESTION # 101
The sales department has asked to limit access to the Amount field on the Opportunity to only tnose users. In the sales department and on the executtve team, Northern Trail Outfitters uses six custom profiles including Sales User. Marketing user, call Center user. Executive User Sales Manager user, ana call Center Manager user. Field level access is removed from three or the profiles In the sandbox.
What action should an administrator take to make sure this change is in production?
- A. Deploy a change set from tht sandbox to prodUGBOffl including the Amount field with all the custom profiles.
- B. Process a change set with the profiles that should no longer have access to the field.
- C. Create a sandbox template and push it to production to reflect the update.
- D. Manually restrict access to this field for each profile via Setup Just like the sandbox.
A change set is a tool that allows you to send customizations from one Salesforce org to another. A change set can contain components such as objects, fields, profiles, permission sets, workflows, and more. You can use change sets to migrate changes from a sandbox org to a production org or between two sandbox orgs that are affiliated with the same production org. In this case, you can deploy a change set from the sandbox to production that includes the Amount field and all the custom profiles that need access to it. This way, you can update the field-level security settings for the field on each profile in one deployment. References:
https://help.salesforce.com/s/ar ... sets.htm&type=5
https://help.salesforce.com/s/ar ... ield.htm&type=5
NEW QUESTION # 102
An administrator created and activated several record-triggered flows that are configured to run before the record is saved on the same object.
What should the administrator consider about the order of execution for flows?
- A. The flow type will determine the order of execution.
- B. The order of flow execution is unpredictable.
- C. The last created date of the flow will determine the order.
- D. The flows will execute in alphabetical order based on their names.
When you have multiple record-triggered flows that are configured to run before the record is saved on the same object, the order of flow execution is unpredictable. This means that you cannot guarantee which flow will run first or last, or how they will affect each other's field updates. Therefore, you should avoid creating multiple before-save flows on the same object and instead consolidate them into one flow if possible.
https://help.salesforce.com/s/ar ... fore.htm&type=5
NEW QUESTION # 103
What type of prices can the system administrator set for an organization's products?
- A. Product prices.
- B. Standard prices.(100%)
- C. Discount prices.
- D. List prices.(100%)
- E. Sales prices.(100%)
Answer: B,D,E
NEW QUESTION # 104
AW Computing wants to embed a report chart on the Account record page that shows the value of closed sales for that account. The chart should be limited to users in the Sales Manager role on the Account record pages.
how should this be accomplished?
- A. Filter component visibility for the Account ID.
- B. Create a new report and assign it to the component.
- C. Create a new page layout for the Sales Manager role.
- D. Filter component visibility for the Sales Manager role.
To embed a report chart on a record page, you need to use a lightning component that displays report charts.
You can filter the component visibility by setting conditions based on record fields, user attributes, or device type. In this case, you can filter the component visibility by matching the Account ID field on the report chart with the Account ID field on the record page. This will ensure that only the relevant data for that account is shown on the chart. References:
https://help.salesforce.com/s/ar ... ning.htm&type=5
https://help.salesforce.com/s/ar ... lity.htm&type=5
NEW QUESTION # 105
You can land your ideal job and advance your career with the Salesforce Advanced-Administrator certification. Success in the Salesforce Advanced-Administrator exam verifies your talent to perform crucial technical tasks. Preparation for this Salesforce Advanced-Administrator exam is a tricky task. Make sure you choose the top-notch Salesforce Advanced-Administrator Study Materials to get ready for this exam. For your smooth Advanced-Administrator test preparation, ActualTorrent provides updated Advanced-Administrator practice material with a success guarantee.
Hot Advanced-Administrator Spot Questions: https://www.actualtorrent.com/Advanced-Administrator-questions-answers.html
- Valid Advanced-Administrator New Dumps Questions Supply you Latest-updated Hot Spot Questions for Advanced-Administrator: Salesforce Certified Advanced Administrator to Study easily 🧾 Search for 「 Advanced-Administrator 」 and download it for free immediately on ▛ [url]www.practicevce.com ▟ 🎥Valid Dumps Advanced-Administrator Ebook[/url]
- Advanced-Administrator Valid Braindumps Files 🔑 Upgrade Advanced-Administrator Dumps 📭 Advanced-Administrator Valid Exam Camp 🙁 Easily obtain 「 Advanced-Administrator 」 for free download through “ [url]www.pdfvce.com ” 🍆Advanced-Administrator Valid Braindumps Files[/url]
- Free Advanced-Administrator Exam ➡️ Advanced-Administrator Valid Exam Bootcamp 🥭 Advanced-Administrator Vce Download 🗳 Download ( Advanced-Administrator ) for free by simply entering ▷ [url]www.troytecdumps.com ◁ website 🛥Latest Advanced-Administrator Braindumps[/url]
- Get Latest Salesforce Advanced-Administrator Exam Dumps [2026] 🧐 Open website ✔ [url]www.pdfvce.com ️✔️ and search for ⏩ Advanced-Administrator ⏪ for free download 🎓Free Advanced-Administrator Exam[/url]
- High Pass Rate Salesforce Advanced-Administrator Test Dumps Cram is the best for you - [url]www.prep4sures.top 🧑 Immediately open ⏩ www.prep4sures.top ⏪ and search for ▷ Advanced-Administrator ◁ to obtain a free download 🔂Exam Advanced-Administrator Study Guide[/url]
- New Advanced-Administrator Braindumps Ebook ↩ New Advanced-Administrator Braindumps Ebook 🦺 Advanced-Administrator Knowledge Points ❕ Search for ☀ Advanced-Administrator ️☀️ and easily obtain a free download on ( [url]www.pdfvce.com ) 🕘Advanced-Administrator Knowledge Points[/url]
- Advanced-Administrator Knowledge Points 🔲 Latest Advanced-Administrator Exam Materials 🚋 Advanced-Administrator Valid Test Guide 🌤 Search for ☀ Advanced-Administrator ️☀️ and download it for free on ▶ [url]www.pass4test.com ◀ website 💟New Advanced-Administrator Dumps Pdf[/url]
- Valid Dumps Advanced-Administrator Ebook ♿ Advanced-Administrator Online Exam 🦌 Valid Advanced-Administrator Exam Questions 🦺 Search for ➡ Advanced-Administrator ️⬅️ and download it for free immediately on ☀ [url]www.pdfvce.com ️☀️ 🌙Exam Advanced-Administrator Study Guide[/url]
- Advanced-Administrator Valid Test Guide ⛺ Advanced-Administrator Valid Test Guide 🏡 Valid Dumps Advanced-Administrator Ebook 🥖 Download [ Advanced-Administrator ] for free by simply entering ⇛ [url]www.prepawayexam.com ⇚ website ♣Free Advanced-Administrator Exam[/url]
- [url=https://www.wiebelwoorden.be/?s=Get%20Latest%20Salesforce%20Advanced-Administrator%20Exam%20Dumps%20[2026]%20%f0%9f%a7%ad%20The%20page%20for%20free%20download%20of%20%e2%9c%94%20Advanced-Administrator%20%ef%b8%8f%e2%9c%94%ef%b8%8f%20on%20%e3%80%8a%20www.pdfvce.com%20%e3%80%8b%20will%20open%20immediately%20%f0%9f%90%9cAdvanced-Administrator%20Vce%20Download]Get Latest Salesforce Advanced-Administrator Exam Dumps [2026] 🧭 The page for free download of ✔ Advanced-Administrator ️✔️ on 《 www.pdfvce.com 》 will open immediately 🐜Advanced-Administrator Vce Download[/url]
- Advanced-Administrator Valid Braindumps Ppt ◀ Advanced-Administrator Valid Braindumps Files 🔌 Advanced-Administrator Vce Download 📟 Easily obtain free download of 「 Advanced-Administrator 」 by searching on ▷ [url]www.prep4away.com ◁ 🤥Advanced-Administrator Valid Braindumps Files[/url]
- www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, devfolio.co, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mecabricks.com, Disposable vapes
P.S. Free & New Advanced-Administrator dumps are available on Google Drive shared by ActualTorrent: https://drive.google.com/open?id=1-44k6NfGR5Gkies6jaXwsFHQyYVuTalH
