[General] CCOA real test engine & CCOA exam training vce & CCOA practice torrent
100
【General】 CCOA real test engine & CCOA exam training vce & CCOA practice torrent
Posted at 1/31/2026 16:19:59      View:144 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Actual4Dumps CCOA dumps from Cloud Storage: https://drive.google.com/open?id=1gvheKZ-F2lrdbC8THl8MOoloZpMZm2Qq
You can conveniently test your performance by checking your score each time you use our ISACA CCOA practice exam software (desktop and web-based). It is heartening to announce that all Actual4Dumps users will be allowed to capitalize on a free ISACA CCOA Exam Questions demo of all three formats of the ISACA CCOA practice test.
Don't let the ISACA Certified Cybersecurity Operations Analyst exam stress you out! Prepare with our CCOA exam dumps and boost your confidence in the CCOA exam. We guarantee your road toward success by helping you prepare for the CCOA exam. Use the best ISACA CCOA practice questions to pass your CCOA Exam with flying colors! In this way, the ISACA Certified Cybersecurity Operations Analyst certified professionals can not only validate their skills and knowledge level but also put their careers on the right track. By doing this you can achieve your career objectives.
Latest CCOA Demo & CCOA Exam TipsAs far as the prices of CCOA exam dumps are concerned, we ensure you that our ISACA Certified Cybersecurity Operations Analyst (CCOA) exam questions prices are entirely affordable for everyone. The real and updated CCOA exam dumps are being offered at discounted prices. You can grab this opportunity and download the top-notch and real ISACA Certified Cybersecurity Operations Analyst (CCOA) exam questions at discounted prices. Best wishes for the final ISACA CCOA certification exam!!!
ISACA Certified Cybersecurity Operations Analyst Sample Questions (Q61-Q66):NEW QUESTION # 61
The user of the Accounting workstation reported thattheir calculator repeatedly opens without their input.
Perform a query of startup items for the agent.nameaccounting-pc in the SIEM for the last 24 hours.
Identifythe file name that triggered RuleName SuspiciousPowerShell. Enter your response below. Your responsemust include the file extension.
See the solution in Explanation.
To identify thefile namethat triggered theRuleName: Suspicious PowerShellon theaccounting-pc workstation, follow these detailed steps:
Step 1: Access the SIEM System
* Open your web browser and navigate to theSIEM dashboard.
* Log in with youradministrator credentials.
Step 2: Set Up the Query
* Go to theSearchorQuerysection of the SIEM.
* Set theTime Rangeto thelast 24 hours.
Query Parameters:
* Agent Name:accounting-pc
* Rule Name:Suspicious PowerShell
* Event Type:Startup items or Process creation
Step 3: Construct the SIEM Query
Here's an example of how to construct the query:
Example Query (Splunk):
index=windows_logs
| search agent.name="accounting-pc" RuleName="Suspicious PowerShell"
| where _time > now() - 24h
| table _time, agent.name, process_name, file_path, RuleName
Example Query (Elastic SIEM):
"query": {
"bool": {
"must": [
{ "match": { "agent.name": "accounting-pc" }},
{ "match": { "RuleName": "Suspicious PowerShell" }},
{ "range": { "@timestamp": { "gte": "now-24h" }}}
Step 4: Analyze the Query Results
* The query should return a table or list containing:
* Time of Execution
* Process Name
* File Path
* Rule Name
Example Output:
_time
agent.name
process_name
file_path
RuleName
2024-04-07T10:45:23
accounting-pc
powershell.exe
C:UsersAccountingAppDataRoamingcalc.ps1
Step 5: Identify the Suspicious File
* Theprocess_namein the output showspowershell.exeexecuting a suspicious script.
* Thefile pathindicates the script responsible:
makefile
* The suspicious script file is:
calc.ps1
Step 6: Confirm the Malicious Nature
* Manual Inspection:
* Navigate to the specified file path on theaccounting-pcworkstation.
* Check the contents of calc.ps1 for any malicious PowerShell code.
* Hash Verification:
* Generate theSHA256 hashof the file and compare it with known malware signatures.
calc.ps1
Step 7: Immediate Response
* Isolate the Workstationisconnectaccounting-pcfrom the network.
* Terminate the Malicious Process:
* Stop the powershell.exe process running calc.ps1.
* Use Task Manager or a script:
powershell
Stop-Process -Name "powershell" -Force
* Remove the Malicious Script:
powershell
Remove-Item "C:UsersAccountingAppDataRoamingcalc.ps1" -Force
* Scan for Persistence Mechanisms:
* CheckStartup itemsandScheduled Tasksfor any references to calc.ps1.
Step 8: Documentation
* Record the following:
* Date and Time:When the incident was detected.
* Affected Host:accounting-pc
* Malicious File:calc.ps1
* Actions Taken:File removal and process termination.
NEW QUESTION # 62
Which of the following is MOST likely to result from misunderstanding the cloud service shared responsibility model?
  • A. Misconfiguration of access controls for cloud services
  • B. Being forced to remain with the cloud service provider due to vendor lock-In
  • C. Improperly securing access to the cloud metastructure layer
  • D. Falsely assuming that certain risks have been transferred to the vendor
Misunderstanding thecloud service shared responsibility modeloften leads to the false assumption that the cloud service provider (CSP) is responsible for securing all aspects of the cloud environment.
* What is the Shared Responsibility Model?It delineates the security responsibilities of the CSP and the customer.
* Typical Misconception:Customers may believe that the provider handles all security aspects, including data protection and application security, while in reality, the customer is usually responsible for securing data and application configurations.
* Impact:This misunderstanding can result in unpatched software, unsecured data, or weak access control.
Incorrect Options:
* B. Improperly securing access to the cloud metastructure layer:This is a specific security flaw but not directly caused by misunderstanding the shared responsibility model.
* C. Misconfiguration of access controls for cloud services:While common, this usually results from poor implementation rather than misunderstanding shared responsibility.
* D. Vendor lock-in:This issue arises from contractual or technical dependencies, not from misunderstanding the shared responsibility model.
Exact Extract from CCOA Official Review Manual, 1st Edition:
Refer to Chapter 3, Section "Cloud Security Models," Subsection "Shared Responsibility Model" - Misunderstanding the shared responsibility model often leads to misplaced assumptions about who handles specific security tasks.
NEW QUESTION # 63
Which of the following would BCST enable an organization to prioritize remediation activities when multiple vulnerabilities are identified?
  • A. Business Impact analysis (BIA)
  • B. Vulnerability exception process
  • C. executive reporting process
  • D. Risk assessment
Arisk assessmentenables organizations toprioritize remediation activitieswhen multiple vulnerabilities are identified because:
* Contextual Risk Evaluation:Assesses the potential impact and likelihood of each vulnerability.
* Prioritization:Helps determine which vulnerabilities pose the highest risk to critical assets.
* Resource Allocation:Ensures that remediation efforts focus on the most significant threats.
* Data-Driven Decisions:Uses quantitative or qualitative metrics to support prioritization.
Other options analysis:
* A. Business Impact Analysis (BIA):Focuses on the impact of business disruptions, not directly on vulnerabilities.
* B. Vulnerability exception process:Manages known risks but does not prioritize them.
* C. Executive reporting process:Summarizes security posture but does not prioritize remediation.
CCOA Official Review Manual, 1st Edition References:
* Chapter 5: Risk Assessment Techniques:Emphasizes the importance of risk analysis in vulnerability management.
* Chapter 7: Prioritizing Vulnerability Remediation:Guides how to rank threats based on risk.
NEW QUESTION # 64
Which of the following has been established when a business continuity manager explains that a critical system can be unavailable up to 4 hours before operation is significantly impaired?
  • A. Maximum tolerable downtime (MID)
  • B. Service level agreement (SLA)
  • C. Recovery time objective (RTO)
  • D. Recovery point objective (RPO)
TheRecovery Time Objective (RTO)is themaximum acceptable timethat a system can be down before significantly impacting business operations.
* Context:If thecritical system can be unavailable for up to 4 hours, the RTO is4 hours.
* Objective:To define how quickly systems must be restored after a disruption tominimize operational impact.
* Disaster Recovery Planning:RTO helps design recovery strategies and prioritize resources.
* A. Maximum tolerable downtime (MTD):Represents the absolute maximum time without operation, not the target recovery time.
* B. Service level agreement (SLA)efines service expectations but not recovery timelines.
* C. Recovery point objective (RPO)efines data loss tolerance, not downtime tolerance.
* Chapter 5: Business Continuity and Disaster Recovery:Explains RTO and its role in recovery planning.
* Chapter 7: Recovery Strategy Planning:Highlights RTO as a key metric.
NEW QUESTION # 65
The network team has provided a PCAP file withsuspicious activity located in the Investigations folderon the Desktop titled, investigation22.pcap.
What date was the webshell accessed? Enter the formatas YYYY-MM-DD.
To determine thedate the webshell was accessedfrom theinvestigation22.pcapfile, follow these detailed steps:
Step 1: Access the PCAP File
* Log into the Analyst Desktop.
* Navigate to theInvestigationsfolder on the desktop.
* Locate the file:
Step 2: Open the PCAP File in Wireshark
* LaunchWireshark.
* Open the PCAP file:
mathematica
File > Open > Desktop > Investigations > investigation22.pcap
* ClickOpento load the file.
Step 3: Filter for Webshell Traffic
* Since webshells typically useHTTP/Sto communicate, apply a filter:
http.request or http.response
* Alternatively, if you know the IP of the compromised host (e.g.,10.10.44.200), use:
nginx
http and ip.addr == 10.10.44.200
* PressEnterto apply the filter.
Step 4: Identify Webshell Activity
* Look for HTTP requests that include:
* Common Webshell Filenames:shell.jsp, cmd.php, backdoor.aspx, etc.
* Suspicious HTTP Methods:MainlyPOSTorGET.
* Right-click a suspicious packet and choose:
arduino
Follow > HTTP Stream
* Inspect the HTTP headers and content to confirm the presence of a webshell.
Step 5: Extract the Access Date
* Look at theHTTP request/response header.
* Find theDatefield orTimestampof the packet:
* Wireshark displays timestamps on the left by default.
* Confirm theHTTP streamincludes commands or uploads to the webshell.
Example HTTP Stream:
POST /uploads/shell.jsp HTTP/1.1
Host: 10.10.44.200
User-Agent: Mozilla/5.0
Date: Mon, 2024-03-18 14:35:22 GMT
Step 6: Verify the Correct Date
* Double-check other HTTP requests or responses related to the webshell.
* Make sure thedate fieldis consistent across multiple requests to the same file.
2024-03-18
Step 7: Document the Finding
* Date of Access:2024-03-18
* Filename:shell.jsp (as identified earlier)
* Compromised Host:10.10.44.200
* Method of Access:HTTP POST
Step 8: Next Steps
* Isolate the Affected Host:
* Remove the compromised server from the network.
* Remove the Webshell:
rm /path/to/webshell/shell.jsp
* Analyze Web Server Logs:
* Correlate timestamps with access logs to identify the initial compromise.
* Implement WAF Rules:
* Block suspicious patterns related to file uploads and webshell execution.
NEW QUESTION # 66
A generally accepted view on society is only the professionals engaged in professionally work, and so on, only professional in accordance with professional standards of study materials, as our ISACA Certified Cybersecurity Operations Analyst study questions, to bring more professional quality service for the user. Our study materials can give the user confidence and strongly rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on CCOA Exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company.
Latest CCOA Demo: https://www.actual4dumps.com/CCOA-study-material.html
So as the most important and indispensable CCOA practice materials in this line, we have confidence in the quality of our CCOA practice materials, and offer all after-sales services for your consideration and acceptance, ISACA CCOA Test Torrent When Can You Claim The Guarantee, ISACA CCOA Test Torrent Unlimited Access allows you to study for multiple certifications by downloading Questions & Answers for all of your IT certification needs, ISACA CCOA Test Torrent This offer serves as the trust-building factor between the customer and us.
Plus the whole book is packed with design techniques, creative ideas CCOA New Questions and stunning layouts that will help you unleash your own creativity, Business Drivers for Enterprise Data Transformation.
100% Pass 2026 Marvelous CCOA: ISACA Certified Cybersecurity Operations Analyst Test TorrentSo as the most important and indispensable CCOA practice materials in this line, we have confidence in the quality of our CCOA practice materials, and offer all after-sales services for your consideration and acceptance.
When Can You Claim The Guarantee, Unlimited Access allows CCOA you to study for multiple certifications by downloading Questions & Answers for all of your IT certification needs!
This offer serves as the trust-building factor CCOA Exam Tips between the customer and us, In the guidance of teaching syllabus as well as theory and practice, our CCOA training engine has achieved high-quality exam materials according to the tendency in the industry.
DOWNLOAD the newest Actual4Dumps CCOA PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1gvheKZ-F2lrdbC8THl8MOoloZpMZm2Qq
Posted at 2/4/2026 11:44:32        Only Author  2#
Your article was such a breath of fresh air, thank you! Improve your IT skills and get free Latest C_BCSBS_2502 exam labs access. Wishing you the best of luck!
