[General] Place Your Order and Download Salesforce Order-Management-Administrator Actual Q
108
General Place Your Order and Download Salesforce Order-Management-Administrator Actual Q
Posted at 1/31/2026 17:03:42      View108 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Pass4guide Order-Management-Administrator dumps for free: https://drive.google.com/open?id=1H1v2G3vSOyzYAoMsBHAnHj6WXhLdnaKj
Beyond knowing the answer, and actually understanding the Order-Management-Administrator test questions puts you one step ahead of the test. Completely understanding a concept and reasoning behind how something works, makes your task second nature. Your Order-Management-Administrator test questions will melt in your hands if you know the logic behind the concepts. Any legitimate Order-Management-Administrator Test Questions should enforce this style of learning - but you will be hard pressed to find more than a Order-Management-Administrator test questions anywhere other than Pass4guide.
Salesforce is obliged to give you 12 months of free update checks to ensure the validity and accuracy of the Salesforce Order-Management-Administrator exam dumps. We also offer you a 100% money-back guarantee, in the very rare case of failure or unsatisfactory results. This puts your mind at ease when you are Salesforce Order-Management-Administrator Exam preparing with us.
Order-Management-Administrator Formal Test | Popular Order-Management-Administrator ExamsThe secret that Pass4guide helps many candidates pass Order-Management-Administrator exam is Salesforce exam questions attentively studied by our professional IT team for years, and the detailed answer analysis. We constantly updated the Order-Management-Administrator Exam Materials at the same time with the exam update. We try our best to ensure 100% pass rate for you.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q93-Q98):NEW QUESTION # 93
An item is not able to be fulfilled by the location assigned to the Item's Fulfillment Order. What two steps does a customer service representative need to do to move the item to a different fulfillment location?
Choose 2 answers
  • A. Create a new Fulfillment Order Product assigned to the appropriate Fulfillment Order
  • B. Delete the Fulfillment Order Product record from the Fulfillment Order's related
  • C. Cancel the Fulfillment Order
  • D. Change the Quantity field of the Fulfillment Order Product to 0 from the Fulfillment Order's related list
NEW QUESTION # 94
Universal Containers needs to implement a new Payment Method. What should the admin evaluate in relation to Payment Gateways and Payment Processors?
  • A. An Apex implementation will need to be written as Payment Methods
    have nothing to do with Payment Gateways and Payment Processors
  • B. A new Payment Processor needs to be adopted since each Payment Method reeds its own Payment Processor
  • C. Ensure the new payment method will support the existing payment gateway and payment processor
  • D. A new Payment Gateway needs to be adopted since each Payment Method needs its own Payment Gateway
NEW QUESTION # 95
Whichtwo Order Management objects have their tabs set to Tab Hidden by default?
  • A. SalesLocation
  • B. Fulfillment Orders
  • C. Accounts
  • D. Locations
  • E. OrderDeliveryMethod
Answer: D,E
The OrderDeliveryMethod and Locations objects have their tabs set to Tab Hidden by default. These objects are used to store information about how an order is delivered and where it is fulfilled from, respectively. They are not meant to be accessed directly by users, but rather through related lists or lookup fields on other objects. References: Order Management Objects
NEW QUESTION # 96
A user wants to review credit card payment data for a specific Order. Which object should the employee navigate to?
  • A. Order
  • B. Order Payment Summary
  • C. Payment Method
  • D. Payment
The object that the user should navigate to to review credit card payment data for a specific Order is Order Payment Summary. An Order Payment Summary is a record that represents a payment made for an order or part of an order. An Order Payment Summary has a lookup relationship to both Order Summary and Invoice objects, and it contains information such as the payment amount, method, status, etc. Verified Reference: https://help.salesforce.com/s/ar ... mary.htm&type=5
NEW QUESTION # 97
An admin is analyzing project requirements and notes that there are requirements to support both high volume and multiple locations. What is the recommended approach for this scenario?
  • A. Download the Single Location High Volume sample flow from the Partner Community and modify all the flows to loop through locations
  • B. Download the Multiple Locations sample flow from the Partner Community and have developers add Apex code to enhance performance
  • C. Download the Single Location High Volume sample flow from the Partner Community and have the developers add Apex code to enhance performance
  • D. Download the Single Location High Volume sample flow and the Multiple Locations sample flow from the Partner Community and make a blend  between the two considering trade-offs
The Single Location High Volume sample flow and the Multiple Locations sample flow are two examples of how to implement order fulfillment with Order Management. The Single Location High Volume sample flow is optimized for performance and scalability, but it only supports one fulfillment location per order. The Multiple Locations sample flow supports multiple fulfillment locations per order, but it has lower performance and scalability. To support both high volume and multiple locations, an admin can download both sample flows from the Partner Community and make a blend between them, considering trade-offs such as complexity, maintainability, and customizability. Reference: Order Fulfillment Flows, Partner Community
NEW QUESTION # 98
It is known to us that our Order-Management-Administrator learning dumps have been keeping a high pass rate all the time. There is no doubt that it must be due to the high quality of our study materials. It is a matter of common sense that pass rate is the most important standard to testify the Order-Management-Administrator training files. The high pass rate of our study materials means that our products are very effective and useful for all people to pass their exam and get the related certification. So if you buy the Order-Management-Administrator study questions from our company, you will get the certification in a shorter time.
Order-Management-Administrator Formal Test: https://www.pass4guide.com/Order-Management-Administrator-exam-guide-torrent.html
Salesforce Exam Dumps Order-Management-Administrator Free If you have any questions about our products, please feel free to contact us, They are dedicated and too captious to tolerant any mistakes in our practice materials, so our Order-Management-Administrator free questions are perfect for your reference, Salesforce Exam Dumps Order-Management-Administrator Free Never have we heard complaint from our old customers, Our Salesforce Order-Management-Administrator free training pdf is definitely your best choice to prepare for it.
As always, Thomas delivers again, I wrote tons of blog posts about the product Order-Management-Administrator and how to use it and cool things I've seen people do with it, If you have any questions about our products, please feel free to contact us.
Updated Salesforce Order-Management-Administrator Exam Questions in PDF DocumentThey are dedicated and too captious to tolerant any mistakes in our practice materials, so our Order-Management-Administrator free questions are perfect for your reference, Never have we heard complaint from our old customers.
Our Salesforce Order-Management-Administrator free training pdf is definitely your best choice to prepare for it, Just try and you will love them.
What's more, part of that Pass4guide Order-Management-Administrator dumps now are free: https://drive.google.com/open?id=1H1v2G3vSOyzYAoMsBHAnHj6WXhLdnaKj
