[General] Plat-Dev-301 Actual Exams, Valid Test Plat-Dev-301 Tips
94
General Plat-Dev-301 Actual Exams, Valid Test Plat-Dev-301 Tips
Posted at 1/31/2026 17:12:24      View204 | Replies0        Print      Only Author   [Copy Link] 1#
In fact, in real life, we often use performance of high and low to measure a person's level of high or low, when we choose to find a good job, there is important to get the Plat-Dev-301 certification as you can. Our product is elaborately composed with major questions and answers. We are choosing the key from past materials to finish our Plat-Dev-301 Guide question. It only takes you 20 hours to 30 hours to do the practice. After your effective practice, you can master the examination point from the Plat-Dev-301 test question. Then, you will have enough confidence to pass it.
Our experts are researchers who have been engaged in professional qualification Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 exams for many years and they have a keen sense of smell in the direction of the examination. Therefore, with our Plat-Dev-301 Study Materials, you can easily find the key content of the exam and review it in a targeted manner so that you can successfully pass the Salesforce Plat-Dev-301 exam.
Revolutionize Your Salesforce Exam Preparation with Our Web-Based Plat-Dev-301 Practice Test SoftwarePass4sureCert is here to provide you with Plat-Dev-301 exam dumps. These Salesforce Plat-Dev-301 practice test materials will help you secure the Plat-Dev-301 credential on the first attempt. Pass4sureCert resolves every problem of the test aspirants with reliable Salesforce Plat-Dev-301 Practice Test material. This Plat-Dev-301 practice exam imitates the Salesforce Plat-Dev-301 real exam pattern. Thus, it helps you kill Salesforce Plat-Dev-301 exam anxiety.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q111-Q116):NEW QUESTION # 111
A software company uses a custom object, Defact__c, to track defects in their software. Defect__c has organization-wide defaults set to private. Each Defect_ c has a related list of Reviewer < records, each with a lookup field to User that is used to indicate that the User will review the defect__c.
What should be used to give the User on the Reviewer_c record read only access to the Defect__c record on the Reviewer_c record?
  • A. Lightning web component
  • B. Apex managed sharing
  • C. Criteria-based sharing
  • D. View All on Defect__c
Apex managed sharing is used to programmatically share records when organization-wide defaults are private. It allows for creating share records that give read-only access to users specified in a related list.
NEW QUESTION # 112
A developer is asked to modify a Lightning web component so that it displays in one column on phones and in two columns on tablets, desktops, and larger devices.
Given to the code below:
Which should the developer add to the code to meet the requirements? A)
B)
C)
D)
  • A. Option B
  • B. Option C
  • C. Option A
  • D. Option D
The requirement is for the Lightning web component to display in one column on phones and in two columns on larger devices. To achieve this, we should specify the size attributes for different devices using the design tokens provided by the Lightning Design System.
Option B is correct because size="6" will set each lightning-layout-item to take up half the available space (since the grid system is based on a 12-column structure), creating two columns on tablets, desktops, and larger devices. small-device-size="12" will ensure that on small devices like phones, each item will take up the full width, resulting in a single column.
Options A, C, and D do not meet the requirement correctly, as they either do not set the size correctly for small devices or do not specify the sizes for both small and larger devices appropriately.
Lightning Design System Grid Documentation: Lightning Grid
NEW QUESTION # 113
A developer is working with existing functionality that tracks how many times a stage has changed for an Opportunity. When the Opportunity's stage is changed, a workflow rule is fired to increase the value of a field by one. The developer wrote an after trigger to create a child record when the field changes from 4 to 5.
A user changes the stage of an Opportunity and manually sets the count field to 4. The count field updates to 5, but the child record is not created.
What is the reason this is happening?
  • A. Trigger.new does not change after a field update.
  • B. After triggers fire before workflow rules.
  • C. Trigger.old does not contain the updated value of the count field.
  • D. After triggers are not fired after field updates.
https://help.salesforce.com/s/articleView?id=000384697&type=1
NEW QUESTION # 114
Instead of waiting to send emails to support personnel directly from the finish method of a batch Apex process, Universal Containers wants to notify an external system in the event that an unhandled exception occurs.
What is the appropriate publish/subscribe logic to meet this requirement?
  • A. Publish the error event using the addError method.
  • B. No publishing is necessary. Have the external system subscribe to the BatchapexErrorEvent.
  • C. Publish the error event with a Flow.
  • D. Publish the error event using the Eventbus. publish () method.
Use BatchApexErrorEvent for notifications. It's automatically triggered for unhandled exceptions in batch Apex. No need for manual publishing. External systems can subscribe to this event to receive notifications.
NEW QUESTION # 115
After a platform event is defined in a Salesforce org,events can be published via which mechanism?
  • A. External Apps require the standard Streaming API.
  • B. External Apps use an API Co publish event messages.
  • C. Internal Apps can use entitlement processes.
  • D. Internal Apps can use outbound messages.
Platform events in Salesforce can be published using a variety of mechanisms, including from external applications through the Salesforce APIs.
Option A is correct because external applications can use Salesforce APIs such as the REST API or the SOAP API to publish events to a platform event in Salesforce.
Options B, C, and D describe mechanisms that are not used for publishing platform events. Entitlement processes are for setting up and tracking service contracts, the standard Streaming API is for subscribing to events not publishing them, and outbound messages are a workflow action used to send information to external services, not for publishing platform events.
Salesforce Developer Documentation - Platform Events
NEW QUESTION # 116
We have installed the most advanced operation system in our company which can assure you the fastest delivery speed, to be specific, you can get immediately our Plat-Dev-301 training materials only within five to ten minutes after purchase after payment. As soon as you pressed the payment button on our Plat-Dev-301 Exam Questions, you can study right away if you choose to buy the Plat-Dev-301 exam practice from us. We aim to leave no misgivings to our customers so that they are able to devote themselves fully to their studies on Plat-Dev-301 guide materials and they will find no distraction from us.
Valid Test Plat-Dev-301 Tips: https://www.pass4surecert.com/Salesforce/Plat-Dev-301-practice-exam-dumps.html
Salesforce Plat-Dev-301 Actual Exams Once you have bought our products and there are new installation package, our online workers will send you an email at once, Plat-Dev-301 practice quiz knows well that the defect will detract greatly from the values of itself, Salesforce Plat-Dev-301 Actual Exams If you have any problems or questions, contact with us please, and we will deal with it seriously, Salesforce Plat-Dev-301 Actual Exams It is enough to help you to easily pass the exam.
Before, if you wanted to share digital photos, Valid Test Plat-Dev-301 Tips you had to e-mail everyone to let them know, The solution, therefore, was to push category-specific feeds, Once you have bought our products Plat-Dev-301 and there are new installation package, our online workers will send you an email at once.
Free PDF Salesforce - Plat-Dev-301 - Perfect Salesforce Certified Platform Developer II - Multiple Choice Actual ExamsPlat-Dev-301 practice quiz knows well that the defect will detract greatly from the values of itself, If you have any problems or questions, contact with us please, and we will deal with it seriously.
It is enough to help you to easily pass the exam, Make sure that you are reading all the Plat-Dev-301 practice questions answer in detail so you can pass Plat-Dev-301 exam on your first attempt.
