[General] Download FCSS_SDW_AR-7.4 Pdf | Braindumps FCSS_SDW_AR-7.4 Downloads
103
General Download FCSS_SDW_AR-7.4 Pdf | Braindumps FCSS_SDW_AR-7.4 Downloads
Posted at 1/31/2026 23:10:33      View122 | Replies2        Print      Only Author   [Copy Link] 1#
What's more, part of that Pass4Test FCSS_SDW_AR-7.4 dumps now are free: https://drive.google.com/open?id=1TK_Tsmyikui2XGp2HM3qCx_G7Xf3um9M
Our experts have devised a set of exam like FCSS_SDW_AR-7.4 practice tests for the candidates who want to ensure the highest percentage in real exam. Doing them make sure your grasp on the syllabus content that not only imparts confidence to you but also develops your time management skills for solving the test comprise given time lim. FCSS_SDW_AR-7.4 Practice Tests comprise a real exam like scenario and are amply fruitful to make sure a memorable success in FCSS_SDW_AR-7.4 exam.
Fortinet FCSS_SDW_AR-7.4 Exam Syllabus Topics:
  • Rules and Routing: Targeted at network engineers, this section assesses the ability to configure SD-WAN rules and routing policies. Candidates will be tested on managing traffic flow and prioritization across the SD-WAN infrastructure.
  • Configure Performances SLAs: Designed for network administrators, this part focuses on setting up performance Service Level Agreements (SLAs) within SD-WAN environments. Candidates must show proficiency in defining criteria to monitor and maintain network performance and reliability.
  • SD-WAN Troubleshooting: This part assesses the troubleshooting skills of network support specialists. Candidates should be able to diagnose and resolve issues related to SD-WAN rules, session behaviors, routing inconsistencies, and ADVPN connectivity problems to maintain seamless network operations.
FCSS_SDW_AR-7.4 Valid Study Guide & FCSS_SDW_AR-7.4 Exam Training Material & FCSS_SDW_AR-7.4 Free Download DemoFor candidates who are going to select the FCSS_SDW_AR-7.4 training materials for the exam, the pass rate for the FCSS_SDW_AR-7.4 training materials is important. With pass rate reaching 98.65%, the exam dumps have reached great popularity among the candidates, and we have received many good feedbacks from the buyers. In addition, FCSS_SDW_AR-7.4 Exam Materials are edited by professional experts, they possess the professional knowledge for the exam, therefore the quality can be guaranteed. We have free demo for you to have a try for FCSS_SDW_AR-7.4 training materials. You can have a try before buying.
Fortinet FCSS - SD-WAN 7.4 Architect Sample Questions (Q64-Q69):NEW QUESTION # 64
Refer to the exhibit. How does FortiGate handle the traffic with the source IP 10.0.1.130 and the destination IP 128.66.0 125?
  • A. FortiGate steers the traffic flow through port2.
  • B. FortiGate load balances the traffic flow through port1 and port2.
  • C. FortiGate routes the traffic flow according to the FIB.
  • D. FortiGate drops the traffic flow.
The router policy explicitly denies traffic with source 10.0.1.128/25 (which includes 10.0.1.130) and destination 128.66.0.0/24 (which includes 128.66.0.125). Even though SD-WAN service 4 shows members (port1 and port2) alive and available for this traffic, the router policy is evaluated first and blocks it. Therefore, FortiGate drops the traffic flow.
NEW QUESTION # 65
Refer to the exhibits. The exhibits show the source NAT (SNAT) global setting. port2 interface settings, and the routing table on FortiGate.
The administrator increases the member priority on port2 to 20. Upon configuration changes and the receipt of new packets, which two actions does FortiGate perform on existing sessions established over port2? (Choose two.)
  • A. FortiGate updates the gateway information of the sessions with SNAT so that they use port1 instead of port2.
  • B. FortiGate continues routing all existing sessions over port2.
  • C. FortiGate flags the sessions as dirty.
  • D. FortiGate routes only new sessions over port2.
  • E. FortiGate flags the SNAT session as dirty only if the administrator has assigned an IP pool to the firewall policies with NAT.
With set snat-route-change enable, FortiGate updates SNAT sessions' egress interface and gateway if a better route becomes available (e.g., port1 after priority change).
The sessions are flagged as dirty, meaning their routing and SNAT details are refreshed upon new traffic matching the session.
NEW QUESTION # 66
Refer to the exhibit. You want to configure SD-WAN on a network as shown in the exhibit. The network contains many FortiGate devices. Some are used as NGFW, and some are installed with extensions such as FortiSwitch, FortiAP or FortiExtender. What should you consider when planning your deployment?
  • A. You must use FortiManager to manage your SD-WAN topology.
  • B. You can build an SD-WAN topology that includes all devices. The hubs can be FortiGate devices with FortiExtender.
  • C. You must build multiple SD-WAN topologies. Each topology must contain only one type of extension.
  • D. You can build an SD-WAN topology that includes all devices. The hubs must be devices without extensions.
FortiGate devices with FortiExtender can act as hubs in an SD-WAN topology. FortiGate supports SD-WAN integration across diverse setups - including those using FortiSwitch, FortiAP, and FortiExtender - as long as the topology and roles are properly defined.
NEW QUESTION # 67
Refer to the exhibit. Which two conclusions can you draw from the output shown? (Choose two.)
  • A. UDP traffic destined to the subnet 10.22.0.0/24 matches a manual SD-WAN rule.
  • B. UDP traffic destined to the subnet 10.22.0.0/24 matches a policy route.
  • C. One SD-WAN rule is defined with application categories as the destination.
  • D. One SD-WAN rule allows traffic load balancing.
One SD-WAN rule is defined with application categories as the destination The diagnose output shows application control matches such as Microsoft.Portal, Operational.Technology, and Social.Media, confirming that SD-WAN rules are using application categories as destinations.
UDP traffic destined to the subnet 10.22.0.0/24 matches a policy route The first entry (id=1) shows protocol=17 (UDP) with destination 10.22.0.0/24, confirming this traffic is handled by a policy route instead of an SD-WAN rule.
NEW QUESTION # 68
The network contains many FortiGate devices. Some are used as NGFW, and some are installed with extensions such as FortiSwitch. FortiAP. or Forti Ex tender.
  • A. You can build an SD-WAN topology that includes all devices. The hubs can be FortiGate devices with Forti Extender.
  • B. You can build an SD-WAN topology that includes all devices. The hubs must be devices without extensions.
  • C. You must use FortiManager to manage your SD-WAN topology.
  • D. You must build multiple SD-WAN topologies. Each topology must contain only one type of extension.
In Fortinet SD-WAN, hubs should not have extensions like FortiSwitch, FortiAP, or FortiExtender installed, as these can affect hub functionality and scalability. While all device types can be included in the topology, the hubs must be "clean" FortiGate devices without such extensions to ensure proper ADVPN and overlay management.
[FCSS_SDW_AR-7.4 1-0.docx Q3]
Fortinet SD-WAN Reference Architecture Guide 7.4 - Hub requirements
NEW QUESTION # 69
PDF design has versatile and printable material for Fortinet FCSS_SDW_AR-7.4 certification, so you all can breeze through the Fortinet FCSS_SDW_AR-7.4 exam without any problem. You can get to the PDF concentrate on material from workstations, tablets, and cell phones for the readiness of FCSS - SD-WAN 7.4 Architect (FCSS_SDW_AR-7.4) exam.
Braindumps FCSS_SDW_AR-7.4 Downloads: https://www.pass4test.com/FCSS_SDW_AR-7.4.html
P.S. Free & New FCSS_SDW_AR-7.4 dumps are available on Google Drive shared by Pass4Test: https://drive.google.com/open?id=1TK_Tsmyikui2XGp2HM3qCx_G7Xf3um9M
Posted at 2/1/2026 11:52:25        Only Author  2#
TestpdfǴʹITʿɹõĴ߻ܶͨ^ITPJCԇ˾ʹ҂TestpdfӖߡ҂TestpdfČ҈FԼĽ酢ITIL ITIL-4-Foundation JCԇĺܶоµЧӖߣITIL ITIL-4-Foundation JCԇyԇǰԇ}ԇ}𰸡҂Testpdfṩԇ}𰸺ԇ}95%ԡʹTestpdfӖߣITIL ITIL-4-Foundation JCԇǿԺpͨ^ġ
Posted at 2/3/2026 16:52:20        Only Author  3#
What an extraordinary piece of writing, thank you for sharing! The Practice C_ARSOR_2404 engine exam is right around the corner. Wish me luck!
