XK0-005Y㏊XK0-005ǥ
Posted at 2/1/2026 01:24:38
View120
Replies1
BONUS MogiExam XK0-005פһoϤǥ`ɣhttps://drive.google.com/open?id=1Kj9pYg5Q_muBsUR-6yWXC_T9PCUEaRGV
XK0-005J^ԇY˺ϸΤϺgǤϤʤϱҪǤҡϤʤԔ}ȴ𤨤XK0-005}ṩޤΆ}ҡνUY댟TҤˤä_kƤޤҡΤФ餷XK0-005}Ϥ͘ԇYؤγɹ_뤳ȤǤޤ
MogiExamϥ֥ȤǤʤaߤΤΌTĤѧĩ`ȤƤʹäǤޤ ˤʤޤXK0-005ȥ`˥YϤθ߶Ȥ\åƥʹäơCompTIA͘٤ٶȤ^Ǥʤ͘ԄӵĤ˱o뤳ȤǤޤ ˡΌTåդ٤ƤΤ͘24rgПoݤXK0-005ԇYCompTIA Linux+ Certification Exam}v륪饤ե``ӥṩޤ ơXK0-005ѧɤκϸʤ99〜100Ǥ XK0-005ʂJȡäޤ
CompTIA XK0-005ǥ & XK0-005YϵXK0-005äʥƥȥYϤϡҪ⺆gʷǥ饤Ȥʾ뤿ᡢXK0-005äʥƥȥɤѧ뤿Εrgȥͥ륮`ϤۤȤɱҪޤ饤ȤϡƥȤѧȜʂ20〜30rgޤ¤ѧʤɤæˤˤȤäƤϡ˥`Ǥʤʤ顢ƥȤΜʂʮ֤ʕrgʤȤ䤹ҪʤʤȤäȤǤ뤫Ǥ XK0-005ѧgɤEǤ顢XK0-005ԇYν̲ĤδǤꡢ饤ȤˤȤäƷdz˱Ǥ
CompTIA Linux+ Certification Exam J XK0-005 ԇY} (Q490-Q495):| # 490
A Linux system is failing to boot with the following error:
Which of the following actions will resolve this issue? (Choose two.)
- A. Boot the system on a LiveCD/ISO.
- B. Interrupt the boot process in the GRUB menu and add rescue to the kernel line.
- C. Interrupt the boot process in the GRUB menu and add single to the kernel line.
- D. Execute grub-install --root-directory=/mnt and reboot.
- E. Fix the partition modifying /etc/default/grub and reboot.
- F. Execute grub-install /dev/sdX and reboot.
⣺AF
h
The administrator should do the following two actions to resolve the issue:
* Boot the system on a LiveCD/ISO. This is necessary to access the system and repair the boot loader. A LiveCD/ISO is a bootable media that contains a Linux distribution that can run without installation. The administrator can boot the system from the LiveCD/ISO and mount the root partition of the system to a temporary directory, such as /mnt.
* Execute grub-install /dev/sdX and reboot. This will reinstall the GRUB boot loader to the disk device, where sdX is the device name of the disk, such as sda or sdb. The GRUB boot loader is a program that runs when the system is powered on and allows the user to choose which operating system or kernel to boot. The issue is caused by a corrupted or missing GRUB boot loader, which prevents the system from booting. The command grub-install will restore the GRUB boot loader and fix the issue.
The other options are incorrect because they either do not fix the boot loader (interrupt the boot process in the GRUB menu or fix the partition modifying /etc/default/grub) or do not use the correct syntax (grub-install -- root-directory=/mnt instead of grub-install /dev/sdX or rescue or single instead of recovery in the GRUB menu). References: CompTIA Linux+ (XK0-005) Certification Study Guide, Chapter 8: Managing the Linux Boot Process, pages 265-266.
| # 491
A systems administrator needs to list the contents of archive.tar.xz. Which of the following commands will list the files?
- A. tar ddf archive.tar.xz
- B. tar jvf archive.tar.xz
- C. tar xzf archive.tar.xz
- D. tar tJf archive.tar.xz
⣺D
| # 492
User1 is a member of the accounting group. Members of this group need to be able to execute but not make changes to a script maintained by User2. The script should not be accessible to other users or groups. Which of the following will give proper access to the script?
- A. chown user2:accounting script.sh
chmod u+x script.sh - B. chown accounting:user1 script.sh
chmod 057 script.sh - C. chown user1:accounting script.sh
chmod 777 script.sh - D. chown user2:accounting script.sh
chmod 750 script.sh
⣺D
h
The commands that will give proper access to the script are:
* chown user2:accounting script.sh: This command will change the ownership of the script to user2 as the
* owner and accounting as the group. The chown command is a tool for changing the owner and group of files and directories on Linux systems. The user2:accounting is the user and group name that the command should assign to the script. The script.sh is the name of the script that the command should modify. The command chown user2:accounting script.sh will ensure that user2 is the owner of the script and accounting is the group of the script, which will allow user2 to maintain the script and the accounting group to access the script.
* chmod 750 script.sh: This command will change the permissions of the script to 750, which means read, write, and execute for the owner; read and execute for the group; and no access for others.
The chmod command is a tool for changing the permissions of files and directories on Linux systems.
The permissions are represented by three digits in octal notation, where each digit corresponds to the owner, group, and others. Each digit can have a value from 0 to 7, where each value represents a combination of read, write, and execute permissions. The 750 is the permission value that the command should assign to the script. The script.sh is the name of the script that the command should modify. The command chmod 750 script.sh will ensure that only the owner and the group can execute the script, but not make changes to it, and that the script is not accessible to other users or groups.
The commands that will give proper access to the script are chown user2:accounting script.sh and chmod 750 script.sh. This is the correct answer to the question. The other options are incorrect because they either do not give proper access to the script (chown user1:accounting script.sh or chown accounting:user1 script.sh) or do not change the permissions of the script (chmod 777 script.sh or chmod u+x script.sh). References: CompTIA Linux+ (XK0-005) Certification Study Guide, Chapter 11: Managing File Permissions and Ownership, pages
346-348.
| # 493
An administrator transferred a key for SSH authentication to a home directory on a remote server. The key file was moved to .ssh/authorized_keys location in order to establish SSH connection without a password.
However, the SSH command still asked for the password. Given the following output:
Which of the following commands would resolve the issue?
- A. ssh_keygen -t rsa -o .ssh/authorized_keys
- B. chown root:root .ssh/authorized_keys
- C. chmod 600 .ssh/authorized_keys
- D. restorecon .ssh/authorized_keys
⣺C
h
The command that would resolve the issue is chmod 600 .ssh/authorized_keys. This command will change the permissions of the .ssh/authorized_keys file to 600, which means that only the owner of the file can read and write it. This is necessary for SSH key authentication to work properly, as SSH will refuse to use a key file that is accessible by other users or groups for security reasons. The output of ls -l shows that currently the .ssh
/authorized_keys file has permissions of 664, which means that both the owner and group can read and write it, and others can read it.
The other options are not correct commands for resolving the issue. The restorecon .ssh/authorized_keys command will restore the default SELinux security context for the .ssh/authorized_keys file, but this will not change its permissions or ownership. The ssh_keygen -t rsa -o .ssh/authorized_keys command is invalid because ssh_keygen is not a valid command (the correct command is ssh-keygen), and the -o option is used to specify a new output format for the key file, not the output file name. The chown root:root .ssh
/authorized_keys command will change the owner and group of the .ssh/authorized_keys file to root, but this will not change its permissions or make it accessible by the user who wants to log in with SSH key authentication. References: How to Use Public Key Authentication with SSH; chmod(1) - Linux manual page
| # 494
Two specific users need access to a directory owned by root where backups are located.
Which of the following commands would BEST ensure the specified users can access the backup files?
- A. setfacl
- B. chcon
- C. chmod
- D. umask
⣺A
h
https://www.2daygeek.com/how-to- ... facl-getfacl-linux/
| # 495
XK0-005JƥȤϡgϤҪʤȤȤơPh뤤δΤˑ餦ŤBΤޤΌTҤϡXK0-005ѧĩ`_k˶यΕrgȥͥ륮`M䤷Ƥޤʤ˽mʤνΰkչˤ˽ʤֱʅfߤˤ뤳ȤǤޤοޤǤˡXK0-005ԇYĤB餷ޤ XK0-005ԇY|ˤĤƤϡϤδΤĿһĿǴ_J뤿˕rgȤᤷޤ
XK0-005ǥ: https://www.mogiexam.com/XK0-005-exam.html
CompTIA XK0-005Y㏊ Ʒ˰ˤĤơΆ}ǤޤMogiExam¤_ԇYXK0-005}⤷ƤޤMogiExamCompTIAXK0-005ԇYȥ`˥YϤx֤ΤxIĤx֤Τ˵ȤǤُǰXK0-005ɤ|ǥ`ɤԇä֧Bˤ餹ʹäǤޤʤϱθƷ|CompTIA XK0-005ԇYYϤäơһؤԇY˺ϸޤCompTIA XK0-005Y㏊ ITƥȤJϵθǤޤϤҪˤʤޤCompTIA XK0-005Y㏊ ؤ¤ʤ㏊ƤYˤȤäƲǷʥĩ`Ǥ
ǰՓƤޤһ˲һ˲˼ǡΤऺ椯ʤ롢Ʒ˰ˤĤơΆ}ǤޤMogiExam¤_ԇYXK0-005}⤷Ƥޤ
ԇYΜʂ䷽-100ϸʤXK0-005Y㏊ԇY-¤XK0-005ǥMogiExamCompTIAXK0-005ԇYȥ`˥YϤx֤ΤxIĤx֤Τ˵ȤǤُǰXK0-005ɤ|ǥ`ɤԇä֧Bˤ餹ʹäǤޤʤϱθƷ|CompTIA XK0-005ԇYYϤäơһؤԇY˺ϸޤ
- XK0-005ԇY౾ 🏫 XK0-005Y 🔁 XK0-005ձZ 🦚 [ [url]www.japancert.com ]Ȥˤ⮆ XK0-005 ⮄}oϤʹXK0-005ձZvB[/url]
- 餷XK0-005Y㏊ȘΤXK0-005ǥ 🐩 ✔ [url]www.goshiken.com ️✔️⏩ XK0-005 ⏪}`XK0-005ϸ[/url]
- -һXK0-005Y㏊ԇY-ԇYΜʂ䷽XK0-005ǥ 🥧 [url]www.mogiexam.com ˤϟoϤ➠ XK0-005 🠰}ޤXK0-005ϸ[/url]
- CompTIA XK0-005Y㏊: CompTIA Linux+ Certification Exam - J^γɹ^, gʥȥ`˥ 📧 ✔ [url]www.goshiken.com ️✔️Ȥˤ⮆ XK0-005 ⮄}`XK0-005㏊[/url]
- XK0-005ϸ 😆 XK0-005ձZ 🥻 XK0-005 🐏 XK0-005 ԇY}➥ [url]www.goshiken.com 🡄ǟoXK0-005YJ^[/url]
- XK0-005YJ^ 🎑 XK0-005}o 🆗 XK0-005}o 💚 ➡ XK0-005 ️⬅️ԇY}☀ [url]www.goshiken.com ️☀️ǟoXK0-005ձZ[/url]
- XK0-005ꆖ} 📞 XK0-005ϸ ⬇ XK0-005ϸYՄ 😓 ▷ [url]www.xhs1991.com ◁▷ XK0-005 ◁ơoϤǺg˥`ɤǤޤXK0-005[/url]
- XK0-005ϸYՄ 🍗 XK0-005Y㏊ 🔛 XK0-005㏊ 🐌 { [url]www.goshiken.com }ϡ➠ XK0-005 🠰oϤǥ`ɤΤmʥȤǤXK0-005Y[/url]
- XK0-005YJ^ 😗 XK0-005ƥȥץ놖} 🐧 XK0-005ƥȥץ놖} 🔴 ➽ [url]www.xhs1991.com 🢪麆g➥ XK0-005 🡄oϤǥ`ɤǤޤXK0-005[/url]
- [url=https://ajinvestfromhome.com/?s=%e4%be%bf%e5%88%a9-%e4%b8%80%e7%95%aa%e5%84%aa%e7%a7%80%e3%81%aaXK0-005%e8%b3%87%e6%96%99%e5%8b%89%e5%bc%b7%e8%a9%a6%e9%a8%93-%e8%a9%a6%e9%a8%93%e3%81%ae%e6%ba%96%e5%82%99%e6%96%b9%e6%b3%95XK0-005%e3%82%af%e3%83%a9%e3%83%a0%e3%83%a1%e3%83%87%e3%82%a3%e3%82%a2%20%f0%9f%a4%99%20%e3%82%b5%e3%82%a4%e3%83%88[%20www.goshiken.com%20]%e3%81%a7%e2%9e%a0%20XK0-005%20%f0%9f%a0%b0%e5%95%8f%e9%a1%8c%e9%9b%86%e3%82%92%e3%83%80%e3%82%a6%e3%83%b3%e3%83%ad%e3%83%bc%e3%83%89XK0-005%e5%95%8f%e9%a1%8c%e7%84%a1%e6%96%99]-һXK0-005Y㏊ԇY-ԇYΜʂ䷽XK0-005ǥ 🤙 [ www.goshiken.com ]➠ XK0-005 🠰}`XK0-005}o[/url]
- XK0-005ϸ ☮ XK0-005Y 🦪 XK0-005ο㏊ 📬 [ [url]www.goshiken.com ][ XK0-005 ]ơoϤǺg˥`ɤǤޤXK0-005YJԇY[/url]
- pixabay.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, knowyourmeme.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, k12.instructure.com, www.stes.tyc.edu.tw, Disposable vapes
oϤǥ饦ɥȥ`¤MogiExam XK0-005 PDFפ`ɤ룺https://drive.google.com/open?id=1Kj9pYg5Q_muBsUR-6yWXC_T9PCUEaRGV
