EXIN CDCS Exam Questions Available At 50% Discount With Free Demo
Posted at 2/1/2026 04:17:51
View103
Replies0
2026 Latest ITCertMagic CDCS PDF Dumps and CDCS Exam Engine Free Share: https://drive.google.com/open?id=163LIuGl-eOTdr4YyWcDsSFqxDJTbIVHs
There are a lot of students that bought ITCertMagic's EXIN CDCS dumps and are satisfied with our services because they passed their EXIN Certification Exams on the very first try. We assure you that if you study with our provided EXIN CDCS Practice Questions, you can pass EXIN EPI Certified Data Centre Specialist (CDCS) certification test in a single attempt, and if you fail to do it, you can claim your money back from us according to terms and conditions.
EXIN CDCS Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Data Centre Environmental Considerations and Efficiency: This section evaluates the proficiency of data center professionals in addressing environmental factors and promoting efficiency within data center operations. The target audience, including data center managers and engineers, will be tested on their ability to identify and implement measures that enhance energy efficiency, cooling management, and sustainable practices.
| | Topic 2 | - Data Centre Life Cycle and Standards: This section of the exam measures the skills of data center professionals and covers the various stages involved in the life cycle of a data center, from planning and design to implementation and decommissioning.
| | Topic 3 | - Designing and Implementing a Data Centre: In this module, the exam assesses the knowledge of Exin data center professionals tasked with the design and implementation of data centers. Candidates will learn the key principles of creating an efficient data center layout, including considerations for scalability, redundancy, and security.
100% Pass 2026 Updated EXIN CDCS: EXIN EPI Certified Data Centre Specialist Pdf FilesOur EXIN EPI Certified Data Centre Specialist test torrent was designed by a lot of experts in different area. You will never worry about the quality and pass rate of our study materials, it has been helped thousands of candidates pass their exam successful and helped them find a good job. If you choose our CDCS study torrent, we can promise that you will not miss any focus about your exam. There are three different versions to meet customers needs you can choose the version that is suitable for you to study. If you buy our EXIN EPI Certified Data Centre Specialist test torrent, you will have the opportunity to make good use of your scattered time to learn whether you are at home, in the company, at school, or at a metro station.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q108-Q113):NEW QUESTION # 108
It is assumed that EMF shielding material must be installed as the EMF levels coming from the transformer room into the computer room are measured at 100mG. The transformer room is approximately 10 meters away from the computer room and is separated by a corridor. You can assume that no physical issues are present for installing shielding material at any area/location.
Where should you recommend the shielding material to be installed?
- A. As close as possible to the computer room
- B. Shielding is not required to be installed as 100mG is within the acceptable levels for computer rooms
- C. As close as possible to the transformer room
- D. It does not matter, either close to the transformer room or the computer room is okay as there is no impact to cost or shielding material performance
EMF shielding is most effective when installed close to the source of the EMF, which in this case is the transformer room. Shielding at the source contains the magnetic fields before they spread, minimizing exposure throughout the facility, including the computer room.
Detailed Explanation:
Placing shielding close to the EMF source minimizes the area impacted by electromagnetic interference, as it reduces the distance over which the EMF can spread. Shielding materials near the source can absorb or redirect EMF, providing the most effective reduction of EMF levels in adjacent spaces, like the data center.
EPI Data Center Specialist References:
EPI data center training advises positioning shielding close to the EMF source to contain fields more effectively and reduce interference in critical areas. This method is more efficient and cost-effective, as it limits the spread of EMF from the point of origin.
NEW QUESTION # 109
What is the minimum requirement for the power feeds to the building for a Rated-3 data center based on the ANSI/TIA-942 standard?
- A. One feed from one substation split over two separated distribution boards in separate rooms
- B. Two feeds coming from two different substations, one power company is acceptable
- C. Two feeds entering the data center building from one substation
- D. Two feeds coming from two different substations, one power company is not acceptable
The minimum requirement for power feeds to a Rated-3 data center according to ANSI/TIA-942 is to have two independent power feeds, which can come from two different substations provided by the same power company. This ensures redundancy and concurrent maintainability, as each feed can support the load independently during maintenance or failure of the other.
The separation by two substations ensures resilience in case of a localized outage or substation maintenance, aligning with Rated-3 requirements for uninterrupted operation. ANSI/TIA-942 permits these feeds from a single utility provider as long as they are supplied from distinct substations.
EPI underscores the importance of dual power feeds from separate substations for Rated-3 facilities, highlighting that the ability to draw from different substations aligns with redundancy requirements for high availability.
NEW QUESTION # 110
You need to determine the strategy for the cooling audit. All the servers are based on a front-to-rear (F-R) airflow design.
Which location for the temperature/humidity measurement should you recommend for the audit?
- A. At the front/intake of the server at 50 mm/2 inch
- B. At the back/rear of the server at 50 mm/2 inch
- C. At 1.5 meters/5 feet above the floor in the middle of the cold aisle
- D. At 1.5 meters/5 feet above the floor in the middle of the hot aisle
For a cooling audit in a data center, it is essential to measure temperature and humidity where air enters the servers to accurately assess cooling performance. In this case, since all servers have a front-to-rear (F-R) airflow design, measuring at the front/intake of the server will provide a precise understanding of the cooling conditions that the equipment is experiencing.
Servers with a front-to-rear airflow design draw in cool air from the cold aisle at the front, which is then exhausted into the hot aisle at the rear. By measuring temperature and humidity 50 mm/2 inches from the front intake, you gather data on the air conditions right before it enters the servers, providing an accurate representation of the cooling environment as it directly impacts the equipment.
Measuring in the cold aisle at the front intake ensures that the readings reflect the actual conditions of the incoming air that the servers depend on for effective cooling. This approach is consistent with best practices for maintaining thermal conditions in a data center, as it helps confirm that the cooling systems are delivering air within the required temperature and humidity specifications.
According to the EPI Data Center Specialist curriculum, the optimal placement for temperature and humidity sensors is at the intake of the equipment in the cold aisle, as it directly correlates to the environmental conditions affecting the servers. This positioning allows for a more effective audit of cooling performance, which is critical for maintaining the reliability and efficiency of the data center's operations.
NEW QUESTION # 111
When are the wet bulb and dry bulb temperatures identical?
- A. When the dry bulb's temperature is at the lowest allowable temperature for IT equipment as per ASHRAE
- B. When the relative humidity is 100%
- C. When the dry bulb's temperature is at the highest allowable temperature for IT equipment as per ASHRAE
- D. When the relative humidity is at the best practice value for relative humidity, being 50% RH
The wet bulb and dry bulb temperatures become identical when the relative humidity reaches 100%. At this point, the air is fully saturated with moisture, meaning it can no longer absorb additional water vapor. As a result, the rate of evaporation decreases, and there is no difference between the dry bulb and wet bulb temperatures.
The dry bulb temperature measures the air temperature, while the wet bulb temperature takes into account the cooling effect of evaporation. When relative humidity is at 100%, the air has reached its saturation point, and no further evaporation occurs. This causes both the wet bulb and dry bulb thermometers to display the same temperature reading. This condition is critical in understanding environmental conditions, particularly in HVAC and data center environments, where humidity control is essential to avoid equipment overheating or corrosion.
The EPI Data Center Specialist training includes understanding humidity levels and their impact on data center environments. Knowing when wet bulb and dry bulb temperatures align helps data center operators manage moisture levels effectively, which is essential for preventing issues related to high humidity, such as condensation on IT equipment.
NEW QUESTION # 112
A data center requires an audit to find out whether it conforms with ANSI/TIA-942 Rated-3 (concurrently maintainable).
Will the network architecture be part of this audit?
- A. No, only the type of cabling used will be audited.
- B. Yes, but only if the network administration does not comply with ANSI/TIA-606.
- C. No, as concurrently maintainable only applies to electrical and mechanical (power and cooling).
- D. Yes, amongst other aspects, the network architecture should be Rated-3 compliant with the requirements of ANSI/TIA-942.
For a Rated-3 data center, network architecture is indeed a key component of the audit under ANSI/TIA-942.
This rating requires concurrent maintainability across all systems, including telecommunications infrastructure. The network architecture must therefore meet specific redundancy and reliability standards to ensure uninterrupted operations during maintenance or failure of any single component.
Rated-3 requirements extend beyond electrical and mechanical systems to include network architecture. This ensures that telecommunications systems are also designed for concurrent maintainability, thus contributing to overall uptime and resilience.
EPI endorses comprehensive assessments for Rated-3 facilities, emphasizing that network systems must meet standards for redundancy and concurrent maintainability, which align with ANSI/TIA-942's holistic approach to data center reliability.
NEW QUESTION # 113
With our CDCS practice test software, you can simply assess yourself by going through the CDCS practice tests. We highly recommend going through the CDCS answers multiple times so you can assess your preparation for the EXIN EPI Certified Data Centre Specialist. Make sure that you are preparing yourself for the CDCS test with our practice test software as it will help you get a clear idea of the real CDCS exam scenario. By passing the exams multiple times on practice test software, you will be able to pass the real CDCS test in the first attempt.
Exam CDCS Introduction: https://www.itcertmagic.com/EXIN/real-CDCS-exam-prep-dumps.html
- CDCS Top Questions 🔟 New CDCS Practice Questions 👤 CDCS Free Practice 🎫 Search for ➡ CDCS ️⬅️ and download exam materials for free through [url]www.vceengine.com 🦺Valid CDCS Exam Forum[/url]
- Valid CDCS Test Pattern 😣 Reliable CDCS Test Objectives 🌹 CDCS Dumps PDF 😖 Easily obtain CDCS for free download through [url]www.pdfvce.com 🍣
remium CDCS Files[/url] - Valid CDCS Test Pattern 🦁 Test CDCS Simulator Fee 💇 CDCS Top Questions 🦅 Open website ⇛ [url]www.exam4labs.com ⇚ and search for ⇛ CDCS ⇚ for free download ⤴New CDCS Practice Materials[/url]
- CDCS New Braindumps Files 🌊 Valid CDCS Exam Forum 😈 CDCS Exams Training 👐 The page for free download of [ CDCS ] on [url]www.pdfvce.com will open immediately 🕉Reliable CDCS Test Objectives[/url]
- Valid CDCS Test Pattern 🍻 Valid Test CDCS Test 🏡 Valid Test CDCS Test 🚬 Search for ➡ CDCS ️⬅️ and obtain a free download on ▶ [url]www.vceengine.com ◀ 🛢CDCS New Braindumps Files[/url]
- CDCS Valid Examcollection 👕 Valid CDCS Test Pattern 🦎 Valid CDCS Exam Forum 🎬 Download ⇛ CDCS ⇚ for free by simply searching on ⇛ [url]www.pdfvce.com ⇚ ⬆
remium CDCS Files[/url] - CDCS New Braindumps Files 💺 New CDCS Practice Questions 🦜 Valid Test CDCS Test 🩺 Open website [url]www.vce4dumps.com and search for ▛ CDCS ▟ for free download 🛒CDCS Dumps PDF[/url]
- Valid Test CDCS Test 🦛 CDCS Reliable Test Labs 🥤 Premium CDCS Files 🏇 Easily obtain free download of ▛ CDCS ▟ by searching on ➽ [url]www.pdfvce.com 🢪 👵Reliable CDCS Test Objectives[/url]
- CDCS Pdf Files - 2026 First-grade EXIN Exam CDCS Introduction 👭 Search on { [url]www.prepawaypdf.com } for CDCS to obtain exam materials for free download 🤫Reliable CDCS Test Objectives[/url]
- New CDCS Practice Questions 👬 CDCS Exam Cost 🍤 Exam CDCS Study Guide 🤑 Copy URL ⇛ [url]www.pdfvce.com ⇚ open and search for CDCS to download for free 🚋Valid Test CDCS Test[/url]
- 2026 CDCS Pdf Files | Pass-Sure EXIN CDCS: EXIN EPI Certified Data Centre Specialist 100% Pass 🦚 Search on ➠ [url]www.practicevce.com 🠰 for ▷ CDCS ◁ to obtain exam materials for free download 🏨CDCS Free Practice[/url]
- bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, justpaste.me, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.divephotoguide.com, Disposable vapes
What's more, part of that ITCertMagic CDCS dumps now are free: https://drive.google.com/open?id=163LIuGl-eOTdr4YyWcDsSFqxDJTbIVHs
