[General] Pass Guaranteed 2026 CCM: Certified Case Manager Certification Exam (CCM) Latest
95
【General】 Pass Guaranteed 2026 CCM: Certified Case Manager Certification Exam (CCM) Latest
Posted at 2/1/2026 05:01:02      View:225 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamDumpsVCE CCM dumps for free: https://drive.google.com/open?id=1GK9x5IoNMzPXUSM-hxuVBfZO6mrk-WIT
The ExamDumpsVCE is a leading platform that has been helping the Certified Case Manager Certification Exam (CCM) (CCM) exam candidates in exam preparation and boosting their confidence to pass the final CCM exam. The ExamDumpsVCE is offering real, valid, and updated Certified Case Manager Certification Exam (CCM) (CCM) practice questions. These Certified Case Manager Certification Exam (CCM) (CCM) exam questions are verified by Medical Professional CCM exam trainers.
ExamDumpsVCE's braindumps provide you the gist of the entire syllabus in a specific set of questions and answers. These study questions are most likely to appear in the actual exam. The Certification exams are actually set randomly from the database of CCM. Thus most of the questions are repeated in CCM Exam and our experts after studying the previous exam have sorted out the most important questions and prepared dumps out of them. Hence ExamDumpsVCE's dumps are a special feast for all the exam takers and sure to bring them not only exam success but also maximum score.
CCM Instant Discount & New CCM Test CampMany clients worry that after they our CCM exam simulation they may fail in the test and waste their money and energy. There are no needs to worry about that situation because our study materials boost high passing rate and hit rate and the possibility to fail in the CCM test is very little. Just consider that our pass rate of the CCM study guide is high as 98% to 100%, which is unique in the market. And you will get the best pass percentage with our CCM learning questions.
Medical Professional Certified Case Manager Certification Exam (CCM) Sample Questions (Q22-Q27):NEW QUESTION # 22
Is the Employer obliged under FIDIC Silver Book (edition 1999) to describe which Documents are to be submitted to the Employer? (1 correct response applies)
  • A. Yes, the Employer should define which documents it wants to receive from the Contractor as Contractor's Documents in the Employer's Requirements, as stated in Sub-Clause 5.2.
  • B. No, because the Contractor has a duty to supply the Employer with every Document, given Sub-Clause
    7.4.
  • C. No, according to Sub-Clause 5.7 provisional operation and maintenance manuals are always required.
  • D. Yes, because otherwise the Contractor doesn't have to submit any Document until Completion of the Works as stated in Sub-Clause 1.8.
Under the FIDIC Silver Book 1999 (Conditions of Contract for EPC/Turnkey Projects), the Employer must specify clearly in the Employer's Requirements which Contractor's Documents are to be submitted. Sub- Clause 5.2 states that the Contractor must submit all documents listed in the Employer's Requirements, ensuring clarity and enabling the Employer to control the documentation process.
Option D is correct because it highlights the need for Employer's Requirements to define the scope and content of the Contractor's Documents.
Option A is incorrect; although operation and maintenance manuals are generally required, they are part of the specified Contractor's Documents, not automatically required without Employer's direction.
Option B is incorrect as the Contractor's duty to supply documents is limited to those specified.
Option C is incorrect because documentation obligations are ongoing and not just at completion.
FIDIC Silver Book 1999 Edition, Sub-Clause 5.2 - Contractor's Documents FIDIC Silver Book 1999 Edition, Sub-Clause 1.8 - Time for Completion FIDIC Contract Manager Study Guide, Module on Contract Administration Procedures
NEW QUESTION # 23
You are the Contract Manager for the Engineer in a hospital project using FIDIC Yellow Book (edition 2017).
The Employer demands perfection in the project's design and construction quality. There are many Variations initiated by the Employer during design and construction. Which one of the following is considered to be a valid Variation?
  • A. The Engineer instructs a change in slopes of the access road to the intensive care unit to meet the Employer's Requirement. The Engineer does so with a Notice in accordance with Sub-Clause 3.5.
  • B. The Employer verbally instructs a change in the type of doors. The Engineer issued a Notice describing the required change and denying any costs for the Contractor.
  • C. The Contractor submits a Value Engineering proposal regarding the lighting system for the operation rooms. The Engineer is positive about the proposal and tells the Contractor they need to look into it.
  • D. The Engineer requests a proposal regarding a change in type of windows and doors. The Contractor submitted the proposal accordingly to the Engineer. The Engineer instructs the Variation.
Option B is correct: A Variation is a formal change to the Works instructed by the Engineer via a Notice (Sub- Clause 3.5). This includes changes to design or execution such as slopes on a road.
Option A is a proposal, not yet a Variation. Positive interest does not constitute a Variation.
Option C is partially correct but depends on formal instruction after proposal acceptance; the question specifies the Engineer instructs the Variation, but since it was a request for proposal first, the Variation instruction comes later. Without explicit instruction, this is not yet a Variation.
Option D is invalid as verbal instruction plus a Notice denying cost claims does not constitute a proper Variation.
FIDIC Yellow Book 2017 Edition, Sub-Clause 3.5 - Variation Procedure
FIDIC Contract Manager Study Guide, Module on Variations and Change Management
NEW QUESTION # 24
Which of the following situations form legally binding contracts? (2 correct answers apply) Choose all of the correct answers (multiple possibilities)
  • A. The Employer received the Contractor's Letter of Tender and issued Letter of Acceptance.
  • B. The Employer received the Contractor's Letter of Tender and issued a conditional Letter of Acceptance.
  • C. The Employer received the Contractor's Letter of Tender and issued a Letter of Intent.
  • D. The Employer and the Contractor signed the Contract Agreement.
A legally binding contract is typically formed when there is an offer, acceptance, and intention to create legal relations. Under FIDIC contracts:
Option B (signing the Contract Agreement) unequivocally forms a binding contract.
Option D (Letter of Acceptance issued after receiving the Contractor's Letter of Tender) generally forms a binding contract unless otherwise specified, as the Letter of Acceptance is the formal acceptance of the tender.
Option A (Letter of Intent) is not necessarily a binding contract; it often serves as an interim arrangement signaling intent but may lack definitive terms to form a contract.
Option C (conditional Letter of Acceptance) may not form a binding contract unless the conditions are fulfilled.
FIDIC Red and Yellow Books 1999 and 2017 Editions - Contract Formation Clauses FIDIC Contract Manager Study Guide, Module on Contract Formation and Execution
NEW QUESTION # 25
Under the FIDIC Construction Contract, which one of the following statements is correct?
  • A. A DAB must give its decision in writing on any dispute when requested by one of the Parties.
  • B. For an ad-hoc DAB, a retainer fee for each DAB Member must be paid to the Member on the first day of each calendar month.
  • C. If all persons nominated to serve as members of an ad hoc DAB do not sign a DAB Agreement, an appointing entity can make appointments.
  • D. Payment to DAB Members must be certified by the Employer.
  • E. Payments of a DAB Member's retainer fee is the sole responsibility of the Contractor.
Under the FIDIC Conditions of Contract (particularly 2017 editions), the Dispute Adjudication Board (DAB) is a standing or ad hoc body that provides binding decisions on disputes. One key requirement is that the DAB must give its decisions in writing upon request by either Party, ensuring clarity and enforceability.
Option E is correct as the DAB's decision must be documented formally.
Option A is incorrect; the cost of the DAB is generally shared by Employer and Contractor as per the contract.
Option B is incorrect because retainer fees can be paid on different schedules, not necessarily monthly on the first day.
Option C is incorrect; payments to DAB members do not require Employer's certification but are agreed as part of the DAB contract.
Option D is partially true but not a standalone correct statement without additional context.
FIDIC Red, Yellow, Silver Books 2017 Edition, Clause 21 - Disputes and DAB Procedures FIDIC Contract Manager Study Guide, Module on Claims and Dispute Resolution
NEW QUESTION # 26
Which one answer holds two statements that are both correct with regards to risks and key considerations regarding the Golden Principles?
  • A. "The Contractor should take advantage of its bargaining power every time possible" AND "Disputes are avoided to the extent achievable, minimised when they do arise, and resolved efficiently."
  • B. "Only the Employer should be the one to obtain the best value for money" AND "The Contractor
    /Subcontractor is paid adequately and timely in accordance with the Contract to maintain its cash flow."
  • C. "The Employer obtains the best value for money" AND "Disputes should be avoided to the extent achievable."
  • D. "The Contractor/Subcontractor is paid adequately and in a timely manner in accordance with the Contract to maintain its cash flow" AND "The terms of the Contract are comprehensive and fair to primarily the Employer".
Option A correctly reflects Golden Principles emphasizing the Employer's objective of obtaining value for money and the importance of avoiding disputes as much as possible.
Other options either misrepresent the balanced nature of FIDIC principles or promote unfair or unbalanced positions.
FIDIC Contract Management Guidelines - Golden Principles
FIDIC Contract Manager Study Guide, Module on Legal and Ethical Considerations
NEW QUESTION # 27
With pass rate reaching 98%, our CCM learning materials have gained popularity among candidates, and they think highly of the exam dumps. In addition, CCM exam braindumps are edited by professional experts, and they have rich experiences in compiling the CCM exam dumps. Therefore, you can use them at ease. We offer you free update for one year for CCM Training Materials, and the update version will be sent to your email automatically. If you have any questions after purchasing CCM exam dumps, you can contact us by email, we will give you reply as quickly as possible.
CCM Instant Discount: https://www.examdumpsvce.com/CCM-valid-exam-dumps.html
“Transparency helps us vet the best ideas no matter where they come from and ExamDumpsVCE helps us scale that.” “Using ExamDumpsVCE is part of a larger investment in developer happiness and building product.” How’s your preparation for Medical Professional Exams CCM: Certified Case Manager Certification Exam (CCM) Certification Exam going on, Our company attaches great importance to overall services, if there is any problem about the delivery of CCM exam materials: Certified Case Manager Certification Exam (CCM), please let us know, a message or an email will be available, Medical Professional CCM Dumps Free Download There are three kinds of demos, namely, PDF Version Demo, PC Test Engine and Online Test Engine.
This quality Medical Professional CCM braindumps PDF polishes your skills and widens your horizons intellectually to ace challenges of a complex IT certification like Medical Professional Medical Professional Exams.
The Manufacturing Mindset, “Transparency helps us vet CCM the best ideas no matter where they come from and ExamDumpsVCE helps us scale that.” “Using ExamDumpsVCE is part of a larger investment in developer happiness and building product.” How’s your preparation for Medical Professional Exams CCM: Certified Case Manager Certification Exam (CCM) Certification Exam going on?
Newest Medical Professional Dumps Free Download – the Best Accurate CCM Instant DiscountOur company attaches great importance to overall services, if there is any problem about the delivery of CCM exam materials: Certified Case Manager Certification Exam (CCM), please let us know, a message or an email will be available.
There are three kinds of demos, namely, PDF Version Demo, PC Test Engine and Online Test Engine, In this way students become careless, But CCM exam is not so simple.
Posted at 2/9/2026 15:43:50        Only Author  2#
This is such a brilliant article, thank you for providing it. Valid C-BCSSS-2502 test syllabus contains comprehensive material, available at no cost to support your learning.
