The Best Accurate Reliable CPQ-Specialist Test Labs to Obtain Salesforce Certifi
Posted at 2/1/2026 06:47:13
View126
Replies0
BTW, DOWNLOAD part of ITPassLeader CPQ-Specialist dumps from Cloud Storage: https://drive.google.com/open?id=1vknqtCMlG2aOpc9PLn8yb-pBiSjstiwu
Practicing for an Salesforce Certified CPQ Specialist (CPQ-Specialist) exam is one of the best ways to ensure success. It helps students become familiar with the format of the actual CPQ-Specialist practice test. It also helps to identify areas where more focus and attention are needed. Furthermore, it can help reduce the anxiety and stress associated with taking an Salesforce Certified CPQ Specialist (CPQ-Specialist) exam as it allows students to gain confidence in their knowledge and skills.
Who should take the Salesforce Certified CPQ SpecialistTypical job roles of a Salesforce Certified CPQ Specialist candidate may include:
- Technical Architect
- Pricing Manager
- Implementation Consultant
- Sales Ops
- IT
Salesforce CPQ-Specialist exam is intended for professionals who have experience in the implementation of Salesforce CPQ solutions. CPQ-Specialist Exam is focused on testing the knowledge of candidates in the areas of product configuration, pricing, and quoting. Candidates are expected to have a deep understanding of the Salesforce CPQ platform and should be able to configure and customize the platform to meet the needs of their organization.
CPQ-Specialist Free Brain Dumps | CPQ-Specialist Practice GuideThe web-based Salesforce Certified CPQ Specialist (CPQ-Specialist) practice exam is accessible from any major OS. These Salesforce CPQ-Specialist exam questions are browser-based, so there's no need to install anything on your computer. Chrome, IE, Firefox, and Opera all support this Salesforce Certified CPQ Specialist (CPQ-Specialist) web-based practice exam. You can take this Salesforce Certified CPQ Specialist (CPQ-Specialist) practice exam without plugins and software installation.
Salesforce Certified CPQ Specialist Sample Questions (Q100-Q105):NEW QUESTION # 100
Universal Containers requires that all users add at least one Product Option from the Maintenance Feature to a bundle. Additionally, users must select at least one and no more than two Product Options from the Support Feature.
How should the Admin set up these requirements for the users?
- A. Set Min Options for Maintenance to one. Set Min Options to zero and Max Options to two for Support.
- B. Set Max Options for Maintenance to one. Set Min Options to one and Max Options to two for Support.
- C. Set Min Options and Max Options to zero for Maintenance. Set Min Options to zero and Max Options to two for Support.
- D. Set Min Options for Maintenance to one. Set Min Options to one and Max Options to two for Support.
NEW QUESTION # 101
An Admin has created a new bundle, and a separate, unrelated Product Rule. Universal Containers wants the t Rule to fire within this specific bundle.
What is a valid setup for the Configuration Rule?
- A. The Configuration Rule must be associated with the Product Feature used within the bundle.
- B. The Configuration Rule must be associated with Product records used in Product Actions.
- C. The Configuration Rule must be associated with the Product Option records used in Product Actions.
- D. The configuration Rule must be associates with the Parent Product in the bundle.
NEW QUESTION # 102
An Admin at Universal Containers has hidden the prices of Products on the Configure Products page.
How should the Admin make the prices visible again?
- A. Go to the Product Option object's Option Configuration Field Set and add the Unit Price field.
- B. Go to the Product Option record and check if the Default Pricing Table field is set to Standard.
- C. Go to the Product Option object's Unit Price field and add visibility to its Field-level security.
- D. Go to the Product Option record and check if the Price Editable field is False.
Issue:
* Prices are hidden on the Configure Products page due to restricted field visibility.
Solution:
* Adjust the Field-Level Security settings for the Unit Price field on the Product Option object to ensure visibility.
Why Other Options Are Incorrect:
* B: The Option Configuration Field Set affects configuration but does not control visibility.
* C & D: Default Pricing Table and Price Editable settings do not impact visibility on the Configure Products page.
Salesforce CPQ Reference:
* Managing field visibility is outlined in CPQ Field-Level Security documentation .
NEW QUESTION # 103
Universal Containers (UC) has a Product Family called Software. When a Configuration Attribute in the bundle is set to Perpetual, UC wants to Hide all Products with the Product Family called Software. The Admin has created a Product Rule with a Configuration Rule.
Which additional supporting records should the Admin configure so the Product Rule meets this requirement?
- A. An Error Condition should compare the Product Family value on the Product Option record. A Product Action should Show all Products with Product Family other that Software.
- B. An Error Condition should compare the Perpetual value against the Configuration Attribute. A Product Action using the Filter Field should Hide the Products.
- C. An Error Condition should check the Product Family value on the Product Option record. A Product Action using the Filter Field should Hide the Products.
- D. An Error Condition should compare the Perpetual value against the Configuration Attribute. A Product Action should Hide each Product.
NEW QUESTION # 104
Universal Container (UC) sells containers in three sizes. The admin has created a bundle product for he containers which product Option for different size lids. The Admins has also created a Configuration Attribute called Container Size with three different values. When a user selects a particular size container in the Configuration Attribute, only the lid for that size container should be available for selection. An Admin has created a lookup table to capture which Product Option are valid for each container size.
Which steps should the Admin take using a product Rule to ensure only the lids of the correct size sold with each container?
- A. Create a Product rule of type validation.
Create a Lookup Quart which compares the Configuration Attributes values to the lookup table and prevents the user from saving without selecting the valid option. - B. Create a Product Rule of type Alert.
Create a Lookup Query which compares the configuration Attribute values to the lookup table and wants the user from saving without selecting the valid option. - C. Create a product Rule of type Selection.
Create a Lookup Query which compares the Configuration Attribute values to the lookup table and select the valid option. - D. Create a Product Rule of type Selection.
NEW QUESTION # 105
About choosing the perfect CPQ-Specialist study material, it may be reflected in matters like quality, prices, after-sale services and so on. CPQ-Specialist exam simulation is accumulation of knowledge about the exam strictly based on the syllabus of the exam. They give users access to information and exam, offering simulative testing environment when you participate it like in the classroom. And if you are afraid of the lack experience of the exam, our CPQ-Specialist Practice Engine will be your good choice.
CPQ-Specialist Free Brain Dumps: https://www.itpassleader.com/Salesforce/CPQ-Specialist-dumps-pass-exam.html
- CPQ-Specialist Simulation Questions 🥡 CPQ-Specialist Official Study Guide 🐔 CPQ-Specialist Exam Certification 🍖 Copy URL ➽ [url]www.practicevce.com 🢪 open and search for ➽ CPQ-Specialist 🢪 to download for free 🥰New CPQ-Specialist Test Dumps[/url]
- Salesforce CPQ-Specialist PDF Questions [2026] To Gain Brilliant Result 🔛 Immediately open [ [url]www.pdfvce.com ] and search for ➠ CPQ-Specialist 🠰 to obtain a free download 😟CPQ-Specialist Reliable Braindumps Pdf[/url]
- Use Salesforce CPQ-Specialist Exam Questions [2026]-Forget About Failure ⭐ Search on ▛ [url]www.examdiscuss.com ▟ for ▛ CPQ-Specialist ▟ to obtain exam materials for free download 💏CPQ-Specialist Reliable Test Questions[/url]
- CPQ-Specialist Official Study Guide 🔯 CPQ-Specialist Reliable Braindumps Ppt 🚼 Exam CPQ-Specialist Learning 🌎 Search for ⮆ CPQ-Specialist ⮄ and download it for free on ▷ [url]www.pdfvce.com ◁ website 🔮Most CPQ-Specialist Reliable Questions[/url]
- Newest Reliable CPQ-Specialist Test Labs, Ensure to pass the CPQ-Specialist Exam 🏁 Copy URL [url]www.dumpsmaterials.com open and search for CPQ-Specialist to download for free 🚑CPQ-Specialist Reliable Test Questions[/url]
- CPQ-Specialist Latest Test Prep 🌔 CPQ-Specialist Reliable Test Questions 👋 Latest CPQ-Specialist Exam Camp 😬 ☀ [url]www.pdfvce.com ️☀️ is best website to obtain CPQ-Specialist for free download 🗓CPQ-Specialist Authorized Certification[/url]
- CPQ-Specialist Exam Certification 🟢 CPQ-Specialist Exam Certification 🚼 New CPQ-Specialist Test Dumps 💫 Search for ▛ CPQ-Specialist ▟ and download exam materials for free through [url]www.testkingpass.com 🆚CPQ-Specialist Exam Certification[/url]
- Free PDF Quiz Unparalleled Salesforce - Reliable CPQ-Specialist Test Labs ⛄ Open ▶ [url]www.pdfvce.com ◀ enter CPQ-Specialist and obtain a free download 🍣Valid CPQ-Specialist Exam Camp Pdf[/url]
- Salesforce CPQ-Specialist PDF Questions [2026] To Gain Brilliant Result 🕝 Download CPQ-Specialist for free by simply searching on [url]www.pdfdumps.com 💡Accurate CPQ-Specialist Prep Material[/url]
- Download The Reliable CPQ-Specialist Test Labs Means that You Have Passed Salesforce Certified CPQ Specialist 😗 Enter [url]www.pdfvce.com and search for ⮆ CPQ-Specialist ⮄ to download for free ⏳CPQ-Specialist Official Study Guide[/url]
- 2026 Reliable Reliable CPQ-Specialist Test Labs Help You Pass CPQ-Specialist Easily ⏬ Search for CPQ-Specialist and download exam materials for free through ▛ [url]www.dumpsquestion.com ▟ 🤍CPQ-Specialist Official Study Guide[/url]
