HPE7-A02 Flexible Learning Mode - Latest HPE7-A02 Dumps Book
Posted at 2/1/2026 08:59:18
View139
Replies1
BONUS!!! Download part of VerifiedDumps HPE7-A02 dumps for free: https://drive.google.com/open?id=1c_uWyiMZCEo6VWSUakq0XcaIcAWIX3u5
Practicing with the HP HPE7-A02 practice test, you can evaluate your HP HPE7-A02 exam preparation. It helps you to pass the HPE7-A02 test with excellent results. HPE7-A02 imitates the actual Aruba Certified Network Security Professional Exam exam environment. You can take the HP HPE7-A02 Practice Exam many times to evaluate and enhance your HP HPE7-A02 exam preparation level.
HP HPE7-A02 Exam is a certification exam designed for IT professionals who want to validate their knowledge and skills in network security using Aruba products. Aruba is a leading provider of network infrastructure solutions, and this certification exam is designed to validate the expertise of professionals in implementing and managing Aruba security solutions.
Latest HPE7-A02 Dumps Book & 100% HPE7-A02 Exam CoverageOur HPE7-A02 Study Guide is famous for its instant download, we will send you the downloading link to you once we receive your payment, and you can down right now. Besides the HPE7-A02 study guide is verified by the professionals, so we can ensure that the quality of it. We also have free update, you just need to receive the latest version in your email address. If you dont have it, you can check in your junk mail or you can contact us.
HP Aruba Certified Network Security Professional Exam Sample Questions (Q17-Q22):NEW QUESTION # 17
You want to examine the applications that a device is using and look for any changes in application usage over several different ranges. In which HPE Aruba Networking solution can you view this information in an easy-to-view format?
- A. HPE Aruba Networking ClearPass Insight using an Active Endpoint Security report
- B. HPE Aruba Networking ClearPass OnGuard agent installed on the device
- C. HPE Aruba Networking Central within a device's Live Monitoring page
- D. HPE Aruba Networking ClearPass Device Insight (CPDI) in the device's network activity
* HPE Aruba Central Live Monitoring:
* Aruba Central provides real-time Live Monitoring of network devices, including:
* Application usage statistics.
* Trends and changes over time for specific devices.
* This information is presented in a clear and easy-to-read format, making it ideal for examining changes in application usage over different time ranges.
* Option Analysis:
* Option A: Incorrect. ClearPass OnGuard monitors endpoint compliance (e.g., antivirus, OS version) but does not analyze application usage.
* Option B: Correct. Aruba Central's Live Monitoring page is specifically designed for this type of analysis.
* Option C: Incorrect. ClearPass Insight generates endpoint security reports but does not track application usage.
* Option D: Incorrect. ClearPass Device Insight (CPDI) focuses on device profiling and identification, not continuous application monitoring.
NEW QUESTION # 18
You have verified that AOS-CX Switch-1 has constructed an IP-to-MAC binding table in VLANs 10-19.
Now you need to enable ARP inspection for the endpoint connected to Switch-1. What must you do first to prevent traffic disruption?
- A. Configure DHCP snooping on VLANs 10-19 on Switch-2.
- B. Configure Switch-1 uplinks as trusted ARP inspection ports.
- C. Create a static IP-to-MAC binding on Switch-1 for the DHCP server.
- D. Configure ARP inspection on VLANs 10-19 on Switch-2.
Dynamic ARP Inspection (DAI):
* ARP inspection verifies ARP packets against a trusted IP-to-MAC binding table to prevent ARP spoofing attacks.
* DHCP snooping is required to construct the IP-to-MAC binding table dynamically.
* To avoid traffic disruption, uplink ports that connect to trusted switches, DHCP servers, or routers must be explicitly configured as trusted ports for ARP inspection.
Steps to Prevent Traffic Disruption:
* Trust the Uplinks: ARP inspection must treat uplink ports as trusted to allow ARP traffic from legitimate DHCP servers and upstream switches.
* Enable DHCP Snooping: DHCP snooping must be enabled on Switch-2 to ensure consistent IP-to- MAC bindings upstream.
Why the Answer is Correct:
* Option A: Incorrect. ARP inspection on Switch-2 is important but not required first to prevent disruption on Switch-1.
* Option B: Incorrect. DHCP snooping must be enabled upstream eventually, but this alone will not stop immediate traffic disruption on Switch-1.
* Option C: Correct. Switch-1 uplinks must be trusted ARP inspection ports first to allow legitimate upstream traffic and prevent ARP disruption.
* Option D: Incorrect. Static bindings are not required if DHCP snooping is enabled, and they are manual, limiting scalability.
Conclusion:
To avoid traffic disruption, configure Switch-1 uplinks as trusted ARP inspection ports to ensure valid ARP traffic can pass upstream and downstream.
NEW QUESTION # 19
You are setting up HPE Aruba Networking SSE to prohibit users from uploading and downloading files from Dropbox. What is part of the process?
- A. Adding a web category that includes Dropbox
- B. Deploying a connector that can reach Dropbox
- C. Installing the HPE Aruba Networking SSE root certificate on clients
- D. Deploying a connector that can reach the remote users
Comprehensive Detailed Explanation
To prohibit users from uploading and downloading files from Dropbox using HPE Aruba Networking SSE (Secure Service Edge), you need to configure web access policies. This typically involves:
* Adding a web category to the SSE configuration that includes Dropbox.
* The SSE solution uses category-based filtering to block access to specific applications or services, such as Dropbox, based on their classification.
Other Options:
* B. Installing the SSE root certificate is required for enabling SSL inspection, but this does not directly control access to Dropbox.
* C and D. Deploying a connector is not necessary for this purpose as the enforcement is done via SSE policies, not by directly interfacing with Dropbox or remote users.
References
* Aruba Networking SSE documentation on web filtering policies.
* HPE Aruba SSE Application Control Best Practices Guide.
NEW QUESTION # 20
You have configured an AOS-CX switch to implement 802.1X on edge ports. Assume ports operate in the default auth-mode. VoIP phones are assigned to the "voice" role and need to send traffic that is tagged for VLAN 12. Where should you configure VLAN 12?
- A. As the trunk native VLAN on edge ports and the trunk native VLAN on the "voice" role.
- B. As the trunk native VLAN in the "voice" role (and not in the edge port settings).
- C. As the allowed trunk VLAN in the "voice" role (and not in the edge port settings).
- D. As a trunk allowed VLAN on edge ports and the trunk native VLAN in the "voice" role.
* Voice Role VLAN Configuration:
* When VoIP phones are authenticated and assigned to the "voice" role, VLAN 12 should be explicitly defined as an allowed trunk VLAN within the role configuration.
* The VLAN configuration should be role-specific rather than on the edge port, as this ensures dynamic VLAN assignment based on authentication results.
* Option Analysis:
* Option A: Incorrect. Native VLANs are for untagged traffic, but VoIP traffic is tagged.
* Option B: Correct. VLAN 12 must be configured as the allowed trunk VLAN in the "voice" role to tag VoIP traffic correctly.
* Option C: Incorrect. Configuring VLAN 12 in both edge port and role settings is redundant and unnecessary.
* Option D: Incorrect. Native VLANs do not handle tagged traffic like VLAN 12 for VoIP phones.
NEW QUESTION # 21
You have downloaded a packet capture that you generated on HPE Aruba Networking Central. When you open the capture in Wireshark, you see the output shown in the exhibit.
What should you do in Wireshark so that you can better interpret the packets?
- A. Apply the following display filter: wlan.fc.type == 1.
- B. Edit the Enabled Protocols and make sure that 802.11, GRE, and Aruba_ERM are enabled.
- C. Choose to decode UDP port 5555 packets as ARUBA_ERM and set the Aruba ERM Type to 0.
- D. Edit preferences for IEEE 802.11 and chose to ignore the Protection bit with IV.
To better interpret the packets shown in the Wireshark capture, you should choose to decode UDP port 5555 packets as ARUBA_ERM and set the Aruba ERM Type to 0. This configuration will allow Wireshark to properly decode and display the Aruba-specific encapsulated remote mirroring (ERM) packets, providing a clearer understanding of the traffic.
1.Decoding Protocols: Selecting the correct protocol decoding in Wireshark ensures that the captured packets are interpreted correctly, displaying the relevant information.
2.Aruba ERM: The packets in the capture are likely encapsulated remote mirroring (ERM) packets specific to Aruba, which require proper decoding settings in Wireshark.
3.Clear Interpretation: By setting the Aruba ERM Type to 0 and decoding the packets as ARUBA_ERM, you can view the encapsulated data accurately.
NEW QUESTION # 22
Will you feel nervous in the exam? If you do, just choose us, our HPE7-A02 Soft test engine can stimulate the real exam environment, which will help you know the procedure of the exam, and will strengthen your confidence. Moreover HPE7-A02 exam dumps are high-quality, and we have professional experts to compile them, and they can help you pass the exam just one time. We offer you free demo to have a try for HPE7-A02 Exam Dumps, and free update for one year. If you indeed have questions, just contact with us.
Latest HPE7-A02 Dumps Book: https://www.verifieddumps.com/HPE7-A02-valid-exam-braindumps.html
- Complete HP HPE7-A02: Aruba Certified Network Security Professional Exam Flexible Learning Mode - Well-Prepared [url]www.troytecdumps.com Latest HPE7-A02 Dumps Book 🎐 Easily obtain free download of ☀ HPE7-A02 ️☀️ by searching on www.troytecdumps.com 🌏HPE7-A02 Examcollection Dumps Torrent[/url]
- HPE7-A02 Valid Exam Objectives 🕴 Reliable Test HPE7-A02 Test 😗 HPE7-A02 Study Materials ↪ Search for HPE7-A02 on ➥ [url]www.pdfvce.com 🡄 immediately to obtain a free download 🥗HPE7-A02 Reliable Dumps Book[/url]
- HPE7-A02 Reliable Test Testking 💺 Reliable HPE7-A02 Exam Simulations 🚢 Reliable HPE7-A02 Exam Simulations 🏈 The page for free download of ✔ HPE7-A02 ️✔️ on ▛ [url]www.prepawayexam.com ▟ will open immediately 🏳Latest HPE7-A02 Test Pass4sure[/url]
- Reliable HPE7-A02 Exam Simulations 📜 Latest HPE7-A02 Test Pass4sure ❤️ Vce HPE7-A02 Test Simulator ⬅️ Search for ✔ HPE7-A02 ️✔️ and easily obtain a free download on ➽ [url]www.pdfvce.com 🢪 🏐HPE7-A02 Latest Exam Papers[/url]
- Reliable HPE7-A02 Learning Materials 😎 HPE7-A02 Valid Exam Objectives 🔹 HPE7-A02 Reliable Dumps Book 🐩 Easily obtain free download of ✔ HPE7-A02 ️✔️ by searching on ▷ [url]www.testkingpass.com ◁ 🏀Vce HPE7-A02 Test Simulator[/url]
- HPE7-A02 Reliable Exam Labs 💹 Latest HPE7-A02 Test Pass4sure 😆 New Soft HPE7-A02 Simulations 👸 Download ➤ HPE7-A02 ⮘ for free by simply entering [url]www.pdfvce.com website 🔅HPE7-A02 Reliable Test Testking[/url]
- Free PDF Quiz HP - Unparalleled HPE7-A02 - Aruba Certified Network Security Professional Exam Flexible Learning Mode 🔺 Download HPE7-A02 for free by simply entering [url]www.troytecdumps.com website 👐HPE7-A02 Visual Cert Test[/url]
- Pass Guaranteed HPE7-A02 - Aruba Certified Network Security Professional Exam CReliable Flexible Learning Mode ⬛ Search for HPE7-A02 and easily obtain a free download on ⮆ [url]www.pdfvce.com ⮄ 🕛HPE7-A02 Reliable Exam Labs[/url]
- Reliable HPE7-A02 Exam Questions 🍫 HPE7-A02 Reliable Test Testking ✊ HPE7-A02 Valid Exam Materials 🥿 Search for ▶ HPE7-A02 ◀ and easily obtain a free download on ▛ [url]www.troytecdumps.com ▟ 💓Reliable HPE7-A02 Learning Materials[/url]
- Quiz 2026 HP Authoritative HPE7-A02: Aruba Certified Network Security Professional Exam Flexible Learning Mode ➕ Search for ⇛ HPE7-A02 ⇚ on ➠ [url]www.pdfvce.com 🠰 immediately to obtain a free download 🍩New Soft HPE7-A02 Simulations[/url]
- Reliable HPE7-A02 Exam Questions 🤗 Reliable HPE7-A02 Learning Materials 🧾 HPE7-A02 Valid Exam Objectives 🍷 Go to website ⇛ [url]www.practicevce.com ⇚ open and search for ⇛ HPE7-A02 ⇚ to download for free 🌺HPE7-A02 Latest Test Braindumps[/url]
- k12.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that VerifiedDumps HPE7-A02 dumps now are free: https://drive.google.com/open?id=1c_uWyiMZCEo6VWSUakq0XcaIcAWIX3u5
