[General] Reliable JN0-336 Test Simulator, Real JN0-336 Exams
96
General Reliable JN0-336 Test Simulator, Real JN0-336 Exams
Posted at 2/1/2026 09:07:51      View104 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PracticeTorrent JN0-336 dumps from Cloud Storage: https://drive.google.com/open?id=1rVPOpTASz-84d5x4BS3hgqkxubVAeU0o
Practicing with the Juniper JN0-336 practice test, you can evaluate your Juniper JN0-336 exam preparation. It helps you to pass the JN0-336 test with excellent results. JN0-336 imitates the actual Security, Specialist (JNCIS-SEC) exam environment. You can take the Juniper JN0-336 Practice Exam many times to evaluate and enhance your Juniper JN0-336 exam preparation level.
Different person has different goals, but our PracticeTorrent aims to help you successfully pass JN0-336 exam. Maybe to pass JN0-336 exam is the first step for you to have a better career in IT industry, but for our PracticeTorrent, it is the entire meaning for us to develop JN0-336 exam software. So we try our best to extend our dumps, and our PracticeTorrent elite comprehensively analyze the dumps so that you are easy to use it. Besides, we provide one-year free update service to guarantee that the JN0-336 Exam Materials you are using are the latest.
Reliable JN0-336 Test Simulator | Reliable Juniper Real JN0-336 Exams: Security, Specialist (JNCIS-SEC)Our JN0-336 practice exam is specially designed for those people who have not any time to attend the class and prepare Juniper exam tests with less energy. You will understand each point of questions and answers with the help of our JN0-336 Exam Review. And our exam pass guide will cover the points and difficulties of the JN0-336 real exam, getting certification are just a piece of cake.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q83-Q88):NEW QUESTION # 83
While working on an SRX firewall, you execute the show security policies policy-name <name> detail command.
Which function does this command accomplish?
  • A. It identifies the different custom policies enabled.
  • B. It shows policy counters for a configured policy.
  • C. It shows the system log files for the local SRX Series device.
  • D. It displays details about the default security policy.
The function that the show security policies policy-name <name> detail command accomplishes is showing policy counters for a configured policy. Policy counters are statistics that indicate how many times a policy has been matched by traffic and what actions have been taken by the policy. Policy counters can help you monitor and troubleshoot the performance and effectiveness of your security policies. The show security policies policy-name <name> detail command displays detailed information about a specific policy, such as its source zone, destination zone, description, state, hit count, byte count, packet count, action count, and session count.
Reference: = show security policies, show security policies information, [SRX] How to troubleshoot a security policy that is not passing data
NEW QUESTION # 84
Which two statements are correct about chassis clustering? (Choose two.)
  • A. The node ID value ranges from 1 to 255.
  • B. The cluster ID is used to identify each device in the chassis cluster.
  • C. The node ID is used to identify each device in the chassis cluster.
  • D. A system reboot is required to activate changes to the cluster.
In chassis clustering, the node ID is indeed used to uniquely identify each device within the cluster. This allows for individual addressing and management of devices within the cluster configuration, which is crucial for operations and maintenance.
Typically, activating changes that involve chassis clustering configuration, such as setting or changing the node ID or forming a new cluster, requires a reboot of the devices. This ensures that all configuration changes are properly applied and that the devices can synchronize their states as part of the cluster.
NEW QUESTION # 85
You are implementing an SRX Series device at a branch office that has low bandwidth and also uses a cloud-based VoIP solution with an outbound policy that permits all traffic.
Which service would you implement at your edge device to prioritize VoIP traffic in this scenario?
  • A. SIP ALG
  • B. AppFW
  • C. AppQoE
  • D. AppQoS
The service that you would implement at your edge device to prioritize VoIP traffic in this scenario is AppQoS. AppQoS is a feature that enables you to allocate bandwidth and prioritize traffic based on application signatures or custom rules. AppQoS can enhance the quality of service and experience for critical or latency-sensitive applications, such as VoIP. You can configure AppQoS policies to assign different classes of service (CoS) values or queue numbers to different applications or traffic flows. You can also define bandwidth limits, guarantees, or bursts for each class or queue. Reference: =
[Application Quality of Service Overview], [Configuring Application Quality of Service]
NEW QUESTION # 86
Which three statements about SRX Series device chassis clusters are true? (Choose three.)
  • A. Chassis cluster member devices synchronize configuration using the control link.
  • B. Recovery from a control link failure requires that the secondary member device be rebooted.
  • C. Chassis cluster control links must be configured using RFC 1918 IP addresses.
  • D. A control link failure causes the secondary cluster node to be disabled.
  • E. Heartbeat messages verify that the chassis cluster control link is working.
Answer: A,D,E
B: Chassis cluster member devices synchronize configuration using the control link: This statement is correct because the control link is used for configuration synchronization among other functions.
C: A control link failure causes the secondary cluster node to be disabled: This statement is correct because a control link failure causes the secondary node to become ineligible for primary role and remain in secondary role until the control link is restored.
E: Heartbeat messages verify that the chassis cluster control link is working: This statement is correct because heartbeat messages are sent periodically over the control link to monitor its status.
NEW QUESTION # 87
You enable chassis clustering on two devices and assign a cluster ID and a node ID to each device.
In this scenario, what is the correct order for rebooting the devices?
  • A. Reboot only the primary device since the secondary will assign itself the correct cluster and node ID.
  • B. Reboot the secondary device, then the primary device.
  • C. Reboot only the secondary device since the primary will assign itself the correct cluster and node ID.
  • D. Reboot the primary device, then the secondary device.
When chassis clustering is enabled and IDs are assigned, it is typically recommended to first reboot the secondary device. This allows the secondary device to fully integrate and recognize its role and settings within the cluster without affecting the ongoing traffic that the primary device might be handling.
Once the secondary device has successfully rebooted and is operational within the cluster, the primary device can then be rebooted. This ensures that the primary device's reboot does not cause any network downtime, as the secondary device, now fully operational, can take over the traffic and roles as needed.
NEW QUESTION # 88
With our outstanding JN0-336 exam questions, we can assure you a 99% percent pass rate. Due to continuous efforts of our experts, we have exactly targeted the content of the JN0-336 exam. You will pass the exam after 20 to 30 hours' learning with our JN0-336 Study Material. Many users have witnessed the effectiveness of our JN0-336 guide exam you surely will become one of them. Try it right now!
Real JN0-336 Exams: https://www.practicetorrent.com/JN0-336-practice-exam-torrent.html
Juniper Reliable JN0-336 Test Simulator It can maximize the efficiency of your work, Our JN0-336 study guide will help you regain confidence, Juniper Reliable JN0-336 Test Simulator In an increasingly competitive social life, we should keep up with the unpredictable world, regain our knowledge, and pursue decent work and a higher standard of living, Choosing good Juniper JN0-336 exam materials, we will be your only option.
The design and implementation of Active Directory on your JN0-336 network plays a critical role in determining how domains should be created and nested within each other.
Adding Comments to JavaScript, It can maximize the efficiency of your work, Our JN0-336 Study Guide will help you regain confidence, In an increasingly competitive social life, we should keep up with the Exam JN0-336 Guide unpredictable world, regain our knowledge, and pursue decent work and a higher standard of living.
JN0-336 Prep Guide is Closely Related with the Real JN0-336 Exam - PracticeTorrentChoosing good Juniper JN0-336 exam materials, we will be your only option, The PracticeTorrent is committed to ace the JN0-336 exam preparation and success journey successfully in a short time period.
What's more, part of that PracticeTorrent JN0-336 dumps now are free: https://drive.google.com/open?id=1rVPOpTASz-84d5x4BS3hgqkxubVAeU0o
