Free PDF Quiz 2026 Oracle Marvelous 1z1-809 Test Cram
Posted at 2/1/2026 12:13:05
If you are boring about daily life and want to improve yourself, getting a practical Oracle certification will be a nice choice that will improve your promotion advantages. 1z1-809 exam study guide will be valid helper which will help you clear exams 100% for sure. Thousands of candidates successfully pass exams and get certifications you desire under the help of our 2Pass4sure's 1z1-809 Dumps PDF files.
Oracle 1z0-809 (Java SE 8 Programmer II) Certification Exam covers a wide range of topics, including advanced Java concepts, concurrency, JDBC, I/O, NIO.2, and Localization. 1z1-809 exam also focuses on the use of Java collections, Lambda expressions, and functional interfaces. Java SE 8 Programmer II certification exam consists of 85 multiple-choice questions that must be completed within 150 minutes. To pass the exam, candidates must achieve a score of at least 65%. Java SE 8 Programmer II certification is valuable for Java professionals who are looking to advance their career and showcase their expertise in developing advanced Java applications.
To pass the Oracle 1z0-809 exam, candidates need to have a solid understanding of Java SE 8 programming language features, as well as the ability to write robust and efficient code. 1z1-809 Exam is ideal for developers who are looking to enhance their Java programming skills and advance their careers in the field of software development. Java SE 8 Programmer II certification is recognized globally and can help candidates stand out in the job market, as well as gain credibility and respect in the industry.
Oracle 1z1-809 exam consists of multiple-choice questions that are designed to test candidates' knowledge and understanding of Java programming language. 1z1-809 exam is computer-based and is available in multiple languages. Candidates will have 150 minutes to complete the exam and must score at least 65% to pass.
Free PDF 2026 Updated Oracle 1z1-809 Test CramThe Java SE 8 Programmer II (1z1-809) exam questions are the real, valid, and updated 1z1-809 Exam Questions that are specifically designed for quick and complete 1z1-809 exam preparation. With 2Pass4sure Java SE 8 Programmer II (1z1-809) practice test questions you can start Oracle 1z1-809 exam preparation immediately.
Oracle Java SE 8 Programmer II Sample Questions (Q60-Q65):NEW QUESTION # 60
Given the code fragments:
public class Book implements Comparator<Book> {
String name;
double price;
public Book () {}
public Book(String name, double price) {
this.name = name;
this.price = price;
public int compare(Book b1, Book b2) {
return b1.name.compareTo(b2.name);
public String toString() {
return name + ":" + price;
and
List<Book>books = Arrays.asList (new Book ("Beginning with Java", 2), new book ("A Guide to Java Tour", 3)); Collections.sort(books, new Book()); System.out.print(books); What is the result?
[A Guide to Java Tour:3.0, Beginning with Java:2.0]
- A. A compilation error occurs because the Book class does not override the abstract method compareTo().
- B. An Exceptionis thrown at run time.
- C. [Beginning with Java:2, A Guide to Java Tour:3]
- D.
NEW QUESTION # 61
Given the code fragment:
List<String> empDetails = Arrays.asList("100, Robin, HR", "200, Mary, AdminServices","101, Peter, HR"); empDetails.stream()
.filter(s-> s.contains("r"))
.sorted()
.forEach(System.out::println); //line n1
What is the result?
- A. E. A compilation error occurs at line n1.
- B. 100, Robin, HR101, Peter, HR
- C. 100, Robin, HR200, Mary, AdminServices101, Peter, HR
- D. 101, Peter, HR200, Mary, AdminServices
NEW QUESTION # 62
Given:
public enum USCurrency {
PENNY (1),
NICKLE(5),
DIME (10),
QUARTER(25);
private int value;
public USCurrency(int value) {
this.value = value;
public int getValue() {return value;}
public class Coin {
public static void main (String[] args) {
USCurrency usCoin =new USCurrency.DIME;
System.out.println(usCoin.getValue()):
Which two modifications enable the given code to compile? (Choose two.)
- A. Remove the new keyword from the instantion of usCoin.
- B. Make the getter method of value as a static method.
- C. Add the final keyword in the declaration of value.
- D. Make the USCurrency enumeration constructor private.
- E. Nest the USCurrency enumeration declaration within the Coin class.
NEW QUESTION # 63
Given:
and the code fragment:
What is the result?
- A. A compilation error occurs at line n1.
- B. 0
- C. A compilation error occurs because the try block is declared without a catch or finally block.
- D. An exception is thrown at line n2.
NEW QUESTION # 64
What is the result?
- A. Compilation fails at both line n1 and line n2.
- B. Compilation fails only at line n2.
- C. Compilation fails only at line n1.
- D. Jesse 25
Walter 52
NEW QUESTION # 65
Oracle 1z1-809 practice exam support team cooperates with users to tie up any issues with the correct equipment. If Java SE 8 Programmer II material changes, CertsFire also issues updates free of charge for three months following the purchase of our Oracle 1z1-809 Exam Questions.
New 1z1-809 Test Bootcamp: https://www.2pass4sure.com/Java-SE/1z1-809-actual-exam-braindumps.html
- Reliable 1z1-809 Exam Questions ♥ Free 1z1-809 Exam Questions 🧥 Practice 1z1-809 Exams Free 🦕 The page for free download of ➥ 1z1-809 🡄 on ▷ [url]www.prep4away.com ◁ will open immediately 🦈Exam 1z1-809 Details[/url]
- Reliable 1z1-809 Test Voucher 💝 Reliable 1z1-809 Exam Vce 🗻 Review 1z1-809 Guide 🕷 Open website ▷ [url]www.pdfvce.com ◁ and search for ➥ 1z1-809 🡄 for free download 🚏Latest 1z1-809 Braindumps Free[/url]
- Oracle Test Cram 1z1-809 - Realistic Java SE 8 Programmer II Test Cram Pass Guaranteed 🕖 ▶ [url]www.prepawaypdf.com ◀ is best website to obtain ➤ 1z1-809 ⮘ for free download 🔱Reliable 1z1-809 Exam Vce[/url]
- 1z1-809 Test Cram|Legal for Java SE 8 Programmer II 🟢 Search for ➥ 1z1-809 🡄 and obtain a free download on ( [url]www.pdfvce.com ) 🍕1z1-809 Reliable Test Vce[/url]
- Reliable 1z1-809 Exam Vce 🍁 1z1-809 Exam Duration 🦌 Reliable 1z1-809 Exam Vce 🏑 Open website 【 [url]www.examcollectionpass.com 】 and search for [ 1z1-809 ] for free download ⛹Test 1z1-809 Assessment[/url]
- Reliable 1z1-809 Test Voucher 🦐 1z1-809 Real Exam Answers ⚖ 1z1-809 Intereactive Testing Engine 🥨 Open ⮆ [url]www.pdfvce.com ⮄ enter 《 1z1-809 》 and obtain a free download 🧑
ractice 1z1-809 Exams Free[/url] - Exam 1z1-809 Voucher 🦨 Exam 1z1-809 Voucher 🧓 Latest 1z1-809 Braindumps Free 🧷 Open website ▶ [url]www.prepawayexam.com ◀ and search for ⮆ 1z1-809 ⮄ for free download 🧘1z1-809 Exam Duration[/url]
- Get Efficient 1z1-809 Test Cram and Pass Exam in First Attempt 🎄 Search for ( 1z1-809 ) and download exam materials for free through ▛ [url]www.pdfvce.com ▟ 😶1z1-809 Reliable Test Vce[/url]
- Pass Guaranteed 2026 - 1z1-809 - Java SE 8 Programmer II Test Cram ➰ Search for 《 1z1-809 》 on ⏩ [url]www.testkingpass.com ⏪ immediately to obtain a free download 🚺Reliable 1z1-809 Exam Questions[/url]
- 1z1-809 Exam Duration 🧐 Reliable 1z1-809 Exam Vce 🤳 Reliable 1z1-809 Test Notes 🍌 Open website ➤ [url]www.pdfvce.com ⮘ and search for 【 1z1-809 】 for free download ⚛New 1z1-809 Braindumps[/url]
- Oracle Test Cram 1z1-809 - Realistic Java SE 8 Programmer II Test Cram Pass Guaranteed 🛸 The page for free download of ▷ 1z1-809 ◁ on ➠ [url]www.prep4sures.top 🠰 will open immediately ↕1z1-809 Intereactive Testing Engine[/url]
