[General] DP-700 Exam Sample | Pass4sure DP-700 Dumps Pdf
108
【General】 DP-700 Exam Sample | Pass4sure DP-700 Dumps Pdf
Posted at 2/1/2026 13:19:54      View:140 | Replies:3        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Actual4Dumps DP-700 dumps for free: https://drive.google.com/open?id=1cAQAfGLT8WoaA37VMwWa-jR6mrkMtHLt
Actual4Dumps's products can not only help customers 100% pass their first time to attend Microsoft Certification DP-700 Exam, but also provide a one-year of free online update service for them, which will delivery the latest exam materials to customers at the first time to let them know the latest certification exam information. So Actual4Dumps is a very good website which not only provide good quality products, but also a good after-sales service.
Microsoft DP-700 Exam Syllabus Topics:
  • Monitor and optimize an analytics solution: This section of the exam measures the skills of Data Analysts in monitoring various components of analytics solutions in Microsoft Fabric. It focuses on tracking data ingestion, transformation processes, and semantic model refreshes while configuring alerts for error resolution. One skill to be measured is identifying performance bottlenecks in analytics workflows.
  • Implement and manage an analytics solution: This section of the exam measures the skills of Microsoft Data Analysts regarding configuring various workspace settings in Microsoft Fabric. It focuses on setting up Microsoft Fabric workspaces, including Spark and domain workspace configurations, as well as implementing lifecycle management and version control. One skill to be measured is creating deployment pipelines for analytics solutions.
  • Ingest and transform data: This section of the exam measures the skills of Data Engineers that cover designing and implementing data loading patterns. It emphasizes preparing data for loading into dimensional models, handling batch and streaming data ingestion, and transforming data using various methods. A skill to be measured is applying appropriate transformation techniques to ensure data quality.
Newest DP-700 Exam Sample | Amazing Pass Rate For DP-700: Implementing Data Engineering Solutions Using Microsoft Fabric | Perfect Pass4sure DP-700 Dumps PdfDo you worry about not having a long-term fixed study time? Do you worry about not having a reasonable plan for yourself? DP-700 exam dumps will solve this problem for you. Based on your situation, including the available time, your current level of knowledge, our study materials will develop appropriate plans and learning materials. You can use DP-700 test questions when you are available, to ensure the efficiency of each use, this will have a very good effect. You don't have to worry about yourself or anything else. Our study materials allow you to learn at any time. Regardless of your identity, what are the important things to do in DP-700 Exam Prep, when do you want to learn when to learn?
Microsoft Implementing Data Engineering Solutions Using Microsoft Fabric Sample Questions (Q97-Q102):NEW QUESTION # 97
You have two Fabric notebooks named Load_Salesperson and Load_Orders that read data from Parquet files in a lakehouse. Load_Salesperson writes to a Delta table named dim_salesperson. Load.Orders writes to a Delta table named fact_orders and is dependent on the successful execution of Load_Salesperson.
You need to implement a pattern to dynamically execute Load_Salesperson and Load_Orders in the appropriate order by using a notebook.
How should you complete the code? To answer, drag the appropriate values the correct targets. Each value may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Topic 2, Contoso, LtdCase Study
This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
To start the case study
To display the first question in this case study, click the Next button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirements, existing environment, and problem statements. If the case study has an All Information tab, note that the information displayed is identical to the information displayed on the subsequent tabs. When you are ready to answer a question, click the Question button to return to the question.
Overview. Company Overview
Contoso, Ltd. is an online retail company that wants to modernize its analytics platform by moving to Fabric.
The company plans to begin using Fabric for marketing analytics.
Overview. IT Structure
The company's IT department has a team of data analysts and a team of data engineers that use analytics systems.
The data engineers perform the ingestion, transformation, and loading of data. They prefer to use Python or SQL to transform the data.
The data analysts query data and create semantic models and reports. They are qualified to write queries in Power Query and T-SQL.
Existing Environment. Fabric
Contoso has an F64 capacity named Cap1. All Fabric users are allowed to create items.
Contoso has two workspaces named WorkspaceA and WorkspaceB that currently use Pro license mode.
Existing Environment. Source Systems
Contoso has a point of sale (POS) system named POS1 that uses an instance of SQL Server on Azure Virtual Machines in the same Microsoft Entra tenant as Fabric. The host virtual machine is on a private virtual network that has public access blocked. POS1 contains all the sales transactions that were processed on the company's website.
The company has a software as a service (SaaS) online marketing app named MAR1. MAR1 has seven entities. The entities contain data that relates to email open rates and interaction rates, as well as website interactions. The data can be exported from MAR1 by calling REST APIs. Each entity has a different endpoint.
Contoso has been using MAR1 for one year. Data from prior years is stored in Parquet files in an Amazon Simple Storage Service (Amazon S3) bucket. There are 12 files that range in size from 300 MB to 900 MB and relate to email interactions.
Existing Environment. Product Data
POS1 contains a product list and related data. The data comes from the following three tables:
Products
ProductCategories
ProductSubcategories
In the data, products are related to product subcategories, and subcategories are related to product categories.
Existing Environment. Azure
Contoso has a Microsoft Entra tenant that has the following mail-enabled security groups:
DataAnalysts: Contains the data analysts
DataEngineers: Contains the data engineers
Contoso has an Azure subscription.
The company has an existing Azure DevOps organization and creates a new project for repositories that relate to Fabric.
Existing Environment. User Problems
The VP of marketing at Contoso requires analysis on the effectiveness of different types of email content. It typically takes a week to manually compile and analyze the data. Contoso wants to reduce the time to less than one day by using Fabric.
The data engineering team has successfully exported data from MAR1. The team experiences transient connectivity errors, which causes the data exports to fail.
Requirements. Planned Changes
Contoso plans to create the following two lakehouses:
Lakehouse1: Will store both raw and cleansed data from the sources
Lakehouse2: Will serve data in a dimensional model to users for analytical queries Additional items will be added to facilitate data ingestion and transformation.
Contoso plans to use Azure Repos for source control in Fabric.
Requirements. Technical Requirements
The new lakehouses must follow a medallion architecture by using the following three layers: bronze, silver, and gold. There will be extensive data cleansing required to populate the MAR1 data in the silver layer, including deduplication, the handling of missing values, and the standardizing of capitalization.
Each layer must be fully populated before moving on to the next layer. If any step in populating the lakehouses fails, an email must be sent to the data engineers.
Data imports must run simultaneously, when possible.
The use of email data from the Amazon S3 bucket must meet the following requirements:
Minimize egress costs associated with cross-cloud data access.
Prevent saving a copy of the raw data in the lakehouses.
Items that relate to data ingestion must meet the following requirements:
The items must be source controlled alongside other workspace items.
Ingested data must land in the bronze layer of Lakehouse1 in the Delta format.
No changes other than changes to the file formats must be implemented before the data lands in the bronze layer.
Development effort must be minimized and a built-in connection must be used to import the source data.
In the event of a connectivity error, the ingestion processes must attempt the connection again.
Lakehouses, data pipelines, and notebooks must be stored in WorkspaceA. Semantic models, reports, and dataflows must be stored in WorkspaceB.
Once a week, old files that are no longer referenced by a Delta table log must be removed.
Requirements. Data Transformation
In the POS1 product data, ProductID values are unique. The product dimension in the gold layer must include only active products from product list. Active products are identified by an IsActive value of 1.
Some product categories and subcategories are NOT assigned to any product. They are NOT analytically relevant and must be omitted from the product dimension in the gold layer.
Requirements. Data Security
Security in Fabric must meet the following requirements:
The data engineers must have read and write access to all the lakehouses, including the underlying files.
The data analysts must only have read access to the Delta tables in the gold layer.
The data analysts must NOT have access to the data in the bronze and silver layers.
The data engineers must be able to commit changes to source control in WorkspaceA.
NEW QUESTION # 98
You are building a data loading pattern by using a Fabric data pipeline. The source is an Azure SQL database that contains 25 tables. The destination is a lakehouse.
In a warehouse, you create a control table named Control.Object as shown in the exhibit. (Click the Exhibit tab.) You need to build a data pipeline that will support the dynamic ingestion of the tables listed in the control table by using a single execution.
NEW QUESTION # 99
HOTSPOT
You have a Fabric workspace that contains an eventstream named EventStream1.
You discover that an EventStream1 transformation fails.
You need to find the following error information:
The error details, including the occurrence time
The total number of errors
What should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 100
You have a Fabric workspace that contains a lakehouse named Lakehousel. Lakehousel contains a table named Status_Target that has the following columns:
* Key
* Status
* LastModified
The data source contains a table named Status.Source that has the same columns as Status_Target. Status.Source is used to populate Status_Target. In a notebook name Notebook!, you load Status_Source to a DataFrame named sourceDF and Status_Target to a DataFrame named targetDF. You need to implement an incremental loading pattern by using Notebook-!. The solution must meet the following requirements:
* For all the matching records that have the same value of key, update the value of LastModified in Status_Target to the value of LastModified in Status_Source.
* Insert all the records that exist in Status_Source that do NOT exist in Status_Target.
* Set the value of Status in Status_Target to inactive for all the records that were last modified more than seven days ago and that do NOT exist in Status.Source.
How should you complete the statement? To answer, select the appropriate options in the answer area.
NEW QUESTION # 101
You are processing streaming data from an external data provider.
You have the following code segment.
Overview
Contoso, Ltd. is an online retail company that wants to modernize its analytics platform by moving to Fabric. The company plans to begin using Fabric for marketing analytics.
NEW QUESTION # 102
Our DP-700 exam quiz is so popular not only for the high quality, but also for the high efficiency services provided which owns to the efforts of all our staffs. First of all, if you are not sure about the DP-700 exam, the online service will find the most accurate and all-sided information for you, so that you can know what is going on about all about the exam and make your decision to buy DP-700 Study Guide or not.
Pass4sure DP-700 Dumps Pdf: https://www.actual4dumps.com/DP-700-study-material.html
BTW, DOWNLOAD part of Actual4Dumps DP-700 dumps from Cloud Storage: https://drive.google.com/open?id=1cAQAfGLT8WoaA37VMwWa-jR6mrkMtHLt
Posted at 2/8/2026 03:57:36        Only Author  2#
Thank you for sharing your article, it’s been truly enlightening. I used the Reliable C-THR81-2505 braindumps book to get a promotion and raise. Now it’s free to all. Best wishes for your professional growth!
Posted at 2/15/2026 08:29:32        Only Author  3#
This article is truly magnificent, thank you so much for sharing. Free Valid C-P2W12-2311 test camp materials exam questions—best of luck to all exam candidates!
Posted at 2/23/2026 07:17:35        Only Author  4#
Your article was truly remarkable, I’m so grateful for it. This Latest C1 exam cram sheet file helped me get promoted and enjoy a salary raise. Now it’s available to you for free. Hope you all advance soon!
