[General] Free PDF Salesforce Analytics-Admn-201 First-grade Salesforce Certified Tableau
99
General Free PDF Salesforce Analytics-Admn-201 First-grade Salesforce Certified Tableau
Posted at 2/1/2026 17:25:48      View108 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest PassTorrent Analytics-Admn-201 PDF Dumps and Analytics-Admn-201 Exam Engine Free Share: https://drive.google.com/open?id=1hDfJBBxBLPkRerj_KqcreFMgEaTIutHX
Our Analytics-Admn-201 preparation exam is compiled specially for it with all contents like exam questions and answers from the real Analytics-Admn-201 exam. If you make up your mind of our Analytics-Admn-201 exam prep, we will serve many benefits like failing the first time attached with full refund service, protecting your interests against any kinds of loss. In a word, you have nothing to worry about with our Analytics-Admn-201 Study Guide.
What do you think of Salesforce Analytics-Admn-201 Certification Exam? As one of the most popular Salesforce certification exams, Analytics-Admn-201 test is also very important. When you are looking for reference materials in order to better prepare for the exam, you will find it is very hard to get the excellent exam dumps. What should we do? It doesn't matter. PassTorrent is well aware of your aspirations and provide you with the best certification training dumps to satisfy your demands.
Salesforce Analytics-Admn-201 Reliable Test Online - Analytics-Admn-201 Valid DumpsChoosing our Analytics-Admn-201 learning guide is not only an enrichment of learning content, but also an opportunity to improve our own discovery space. Our Analytics-Admn-201 study dumps could bring huge impact to your personal development, because in the process of we are looking for a job, hold a certificate you have more advantage than your competitors, the company will be a greater probability of you. After using our Analytics-Admn-201 Study Dumps, users can devote more time and energy to focus on their major and makes themselves more and more prominent in the professional field. Therefore, our Analytics-Admn-201 exam materials can help you achieve multiple returns in the future, provide you with more opportunities to pursue higher life goals, and create a higher quality of life.
Salesforce Certified Tableau Server Administrator Sample Questions (Q22-Q27):NEW QUESTION # 22
What is the minimum required free hard disk space recommended for a Tableau Server installation in production?
  • A. 15 GB
  • B. 50 GB
  • C. 32 GB
  • D. 64 GB
Tableau Server has specific hardware requirements for production environments to ensure stability and performance. The minimum recommended free disk space for a production installation is 50 GB. This accounts for:
* The installation itself (approximately 1-2 GB).
* Space for log files, temporary files, and extracts managed by the File Store and Data Engine.
* Room for backups and operational overhead.
The full minimum hardware recommendations for a single-node production deployment are:
* 8 CPU cores (2.0 GHz or faster).
* 32 GB RAM.
* 50 GB free disk space (on the system drive, typically C: on Windows).
* Option A (32 GB): Incorrect. While 32 GB is the minimum RAM requirement, it's insufficient for disk space in production.
* Option B (50 GB): Correct. This matches Tableau's official recommendation for production environments.
* Option C (15 GB): Incorrect. 15 GB is the minimum for a non-production or trial installation, not production.
* Option D (64 GB): Incorrect. While 64 GB exceeds the minimum, it's not the specified requirement-
50 GB is sufficient.
Reference: Tableau Server Documentation - "Minimum Hardware Recommendations" (https://help.tableau.
com/current/server/en-us/requirements.htm).
NEW QUESTION # 23
You use Tableau Desktop 10.5 and plan to publish a visualization to a Tableau Server that runs version
2020.1. You are assigned the Creator site role, and Publisher permissions for a project. What statement correctly describes what happens when you attempt to publish the visualization?
  • A. You will successfully publish the visualization without any errors or warnings
  • B. You will see a warning message instructing you that embedded .tde extracts will be upgraded to .hyper
  • C. You will see a warning message instructing you that the workbook will be upgraded to a new version
  • D. You will see an error message instructing you that you are unable to publish the workbook to a newer version of Tableau Server
Tableau Desktop and Tableau Server have versioning considerations when publishing content, particularly regarding compatibility between older Desktop versions (e.g., 10.5) and newer Server versions (e.g., 2020.1).
Let's break this down step-by-step:
* Version Context: Tableau Desktop 10.5 was released in 2017 and used the .tde (Tableau Data Extract) format for extracts. Tableau Server 2020.1, released in 2020, introduced the .hyper extract format (starting with version 10.5, but fully standardized later). When publishing from an older Desktop version to a newer Server version, Tableau ensures backward compatibility but may upgrade certain components.
* Publishing Process: With a Creator site role and Publisher permissions, you have the rights to publish workbooks to the specified project. Tableau Server accepts workbooks from older Desktop versions (e.
g., 10.5) and upgrades them to the current Server version (2020.1) during publishing. This process is seamless for the workbook itself, but extracts require special handling.
* Extract Handling: If the workbook contains embedded .tde extracts (stored within the .twb or .twbx file), Tableau Server 2020.1 converts these to .hyper format upon publishing. This conversion is necessary because .hyper replaced .tde as the default extract engine starting in Tableau 10.5 and beyond, offering better performance and scalability. During this process, Tableau Desktop or Server displays a warning to inform the user of the upgrade, as it's a one-way conversion (you can't revert to .
tde on the Server).
Now, let's evaluate the options:
* Option A (You will successfully publish without any errors or warnings): Incorrect. While the publishing succeeds, a warning about the .tde to .hyper conversion appears if the workbook contains embedded extracts. Without extracts, no warning occurs, but the question's context implies extracts are likely involved (common in visualizations).
* Option B (Error message: unable to publish to a newer version): Incorrect. Tableau supports publishing from older Desktop versions to newer Server versions. There's no outright error blocking this; compatibility is maintained.
* Option C (Warning: embedded .tde extracts will be upgraded to .hyper): Correct. This is the precise warning displayed when a workbook with .tde extracts is published to a Server version that uses
.hyper. It ensures the user is aware of the format change, which might affect extract refresh schedules or performance expectations.
* Option D (Warning: workbook will be upgraded to a new version): Partially correct but less specific. The workbook is upgraded to 2020.1 compatibility, but the warning focuses on the extract format change (.tde to .hyper), not the workbook version generically. Option C is more accurate.
Why This Matters: The .tde to .hyper shift improves query performance and supports larger datasets, but users need to know about it for planning (e.g., extract refresh schedules might need adjustment). The warning ensures transparency.
Reference: Tableau Server Documentation - "Publish a Workbook" (https://help.tableau.com/current/server
/en-us/publish_workbook.htm) and "Hyper Extract FAQ" (https://help.tableau.com/current/server/en-us
/hyper_faq.htm).
NEW QUESTION # 24
You are the server administrator of a single-node Tableau Server installation. The server hosts five schedules that each execute once a day: Weekday 3:00 PM Extract Refresh, Weekday 5:00 PM Subscription, Weekday
2:00 AM Extract Refresh, Weekday 7:00 AM Extract Refresh, and Weekday 8:00 AM Subscription. The schedules are scheduled to execute during periods when Tableau Server is least active. The busiest period for your server is immediately after the workday begins at 9:00 AM. The office of the CEO reports that every morning at 9:00 AM, they access the views in a particular workbook. The data for these views is refreshed by a task associated with the 7:00 AM schedule. The CEO reports that the data in the views is only being refreshed about 70% of the time. What should you do to attempt to resolve the CEO's problem?
  • A. Set the priority of this task to 100
  • B. Set the default priority of this schedule to 50
  • C. Set the priority for all other tasks to 50
  • D. Set the priority of this task to 1
In Tableau Server, schedules manage tasks like extract refreshes and subscriptions. Each task within a schedule has a priority value (ranging from 1 to 100, where 1 is the highest priority and 100 is the lowest).
Tasks with higher priority (lower numbers) are executed before tasks with lower priority (higher numbers) when queued by the Backgrounder process. If the Backgrounder is overloaded or delayed, lower-priority tasks may not complete on time, leading to inconsistent refreshes.
In this scenario:
The 7:00 AM Extract Refresh task is critical for the CEO's workbook, but the data is only refreshed 70% of the time by 9:00 AM.
The server has a single node, meaning a single Backgrounder process handles all tasks. With five schedules (some overlapping in the early morning), contention or delays could prevent the 7:00 AM task from completing reliably before 9:00 AM.
Option C (Set the priority of this task to 1): Correct. Setting the task priority to 1 ensures it has the highest priority among all queued tasks. This increases the likelihood that the Backgrounder executes it promptly at 7:
00 AM, completing the refresh before the CEO accesses the workbook at 9:00 AM. You can adjust task priority in the Tableau Server web interface under Schedules > Tasks > Edit Priority.
Option A (Set the default priority of this schedule to 50): Incorrect. The default priority for schedules is already 50, and this option refers to the schedule's default, not the specific task. It wouldn't address the contention issue.
Option B (Set the priority for all other tasks to 50): Incorrect. This keeps all tasks at the default priority (50), leaving the 7:00 AM task without a relative advantage. It doesn't prioritize the CEO's task.
Option D (Set the priority of this task to 100): Incorrect. Priority 100 is the lowest, which would deprioritize the task, making the refresh even less reliable.
Reference: Tableau Server Documentation - "Manage Schedules and Tasks" (https://help.tableau.com/current
/server/en-us/schedule_manage.htm).
NEW QUESTION # 25
You activate the same Tableau Server product key on three installations for Dev, Test, and Production. You plan to move the Test environment to new hardware. What is the recommended workflow for managing the product key?
  • A. Deactivate the product key on the existing Test environment, and then install and activate Tableau Server on the new hardware
  • B. Install and activate Tableau Server on the new hardware and keep the existing Test environment as a backup
  • C. Install and activate Tableau Server on the new hardware, and then deactivate it on the old hardware
  • D. Install and activate Tableau Server on the new hardware, and then run the following script in the old environment: tableau-server-obliterate.cmd -y -y -y
Tableau Server's licensing ties product keys to specific machines. Moving an environment requires managing activations to stay compliant. Let's break this down:
* Licensing Rules:
* A product key can be activated on multiple machines (e.g., Dev, Test, Prod), but only up to the licensed limit (typically 3 for such setups).
* Deactivation frees the key for reuse elsewhere.
* Recommended Workflow:
* Deactivate first: Use tsm licenses deactivate on the old Test machine to release the key.
* Then activate: Install on the new hardware and activate with tsm licenses activate -k <key>.
* Why: Ensures compliance and avoids activation conflicts (e.g., exceeding the key's limit).
* Option B (Deactivate on Test, then install/activate on new hardware): Correct.
* Steps:
* On old Test: tsm licenses deactivate.
* Install Tableau Server on new hardware.
* On new Test: tsm licenses activate -k <key>.
* Benefit: Clean, compliant transfer-preserves license integrity.
* Option A (Activate new, then deactivate old): Incorrect.
* Risk: If the key's limit is reached (e.g., 3 activations), the new activation fails until deactivation occurs. Order matters.
* Option C (Activate new, keep old as backup): Incorrect.
* Issue: Exceeds license limit (4 activations) and risks non-compliance. Backup requires deactivation or a separate key.
* Option D (Activate new, obliterate old): Incorrect.
* Details: tableau-server-obliterate.cmd wipes the entire install (data, config)-overkill and doesn't formally deactivate the key via TSM, potentially leaving licensing inconsistent.
Why This Matters: Proper license management prevents activation errors and ensures legal use across environments.
Reference: Tableau Server Documentation - "Manage Product Keys" (https://help.tableau.com/current/server
/en-us/license_manage.htm).
NEW QUESTION # 26
Which two types of content can you include in comments on a visualization? (Choose two.)
  • A. Interactive snapshots of a view
  • B. @mentions
  • C. Text
  • D. Images (jpg, png)
Comments on Tableau Server visualizations facilitate collaboration. Let's explore what's supported:
* Comments Feature: Enabled per site (Settings > General > Allow Comments). Users with "Add Comment" permission can post on views.
* Option B (Text): Correct.
* Details: The primary content type-users type free-form text in the comment box.
* Use: Notes, questions, or feedback (e.g., "Sales spiked here-why?").
* Option C (@mentions): Correct.
* Details: Typing @username notifies the mentioned user via email or the UI (if notifications are enabled).
* Use: Directs comments to specific people (e.g., "@John, check this trend").
* Option A (Interactive snapshots of a view): Incorrect.
* Details: Snapshots (static images) aren't supported in comments-users must take screenshots externally and can't embed them interactively.
* Option D (Images - jpg, png): Incorrect.
* Details: No attachment or image embedding in comments-text and mentions only. Workaround:
Link to an image hosted elsewhere.
Why This Matters: Comments enhance teamwork, but their simplicity (text + mentions) keeps the interface lightweight and focused.
Reference: Tableau Server Documentation - "Comment on a View" (https://help.tableau.com/current/server
/en-us/comment.htm).
NEW QUESTION # 27
The client can try out and download our Analytics-Admn-201 training materials freely before their purchase so as to have an understanding of our Analytics-Admn-201 exam questions and then decide whether to buy them or not. The website pages of our product provide the details of our Analytics-Admn-201 learning questions. You can see the demos of our Analytics-Admn-201 Study Guide, which are part of the all titles selected from the test bank and the forms of the questions and answers and know the form of our software on the website pages of our Analytics-Admn-201 study materials.
Analytics-Admn-201 Reliable Test Online: https://www.passtorrent.com/Analytics-Admn-201-latest-torrent.html
Salesforce Analytics-Admn-201 Key Concepts Students can also get decent jobs after getting necessary certification in IT, Salesforce Analytics-Admn-201 Key Concepts Just login your account and download the product, And to cater to our customers' different study interests and hobbies, we have multiple choices on the Analytics-Admn-201 exam materials versions for you to choose: the PDF, the Software and the APP online, Learn for your Salesforce certification with confidence by utilizing the PassTorrent Analytics-Admn-201 study guide, which is always forward-thinking, convenient, current, and dependable.
Sidebar Items Cant Be Renamed, DDoS Mitigation Overview, Students Analytics-Admn-201 can also get decent jobs after getting necessary certification in IT, Just login your account and download the product.
And to cater to our customers' different study interests and hobbies, we have multiple choices on the Analytics-Admn-201 exam materials versions for you to choose: the PDF, the Software and the APP online.
100% Pass 2026 Salesforce Unparalleled Analytics-Admn-201: Salesforce Certified Tableau Server Administrator Key ConceptsLearn for your Salesforce certification with confidence by utilizing the PassTorrent Analytics-Admn-201 study guide, which is always forward-thinking, convenient, current, and dependable.
The staff and employees are hospitable to offer help 24/7.
BONUS!!! Download part of PassTorrent Analytics-Admn-201 dumps for free: https://drive.google.com/open?id=1hDfJBBxBLPkRerj_KqcreFMgEaTIutHX
