AZ-400 Exam Reviews - Reliable Exam AZ-400 Pass4sure
Posted at 2/1/2026 17:46:48
P.S. Free & New AZ-400 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=10c2v9Lhr6hCUa0vVLIQJPThsPXRmAMlD
Passing the Designing and Implementing Microsoft DevOps Solutions exam at first attempt is a goal that many candidates strive for. However, some of them think that good Microsoft AZ-400 study material is not important, but this is not true. The right AZ-400 preparation material is crucial for success in the exam. And applicants who don’t find updated AZ-400 prep material ultimately fail in the real examination and waste money. That's why PrepAwayPDF offers actual AZ-400 exam questions to help candidates pass the exam and save their resources.
There are three different versions of our AZ-400 exam questions to meet customers' needs you can choose the version that is suitable for you to study. If you buy our AZ-400 test torrent, you will have the opportunity to make good use of your scattered time to learn. If you choose our AZ-400 study torrent, you can make the most of your free time. So using our AZ-400 Exam Prep will help customers make good use of their fragmentation time to study and improve their efficiency of learning. It will be easier for you to pass your AZ-400 exam and get your certification in a short time.
Well-known AZ-400 Practice Engine Sends You the Best Training Dumps - PrepAwayPDFIf you want the AZ-400 certification to change your life and make it better, what are you waiting for? You should act quickly and make use of spare time of study or work to obtain a AZ-400 certification and master one more skill. With the help of our AZ-400 Exam Materials, you will find all of these desires are not dreams anymore. With the high pass rate as 98% to 100%, our AZ-400 learning questions can help you get your certification with ease.
Microsoft Designing and Implementing Microsoft DevOps Solutions Sample Questions (Q397-Q402):NEW QUESTION # 397
You need to create a virtual machine template in an Azure DevTest Labs environment named az400-9940427- dtl1. The template must be based on Windows Server 2016 Datacenter. Virtual machines created from the template must include the selenium tool and the Google Chrome browser.
To complete this task, sign in to the Microsoft Azure portal.
See solution below.
1. Open Microsoft Azure Portal
2. Select All Services, and then select DevTest Labs in the DEVOPS section.
3. From the list of labs, select the az400-9940427-dtl1 lab
4. On the home page for your lab, select + Add on the toolbar.
5. Select the Windows Server 2016 Datacenter base image for the VM.
6. Select automation options at the bottom of the page above the Submit button.
7. You see the Azure Resource Manager template for creating the virtual machine.
8. The JSON segment in the resources section has the definition for the image type you selected earlier.
https://docs.microsoft.com/bs-cy ... t-lab-vm-powershell
NEW QUESTION # 398
You need to configure Azure Automation for the computer in Group7.
1 - Create a Desired State Configuration (DSC) configuration file that has an extension of .ps1.
2 - Run the Import-AzureRmAutomationDscConfiguration Azure Powershell cmdlet
3 - Run the Start-AzureRmAutomationDscCompilationJob Azure Powershell cmdlet Reference:
https://docs.microsoft.com/en-us ... iondscconfiguration
https://docs.microsoft.com/en-us ... ondsccompilationjob
Topic 1, Contoso
Existing Environment
Contoso, Ltd. is a manufacturing company that has a main office in Chicago.
Requirements
Contoso plans to improve its IT development and operations processes implementing Azue DevOps principles. Contoso has an Azure subscription and creates an Azure DevelPs organization.
The Azure DevOps organization includes:
The Docker extension
A deployment pool named Pool7 that contains 10 Azure virtual machines that run Windows Server 2016.
The Azure subscription contains an Azure Automation account.
Planned Changes
Contoso plans to create projects in Azure DevOps as shown in the following table.
Technical Requirements
Contoso identities the following technical requirements:
* Implement build agents rot Project 1.
* Whenever possible, use Azure resources
* Avoid using deprecated technologies
* Implement a code flow strategy for Project2 that will:
* Enable Team 2 to submit pull requests for Project2.
* Enable Team 2 to work independently on changes to a copy of Project?
* Ensure that any intermediary changes performed by Tram2 on a copy of Project2 will be subject to the same restrictions as the ones defied in the build policy of Project2.
* Whenever possible. Implement automation and minimize administrative effort.
* Implement Protect3, Project5, Project6, and Project7 based on the planned changes.
* Implement Project4 and configure the project to push Docker images to Azure Container Reentry.
NEW QUESTION # 399
Where should the build and release agents for the investment planning application suite run? To answer, select the appropriate options in the answer area.
Box 1: A source control system
A source control system, also called a version control system, allows developers to collaborate on code and track changes. Source control is an essential tool for multi-developer projects.
Box 2: A hosted service
To build and deploy Xcode apps or Xamarin.iOS projects, you'll need at least one macOS agent. If your pipelines are in Azure Pipelines and a Microsoft-hosted agent meets your needs, you can skip setting up a self-hosted macOS agent.
Scenario: The investment planning applications suite will include one multi-tier web application and two iOS mobile applications. One mobile application will be used by employees; the other will be used by customers.
https://docs.microsoft.com/en-us ... x?view=azure-devops
NEW QUESTION # 400
You have an application named App1 that has a custom domain of app.contoso.com. You create a test in Azure Application Insights as shown in the following exhibit.
NEW QUESTION # 401
You manage the Git repository for a large enterprise application.
You need to minimize the data size of the repository.
How should you complete the commands? To answer, select theappropriate options in the answer area.
Box 1:--aggressive
Cleanup unnecessary files and optimize the local repository:
get gc --aggressive
Box 2: prune
Prune all unreachable objects from the object database:
git prune
https://gist.github.com/Zoramite/2039636
NEW QUESTION # 402
The successful selection, development and AZ-400 training of personnel are critical to our company's ability to provide a high standard of service to our customers and to respond their needs. That's the reason why we can produce the best AZ-400 exam prep and can get so much praise in the international market. And we always believe first-class quality comes with the first-class service. Yowill find we are proffessional on the answering the questions on our AZ-400 Study Materials.
Reliable Exam AZ-400 Pass4sure: https://www.prepawaypdf.com/Microsoft/AZ-400-practice-exam-dumps.html
Secondly, we can provide the fastest delivery speed for our customers, you can get our AZ-400 test-king files within 5 to 10 minutes after paying, If you want to have a try, we have free demos of our AZ-400 exam questions to help you know about our products, As a working person, the Microsoft AZ-400 practice exam will be a great help because you are left with little time to prepare for the Microsoft AZ-400 certification exam which you cannot waste to make time for the Microsoft AZ-400 exam questions, If you need IT exam training materials, if you do not choose PrepAwayPDF's Microsoft AZ-400 exam training materials, you will regret forever.
It presents itself as an animated rotating circle of AZ-400 sorts while the operation is happening, Configure Server Core, including roles and remote administration, Secondly, we can provide the fastest delivery speed for our customers, you can get our AZ-400 test-king files within 5 to 10 minutes after paying.
Starting Your Microsoft AZ-400 Exam Preparation? Get the Right Direction HereIf you want to have a try, we have free demos of our AZ-400 exam questions to help you know about our products, As a working person, the Microsoft AZ-400 practice exam will be a great help because you are left with little time to prepare for the Microsoft AZ-400 certification exam which you cannot waste to make time for the Microsoft AZ-400 exam questions.
If you need IT exam training materials, if you do not choose PrepAwayPDF's Microsoft AZ-400 exam training materials, you will regret forever, It means you can use the Designing and Implementing Microsoft DevOps Solutions (AZ-400) PDF version of PrepAwayPDF anywhere at any time on the smart device you have.
- Reliable AZ-400 Real Test 🏧 AZ-400 Dump Torrent 🥶 Test AZ-400 Practice 🚦 Easily obtain ✔ AZ-400 ️✔️ for free download through ➡ [url]www.testkingpass.com ️⬅️ 🚬Valid AZ-400 Test Vce[/url]
- AZ-400 practice materials - AZ-400 real test - AZ-400 test prep 🧾 Immediately open “ [url]www.pdfvce.com ” and search for ➽ AZ-400 🢪 to obtain a free download ☘AZ-400 Real Exam Answers[/url]
- Take Your Exam Preparation to the Next Level with AZ-400 Web-Based Practice Test 🐩 Open ▷ [url]www.examcollectionpass.com ◁ and search for ▷ AZ-400 ◁ to download exam materials for free 🥜Test AZ-400 Preparation[/url]
- AZ-400 Dump Torrent 🌼 AZ-400 Online Test 🦜 Reliable AZ-400 Real Test 🚼 Search for ➠ AZ-400 🠰 and obtain a free download on 「 [url]www.pdfvce.com 」 🌄Latest AZ-400 Training[/url]
- Quiz Microsoft - AZ-400 - Valid Designing and Implementing Microsoft DevOps Solutions Exam Reviews 🌟 Enter ( [url]www.vce4dumps.com ) and search for ➤ AZ-400 ⮘ to download for free 🍢Exam Sample AZ-400 Questions[/url]
- Latest AZ-400 Exam Question 📰 AZ-400 Exam Papers 📍 AZ-400 Reliable Test Answers 👫 Download ⮆ AZ-400 ⮄ for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🤪Latest AZ-400 Exam Answers[/url]
- Test AZ-400 Preparation 🟢 Authorized AZ-400 Pdf ↪ Test AZ-400 Preparation 💔 Download ▷ AZ-400 ◁ for free by simply entering 【 [url]www.vce4dumps.com 】 website 😏AZ-400 Online Test[/url]
- Latest AZ-400 Training 🧫 AZ-400 VCE Exam Simulator 🚉 Valid AZ-400 Test Vce 🏞 Easily obtain 「 AZ-400 」 for free download through ▛ [url]www.pdfvce.com ▟ 🕢AZ-400 Online Test[/url]
- Microsoft AZ-400 Exam Questions | Reduce Your Fear in Final Exam ✴ Search for 【 AZ-400 】 on 《 [url]www.pdfdumps.com 》 immediately to obtain a free download 🪂Test AZ-400 Preparation[/url]
- Actual Microsoft AZ-400 Exam Dumps - Pass Exam With Good Scores 🚁 Immediately open ➥ [url]www.pdfvce.com 🡄 and search for ➡ AZ-400 ️⬅️ to obtain a free download 📁Latest AZ-400 Exam Question[/url]
- Popular AZ-400 Exams ⬅️ Test AZ-400 Preparation 🎭 Reliable AZ-400 Real Test 🛵 ▛ [url]www.troytecdumps.com ▟ is best website to obtain ⮆ AZ-400 ⮄ for free download 🎻AZ-400 Dump Torrent[/url]
- bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dl.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, jaxedyhe.obsidianportal.com, Disposable vapes
What's more, part of that PrepAwayPDF AZ-400 dumps now are free: https://drive.google.com/open?id=10c2v9Lhr6hCUa0vVLIQJPThsPXRmAMlD
