[General] Online DVA-C02 Tests | Latest DVA-C02 Test Pdf
80
General Online DVA-C02 Tests | Latest DVA-C02 Test Pdf
Posted at 2/1/2026 19:01:20      View100 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsReview DVA-C02 PDF Dumps and DVA-C02 Exam Engine Free Share: https://drive.google.com/open?id=19hMMSR2eIoSdCHrhBQszqeOvzyrEYl5m
We offer a full refund guarantee, which means DumpsReview is obliged to return 100% of your money in case of failure after using our Amazon DVA-C02 dumps. Buy Amazon DVA-C02 updated exam questions today and start your journey towards success in the AWS Certified Developer - Associate (DVA-C02) test. Our dedicated customer support team is available 24/7 to help you ease your confusion.
Amazon DVA-C02 Exam is a comprehensive and challenging certification that can help developers advance their careers by demonstrating their expertise in AWS technologies. Candidates who pass the exam will be able to showcase their skills to potential employers and clients, and will have access to a range of job opportunities in the fast-growing cloud computing industry.
Amazon DVA-C02 Exam is Easy with Our Trustable Online DVA-C02 Tests: AWS Certified Developer - Associate EffectivelyImprove your professional ability with our DVA-C02 certification. Getting qualified by the Amazon certification will position you for better job opportunities and higher salary. Now, lets start your preparation with DVA-C02 training material. The DVA-C02 practice pdf offered by DumpsReview latest pdf is the latest and valid study material which suitable for all of you. The DVA-C02 free demo is especially for you to free download for try before you buy. You can get a lot from the DVA-C02 simulate exam dumps and get your DVA-C02 certification easily.
Amazon AWS Certified Developer - Associate Sample Questions (Q303-Q308):NEW QUESTION # 303
A developer wants to expand an application to run in multiple AWS Regions. The developer wants to copy Amazon Machine Images (AMIs) with the latest changes and create a new application stack in the destination Region. According to company requirements, all AMIs must be encrypted in all Regions. However, not all the AMIs that the company uses are encrypted.
How can the developer expand the application to run in the destination Region while meeting the encryption requirement?
  • A. Copy the unencrypted AMIs to the destination Region. Enable encryption by default in the destination Region.
  • B. Create new AMIs, and specify encryption parameters. Copy the encrypted AMIs to the destination Region. Delete the unencrypted AMIs.
  • C. Use AWS Key Management Service (AWS KMS) to enable encryption on the unencrypted AMIs. Copy the encrypted AMIs to the destination Region.
  • D. Use AWS Certificate Manager (ACM) to enable encryption on the unencrypted AMIs. Copy the encrypted AMIs to the destination Region.
NEW QUESTION # 304
A developer is writing an application that will run on Amazon EC2 instances in an Auto Scaling group. The developer wants to externalize the session state to support the application.
Which AWS services or resources can the developer use to meet these requirements? (Choose two.)
  • A. Application Load Balancer
  • B. Amazon ElastiCache
  • C. Amazon Cognito
  • D. Amazon DynamoDB
  • E. Amazon Simple Queue Service (Amazon SQS)
NEW QUESTION # 305
A developer deployed an application to an Amazon EC2 instance The application needs to know the public IPv4 address of the instance How can the application find this information?
  • A. Query the instance user data from http '169 254.169 254. latest/user-data/
  • B. Query
    the Amazon Machine Image (AMI) information from http://169.254.169.254/latest/meta-data/ami/.
  • C. Check the hosts file of the operating system
  • D. Query the instance metadata from http./M69.254.169.254. latestmeta-data/.
The
instance metadata service provides information about the EC2 instance, including the public IPv4 address, which can be obtained by querying the endpoint http://169.254.169.254/latest/meta-data/public-ipv4.
References
* Instance metadata and user data
* Get Public IP Address on current EC2 Instance
* Get the public ip address of your EC2 instance quickly
NEW QUESTION # 306
A company runs its website on AWS. The company posts daily polls on its website and publishes the poll results next day. The website stores user responses in an Amazon DynamoDB table.
After the poll results are published, the company does not need to keep the user responses.
A developer needs to implement a solution that will automatically remove old user responses from the DynamoDB table. The developer adds a new expiration_date attribute to the DynamoDB table. The developer plans to use the expiration_date attribute for the automation.
Which solution will meet these requirements with the LEAST development effort?
  • A. Create an AWS Glue job to delete old user responses based on the expiration_date attribute.
    Create an AWS Glue trigger schedule to run the job daily.
  • B. Enable TTL on the DynamoDB table and specify the expiration_date attribute. Expire old user responses by using DynamoDB TTL.
  • C. Create an AWS Fargate task in Amazon Elastic Container Service (Amazon ECS) to delete old user responses based on the expiration_date attribute. Create an Amazon EventBridge schedule to run the Fargate task daily.
  • D. Create an AWS Lambda function to delete old user responses based on the expiration_date attribute. Create an Amazon EventBridge schedule to run the Lambda function daily.
NEW QUESTION # 307
A developer is setting up AWS CodePipeline for a new application. During each build, the developer must generate a test report.
Which solution will meet this requirement?
  • A. Create an AWS CodeDeploy deployment that runs tests. Configure the AppSpec file with the test report information.
  • B. Create an AWS CodeBuild build project that runs tests. Configure the buildspec file with the test report information.
  • C. Create a repository in AWS CodeArtifact. Select the test report template.
  • D. Run the builds on an Amazon EC2 instance that has AWS Systems Manager Agent (SSM Agent) installed and activated.
NEW QUESTION # 308
Our DVA-C02 study materials just need you to memorize all keypoints of the knowledge of the real exam. It is unnecessary to review all irrelevant knowledges. At present, our DVA-C02 exam questions have helped thousands of people pass the exam and obtain the certificate. Also, the passing rate of our DVA-C02 Training Materials is the highest according to our investigation. None of the other exam braindumps in the market has the pass rate high as 98% to 100% as our DVA-C02 learning quiz.
Latest DVA-C02 Test Pdf: https://www.dumpsreview.com/DVA-C02-exam-dumps-review.html
DOWNLOAD the newest DumpsReview DVA-C02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=19hMMSR2eIoSdCHrhBQszqeOvzyrEYl5m
