[General] Amazon SCS-C02 Brain Dumps & New SCS-C02 Test Preparation
78
General Amazon SCS-C02 Brain Dumps & New SCS-C02 Test Preparation
Posted at 2/1/2026 19:34:39      View134 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of TestkingPDF SCS-C02 dumps for free: https://drive.google.com/open?id=12ui_1vFEgwytA8OtrYNma2hqwDi4nbgD
The TestkingPDF is one of the top-rated and trusted platforms that are committed to making the Amazon SCS-C02 exam preparation simple, easy, and quick. To achieve this objective the TestkingPDF is offering valid, updated, and easy-to-use Amazon SCS-C02 Exam Practice test questions in three different formats. These three formats are Amazon SCS-C02 exam practice test questions PDF dumps, desktop practice test software, and web-based practice test software.
They work closely and check all Amazon SCS-C02 PDF questions one by one and they ensure the best possible answers to Amazon SCS-C02 exam dumps. So you can trust the SCS-C02 practice test and start this journey with complete peace of mind and satisfaction. The AWS Certified Security - Specialty (SCS-C02) exam PDF questions will not assist you in AWS Certified Security - Specialty (SCS-C02) exam preparation but also provide you with in-depth knowledge about the AWS Certified Security - Specialty (SCS-C02) exam topics. This knowledge will be helpful to you in your professional life. So AWS Certified Security - Specialty (SCS-C02) exam questions are the ideal study material for quick Amazon SCS-C02 exam preparation.
New SCS-C02 Test Preparation, Pass SCS-C02 GuideThe AWS Certified Security - Specialty PDF practice material contains actual Amazon SCS-C02 Exam Questions compiled by certified experts around the globe to benefit candidates. The criteria and pattern of the AWS Certified Security - Specialty exam often change, and hence it is essential to use the updated exam study material for preparation. TestkingPDF provides free updates after purchase so that you get the latest Amazon Exam Questions for the exam.
Amazon SCS-C02 Exam Syllabus Topics:
  • Identity and Access Management: The topic equips AWS Security specialists with skills to design, implement, and troubleshoot authentication and authorization mechanisms for AWS resources. By emphasizing secure identity management practices, this area addresses foundational competencies required for effective access control, a vital aspect of the certification exam.
  • Threat Detection and Incident Response: In this topic, AWS Security specialists gain expertise in crafting incident response plans and detecting security threats and anomalies using AWS services. It delves into effective strategies for responding to compromised resources and workloads, ensuring readiness to manage security incidents. Mastering these concepts is critical for handling scenarios assessed in the SCS-C02 Exam.
  • Security Logging and Monitoring: This topic prepares AWS Security specialists to design and implement robust monitoring and alerting systems for addressing security events. It emphasizes troubleshooting logging solutions and analyzing logs to enhance threat visibility.
  • Infrastructure Security: Aspiring AWS Security specialists are trained to implement and troubleshoot security controls for edge services, networks, and compute workloads under this topic. Emphasis is placed on ensuring resilience and mitigating risks across AWS infrastructure. This section aligns closely with the exam's focus on safeguarding critical AWS services and environments.
Amazon AWS Certified Security - Specialty Sample Questions (Q77-Q82):NEW QUESTION # 77
A company has AWS accounts in an organization in AWS Organizations. The company requires a specific software application to be installed on all new and existing Amazon EC2 instances in the organization AWS Systems Manager Agent (SSM Agent) is installed and active on all the instances.
How can the company continuously monitor the deployment status of the software application on all the instances?
  • A. Configure Systems Manager Application Manager to collect a current list of installed software applications in the entire organization Filter for the required application by software status.
  • B. Enable AWS Config for the entire organization. For all accounts, set up the ec2-managedinstance- applications-required AWS. Config managed rule and specify the application name.
  • C. Create a Systems Manager Distributor package for the required software application for the entire organization Install the Distributor package by using Systems Manager Run Command Review the output.
  • D. Enable AWS Config for the entire organization Provide new AMIs that have the required software application pre-installed Set up the approved-amis-by-id AWS Config managed rule for all accounts.
NEW QUESTION # 78
A company's public Application Load Balancer (ALB) recently experienced a DDoS attack. To mitigate this issue, the company deployed Amazon CloudFront in front of the ALB so that users would not directly access the Amazon EC2 instances behind the ALB.
The company discovers that some traffic is still coming directly into the ALB and is still being handled by the EC2 instances.
Which combination of steps should the company take to ensure that the EC2 instances will receive traffic only from CloudFront? (Choose two.)
  • A. Configure the ALB to forward only requests that contain the custom HTTP header.
  • B. Configure CloudFront to add a cache key policy to allow a custom HTTP header that CloudFront sends to the ALB.
  • C. Configure the ALB and CloudFront to use the same X.509 certificate that is generated by AWS Certificate Manager (ACM).
  • D. Configure CloudFront to add a custom HTTP header to requests that CloudFront sends to the ALB.
  • E. Configure the ALB and CloudFront to use the X-Forwarded-For header to check client IP addresses.
https://docs.aws.amazon.com/Amaz ... ample-function-add- true-client-ip-header.html
https://aws.amazon.com/blogs/sec ... f-rate-based-rules/
NEW QUESTION # 79
A security engineer needs to configure an Amazon S3 bucket policy to restrict access to an S3 bucket that is named DOC-EXAMPLE-BUCKET. The policy must allow access to only DOC-EXAMPLE-BUCKET from only the following endpoint: vpce-1a2b3c4d. The policy must deny all access to DOC-EXAMPLE-BUCKET if the specified endpoint is not used.
Which bucket policy statement meets these requirements?
  • A.
  • B.
  • C.
  • D.
https://docs.aws.amazon.com/Amaz ... s-vpc-endpoint.html
NEW QUESTION # 80
A company has several workloads running on AWS. Employees are required to authenticate using on-premises ADFS and SSO to access the AWS Management Console. Developers migrated an existing legacy web application to an Amazon EC2 instance. Employees need to access this application from anywhere on the internet, but currently, there is no authentication system built into the application.
How should the security engineer implement employee-only access to this system without changing the application?
  • A. Create an AWS Lambda custom authorizer as the authenticator for a reverse proxy on Amazon EC2. Ensure the security group on Amazon EC2 only allows access from the Lambda function.
  • B. Place the application behind an Application Load Balancer (ALB). Use Amazon Cognito as authentication for the ALB. Define a SAML-based Amazon Cognito user pool and connect it to ADFS.
  • C. Implement AWS IAM Identity Center (AWS Single Sign-On) in the management account and link it to ADFS as an identity provider. Define the EC2 instance as a managed resource, then apply an IAM policy on the resource.
  • D. Define an Amazon Cognito identity pool, then install the connector on the Active Directory server.
    Use the Amazon Cognito SDK on the application instance to authenticate the employees using their Active Directory user names and passwords.
https://docs.aws.amazon.com/elas ... tener-authenticate- users.html
NEW QUESTION # 81
Your CTO is very worried about the security of your IAM account. How best can you prevent hackers from completely hijacking your account?
Please select:
  • A. Use IAM IAM Geo-Lock and disallow anyone from logging in except for in your city.
  • B. Use short but complex password on the root account and any administrators.
  • C. Use MFA on all users and accounts, especially on the root account.
  • D. Don't write down or remember the root account password after creating the IAM account.
Multi-factor authentication can add one more layer of security to your IAM account Even when you go to your Security Credentials dashboard one of the items is to enable MFA on your root account
Option A is invalid because you need to have a good password policy Option B is invalid because there is no IAM Geo-Lock Option D is invalid because this is not a recommended practices For more information on MFA, please visit the below URL
http://docs.IAM.amazon.com/IAM/latest/UserGuide/id
credentials mfa.htmll
The correct answer is: Use MFA on all users and accounts, especially on the root account.
Submit your Feedback/Queries to our Experts
NEW QUESTION # 82
The contents of SCS-C02 study materials are all compiled by industry experts based on the examination outlines and industry development trends over the years. And our SCS-C02 exam guide has its own system and levels of hierarchy, which can make users improve effectively. Our SCS-C02 learning dumps can simulate the real test environment. After the exam is over, the system also gives the total score and correct answer rate.
New SCS-C02 Test Preparation: https://www.testkingpdf.com/SCS-C02-testking-pdf-torrent.html
