Analytics-Admn-201日本語版受験参考書 & Analytics-Admn-201合格問題
Posted at 2/1/2026 21:33:00
さらに、GoShiken Analytics-Admn-201ダンプの一部が現在無料で提供されています:https://drive.google.com/open?id=1r19EWIj5790PrBkLOnXfdkMJO1kCpyoB
Analytics-Admn-201試験問題の最大の利点は、時間と市場の試練に耐えることです。それは、誠実で温かいサービスです。受験者がAnalytics-Admn-201試験に合格できるように、完璧な製品とサービスシステムを確立しています。対応する製品とサービスをお楽しみいただける、適切で満足のいくAnalytics-Admn-201試験問題を提供できます。絶対に100%良いとは言えませんが、すべての顧客にサービスを提供するために最善を尽くしています。このようにして初めて、顧客を維持し、長期的な協力パートナーになれます。 Analytics-Admn-201テストガイドへの転送をお試しください。
Salesforce Analytics-Admn-201 認定試験の出題範囲:| トピック | 出題範囲 | | トピック 1 | - Administration: This section of the exam measures the skills of Tableau Administrators and covers the day-to-day tasks of maintaining Tableau Server. Candidates should understand how to create and manage schedules, subscriptions, backups, and restores, as well as how to use tools such as TSM, Tabcmd, and REST API. It emphasizes monitoring, server analysis, log file usage, and embedding practices. It also includes managing projects, sites, and nested structures, while contrasting end-user and administrator abilities. Knowledge of publishing, web authoring, sharing views, caching, and data source certification is also tested.
| | トピック 2 | - Troubleshooting: This section of the exam measures the skills of Support Specialists and covers resolving common Tableau Server issues. Candidates must know how to reset accounts, package logs, validate site resources, rebuild search indexes, and use analysis reports. It also includes understanding the role of browser cookies and creating support requests when needed.
| | トピック 3 | - Installation and Configuration: This section of the exam measures the skills of Server Engineers and covers the process of installing Tableau Server, understanding installation paths, identity store options, SSO integrations, SSL setup, and silent installs. Candidates also need to demonstrate the ability to configure Tableau Server by setting cache, distributing processes, customizing sites, and configuring user quotas. It further includes adding users, managing their roles and permissions, and applying Tableau’s security model at different levels from sites to workbooks.
| | トピック 4 | - Connecting to and Preparing Data: This section of the exam measures the skills of Tableau Administrators and covers the basic understanding of Tableau Server’s interface, navigation, and overall topology. Candidates are expected to recognize both client and server components, understand how these interact, and know where to find information about versions, releases, and updates. It also focuses on system requirements, including hardware, operating systems, browsers, email configurations, cloud considerations, and licensing models. Additionally, it examines knowledge of server processes, data source types, network infrastructure, and ports needed for a stable deployment.
| | トピック 5 | - Migration & Upgrade: This section of the exam measures the skills of System Engineers and covers the process of upgrading and migrating Tableau Server environments. Candidates should understand how to carry out clean reinstalls, migrate servers to new hardware, and maintain backward compatibility during the process.
Analytics-Admn-201合格問題 & Analytics-Admn-201コンポーネントあなたがSalesforce Analytics-Admn-201試験に順調に合格できるのは我々の目標です。そして、あなたがAnalytics-Admn-201試験に合格できるのは弊社が存在する意義です。だから、弊社は全力を尽くしてSalesforce Analytics-Admn-201試験資料を改善し、試験制度の変更に応じて更新します。あなたはAnalytics-Admn-201試験資料の最新版の問題集を使用できるために、ご購入の一年間で無料の更新を提供します。
Salesforce Certified Tableau Server Administrator 認定 Analytics-Admn-201 試験問題 (Q19-Q24):質問 # 19
What command should you run to update the automatically-generated secrets that are created during a Tableau Server installation?
- A. tsm security validate-asset-keys
- B. tsm data-access caching set -r 1
- C. tsm licenses refresh
- D. tsm security regenerate-internal-tokens
Tableau Server uses internal secrets (tokens) for secure communication between its processes (e.g., Repository, File Store). These are automatically generated during installation and can be regenerated if compromised or for security maintenance. The command to update these is:
* tsm security regenerate-internal-tokens: This regenerates the internal security tokens, ensuring all processes use the new tokens after a restart.
* Option C (tsm security regenerate-internal-tokens): Correct. This is the documented command for updating internal secrets.
* Option A (tsm data-access caching set -r 1): Incorrect. This command configures caching behavior, not security tokens.
* Option B (tsm licenses refresh): Incorrect. This refreshes license data, unrelated to internal secrets.
* Option D (tsm security validate-asset-keys): Incorrect. This validates encryption keys for assets, not internal tokens.
Reference: Tableau Server Documentation - "Regenerate Internal Tokens" (https://help.tableau.com/current
/server/en-us/cli_security.htm#regenerate-internal-tokens).
質問 # 20
Which three types of authentications can you use to implement single-sign-on (SSO) authentication to Tableau Server? (Choose three.)
- A. OpenID Connect
- B. Local Authentication
- C. Security Assertion Markup Language (SAML)
- D. Kerberos with Active Directory
正解:A、C、D
Single Sign-On (SSO) allows users to authenticate once (e.g., via a corporate identity provider) and access Tableau Server without re-entering credentials. Tableau Server supports several SSO methods:
* OpenID Connect (OIDC): An OAuth 2.0-based protocol for SSO, configured via Tableau's SAML settings with an OIDC-compatible IdP (e.g., Google, Okta).
* Kerberos with Active Directory: A ticket-based SSO protocol, widely used in Windows environments with AD integration.
* SAML: A flexible SSO standard using XML assertions, supporting various IdPs (e.g., ADFS, PingFederate).
Let's evaluate:
* Option A (OpenID Connect): Correct. OIDC is an SSO method, implemented as a SAML variant in Tableau Server, enabling seamless login.
* Option C (Kerberos with Active Directory): Correct. Kerberos provides SSO in AD environments, delegating authentication to the domain controller.
* Option D (Security Assertion Markup Language - SAML): Correct. SAML is a core SSO method in Tableau, widely adopted for enterprise integrations.
* Option B (Local Authentication): Incorrect. Local Authentication uses Tableau's internal user database, requiring manual credential entry-no SSO support.
Why This Matters: SSO enhances user experience and security by leveraging existing identity systems, reducing password fatigue.
Reference: Tableau Server Documentation - "Authentication" (https://help.tableau.com/current/server/en-us
/auth_overview.htm).
質問 # 21
What type of information is stored in the tsm maintenance backup -f <filename>.tsbak command?
- A. Notification settings
- B. Repository data
- C. SMTP server settings
- D. Topology data
The tsm maintenance backup command creates a backup file (with a .tsbak extension) that captures critical data needed to restore Tableau Server in case of failure or migration. This backup primarily includes:
Repository data: This encompasses the PostgreSQL database, which stores metadata such as workbooks, data sources, user information, permissions, schedules, and subscriptions.
Configuration data: This includes server settings like authentication methods, port configurations, and service layouts, but it does not include topology data as a separate entity (topology is part of the configuration).
The command does not back up the following:
Extract files (stored in the File Store), which must be backed up separately if needed.
Log files, which are archived using tsm maintenance ziplogs.
Option A (Notification settings) is incorrect because while notification settings are part of the configuration data stored in the repository, they are not the primary focus of the backup. The broader category is "repository data." Option B (SMTP server settings) is also incorrect for the same reason-SMTP settings are configuration data within the repository, but the backup is not limited to just these settings.
Option D (Topology data) is incorrect because topology data (e.g., how services are distributed across nodes) is part of the configuration included in the backup, but it's not stored as a standalone item. The .tsbak file is centered on the repository database.
Reference: Tableau Server Documentation - "Back Up Tableau Server Data" (https://help.tableau.com/current
/server/en-us/backup_restore.htm).
質問 # 22
What statement correctly describes locking permissions to a project?
- A. Content permissions are locked to a project by default
- B. You can lock permissions to a project by setting the appropriate Project permission role
- C. Locking permissions to projects must be enabled on the Tableau Server Settings page
- D. You can lock permissions to a project by changing Customizable to Locked
In Tableau Server, projects organize content (workbooks, data sources) and use permissions to control access. "Locking permissions" restricts how permissions are managed within a project-let's explore this exhaustively:
* Permission Management Modes:
* Managed by Owner: Default mode. Content owners (e.g., workbook publishers) can set permissions on their items, inheriting project defaults as a starting point.
* Locked to the Project: Project-level permissions are enforced, and content owners cannot modify them. This ensures consistency across all items in the project.
* How to Lock:
* In the Tableau Server web UI:
* Go to Content > Projects.
* Select a project, click Actions > Permissions.
* In the Permissions dialog, change Permissions Management from "Customizable" (Managed by Owner) to "Locked."
* Set the desired permissions (e.g., Viewer, Editor) for users/groups, which then apply uniformly to all content.
* Via REST API: Use the updateProject endpoint with "permissionsLocked": true.
* Option B (You can lock permissions to a project by changing Customizable to Locked): Correct.
* Details: This is the precise action in the UI-switching from "Customizable" to "Locked" locks permissions at the project level.
* Impact: Owners lose the ability to override permissions on individual workbooks/data sources, enforcing governance.
* Example: Set "All Users" to Viewer (Locked)-all content in the project is view-only, regardless of owner intent.
* Option A (Locking permissions must be enabled on the Server Settings page): Incorrect.
* Why: Locking is a per-project setting, not a server-wide toggle. The Server Settings page (via TSM) controls global configs (e.g., authentication), not project permissions.
* Option C (Content permissions are locked by default): Incorrect.
* Default: New projects are "Managed by Owner" (Customizable), allowing flexibility unless explicitly locked by an admin.
* Option D (By setting the appropriate Project permission role): Incorrect.
* Confusion: "Project permission role" isn't a term-permissions are set via rules (e.g., Viewer, Editor), but locking is a separate action (Customizable # Locked).
Why This Matters: Locking permissions ensures uniform access control, critical for regulated environments or large teams where consistency trumps flexibility.
Reference: Tableau Server Documentation - "Lock Project Permissions" (https://help.tableau.com/current
/server/en-us/permissions_lock.htm).
質問 # 23
Which three data sources support Kerberos delegation with Tableau Server? (Choose three.)
- A. SQL Server
- B. Teradata
- C. PostgreSQL
- D. SAP HANA
正解:A、B、D
Kerberos delegation allows Tableau Server to pass a user's Kerberos credentials to a data source for seamless authentication (SSO)-let's explore which sources support it:
* Kerberos Overview:
* Used with Active Directory (AD) for SSO in Windows environments.
* Tableau Server delegates the user's ticket to the data source, avoiding embedded credentials.
* Requires:
* Data source support for Kerberos.
* Proper configuration (e.g., SPN, constrained delegation).
* Supported Data Sources: Per Tableau's documentation:
* Option A (Teradata): Correct.
* Details: Supports Kerberos delegation-common in enterprise data warehouses.
* Config: Enable in TSM (tsm authentication kerberos configure) and set SPN for Teradata.
* Option C (SQL Server): Correct.
* Details: Fully supports Kerberos-widely used with AD-integrated SQL Server instances.
* Config: Requires AD setup and "Trustworthy" delegation in SQL Server.
* Option D (SAP HANA): Correct.
* Details: Supports Kerberos SSO via delegation-popular in SAP ecosystems.
* Config: Needs HANA Kerberos setup (e.g., keytab) and Tableau Server integration.
* Option B (PostgreSQL): Incorrect.
* Why: Supports Kerberos authentication natively, but Tableau Server doesn't enable delegation to PostgreSQL-users must embed credentials or use other methods (e.g., OAuth).
Why This Matters: Kerberos delegation enhances security by avoiding stored passwords-knowing supported sources ensures SSO feasibility.
Reference: Tableau Server Documentation - "Kerberos Delegation" (https://help.tableau.com/current/server
/en-us/kerberos_delegation.htm), "Supported Connectors" (https://help.tableau.com/current/server/en-us
/datasource.htm).
質問 # 24
GoShikenの専門家チームがSalesforceのAnalytics-Admn-201認証試験に対して最新の短期有効なトレーニングプログラムを研究しました。SalesforceのAnalytics-Admn-201「Salesforce Certified Tableau Server Administrator」認証試験に参加者に対して30時間ぐらいの短期の育成訓練でらくらくに勉強しているうちに多くの知識を身につけられます。
Analytics-Admn-201合格問題: https://www.goshiken.com/Salesforce/Analytics-Admn-201-mondaishu.html
- Analytics-Admn-201日本語版受験参考書|Salesforce Certified Tableau Server Administrator最適に合格 🦪 ⇛ [url]www.passtest.jp ⇚には無料の“ Analytics-Admn-201 ”問題集がありますAnalytics-Admn-201模擬体験[/url]
- 試験の準備方法-権威のあるAnalytics-Admn-201日本語版受験参考書試験-高品質なAnalytics-Admn-201合格問題 🍦 ➽ [url]www.goshiken.com 🢪サイトにて最新➤ Analytics-Admn-201 ⮘問題集をダウンロードAnalytics-Admn-201模擬体験[/url]
- Analytics-Admn-201資格問題集 🍋 Analytics-Admn-201試験攻略 🥠 Analytics-Admn-201難易度 ☮ { Analytics-Admn-201 }を無料でダウンロード➠ [url]www.xhs1991.com 🠰ウェブサイトを入力するだけAnalytics-Admn-201模擬試験最新版[/url]
- 試験の準備方法-効果的なAnalytics-Admn-201日本語版受験参考書試験-最新のAnalytics-Admn-201合格問題 ⛴ ✔ [url]www.goshiken.com ️✔️は、▷ Analytics-Admn-201 ◁を無料でダウンロードするのに最適なサイトですAnalytics-Admn-201日本語サンプル[/url]
- 素晴らしいAnalytics-Admn-201日本語版受験参考書 - 合格スムーズAnalytics-Admn-201合格問題 | 更新するAnalytics-Admn-201コンポーネント Salesforce Certified Tableau Server Administrator 🗳 サイト✔ [url]www.passtest.jp ️✔️で☀ Analytics-Admn-201 ️☀️問題集をダウンロードAnalytics-Admn-201資格問題集[/url]
- SalesforceのAnalytics-Admn-201認定試験の一番新しい問題集の登場 🤞 今すぐ✔ [url]www.goshiken.com ️✔️を開き、☀ Analytics-Admn-201 ️☀️を検索して無料でダウンロードしてくださいAnalytics-Admn-201試験問題[/url]
- SalesforceのAnalytics-Admn-201認定試験の一番新しい問題集の登場 🥟 ➽ Analytics-Admn-201 🢪を無料でダウンロード「 [url]www.passtest.jp 」で検索するだけAnalytics-Admn-201受験練習参考書[/url]
- SalesforceのAnalytics-Admn-201認定試験の一番新しい問題集の登場 🐟 “ Analytics-Admn-201 ”を無料でダウンロード➠ [url]www.goshiken.com 🠰ウェブサイトを入力するだけAnalytics-Admn-201試験問題[/url]
- Analytics-Admn-201資格問題集 ⛴ Analytics-Admn-201資格問題集 🚊 Analytics-Admn-201試験問題 🦹 ➥ [url]www.passtest.jp 🡄で{ Analytics-Admn-201 }を検索し、無料でダウンロードしてくださいAnalytics-Admn-201試験問題[/url]
- SalesforceのAnalytics-Admn-201認定試験の一番新しい問題集の登場 Ⓜ ⏩ [url]www.goshiken.com ⏪に移動し、【 Analytics-Admn-201 】を検索して、無料でダウンロード可能な試験資料を探しますAnalytics-Admn-201日本語版対策ガイド[/url]
- Analytics-Admn-201必殺問題集 🍧 Analytics-Admn-201オンライン試験 ✌ Analytics-Admn-201オンライン試験 😝 【 [url]www.mogiexam.com 】から“ Analytics-Admn-201 ”を検索して、試験資料を無料でダウンロードしてくださいAnalytics-Admn-201模擬試験最新版[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, connect.garmin.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
ちなみに、GoShiken Analytics-Admn-201の一部をクラウドストレージからダウンロードできます:https://drive.google.com/open?id=1r19EWIj5790PrBkLOnXfdkMJO1kCpyoB
