[General] FCSS_SDW_AR-7.4 Test Engine | Reliable FCSS_SDW_AR-7.4 Test Topics
94
General FCSS_SDW_AR-7.4 Test Engine | Reliable FCSS_SDW_AR-7.4 Test Topics
Posted at 2/1/2026 23:11:17      View117 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Itcertmaster FCSS_SDW_AR-7.4 dumps for free: https://drive.google.com/open?id=135xeu042R8DRMAwj3cbhWHDavh6sCVUs
If you are not aware of your problem, please take a good look at the friends around you! Now getting an international FCSS_SDW_AR-7.4 certificate has become a trend. If you do not hurry to seize the opportunity, you will be far behind others! Now the time cost is so high, choosing FCSS_SDW_AR-7.4 Exam Prep will be your most efficient choice. You can pass the FCSS_SDW_AR-7.4 exam in the shortest possible time to improve your strength.
Fortinet FCSS_SDW_AR-7.4 Exam Syllabus Topics:
  • SD-WAN Troubleshooting: This part assesses the troubleshooting skills of network support specialists. Candidates should be able to diagnose and resolve issues related to SD-WAN rules, session behaviors, routing inconsistencies, and ADVPN connectivity problems to maintain seamless network operations.
  • Configure Performances SLAs: Designed for network administrators, this part focuses on setting up performance Service Level Agreements (SLAs) within SD-WAN environments. Candidates must show proficiency in defining criteria to monitor and maintain network performance and reliability.
  • SD-WAN Configuration: This section of the exam measures the skills of network engineers and covers configuring a basic SD-WAN setup. Candidates are expected to demonstrate their ability to define SD-WAN members and zones effectively, ensuring foundational network segmentation and management.
  • Advanced IPsec: Intended for security engineers, this section covers the deployment of advanced IPsec topologies for SD-WAN, including hub-and-spoke models, ADVPN configurations, and complex multi-hub or multi-region deployments. Candidates need to demonstrate expertise in securing wide-area networks using IPsec technologies.
Topic 5
  • Rules and Routing: Targeted at network engineers, this section assesses the ability to configure SD-WAN rules and routing policies. Candidates will be tested on managing traffic flow and prioritization across the SD-WAN infrastructure.
Reliable FCSS_SDW_AR-7.4 Test Topics, Latest FCSS_SDW_AR-7.4 Test OnlineThere is no need to worry about failure when you already have the most probable FCSS - SD-WAN 7.4 Architect (FCSS_SDW_AR-7.4) questions in the Cert2Pass PDF document. All you need is to stay positive, put in your best efforts, and be confident while appearing for the Fortinet FCSS_SDW_AR-7.4 Exam. Laptops, smartphones, and tablets support the PDF format.
Fortinet FCSS - SD-WAN 7.4 Architect Sample Questions (Q23-Q28):NEW QUESTION # 23
As an IT manager for a healthcare company, you want to delegate the installation and management of your SD-WAN deployment to a managed security service provider (MSSP). Each site must maintain direct internet access and ensure that it is secure. You expected significant traffic flow between the sites and want to delegate as much of the network administration and management as possible to the MSSP.
Which two MSSP deployment blueprints best address the customer's requirements? (Choose two.)
  • A. Use a shared hub at the MSSP premises and a dedicated hub at the customer premises and install the spokes at the customer premises.
  • B. Install the hub and spokes at the customer premises and enable the MSSP to manage the SD-WAN deployment using FortiManager with a dedicated ADOM.
  • C. Install a dedicated hub at the MSSP premises for the new customer, and install the spokes at the customer premises.
  • D. Use a shared hub at the MSSP premises with a dedicated VDOM for the new customer, and install the spokes at the customer premises.
Hosting the hub at the MSSP centralizes installation, security, and ongoing management while each site (spoke) keeps local DIA. This can be done multi-tenant with a shared hub using a dedicated VDOM or with a fully dedicated hub per customer for stricter isolation and control, both meeting the requirement to delegate administration to the MSSP and support high inter-site traffic.
NEW QUESTION # 24
You configured an SD-WAN rule with the best quality strategy and selected the predefined health check, Default_FortiGuard, to check the link performances against FortiGuard servers.
For the quality criteria, you selected Custom-profile-1.
Which factors does FortiGate use, and in which order. to determine the link that it should use to steer the traffic?
  • A. Latency - Member configuration order - Link cost threshold
  • B. Latency - Jitter - Packet loss - Bibandwidth - Member configuration order
  • C. Link quality index - Member configuration order - Link cost threshold
  • D. Links that meet the SLA targets - Member configuration order - Member local cost
With the Best Quality strategy, FortiGate first checks which links meet the SLA targets defined in the selected performance SLA (in this case, Custom-profile-1). Among those qualified links, FortiGate then uses the member configuration order to decide preference. If multiple links still qualify, it finally considers the member local cost to select the best path.
NEW QUESTION # 25
Refer to the exhibits.
The exhibits show the configuration for SD-WAN performance. SD-WAN rule, the application IDs of Facebook and YouTube along with the firewall policy configuration and the underlay zone status.
Which two statements are true about the health and performance of SD-WAN members 3 and 4? (Choose two.)
  • A. Only related TCP traffic is used for performance measurement.
  • B. Encrypted traffic is not used for the performance measurement.
  • C. The performance is an average of the metrics measured for Facebook and YouTube traffic passing through the member.
  • D. FortiGate identifies the member as dead when there is no Facebook and YouTube traffic passing through the member.
NEW QUESTION # 26
Refer to the exhibits. The first exhibit shows the SD-WAN zone HUB1 and SD-WAN member configuration from an SD-WAN template, and the second exhibit shows the output of command diagnose sys sdwan membercollected on a FortiGate device.
Which statement best describes what the diagnose output shows?
  • A. The diagnose output was collected on the device branch2_fgt.
  • B. The diagnose output does not correspond to a device configured with the SD-WAN template shown in the exhibit.
  • C. The diagnose output was collected on the device branch1_fgt
  • D. The diagnose output shows that HUB1-VPN1 and all HUBx-VPNy members are dead.
The diagnose output lists SD-WAN members 4(HUB1-VPN1), 5(HUB1-VPN2), 7(HUB2-VPN1),
8(HUB2-VPN2), and 9(HUB2-VPN3). It does not include member 6 (HUB1-VPN3). From the template, HUB1-VPN3 is installed only on branch2_fgt and branch3_fgt - not on branch1_fgt.
Therefore, the output must be from branch1_fgt.
NEW QUESTION # 27
You manage an SD-WAN topology. You will soon deploy 50 new branches.
Which three tasks can you do in advance to simplify this deployment? (Choose three.)
  • A. Define metadata variables value for each device.
  • B. Create policy blueprint.
  • C. Update the DHCP server configuration.
  • D. Create a ZTP template.
  • E. Create model devices.
Answer: B,D,E
NEW QUESTION # 28
The FCSS - SD-WAN 7.4 Architect (FCSS_SDW_AR-7.4) practice test questions prep material has actual FCSS - SD-WAN 7.4 Architect exam questions for our customers so they don't face any hurdles while preparing for Fortinet FCSS_SDW_AR-7.4 certification exam. The study material is made by professionals while thinking about our users. We have made the product user-friendly so it will be an easy-to-use learning material. We even guarantee our users that if they couldn't pass the Fortinet FCSS_SDW_AR-7.4 Certification Exam on the first try with their efforts, they can claim a full refund of their payment from us (terms and conditions apply).
Reliable FCSS_SDW_AR-7.4 Test Topics: https://www.itcertmaster.com/FCSS_SDW_AR-7.4.html
BTW, DOWNLOAD part of Itcertmaster FCSS_SDW_AR-7.4 dumps from Cloud Storage: https://drive.google.com/open?id=135xeu042R8DRMAwj3cbhWHDavh6sCVUs
