1z1-076 PDF - 1z1-076 Materials
Posted at 2/1/2026 23:16:33
View110
Replies2
P.S. Free & New 1z1-076 dumps are available on Google Drive shared by Itcerttest: https://drive.google.com/open?id=1D80zfsD6GVNFI7gD6Usiet4rdKUqq90J
With the rise of internet and the advent of knowledge age, mastering knowledge about computer is of great importance. This 1z1-076 exam is your excellent chance to master more useful knowledge of it. Up to now, No one has questioned the quality of our 1z1-076 training materials, for their passing rate has reached up to 98 to 100 percent. Our Oracle Database 19c study dumps are priced reasonably so we made a balance between delivering satisfaction to customers and doing our own jobs. So in this critical moment, our 1z1-076 real materials will make you satisfied. Our 1z1-076 exam materials can provide integrated functions. You can learn a great deal of knowledge and get the certificate of the exam at one order like win-win outcome at one try.
We are committed to designing a kind of scientific 1z1-076 study material to balance your business and study schedule. With our 1z1-076 exam guide, all your learning process includes 20-30 hours. As long as you spare one or two hours a day to study with our laTest 1z1-076 Quiz prep, we assure that you will have a good command of the relevant knowledge before taking the 1z1-076 exam. What you need to do is to follow the 1z1-076 exam guide system at the pace you prefer as well as keep learning step by step.
1z1-076 Materials & Reliable 1z1-076 Test TopicsIn accordance to the fast-pace changes of bank market, we follow the trend and provide the latest version of 1z1-076 study materials to make sure you learn more knowledge. And since our 1z1-076 training quiz appeared on the market, so our professional work team has years' of educational background and vocational training experience, thus our 1z1-076 Preparation materials have good dependability, perfect function and strong practicability. So with so many advantages we can offer, why not get moving and have a try on our 1z1-076 training materials?
Oracle Database 19c: Data Guard Administration Sample Questions (Q90-Q95):NEW QUESTION # 90
Which THREE are true about using flashback database in a Data Guard environment?
- A. It may be used to flash back a physical standby that receives redo from a far sync instance.
- B. You can use it when real-time apply is enabled in case the phylt may not be used to flash back a primary database after a failover to a logical standby.
- C. It may not be used to flash back a primary database after a failover to a physical standby.
- D. When a flashback database operation is performed on a primary database, a physical standby database is also flashed back automatically.
- E. You can use it when real-time apply is enabled in case the physical standby suffers from logical corruption.
- F. When a flashback database operation is performed on a primary database, a logical standby database is also flashed back automatically.
Answer: A,C,E
Flashback Database is a feature that allows reverting a database to a previous point in time, which is extremely useful in various Data Guard configurations:
It may be used to flash back a physical standby that receives redo from a far sync instance (C): Flashback Database can be used on a physical standby database to revert it to a past point in time, even when it is receiving redo data from a far sync instance. This can be particularly useful to recover from logical corruptions or unwanted changes.
You can use it when real-time apply is enabled in case the physical standby suffers from logical corruption (D): Even when real-time apply is enabled, which allows redo data to be applied to the standby database as soon as it is received, Flashback Database can be used to revert the physical standby database to a point in time before the logical corruption occurred.
It may not be used to flash back a primary database after a failover to a physical standby (E): After a failover has occurred from a primary to a physical standby database, making the standby the new primary, Flashback Database cannot be used to revert the old primary database to a state before the failover because the failover operation makes irreversible changes to the database role and configuration.
Oracle Database Backup and Recovery User's Guide
Oracle Data Guard Concepts and Administration
NEW QUESTION # 91
In Oracle Database 19c, you can set the value of database initialization parameters in a database using the EDIT DATABASE... SET PARAMETER Command:
DGMGRL> EDIT DATABASE 'boston' SET PARAMETER log_archive_trace - 1;
Which THREE statements are TRUE about the command?
- A. The edit database parameter command can only be used to modify the value of a dynamic parameter in a database.
- B. The value set using this command is directly stored in the broker configuration file.
- C. The EDIT DATABASE PARAMETER command can be used to set the value of a static parameter in a database.
- D. The database must be available when the above command is run.
- E. The value set using this command is directly applied to the boston database.
Answer: A,D,E
The EDIT DATABASE...SET PARAMETER command in Data Guard Management (DGMGRL) is used to modify the value of initialization parameters for a database within a Data Guard configuration. This command can be used to modify both static and dynamic parameters, but if a static parameter is changed, the new value will take effect only after the database is restarted. The database must be up and running for the command to execute, and the values set using the command are directly applied to the specified database (in this case, 'boston') .
NEW QUESTION # 92
There are currently 6 applief. and 6 pfepafef processes running and no idle applier processes on y logical standby database.
The max_SERVERS SQL apply parameter and number of archiver processes are both set to 12.
Identify two changes, each of which would allow you to increase the number of applier processes.
- A. Increase the value for the MAX_SERVERS SQL apply parameter.
- B. Increase the RECOVERY_PARALLEL initialization parameter.
- C. Increase the parallel_max_server initialization parameter.
- D. Increase the processes initialization parameter. D Decrease the number of FREPARER processes.
- E. Decrease the number of archiver processes on the standby database.
To increase the number of applier processes on a logical standby database, the following changes can be made:
C: Increasing the value for the MAX_SERVERS SQL apply parameter would allow for more applier processes to be initiated, assuming that system resources permit.
D: Increasing the PARALLEL_MAX_SERVERS initialization parameter would allow for more parallel execution processes, which can be used by SQL apply to increase the number of applier processes.
Option A is incorrect as decreasing the number of archiver processes will not necessarily increase the number of applier processes; these are unrelated components.
Option B is incorrect because the 'FREPARER' processes do not exist, it seems to be a typographical error, and the 'REPARER' is not a valid Oracle process or parameter.
Option E is incorrect because the RECOVERY_PARALLELISM parameter controls the number of processes used for instance recovery and media recovery, not for SQL apply.
NEW QUESTION # 93
You are planning to perform block comparison using the dbms comp package:
Which TWO statements are true?
- A. It requires that the DB_LOST_WKITE_protect initialization parameter be enabled.
- B. The databases should be at least mounted before block comparison.
- C. It can be used to detect lost writes and inconsistencies between the primary database and the cascaded standbys.
- D. You can monitor the progress of an ongoing block comparison operation by querying VS SES SION_LONGOPS.
- E. Logical standby databases can be the target database for the dbms_dbcomp.dbcomp procedure.
The DBMS_COMPARISON package, used for comparing and converging data objects within a single database or between databases, requires that the databases involved in the block comparison be at least mounted (A). This allows the procedure to access the data blocks for comparison. Additionally, the progress of long-running operations such as block comparison can be monitored using the dynamic performance view V$SESSION_LONGOPS (D), which provides information on the operation's progress and estimated completion time.
Oracle Database PL/SQL Packages and Types Reference provides comprehensive details on the DBMS_COMPARISON package, including its procedures and how to monitor their progress. Additionally, Oracle Database Reference explains the V$SESSION_LONGOPS view, which is commonly used for monitoring long operations in the database.
NEW QUESTION # 94
Which two are true about database roles in an Oracle Data Guard configuration?
- A. A Logical Standby Database can cascade redo to a terminal destination.
- B. A configuration consisting only of a primary and one or more physical standby databases can support a rolling release upgrade.
- C. A Logical Standby Database can be converted to a Snapshot Standby Database.
- D. A Physical Standby Database can be converted into a Logical Standby Database.
- E. A Snapshot Standby Database can be a fast-start failover target.
A Physical Standby Database can indeed be converted into a Logical Standby Database, providing flexibility in a Data Guard configuration. This allows for the database to switch roles and supports SQL apply operations, enabling more granular control over the data and transactions being replicated and applied. Additionally, having a configuration with a primary database and one or more physical standby databases allows for rolling upgrades to be performed. This means that each database in the Data Guard configuration can be upgraded in a phased manner, minimizing downtime and ensuring high availability during the upgrade process.
NEW QUESTION # 95
We are always on the way to be better for we can't be satisfied to be the best on the 1z1-076 exam questions. We are trying to apply the most latest technologies to the compiling and designing on the 1z1-076 learning guide. With these innovative content and displays, our company is justified in claiming for offering unique and unmatched 1z1-076 Study Material to certifications candidates. And you won't regret for your choice if you buy our 1z1-076 practice engine.
1z1-076 Materials: https://www.itcerttest.com/1z1-076_braindumps.html
How can I activate 1z1-076 Materials Exam Simulator, If you are interest in our 1z1-076 vce exam please download our 1z1-076 dumps free before you purchase, Oracle 1z1-076 PDF To meet your needs to the exam, we have been dedicated in this area for more than ten years without sluggish action, Almost everyone is trying to get Oracle Database 19c: Data Guard Administration (1z1-076) certification to update their CV or get the desired job.
Windows features and upgrade paths, Risk assessments tend 1z1-076 to rely on risk matrices" which use a grid to compare the likelihood of the risk and the severity of the impact.
How can I activate Oracle Database 19c Exam Simulator, If you are interest in our 1z1-076 Vce Exam please download our 1z1-076 dumps free before you purchase, To meet your needs to the 1z1-076 Materials exam, we have been dedicated in this area for more than ten years without sluggish action.
Pass Guaranteed Latest Oracle - 1z1-076 - Oracle Database 19c: Data Guard Administration PDFAlmost everyone is trying to get Oracle Database 19c: Data Guard Administration (1z1-076) certification to update their CV or get the desired job, What is the reason behind this?
- 1z1-076 Oracle Database 19c: Data Guard Administration Web-Based Practice Exam 🚍 Easily obtain free download of ☀ 1z1-076 ️☀️ by searching on ➠ [url]www.exam4labs.com 🠰 💁New 1z1-076 Test Labs[/url]
- Experience the real Oracle exam environment with our web-based 1z1-076 practice test 🤧 Search for ➽ 1z1-076 🢪 and obtain a free download on ➥ [url]www.pdfvce.com 🡄 ☝Reliable 1z1-076 Test Topics[/url]
- Exam 1z1-076 Questions Answers 🔟 1z1-076 Updated Demo 🤑 1z1-076 Real Testing Environment 🦄 Search for ▛ 1z1-076 ▟ and download it for free immediately on [url]www.easy4engine.com 🍈1z1-076 Reliable Study Guide[/url]
- 1z1-076 VCE Dumps 🆒 Test 1z1-076 Assessment 🏨 1z1-076 VCE Dumps ⛺ Download 1z1-076 for free by simply searching on { [url]www.pdfvce.com } 📦1z1-076 VCE Dumps[/url]
- New 1z1-076 Test Labs 📢 Exam 1z1-076 Questions Answers 🍎 1z1-076 Exam Reference ⏳ Easily obtain ➤ 1z1-076 ⮘ for free download through [url]www.troytecdumps.com 🙉1z1-076 VCE Dumps[/url]
- Oracle Marvelous 1z1-076 PDF 🌱 Search for ➥ 1z1-076 🡄 and download it for free on ➥ [url]www.pdfvce.com 🡄 website 🌜New 1z1-076 Test Materials[/url]
- 1z1-076 good exam reviews - Oracle 1z1-076 valid exam dumps 👿 ⏩ [url]www.practicevce.com ⏪ is best website to obtain 1z1-076 for free download 🤢1z1-076 Exam Forum[/url]
- 1z1-076 good exam reviews - Oracle 1z1-076 valid exam dumps 🕗 Immediately open ➽ [url]www.pdfvce.com 🢪 and search for ⏩ 1z1-076 ⏪ to obtain a free download 🌰1z1-076 Latest Test Prep[/url]
- 1z1-076 good exam reviews - Oracle 1z1-076 valid exam dumps 🌅 Easily obtain free download of ➤ 1z1-076 ⮘ by searching on ⏩ [url]www.prepawayete.com ⏪ 🔟1z1-076 Updated Demo[/url]
- 1z1-076 Brain Exam 🏗 New 1z1-076 Test Materials 😅 1z1-076 Study Tool 👛 Immediately open ➤ [url]www.pdfvce.com ⮘ and search for ✔ 1z1-076 ️✔️ to obtain a free download 🩲1z1-076 Reliable Test Practice[/url]
- Accurate 1z1-076 Study Material 💈 1z1-076 Exam Forum 🧡 1z1-076 Exam Forum ⌨ Simply search for ▛ 1z1-076 ▟ for free download on ➽ [url]www.examcollectionpass.com 🢪 🍴1z1-076 Brain Exam[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.slideshare.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, faithlife.com, Disposable vapes
P.S. Free 2026 Oracle 1z1-076 dumps are available on Google Drive shared by Itcerttest: https://drive.google.com/open?id=1D80zfsD6GVNFI7gD6Usiet4rdKUqq90J
