[General] 100% Pass Quiz 2026 High Hit-Rate VMware 2V0-13.25: Pass4sure VMware Cloud Found
89
General 100% Pass Quiz 2026 High Hit-Rate VMware 2V0-13.25: Pass4sure VMware Cloud Found
Posted at 2/1/2026 23:33:48      View161 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest PremiumVCEDump 2V0-13.25 PDF Dumps and 2V0-13.25 Exam Engine Free Share: https://drive.google.com/open?id=1WZmj4Ll4ygD306iUDfJTzr63baX0oW2B
The VMware 2V0-13.25 Exam registration fee varies between 100 usd and 1000 usd, and a candidate cannot risk wasting his time and money, thus we ensure your success if you study from the updated VMware 2V0-13.25 practice material. We offer the demo version of the actual VMware 2V0-13.25 questions so that you may confirm the validity of the product before actually buying it, preventing any sort of regret.
No matter you are a fresh man or experienced IT talents, here, you may hear that 2V0-13.25 certifications are designed to take advantage of specific skills and enhance your expertise. While, if you want to be outstanding in the crowd, it is better to get the 2V0-13.25 certification. While, where to find the latest 2V0-13.25 Study Material for preparation is another question. VMware 2V0-13.25 exam training will guide you and help you to get the 2V0-13.25 certification. Hurry up, download 2V0-13.25 test practice torrent for free, and start your study at once.
100% Pass 2026 VMware Authoritative Pass4sure 2V0-13.25 Exam PrepOur 2V0-13.25 study materials are excellent examination review products composed by senior industry experts that focuses on researching the mock examination products which simulate the real 2V0-13.25 test environment. Experts fully considered the differences in learning methods and examination models between different majors and eventually formed a complete review system. It will help you to Pass 2V0-13.25 Exam successfully after a series of exercises, correction of errors, and self-improvement.
VMware Cloud Foundation 9.0 Architect Sample Questions (Q16-Q21):NEW QUESTION # 16
Which Broadcom products support the configuration of a highly available VMware environment?
  • A. vSphere HA
  • B. vSAN
  • C. Broadcom 25GbE Ethernet Adapter
  • D. Broadcom RAID Controller
Answer: A,B,D
Broadcom RAID Controllers, vSphere HA, and vSAN support high availability in VMware environments.
NEW QUESTION # 17
What actions are important when troubleshooting network slowness in VMware environments using Broadcom 10GbE Ethernet adapters?
  • A. Enable Jumbo Frames
  • B. Disable 10GbE adapter features
  • C. Verify NIC team settings
  • D. Check for network congestion
Answer: A,C,D
Checking for congestion, verifying NIC team settings, and enabling Jumbo Frames are essential troubleshooting steps.
NEW QUESTION # 18
What is the purpose of VMware's Open Virtualization Format (OVF)?
  • A. Standardize VM deployment
  • B. Simplify network configurations
  • C. Enhance storage compatibility
  • D. Increase VM performance
OVF standardizes VM packaging for cross-platform compatibility.
NEW QUESTION # 19
Which Broadcom solutions optimize storage performance in VMware Cloud Foundation environments?
  • A. Broadcom Fibre Channel HBAs
  • B. Broadcom Ethernet adapters
  • C. Broadcom RAID controllers
  • D. Broadcom NVMe SSDs
Broadcom NVMe SSDs and RAID controllers help optimize storage performance in VMware Cloud Foundation environments.
NEW QUESTION # 20
An administrator is documenting the design for a new VMware Cloud Foundation (VCF) solution. During discovery workshops with the customer, the following information was shared with the architect:
All users and administrators of the solution will need to be authenticated using accounts in the corporate directory service.
The solution will need to be deployed across two geographically separate locations and run in an Active/Standby configuration where supported.
The management applications deployed as part of the solution will need to be recovered to the standby location in the event of a disaster.
All management applications will need to be deployed into a management tooling zone of the network, which is separated from the corporate network zone by multiple firewalls.
The corporate directory service is deployed in the corporate zone.
There is an internal organization policy that requires each application instance (management or end user) to detail the ports that access is required on through the firewall separately.
Firewall rule requests are processed manually one application instance at a time and typically take a minimum of 8 weeks to complete.
The customer also informed the architect that the new solution needs to be deployed and ready to start the organization's acceptance into service process within 3 months, as it is a dependency in the deployment of a business-critical application. When considering the design for the Cloud Automation and Operations products within the VCF solution, which three design decisions should the architect include based on this information? (Choose three.)
  • A. The Cloud Automation and Operations products will be integrated directly with the corporate directory service.
  • B. The Cloud Automation and Operations products will be reconfigured to integrate with the Identity Broker solution instance at the standby site in case of a Disaster Recovery incident.
  • C. The Identity Broker solution will be deployed at both the primary and standby site.
  • D. The Identity Broker solution will be connected with the corporate directory service for user authentication.
  • E. The Identity Broker solution will be deployed at the primary site and failed over to the standby site in case of a disaster.
  • F. The Cloud Automation and Operations products will be integrated with a single instance of an Identity Broker solution at the primary site.
Answer: C,D,F
In VMware Cloud Foundation (VCF) 5.2, Cloud Automation (e.g., Aria Automation) and Operations (e.g., Aria Operations) products rely on identity management for authentication. The customer's requirements-corporate directory authentication, Active/Standby across two sites, disaster recovery (DR), network zoning, slow firewall processes, and a 3-month deployment timeline-shape the design decisions. The architect must ensure authentication works efficiently across sites while meeting the timeline and DR needs. Let's evaluate:
Key Constraints and Context:
Authentication: All users/administrators use the corporate directory (e.g., Active Directory in the corporate zone).
Deployment: Active/Standby across two sites, with management apps in a separate tooling zone behind firewalls.
DR: Management apps must recover to the standby site.
Firewall Delays: 8-week minimum per rule, but deployment must occur within 12 weeks (3 months).
Identity Broker: In VCF, VMware Workspace ONE Access (or similar) acts as an identity broker, bridging VCF components with external directories (e.g., AD via LDAP/S).
Evaluation of Options:
Option A: The Cloud Automation and Operations products will be reconfigured to integrate with the Identity Broker solution instance at the standby site in case of a Disaster Recovery incident This implies a single Identity Broker at the primary site, with reconfiguration to a standby instance post-DR. Reconfiguring products (e.g., updating SSO endpoints) during DR adds complexity and downtime, contradicting the Active/Standby goal of seamless failover. It's feasible but not optimal given the need for continuous operation and the 3-month timeline.
Option B: The Identity Broker solution will be deployed at both the primary and standby site This is correct. Deploying Workspace ONE Access (or equivalent) at both sites supports Active/Standby by ensuring authentication availability at the primary site and immediate usability at the standby site post-DR. It aligns with VCF's multi-site HA capabilities and avoids reconfiguration delays, addressing the DR requirement efficiently within the timeline.
Option C: The Identity Broker solution will be connected with the corporate directory service for user authentication This is correct. The requirement states all users/administrators authenticate via the corporate directory (in the corporate zone). An Identity Broker (e.g., Workspace ONE Access) connects to AD via LDAP/S, acting as a proxy between the management tooling zone and corporate zone. This satisfies the authentication need and simplifies firewall rules (one broker-to-AD connection vs. multiple app connections), critical given the 8-week delay.
Option D: The Identity Broker solution will be deployed at the primary site and failed over to the standby site in case of a disaster This suggests a single Identity Broker with DR failover. While possible (e.g., via vSphere Replication), it risks authentication downtime during failover, conflicting with Active/Standby continuity. The 8-week firewall rule delay for the standby site's broker connection post-DR also jeopardizes the 3-month timeline and DR readiness, making this less viable than dual-site deployment (B).
Option E: The Cloud Automation and Operations products will be integrated with a single instance of an Identity Broker solution at the primary site This is correct. Integrating Aria products with one Identity Broker instance at the primary site during initial deployment simplifies setup and meets the 3-month timeline. It leverages the broker deployed at the primary site (part of B) for authentication, minimizing firewall rules (one broker vs. multiple apps). Pairing this with a standby instance (B) ensures DR readiness without immediate complexity.
Option F: The Cloud Automation and Operations products will be integrated directly with the corporate directory service This is incorrect. Direct integration requires each product (e.g., Aria Automation, Operations) to connect to AD across the firewall, necessitating multiple rule requests. With an 8-week minimum per rule and several products, this exceeds the 3-month timeline. It also complicates DR, as each app would need re-pointing to a standby AD, violating efficiency and zoning policies.
Conclusion:
The three design decisions are:
B: Identity Broker at both sites ensures Active/Standby and DR readiness.
C: Connecting the broker to the corporate directory fulfills the authentication requirement and simplifies firewall rules.
E: Integrating products with a primary-site broker meets the 3-month deployment goal while leveraging B and C for DR.
This trio balances timeline, security, and DR needs in VCF 5.2.
Reference: VMware Cloud Foundation 5.2 Architecture and Deployment Guide (Section: Identity and Access Management) VMware Aria Automation 8.10 Documentation (integrated in VCF 5.2): Authentication Design VMware Cloud Foundation 5.2 Planning and Preparation Guide (Section: Multi-Site and DR Considerations)
NEW QUESTION # 21
If you want to pass 2V0-13.25 exam certification or improve your IT skills, PremiumVCEDump will be your best choice. With many years'hard work, the passing rate of 2V0-13.25 test of PremiumVCEDump is 100%. Our 2V0-13.25 Exam Dumps and training materials include complete restore and ensure you pass the 2V0-13.25 exam certification easier.
2V0-13.25 Practice Test: https://www.premiumvcedump.com/VMware/valid-2V0-13.25-premium-vce-exam-dumps.html
Let our 2V0-13.25 real exam questions and 2V0-13.25 test dumps vce pdf help you pass exam easily, VMware Pass4sure 2V0-13.25 Exam Prep When do your products update, PremiumVCEDump 2V0-13.25 dumps PDF files make sure candidates pass exam for certain, And you must not miss the opportunity to pass 2V0-13.25 test successfully, We believe that you will benefit a lot from our 2V0-13.25 study question.
I mean, really, really like bass drum for long 2V0-13.25 extended periods of time, and you like it followed by layering weird synthesizer sounds, This was the best new property for me, Pass4sure 2V0-13.25 Exam Prep since it simplifies the development of sets that had to be full of nested functions.
Evaluate Your Skills with Online VMware 2V0-13.25 Practice Test EngineLet our 2V0-13.25 Real Exam Questions and 2V0-13.25 test dumps vce pdf help you pass exam easily, When do your products update, PremiumVCEDump 2V0-13.25 dumps PDF files make sure candidates pass exam for certain.
BTW, DOWNLOAD part of PremiumVCEDump 2V0-13.25 dumps from Cloud Storage: https://drive.google.com/open?id=1WZmj4Ll4ygD306iUDfJTzr63baX0oW2B
Posted at 2/5/2026 00:32:50        Only Author  2#
힘든MI PMP-KR시험패스도 간단하게 ! ITDumpsKR의 전문가들은MI PMP-KR 최신시험문제를 연구하여 시험대비에 딱 맞는MI PMP-KR덤프를 출시하였습니다. ITDumpsKR덤프를 구매하시면 많은 정력을 기울이지 않으셔도 시험을 패스하여 자격증취득이 가능합니다. ITDumpsKR의 PMI PMP-KR덤프로 자격증 취득의 꿈을 이루어보세요.
Posted at 2/8/2026 18:05:32        Only Author  3#
MicrosoftSC-100γߤʤΤǡǤޤ JpshikenϾyQǤޤJpshikenѧ̲ĤϤʾѤ򺬤ޤƤޤЩ`ʤߤǤ顢ߤˤƤ⺆g˸ޤä顢MicrosoftSC-100ԇY˺ϸ񤹤I֤ĤȤǤޤޤǤ֤äƤʤŤ֤ĤȤǤޤޤΤäƤΤǤ礦
