[General] Original Mule-Arch-201 Questions - Mule-Arch-201 Latest Braindumps Sheet
94
General Original Mule-Arch-201 Questions - Mule-Arch-201 Latest Braindumps Sheet
Posted at 2/2/2026 00:37:51      View126 | Replies0        Print      Only Author   [Copy Link] 1#
As our Salesforce Certified MuleSoft Platform Architect study questions can bring more professional quality service for the user. Our Mule-Arch-201 study materials can give the user confidence and strongly rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on Mule-Arch-201 Exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company. Now, you can free download the demo of our Mule-Arch-201 test guide to understand in more details.
Salesforce Mule-Arch-201 dumps PDF version is printable and embedded with valid Salesforce Mule-Arch-201 questions to help you get ready for the Mule-Arch-201 exam quickly. Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) exam dumps pdf are also usable on several smart devices. You can use it anywhere at any time on your smartphones and tablets. We update our Salesforce Mule-Arch-201 Exam Questions bank regularly to match the changes and improve the quality of Mule-Arch-201 questions so you can get a better experience.
Salesforce Mule-Arch-201 Latest Braindumps Sheet, Updated Mule-Arch-201 DumpsOnce you compare our Mule-Arch-201 study materials with the annual real exam questions, you will find that our Mule-Arch-201 exam questions are highly similar to the real exam questions. We have strong strengths to assist you to pass the exam. All in all, we hope that you are brave enough to challenge yourself. Our Mule-Arch-201 learning prep will live up to your expectations. It will be your great loss to miss our Mule-Arch-201 practice engine.
Salesforce Certified MuleSoft Platform Architect Sample Questions (Q83-Q88):NEW QUESTION # 83
Which statement is true about Spike Control policy and Rate Limiting policy?
  • A. All requests are rejected after the limit is reached in Rate Limiting policy, whereas the requests are queued in Spike Control policy after the limit is reached
  • B. In order to apply Rate Limiting and Spike Control policies, a contract to bind client application and API is needed for both
  • C. In a clustered environment, the Rate Limiting.and Spike Control policies are applied to each node in the cluster
  • D. To protect Experience APIs by limiting resource consumption, Rate Limiting policy must be applied
Understanding Spike Control and Rate Limiting Policies:
Spike Control Policy: Limits the number of requests processed by the API in a short time to handle sudden bursts of traffic. It does not queue requests but rejects any request that exceeds the allowed burst rate.
Rate Limiting Policy: Sets a limit on the number of requests that an API can handle within a given timeframe. Once the limit is reached, additional requests are rejected.
Evaluating the Options:
Option A: Incorrect. In both Spike Control and Rate Limiting policies, requests are rejected once the limit is reached. Spike Control does not queue requests; it only controls the burst rate by rejecting excessive requests.
Option B (Correct Answer): In a clustered environment, each node independently enforces the Rate Limiting and Spike Control policies, meaning that the limits apply to each node separately. This ensures that each node can control its own resource usage independently within the cluster.
Option C: This is partially correct, as Rate Limiting is often used to protect Experience APIs, but Spike Control could also be useful in limiting resource consumption under high burst conditions.
Option D: Incorrect. Although a contract is required to enforce client-specific policies, Rate Limiting and Spike Control do not require a contract to function for general traffic control.
Conclusion:
Option B is the correct answer because, in a clustered environment, Rate Limiting and Spike Control policies apply separately to each node, helping each instance to manage its own load.
For more information, refer to MuleSoft's documentation on applying Rate Limiting and Spike Control policies in a clustered environment.
NEW QUESTION # 84
A new upstream API Is being designed to offer an SLA of 500 ms median and 800 ms maximum (99th percentile) response time. The corresponding API implementation needs to sequentially invoke 3 downstream APIs of very similar complexity.
The first of these downstream APIs offers the following SLA for its response time: median: 100 ms, 80th percentile: 500 ms, 95th percentile: 1000 ms.
If possible, how can a timeout be set in the upstream API for the invocation of the first downstream API to meet the new upstream API's desired SLA?
  • A. Do not set a timeout; the Invocation of this API Is mandatory and so we must wait until it responds
  • B. Set a timeout of 100 ms; that leaves 400 ms for the other two downstream APIs to complete
  • C. Set a timeout of 50 ms; this times out more invocations of that API but gives additional room for retries
  • D. No timeout is possible to meet the upstream API's desired SLA; a different SLA must be negotiated with the first downstream API or invoke an alternative API
Correct Answe r: Set a timeout of 100ms; that leaves 400ms for other two downstream APIs to complete
Key details to take from the given scenario:
>> Upstream API's designed SLA is 500ms (median). Lets ignore maximum SLA response times.
>> This API calls 3 downstream APIs sequentially and all these are of similar complexity.
>> The first downstream API is offering median SLA of 100ms, 80th percentile: 500ms; 95th percentile: 1000ms.
Based on the above details:
>> We can rule out the option which is suggesting to set 50ms timeout. Because, if the median SLA itself being offered is 100ms then most of the calls are going to timeout and time gets wasted in retried them and eventually gets exhausted with all retries. Even if some retries gets successful, the remaining time wont leave enough room for 2nd and 3rd downstream APIs to respond within time.
>> The option suggesting to NOT set a timeout as the invocation of this API is mandatory and so we must wait until it responds is silly. As not setting time out would go against the good implementation pattern and moreover if the first API is not responding within its offered median SLA 100ms then most probably it would either respond in 500ms (80th percentile) or 1000ms (95th percentile). In BOTH cases, getting a successful response from 1st downstream API does NO GOOD because already by this time the Upstream API SLA of 500 ms is breached. There is no time left to call 2nd and 3rd downstream APIs.
>> It is NOT true that no timeout is possible to meet the upstream APIs desired SLA.
As 1st downstream API is offering its median SLA of 100ms, it means MOST of the time we would get the responses within that time. So, setting a timeout of 100ms would be ideal for MOST calls as it leaves enough room of 400ms for remaining 2 downstream API calls.
NEW QUESTION # 85
An organization uses one specific CloudHub (AWS) region for all CloudHub deployments.
How are CloudHub workers assigned to availability zones (AZs) when the organization's Mule applications are deployed to CloudHub in that region?
  • A. AZs are selected as part of the Mule application's deployment configuration
  • B. Workers are randomly distributed across available AZs within that region
  • C. An AZ is randomly selected for a Mule application, and all the Mule application's CloudHub workers are assigned to that one AZ
  • D. Workers belonging to a given environment are assigned to the same AZ within that region
Correct Answe r: Workers are randomly distributed across available AZs within that region.
>> Currently, we only have control to choose which AWS Region to choose but there is no control at all using any configurations or deployment options to decide what Availability Zone (AZ) to assign to what worker.
>> There are NO fixed or implicit rules on platform too w.r.t assignment of AZ to workers based on environment or application.
>> They are completely assigned in random. However, cloudhub definitely ensures that HA is achieved by assigning the workers to more than on AZ so that all workers are not assigned to same AZ for same application.
Bottom of Form
Top of Form
NEW QUESTION # 86
A circuit breaker strategy is planned in order to meet the goal of improved response time and demand on a downstream API.
* Circuit Open: More than 10 errors per minute for three minutes
* Circuit Half-Open: One error per minute
* Circuit Closed: Less than one error per minute for five minutes
Out of several proposals from the engineering team, which option will meet this goal?
  • A. Create a custom policy that implements the circuit breaker and includes policy template expressions for the required settings
  • B. Create Anypoint Monitoring alerts for Circuit Open/Closed configurations, and then implement a retry strategy for Circuit Half-Open configuration
  • C. Add the Circuit Breaker policy to the API instance, and configure the required settings
  • D. Implement the strategy in a Mule application, and provide the settings in the YAML configuration
Understanding Circuit Breaker Policy:
A circuit breaker is a design pattern used to detect failures and prevent an application from continually trying to execute a failing operation. In this case, it will help improve response time and reduce demand on the downstream API.
The specified configuration includes conditions for opening, half-opening, and closing the circuit based on error rates over time:
Circuit Open: Triggered if there are more than 10 errors per minute for three consecutive minutes.
Circuit Half-Open: The circuit transitions to half-open if there is one error per minute.
Circuit Closed: The circuit closes if the error rate is less than one error per minute for five minutes.
Option A: Creating a custom policy with template expressions could work, but it would require custom development. Since the Anypoint Platform already has a Circuit Breaker policy available, this would be a less efficient and more complex solution.
Option B: Anypoint Monitoring alerts can be used for monitoring the API, but they do not provide circuit-breaking functionality. Additionally, implementing a retry strategy for the half-open state is not sufficient to achieve the required circuit breaker behavior.
Option C (Correct Answer): Adding the Circuit Breaker policy to the API instance on Anypoint Platform allows you to set up circuit-breaking conditions directly. This approach uses the built-in Circuit Breaker policy, where you can configure parameters such as error thresholds and time intervals to match the requirements. This solution is efficient, reliable, and leverages Anypoint's out-of-the-box capabilities.
Option D: Implementing the strategy within a Mule application with a YAML configuration could be complex and less manageable. Additionally, it does not leverage Anypoint Platform's built-in Circuit Breaker policy, which is more suited to this scenario.
Conclusion:
Option C is the correct choice, as it leverages Anypoint Platform's Circuit Breaker policy. This solution allows for configuring thresholds and time intervals as specified, improving response time and reducing demand on the downstream API while utilizing Anypoint's managed policy feature.
Refer to MuleSoft's documentation on implementing the Circuit Breaker policy in API Manager for detailed configuration guidance.
NEW QUESTION # 87
A large organization with an experienced central IT department is getting started using MuleSoft. There is a project to connect a siloed back-end system to a new Customer Relationship Management (CRM) system. The Center for Enablement is coaching them to use API-led connectivity.
What action would support the creation of an application network using API-led connectivity?
  • A. To expedite this project, central IT should extend the CRM system and back-end systems to connect to one another using built in integration interfaces
  • B. Create a System API to unlock the data on the back-end system using a REST API
  • C. Determine if the new CRM system supports the creation of custom: REST APIs, establishes 4 private network with CloudHub, and supports GAuth 2.0 authentication
  • D. Invite the business analyst to create a business process model to specify the canonical data model between the two systems
For an organization starting with API-led connectivity to integrate a siloed back-end system with a new CRM, the following approach aligns with best practices and MuleSoft's Center for Enablement (C4E) guidance:
API-led Connectivity: This model organizes APIs into distinct layers (System, Process, and Experience) to improve reusability, modularity, and manageability.
System APIs are used to expose and unlock data from core systems (such as back-end applications or databases).
Process APIs orchestrate data across multiple systems and transform it as needed.
Experience APIs format the data specifically for consumption by applications or devices, such as the CRM in this case.
Step to Support Application Network:
Create a System API for the back-end system. This API should expose the necessary data to support integration with the CRM.
By creating a System API with a RESTful interface, data can be accessed in a standardized way, making it easier to integrate with other systems and supporting future scalability.
Why Option D is Correct:
Creating a System API aligns with the principle of API-led connectivity, ensuring that data is exposed in a reusable manner. This API can then be orchestrated by Process APIs as needed to meet CRM requirements and can easily be extended to other applications.
of Incorrect Options:
Option A (creating a business process model) does not directly enable connectivity or expose back-end data through APIs.
Option B is unnecessary at this stage; assessing CRM capabilities like OAuth 2.0 support is not directly related to creating the application network via System APIs.
Option C contradicts API-led best practices by suggesting a point-to-point integration, which API-led connectivity seeks to avoid due to its lack of flexibility and scalability.
Reference
Refer to MuleSoft's API-led Connectivity resources for a detailed framework on building scalable integration layers using System, Process, and Experience APIs.
NEW QUESTION # 88
The field of Salesforce is growing rapidly and you need the Salesforce Mule-Arch-201 certification to advance your career in it. But clearing the Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) test is not an easy task. Applicants often don't have enough time to study for the Mule-Arch-201 Exam. They are in desperate need of real Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) exam questions which can help them prepare for the Salesforce Certified MuleSoft Platform Architect (Mule-Arch-201) test successfully in a short time.
Mule-Arch-201 Latest Braindumps Sheet: https://www.dumpexam.com/Mule-Arch-201-valid-torrent.html
Salesforce Original Mule-Arch-201 Questions Supportive for online and offline use for APP version, Salesforce Original Mule-Arch-201 Questions No matter how successful you are at present, it is really necessary for you to build on past success and open up new horizon for new progress, For the trial versions are the free demos which are a small of the Mule-Arch-201 exam questions, they are totally free for our customers to download, So your chance of getting success will be increased greatly by our Mule-Arch-201 exam questions!
While most likely not, at this time our sole focus was not to end up on the front Mule-Arch-201 page of the Wall Street Journal and live to play another day, Carlberg has become a world-class guide for Excel users wanting to do quantitative analysis.
Major Formats of Salesforce Mule-Arch-201 Exam QuestionsSupportive for online and offline use for APP version, No matter how Exam Topics Mule-Arch-201 Pdf successful you are at present, it is really necessary for you to build on past success and open up new horizon for new progress.
For the trial versions are the free demos which are a small of the Mule-Arch-201 Exam Questions, they are totally free for our customers to download, So your chance of getting success will be increased greatly by our Mule-Arch-201 exam questions!
The Mule-Arch-201 exam was updated on 2 January, 2021to meet the requirements of the fast-evolving industry.
