{2026} Salesforce Plat-Dev-301 Dumps - A Direction Toward Certain Success
59
Posted at 2/2/2026 00:46:25      View150 | Replies1        Print      Only Author   [Copy Link] 1#
In this age of the Internet, do you worry about receiving harassment of spam messages after you purchase a product, or discover that your product purchases or personal information are illegally used by other businesses? Please do not worry; we will always put the interests of customers in the first place, so Plat-Dev-301 study materials ensure that your information will not be leaked to any third party. After you pass the exam, if you want to cancel your account, contact us by email and we will delete all your relevant information. Second, the purchase process of Plat-Dev-301 Study Materials is very safe and transactions are conducted through the most reliable guarantee platform. Last but not least, our website platform has no viruses and you can download Plat-Dev-301 study materials at ease. If you encounter difficulties in installation or use of Plat-Dev-301 study materials, we will provide you with remote assistance from a dedicated expert.
The Salesforce Certified Platform Developer II - Multiple Choice certification exam is one of the top-rated career advancement certification exams. The Salesforce Plat-Dev-301 certification exam can play a significant role in career success. With the Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) certification, you can gain several benefits such as validation of skills, career advancement, competitive advantage, continuing education, and global recognition of your skills and knowledge.
Accurate Reliable Plat-Dev-301 Cram Materials | Trustable Plat-Dev-301 Guide and Fast Download Test Salesforce Certified Platform Developer II - Multiple Choice RegistrationWith all the questons and answers of our Salesforce Plat-Dev-301 study materials, your success is guaranteed. Moreover, we have Demos as freebies. The free demos give you a prove-evident and educated guess about the content of our Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 Practice Questions. As long as you make up your mind on this Plat-Dev-301 exam, you can realize their profession is unquestionable.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q21-Q26):NEW QUESTION # 21
Exhibit.
Given the code above, which two changes need to be made in the Apex Controller for the code to work? Choose 2 answers
  • A. Remove line 06 from the Apex Controller and instead use firstName in the return on line 07.
  • B. Annotate the entire class as @AuraEnabled instead of just the single method.
  • C. Change the argument in the Apex Controller line 05 from subject to string.
  • D. Change the method signature to be global static, not public to String.
Based on the code provided, here are the necessary changes:
Change B is required because the argument in the Apex controller's serverEcho method must match the data type expected by the JavaScript calling the method. The Apex method expects an Object named firstName, which is then cast to a String inside the method. The JavaScript is passing an object with a property firstName, so no change is needed in the JavaScript.
Change D is correct because line 06 is redundant and unnecessary. We can directly use firstName in the return statement as it is already a String type. The get() method is typically used when you have a Map and you need to retrieve a value by its key. Since firstName is already being passed as a String, there's no need to cast it or retrieve it using get().
Apex Developer Guide
NEW QUESTION # 22
Refer to the Aura component below:
A developer receives complaints that the component loads slowly. Which change can the developer implement to make the component perform faster?
  • A. Move the contents of <c: contactInfo into the componant.
  • B. Change the type of contactInfo to "Map".
  • C. Change the default for showContactInfo to "False.
  • D. Add a change event handler for showContactInfo.
To improve the performance of an Aura component that is loading slowly, the developer can make the following change:
Lightning Components Performance Best Practices: Improve Performance
D). Change the default for showContactInfo to "False": By setting the default value of showContactInfo to False, the component does not fetch or render the contact information by default, which can reduce the initial load time. The information can be fetched and displayed later based on user action or other triggers.
NEW QUESTION # 23
In an organization that has multi-currency enabled, a developer Is tasked with building a Lighting component that displays the top ten Opportunities most recently accessed by the logged in user. The developer must ensure the Amount and LastModifiedDate field values are displayed according to the user's locale.
What is the most effective approach to ensure values displayed respect the user's locale settings?
  • A. Use REGEX expressions to format the values retrieved via SOQL.
  • B. Use the FOR VIEW clause in the SOQL query.
  • C. Use a wrapper class to format the values retrieved via SOQL.
  • D. Use the FORMAT () function in the SOQL query.
In a multi-currency Salesforce organization, displaying currency amounts according to the user's locale is crucial for ensuring data clarity and relevance. To achieve this, developers can leverage Salesforce's built-in capabilities to format field values directly within SOQL queries. The FORMAT() function is particularly useful as it formats currency fields according to the organization's locale settings. By using this function in a SOQL query, developers can ensure that the Amount and LastModifiedDate fields are displayed correctly. This method is more effective and efficient than post-processing the values in Apex, which would be required if using wrapper classes or REGEX expressions. Additionally, using the FOR VIEW clause in a SOQL query will mark records as recently viewed, which does not format the fields as per the user's locale.
SOQL FORMAT Function
Working with Multi-Currency
NEW QUESTION # 24
What is the best practice to initialize a Vizualforce page in a test class?
  • A. Use Test. setCurrentPage MyTestPags;
  • B. Use controller. currentPage. setPage (MyTastfage) ;
  • C. Use Test. setCurrentPage (Page. MyTeatPage);
  • D. Use Test. currantPage .getParamatars put (MyTaestPaga) ;
Test.setCurrentPage(Page.MyTestPage) is used to set the context to a Visualforce page in tests, allowing you to simulate a page request in a test method.
NEW QUESTION # 25
Just prior to a new deployment the Salesforce administrator, who configured a new order fulfillment process feature in a developer sandbox, suddenly left the company.
Ag part of the UAT cycle, the users had fully tested all of the changes in the sandbox and signed off on them; making the Order fulfillment feature ready for its go-live in the production environment.
Unfortunately, although a Change Set was started, it was not completed by the former administrator.
A developer is brought in to finish the deployment.
What should the developer do to identify the configuration changes that need to be moved into production?
  • A. Leverage the Setup Audit Trail to review the changes made by the departed Administrator and identify which changes should be added to the Change Set.
  • B. Use the Metadata API and a supported development IDE to push all of the configuration from the sandbox into production to ensure no changes are lost.
  • C. In Salesforce setup, look at the last modified date for every object to determine which should be added to the Change Set.
  • D. Set up Continuous Integration and a Git repository to automatically merge all changes from the sandbox metadata with the production metadata.
To identify the configuration changes made by the former administrator, the developer should leverage the Setup Audit Trail. This allows tracking changes made in the Setup area of Salesforce, showing the date of the change, who made it, and what the change was.
NEW QUESTION # 26
The Plat-Dev-301 exam questions are being offered in three different formats. The names of these formats are Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) desktop practice test software, web-based practice test software, and PDF dumps file. The Salesforce desktop practice test software and web-based practice test software both give you real-time Salesforce Plat-Dev-301 Exam environment for quick and complete exam preparation.
Plat-Dev-301 Guide: https://www.torrentexam.com/Plat-Dev-301-exam-latest-torrent.html
Like others I did not have the time to go through every Salesforce Plat-Dev-301 Guide study guide available, so I just resorted to Test King, Please try Plat-Dev-301 free practice pdf demo we offer you, Whenever you have questions or doubts about Salesforce Developer Plat-Dev-301 perp training and send email to us, we will try our best to reply you in two hours, Salesforce Reliable Plat-Dev-301 Cram Materials Perhaps our research data will give you some help.
He is currently an Instructional Designer Plat-Dev-301 Free Brain Dumps for the graphic design segment on the Learn team at Adobe, Allow Split Footnotes,Like others I did not have the time to go Plat-Dev-301 through every Salesforce study guide available, so I just resorted to Test King.
CorpName} Plat-Dev-301 Exam Practice Material in Three FormatsPlease try Plat-Dev-301 free practice pdf demo we offer you, Whenever you have questions or doubts about Salesforce Developer Plat-Dev-301 perp training and send email to us, we will try our best to reply you in two hours.
Perhaps our research data will give you some help, Here we would like to introduce our Plat-Dev-301 practice materials for you with our heartfelt sincerity.
Posted at 2/10/2026 14:27:40        Only Author  2#
Thank you for the article; it really piqued my interest. Hope I perform well in the Latest C_ARCIG_2508 practice materials exam C wish me luck!
