NCP-AI Reliable Exam Preparation - New NCP-AI Exam Pdf
95
Posted at 2/2/2026 02:21:47      View:100 | Replies:2        Print      Only Author   [Copy Link] 1#
Our ActualPDF provides the latest and the most complete NCP-AI exam questions and answers aimed at becoming the most reliable dumps provider in IT exam software. With the help of our ActualPDF, nearly all those who have purchased our dumps have successfully passed the difficult NCP-AI Exam, which gives us great confidence to recommend our reliable products to you. We can assure you that we will fully refund the cost you purchased our dump, if you fail NCP-AI exam with our dumps. So, just rest assured to prepare for your exam.
Nutanix NCP-AI Exam Syllabus Topics:
  • Perform Day 2 Operations: This domain addresses ongoing management including preparing application integration requirements, interpreting and optimizing performance metrics, monitoring access for anomalies, and selecting appropriate LLMs for optimal output.
  • Configure a Nutanix Enterprise AI Environment: This domain focuses on operational setup including onboarding users, importing large language models, creating and securing API endpoints with keys, and delivering these endpoints to consumers.
  • Deploy a Nutanix Enterprise AI Environment: This domain covers initial deployment tasks including validating prerequisites, installing Enterprise AI components, and configuring DNS, URLs, and certificates for secure platform operation.
  • Connect Applications to a Nutanix Enterprise AI Environment: This domain focuses on configuring and validating application connections to endpoints and monitoring endpoint metrics to track application usage and integration performance.
Topic 5
  • Troubleshoot a Nutanix Enterprise AI Environment: This domain covers diagnosing and resolving performance issues, resource utilization problems, cluster health check failures, and model import or endpoint creation errors.
NCP-AI Study Questions are Most Powerful Weapon to Help You Pass the Nutanix Certified Professional - Artificial Intelligence v6.10 exam - ActualPDFIf you are preparing for the practice exam, we can make sure that the NCP-AI test practice files from our company will be the best choice for you, and you cannot find the better study materials than our company'. There are a lot of advantages of our NCP-AI preparation materials, and you can free download the demo of our NCP-AI training guide to know the special functions of our NCP-AI prep guide in detail. And you will know the quality of our NCP-AI study prep as well. We are hopeful that you will like our NCP-AI exam questions.
Nutanix Certified Professional - Artificial Intelligence v6.10 Sample Questions (Q15-Q20):NEW QUESTION # 15
An administrator is integrating an application with an endpoint and finds that the application is experiencing high latency.
What action should the administrator take to ensure the lowest latency when creating endpoints?
  • A. Reduce the payload size limit.
  • B. Increase the timeout value on the endpoints.
  • C. Increase the number of endpoint instances.
  • D. Increase the cache expiration time.
NEW QUESTION # 16
An administrator is managing a Nutanix AI cluster used for NLP (Natural Language Processing) training. A data scientist reports that training jobs intermittently stall and fail to complete within the expected time window. The administrator reviews the performance data for the VM hosting the job and finds:
The VM is configured with passthrough access to a dedicated GPU
Memory ballooning is active, and swap usage is increasing
CPU utilization is moderate (~60%)
GPU utilization is stable and high (~85%)
The VM has 8 vCPUs and 24 GB of RAM assigned
NCC shows no hardware or driver issues
What is the most appropriate optimization to improve workload stability and performance?
  • A. Add additional vGPUs to the VM to reduce processing time.
  • B. Disable GPU passthrough and use a shared vGPU profile insteaD.
  • C. Increase the VM's RAM to eliminate memory ballooning and swap usage.
  • D. Reduce the number of vCPUs allocated to lower the CPU scheduling overheaD.
NEW QUESTION # 17
An administrator has been asked to install Nutanix Enterprise AI and is defining the NFS storage class for storing models.
What type of access mode needs to be defined?
  • A. ReadWriteOncePod (RWOP)
  • B. ReadOnlyMany (ROX)
  • C. ReadWriteOnce (RWO)
  • D. ReadWriteMany (RWX)
NEW QUESTION # 18
An administrator is configuring a new endpoint in Nutanix Enterprise AI (NAI) using an NVIDIA NIM model. During the configuration, the administrator notices that the Use GPU checkbox is selected and cannot be modifieD.
What is the reason the checkbox is locked in this state?
  • A. These models require GPU resources to run.
  • B. System has already validated the endpoint configuration.
  • C. Setting is locked due to a cluster-level policy restriction.
  • D. All endpoints in NAI require using GPUs.
NEW QUESTION # 19
An administrator is deploying a customer support chatbot that needs to integrate with a large language model hosted in the Nutanix Enterprise AI platform. The goal is to enable real-time inference while following best practices for security and scalability.
Which action should the administrator perform to meet these requirements?
  • A. Configure a firewall exception using Nutanix Flow and force restricted access from the chatbot subnet to the AI model.
  • B. Create an API endpoint in the NAI Dashboard and generate an API key to assign to the endpoint for secure access.
  • C. Enable access to the model through SSH and use raw socket communication between the chatbot and model service.
  • D. Register the chatbot application in Prism Central and map it to the deployed model through application profiles.
NEW QUESTION # 20
In order to make your exam easier for every candidate, our NCP-AI exam prep is capable of making you test history and review performance, and then you can find your obstacles and overcome them. In addition, once you have used this type of NCP-AI exam question online for one time, next time you can practice in an offline environment. The NCP-AI test torrent also offer a variety of learning modes for users to choose from, which can be used for multiple clients of computers and mobile phones to study online, as well as to print and print data for offline consolidation. Therefore, for your convenience, more choices are provided for you, we are pleased to suggest you to choose our NCP-AI Exam Question for your exam.
New NCP-AI Exam Pdf: https://www.actualpdf.com/NCP-AI_exam-dumps.html
Posted at 2/16/2026 06:50:18        Only Author  2#
This article is so powerful, thank you for the inspiration! The Sustainable-Investing certification test answers exam questions are free—your key to a brighter career and higher salary!
Posted at 2/20/2026 16:58:46        Only Author  3#
This article is a gem, thank you for sharing it with us! I’m heading into the Valid test Arch-303 questions answers exam soon. Wish me success!
