1z1-076 Certificate Exam & Latest 1z1-076 Material
Posted at 2/2/2026 02:42:04
View176
Replies2
BONUS!!! Download part of TestSimulate 1z1-076 dumps for free: https://drive.google.com/open?id=14nRbiM9dWqVc9Q1mOnwBeL2BGb3yrXd3
The Channel Partner Program Oracle Database 19c: Data Guard Administration 1z1-076 certification enables you to move ahead in your career later. With the Oracle 1z1-076 certification exam you can climb up the corporate ladder faster and achieve your professional career objectives. Do you plan to enroll in the Oracle Database 19c: Data Guard Administration 1z1-076 Certification Exam? Looking for a simple and quick way to crack the Oracle 1z1-076 test?
Oracle 1z1-076 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
| | Topic 3 | - Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
| | Topic 4 | - Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
| | Topic 5 | - Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
| | Topic 6 | - Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
| | Topic 7 | - Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
| | Topic 8 | - Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
| | Topic 9 | - Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
| | Topic 11 | - Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
| | Topic 12 | - Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
TestSimulate Oracle 1z1-076 exam practice questions and answersThe Oracle Database 19c: Data Guard Administration (1z1-076) certification is one of the hottest career advancement credentials in the modern Oracle world. The Oracle Database 19c: Data Guard Administration (1z1-076) certification can help you to demonstrate your expertise and knowledge level. With only one badge of Oracle Database 19c: Data Guard Administration in 1z1-076 Certification, successful candidates can advance their careers and increase their earning potential.
Oracle Database 19c: Data Guard Administration Sample Questions (Q52-Q57):NEW QUESTION # 52
Which TWO are TRUE about offloading backups to a physical standby database in a Data Guard environment?
- A. The standby database can not be registered in an RMAN catalog if the primary database has not been registered.
- B. The standby database must be registered in an RMAN catalog after the primary database has been registered.
- C. The standby database must be registered in an RMAN catalog before the primary database has been registered.
- D. Backups of the standby control file taken while connected to the catalog where the database is registered, may be used to restore the control file on the primary database.
In a Data Guard environment, offloading backups to a physical standby database has certain requirements:
A: Once the primary database is registered in an RMAN catalog, the standby database can also be registered. This allows RMAN to manage backups coherently across both databases and leverage the standby database for backup purposes without interfering with the primary database's workload.
C: Backups of the standby control file taken while connected to the catalog where the database is registered can be used to restore the control file on the primary database. This ensures that backup metadata is consistent across the Data Guard configuration.
Options B and D are incorrect because there is no strict requirement for the order in which the primary and standby databases must be registered in an RMAN catalog. However, it is a common practice to register the primary database first.
NEW QUESTION # 53
A customer asks for your recommendation regarding this requirement:
1. We plan to have a Data Guard Configuration with one primary database and one physical standby database.
2. We want zero data loss in case of a disaster involving the loss of one component.
3. We want to do Real Application Testing occasionally on the Standby Database.
Which solution, if any, satisfies these requirements?
- A. These requirements cannot be met.
- B. A far sync instance plus a snapshot standby database and real time apply that can be converted regularly into logical standby database to do real application testing
- C. A physical standby database with synchronous redo transport that can be converted regularly into a snapshot standby to do real application testing
- D. A snapshot standby database with real time query that can be converted regularly into a physical standby database open read write, to do real application testing
Synchronous redo transport for zero data loss (B): To guarantee zero data loss in the case of a disaster, synchronous redo transport must be configured between the primary and standby databases.
Conversion to snapshot standby for testing (B): A physical standby database can be temporarily converted into a snapshot standby database to perform real application testing. After testing is completed, the snapshot standby can be converted back to a physical standby to resume its disaster recovery role.
Oracle Data Guard Concepts and Administration Guide
Oracle Database Testing Guide
NEW QUESTION # 54
You must configure an Oracle Data..........
1. A primary database
2. A physical standby database
Examine these requirements: 1. Data loss is not permitted.
2. It should be possible to convert the physical standby database to a snapshot standby database.
3. Under normal operations, transactions should commit when redo is written to disk on the primary database and as soon as it has been received by the standby database instance.
4. The availability of the primary database should not be compromised by the availability of the standby database.
5. It should be possible to convert the physical standby database to a logical standby database
6. It should be possible to deploy Real Application Clusters on the primary database.
7. It should be possible to deploy Real Application Clusters on the physical standby database.
You configure SYNC redo transport mode in combination with Maximum Protection mode.
- A. 1, 2, 6, and 7
- B. 1, 2, 3, 6, and 7
- C. 1, 2, 3, 4, 5, 6, and 7
- D. 1, 2, and 5
- E. 1, 6, and 7
When SYNC redo transport mode is combined with Maximum Protection mode, it ensures that no data loss will occur (requirement 1). The physical standby can be converted to a snapshot standby (requirement 2) and later to a logical standby database (requirement 5), satisfying both transformation requirements. Transactions commit as soon as redo data is received by the standby database (requirement 3). The availability of the primary is not dependent on the standby database in Maximum Protection mode, as the primary database will halt if the standby cannot acknowledge the redo (requirement 4), thus indirectly ensuring its availability. It is also possible to deploy Real Application Clusters on both the primary (requirement 6) and the physical standby database (requirement 7), providing high availability and scalability.
ReferencesOracle Data Guard documentation detailing the requirements for different database roles, protection modes, and redo transport modes, as well as the capabilities and limitations of each configuration.
NEW QUESTION # 55
Examine the fast-start failover configuration:
- A. The observer will initiate a failover when the primary database is unable to produce local archived redo log files.
- B. A failover may occur if the observer has lost connectivity to the primary database, even if the Fast-Start Failover target standby database has a good connection to the primary database
- C. If South_Sales develops a problem and cannot be the target of a failover, the broker automatically changes the fast-start failover target to one of the other candidate targets.
- D. You must disable fast-start failover first to change the fast-start failover target to East sales.
- E. The observer is running.
Answer: A,B,E
NEW QUESTION # 56
Which TWO statements are true about database parameters for databases in a Data Guard environment?
- A. LOG_FILE_NAME_CONVERT applies to online redo logs and archived logs.
- B. The databases that are part of a Data Guard configuration must have different DB_UNIQUE_NAME initialization parameters.
- C. DB_FILE_NAME_CONVERT is only required if the standby database is on the same host as the primary database.
- D. If DB_RECOVERY_FILE_DEST is specified, then LOG_ARCHIVE_DEST_n is not required for local archive logs.
- E. COMPATIBLE must have identical values for primary and standby databases.
Answer: B,E
NEW QUESTION # 57
We cannot predicate the future but we can live in the moment. There are many meaningful things waiting for us to do. Try to immerse yourself in new experience. Once you get the Oracle 1z1-076 certificate, your life will change greatly. First of all, you will grow into a comprehensive talent under the guidance of our Oracle Database 19c: Data Guard Administration 1z1-076 Exam Materials, which is very popular in the job market.
Latest 1z1-076 Material: https://www.testsimulate.com/1z1-076-study-materials.html
- 2026 1z1-076 Certificate Exam | Valid Oracle 1z1-076: Oracle Database 19c: Data Guard Administration 100% Pass 🐄 Search for ➥ 1z1-076 🡄 and obtain a free download on ⮆ [url]www.examcollectionpass.com ⮄ 🎪1z1-076 Latest Exam Camp[/url]
- VCE 1z1-076 Exam Simulator 🚻 Reliable 1z1-076 Exam Cost 🍼 1z1-076 Latest Exam Camp 🦈 Search for ➡ 1z1-076 ️⬅️ and download it for free immediately on ➠ [url]www.pdfvce.com 🠰 🏬Test 1z1-076 Lab Questions[/url]
- Valid Braindumps 1z1-076 Ppt ⛲ Exam 1z1-076 Passing Score 📐 Latest 1z1-076 Mock Exam 😢 Open [url]www.practicevce.com enter { 1z1-076 } and obtain a free download 👶Valid Dumps 1z1-076 Free[/url]
- Oracle Database 19c: Data Guard Administration latest study torrent - Oracle Database 19c: Data Guard Administration reliable vce pdf - Oracle Database 19c: Data Guard Administration valid training dumps ⏯ Easily obtain ▶ 1z1-076 ◀ for free download through ➡ [url]www.pdfvce.com ️⬅️ 🍎New Exam 1z1-076 Braindumps[/url]
- Latest 1z1-076 Practice Questions 🦠 1z1-076 Real Dumps Free 🏋 VCE 1z1-076 Exam Simulator 📒 Easily obtain free download of ✔ 1z1-076 ️✔️ by searching on { [url]www.prep4away.com } 🥐Exam 1z1-076 Lab Questions[/url]
- Updated and Error-free Oracle 1z1-076 Exam Practice Test Questions 🛹 [url]www.pdfvce.com is best website to obtain ✔ 1z1-076 ️✔️ for free download 🚌1z1-076 Reliable Exam Materials[/url]
- 1z1-076 New Test Materials 🛫 Exam 1z1-076 Passing Score 🕔 Exam 1z1-076 Lab Questions 🧫 Download ➡ 1z1-076 ️⬅️ for free by simply entering { [url]www.dumpsquestion.com } website ⚡1z1-076 Real Dumps Free[/url]
- Free PDF 2026 Pass-Sure 1z1-076: Oracle Database 19c: Data Guard Administration Certificate Exam 🍾 Easily obtain free download of 1z1-076 by searching on [url]www.pdfvce.com 🎏Reliable 1z1-076 Test Syllabus[/url]
- Valid Dumps 1z1-076 Free 🐙 1z1-076 New Test Materials 🧹 1z1-076 Real Dumps Free 💛 Copy URL [url]www.vceengine.com open and search for 1z1-076 to download for free ⚓1z1-076 Exam Questions Vce[/url]
- Reliable 1z1-076 Exam Cost 🍷 Latest 1z1-076 Practice Questions 👓 1z1-076 Lead2pass Review 🍷 [url]www.pdfvce.com is best website to obtain 1z1-076 for free download 🌤1z1-076 Latest Exam Camp[/url]
- Reliable 1z1-076 Exam Cost 🐐 Valid Dumps 1z1-076 Free 🚍 1z1-076 Exam Questions Vce 🌗 Search for ⏩ 1z1-076 ⏪ and download exam materials for free through ➠ [url]www.easy4engine.com 🠰 😏New Exam 1z1-076 Braindumps[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, ycs.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
