C_ARCON_2508최고덤프인기시험3
Posted at 2/2/2026 03:26:09
View156
Replies2
BONUS!!! Pass4Test C_ARCON_2508 시험 문제집 전체 버전을 무료로 다운로드하세요: https://drive.google.com/open?id=1ypBQ6pLweoGUgaiNsMElfPQUPU7eQcke
Pass4Test의SAP C_ARCON_2508 덤프 구매 후 등록된 사용자가 구매일로부터 일년 이내에SAP C_ARCON_2508시험에 실패하셨다면 Pass4Test메일에 주문번호와 불합격성적표를 보내오셔서 환불신청하실수 있습니다.구매일자 이전에 발생한 시험불합격은 환불보상의 대상이 아닙니다. 개별 인증사는 불합격성적표를 발급하지 않기에 재시험신청내역을 환불증명으로 제출하시면 됩니다.
SAP C_ARCON_2508 시험요강:| 주제 | 소개 | | 주제 1 | - Suppliers and Users: This section of the exam measures skills of Supplier Relationship Managers and covers managing supplier and user access within SAP Ariba Contracts. It includes user role configuration, permissions, supplier onboarding, and maintaining compliance with supplier management policies.
| | 주제 2 | - Contract Requests and Contract Workspaces: This section of the exam measures skills of Contract Administrators and focuses on managing contract requests and workspaces in SAP Ariba. It includes creating, processing, and managing contract requests, setting up collaborative workspaces, tracking progress, and maintaining version control for contract documents.
| | 주제 3 | - Best Practices: This section of the exam measures skills of SAP Solution Architects and focuses on the application of SAP-recommended best practices in Ariba Contracts. It includes implementing standardized workflows, templates, and governance strategies to ensure efficient contract and procurement operations.
| | 주제 4 | - SAP Ariba Contracts Configuration: This section of the exam measures skills of SAP Configuration Analysts and covers setting up and managing SAP Ariba Contracts functionality. It focuses on configuring system parameters, defining contract types, templates, approval workflows, and managing compliance rules for contract lifecycle processes.
| | 주제 5 | - Contract Authoring: This section of the exam measures skills of Contract Managers and covers the processes related to creating and managing contracts within SAP Ariba. It includes authoring contract documents, managing clauses and templates, collaborating with stakeholders, and ensuring consistency and compliance across all contract types.
| | 주제 6 | - Procurement Knowledge: This section of the exam measures skills of Procurement Specialists and focuses on understanding procurement processes and their alignment with SAP Ariba. It covers the end-to-end procurement lifecycle, contract management principles, and how procurement operations integrate with broader business goals.
| | 주제 7 | - Search and Reporting: This section of the exam measures skills of Business Analysts and focuses on using SAP Ariba search and reporting capabilities. It includes searching contract data, generating standard and custom reports, and leveraging analytics to monitor performance and compliance.
SAP C_ARCON_2508최신덤프자료 - C_ARCON_2508최신 업데이트 시험덤프최근 IT 업종에 종사하는 분들이 점점 늘어가는 추세하에 경쟁이 점점 치열해지고 있습니다. IT인증시험은 국제에서 인정받는 효력있는 자격증을 취득하는 과정으로서 널리 알려져 있습니다. Pass4Test의 SAP인증 C_ARCON_2508덤프는IT인증시험의 한 과목인 SAP인증 C_ARCON_2508시험에 대비하여 만들어진 시험전 공부자료인데 높은 시험적중율과 친근한 가격으로 많은 사랑을 받고 있습니다.
최신 SAP Certified Associate C_ARCON_2508 무료샘플문제 (Q35-Q40):질문 # 35
Which conditions have to be met for a user to copy an existing contract workspace? Note: There are 2 correct answers to this question.
- A. The user must have the system permission to create contract workspaces.
- B. The Access Control settings of the existing contract workspace must allow the user access to the contract workspace.
- C. The template configuration must allow for the contract workspace to be copied.
- D. The new contract workspace must have the same expiration date as the copied one.
정답A,C
질문 # 36
When will templates and contract workspaces that use the clause be updated with the new language?Note:
There are 2 correctanswers to this question.
- A. Contract workspaces in draft status will have the updated language immediately.
- B. Newly-created contract workspaces will have the updated language once all required tasks are completed.
- C. Contract workspaces in draft will have the updated language only if you substitute or add the updated clause.
- D. Newly-created contract workspaces will have the updated language immediately.
정답C,D
질문 # 37
Which of the following sources can provide line items to use in a Contract Line Items document? Note: There are 2 correct answers to this question.
- A. Clause library
- B. Contract repository
- C. Sourcing library
- D. Sourcing event
정답B,D
질문 # 38
Which actions can contract owners perform on clauses from the Outline View of a Main Agreement? Note:
There are 3 correctanswers to this question.
- A. Promote a clause
- B. Substitute a clause
- C. View versions of a clause
- D. Check other contract workspaces where the clause was used
- E. Edit a clause
정답A,B,C
설명
Solution:
The three correct actions that contract owners can perform on clauses from the Outline View of a Main Agreement are:
*A. Promote a clause SAP Help Portal+1
*C. Substitute a clause SAP Learning+2SAP Learning+2
*D. View versions of a clause SAP Learning+1
질문 # 39
You must update a template that is currently Active and being used.What is the recommended procedure to ensure users can continue to create projects using the template while it is being updated?
- A. In the existing template, create a new version and set an expiration date in the future. Create the new template and pt the same day.
- B. Export the existing template. Make changes to the XML files within the exported archive. When you reimport the archi automatically be updated.
- C. Export the template and load it into the test site. Make changes on the test site template. When the template is ready to be published, choose "Publish to Production."
- D. In the existing template, select the option to create a new version. When the template is ready to be published, publish the new version
정답D
질문 # 40
Pass4Test에서는 전문SAP C_ARCON_2508인증시험을 겨냥한 덤프 즉 문제와 답을 제공합니다.여러분이 처음SAP C_ARCON_2508인증시험준비라면 아주 좋은 덤프입니다. Pass4Test에서 제공되는 덤프는 모두 실제시험과 아주 유사한 덤프들입니다.SAP C_ARCON_2508인증시험패스는 보장합니다. 만약 떨어지셨다면 우리는 덤프비용전액을 환불해드립니다.
C_ARCON_2508최신덤프자료: https://www.pass4test.net/C_ARCON_2508.html
- C_ARCON_2508참고덤프 ☎ C_ARCON_2508퍼펙트 덤프데모문제 보기 🍍 C_ARCON_2508테스트자료 📸 무료 다운로드를 위해 C_ARCON_2508 를 검색하려면✔ [url]www.koreadumps.com ️✔️을(를) 입력하십시오C_ARCON_2508덤프공부[/url]
- 시험패스에 유효한 C_ARCON_2508최고덤프 덤프문제보기 💚 무료로 다운로드하려면▶ [url]www.itdumpskr.com ◀로 이동하여✔ C_ARCON_2508 ️✔️를 검색하십시오C_ARCON_2508 100시험패스 공부자료[/url]
- 최신 C_ARCON_2508최고덤프 덤프샘플문제 다운로드 🎴 검색만 하면☀ kr.fast2test.com ️☀️에서☀ C_ARCON_2508 ️☀️무료 다운로드C_ARCON_2508시험문제
- C_ARCON_2508퍼펙트 최신 덤프공부 🎣 C_ARCON_2508 100시험패스 공부자료 😍 C_ARCON_2508퍼펙트 최신 덤프공부 🔈 무료로 쉽게 다운로드하려면⏩ [url]www.itdumpskr.com ⏪에서⇛ C_ARCON_2508 ⇚를 검색하세요C_ARCON_2508시험대비 최신 덤프문제[/url]
- C_ARCON_2508최고덤프 덤프 최신 업데이트버전 자료 🔖 { C_ARCON_2508 }를 무료로 다운로드하려면[ [url]www.pass4test.net ]웹사이트를 입력하세요C_ARCON_2508시험문제[/url]
- 높은 통과율 C_ARCON_2508최고덤프 인기 시험자료 🔽 무료 다운로드를 위해 지금☀ [url]www.itdumpskr.com ️☀️에서➤ C_ARCON_2508 ⮘검색C_ARCON_2508퍼펙트 덤프데모문제 보기[/url]
- C_ARCON_2508퍼펙트 최신 덤프공부 🏃 C_ARCON_2508최고품질 덤프데모 다운로드 🧚 C_ARCON_2508높은 통과율 덤프샘플문제 👕 ➥ [url]www.koreadumps.com 🡄에서▛ C_ARCON_2508 ▟를 검색하고 무료 다운로드 받기C_ARCON_2508인기자격증 덤프문제[/url]
- C_ARCON_2508높은 통과율 덤프샘플문제 👹 C_ARCON_2508퍼펙트 최신 덤프 🔊 C_ARCON_2508최고덤프샘플 🐲 무료 다운로드를 위해 지금⮆ [url]www.itdumpskr.com ⮄에서➡ C_ARCON_2508 ️⬅️검색C_ARCON_2508퍼펙트 덤프데모문제 보기[/url]
- 높은 통과율 C_ARCON_2508최고덤프 인기 시험자료 👭 ⇛ [url]www.passtip.net ⇚을 통해 쉽게➠ C_ARCON_2508 🠰무료 다운로드 받기C_ARCON_2508시험문제[/url]
- C_ARCON_2508시험대비 최신 덤프문제 😚 C_ARCON_2508최신버전자료 😲 C_ARCON_2508시험문제 🏘 지금➤ [url]www.itdumpskr.com ⮘에서➡ C_ARCON_2508 ️⬅️를 검색하고 무료로 다운로드하세요C_ARCON_2508높은 통과율 덤프샘플문제[/url]
- 높은 통과율 C_ARCON_2508최고덤프 인기 시험자료 🔚 [ [url]www.itdumpskr.com ]을 통해 쉽게 C_ARCON_2508 무료 다운로드 받기C_ARCON_2508 100시험패스 공부자료[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
그리고 Pass4Test C_ARCON_2508 시험 문제집의 전체 버전을 클라우드 저장소에서 다운로드할 수 있습니다: https://drive.google.com/open?id=1ypBQ6pLweoGUgaiNsMElfPQUPU7eQcke
