[General] SD-WAN-Engineer Practice Test Pdf, Test SD-WAN-Engineer Free
102
General SD-WAN-Engineer Practice Test Pdf, Test SD-WAN-Engineer Free
Posted at 2/2/2026 03:58:06      View153 | Replies4        Print      Only Author   [Copy Link] 1#
Thanks to modern technology, learning online gives people access to a wider range of knowledge, and people have got used to convenience of electronic equipment. As you can see, we are selling our SD-WAN-Engineer learning guide in the international market, thus there are three different versions of our SD-WAN-Engineer exam materials: PDF, Soft and APP versions. It is worth mentioning that, the simulation test of our SD-WAN-Engineer Study Guide is available in our software version. With the simulation test, all of our customers will get accustomed to the SD-WAN-Engineer exam easily, and pass the exam with confidence.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
Topic 5
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
100% Pass Fantastic Palo Alto Networks - SD-WAN-Engineer - Palo Alto Networks SD-WAN Engineer Practice Test PdfAchieving the Palo Alto Networks SD-WAN-Engineer test certification can open up unlimited possibilities for your future career, if you are truly dedicated to jump out your career and willing to make additional learning and extra income. DumpsReview SD-WAN-Engineer exam dumps can help you to overcome the difficultyfrom understanding the necessary and basic knowledge to passing the Network Security Administrator Palo Alto Networks SD-WAN Engineer exam test. The goal of Palo Alto Networks SD-WAN-Engineer is to help our customers optimize their IT technology by providing convenient, high quality Network Security Administrator exam prep training that they can rely on. Palo Alto Networks SD-WAN-Engineer sure pass exam dumps empower the candidates to master their desired technologies for their own Network Security Administrator exam test.Dear every one, passing the Palo Alto Networks SD-WAN-Engineer actual test is an easy case for you.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q75-Q80):NEW QUESTION # 75
A network administrator is viewing the Flow Browser to investigate a report that a specific user cannot access an internal web server. The flow entry for this traffic shows the "Flow State" as "INIT" and it remains in that state until it times out.
What does the "INIT" state indicate about the traffic flow?
  • A. The TCP 3-way handshake was completed successfully, and data is being transferred.
  • B. The ION device received the SYN packet from the client but never saw a SYN-ACK response from the server.
  • C. The flow was denied by a Zone-Based Firewall policy on the ION.
  • D. The traffic is being buffered while the ION waits for a dynamic VPN tunnel to establish.
Comprehensive and Detailed Explanation
In the Prisma SD-WAN Flow Browser, the Flow State provides a real-time snapshot of the TCP/UDP session lifecycle.
INIT (Initialization): This state indicates that the ION device has seen the initial packet of a new session (typically a TCP SYN) originating from the client (Source), but it has not yet seen a return packet (such as a TCP SYN-ACK) from the destination server.
Diagnosis: A flow stuck in INIT is a classic indicator of a "Blackhole" or reachability issue downstream. It implies that the ION successfully routed the packet out toward the destination, but the destination did not reply. Common causes include:
The server is offline.
A firewall in the path (or on the server itself) is dropping the traffic.
Routing is broken on the return path (asymmetric routing where the return traffic bypasses the ION).
If the flow had been denied by the ION's own firewall (Option C), the state would typically show as DENY or REJECT. If the handshake completed (Option A), the state would be ESTABLISHED. Therefore, INIT points to a lack of response from the remote end.
NEW QUESTION # 76
What is the default behavior of the Zone-Based Firewall (ZBFW) for traffic originating from the ION device itself (e.g., DNS queries, NTP sync, or Controller connectivity) destined for the "Internet" zone?
  • A. It is denied by the default "Deny All" rule unless explicitly allowed.
  • B. It is allowed only if the "Management" interface is used.
  • C. It is inspected by the "Global" security stack but bypasses local rules.
  • D. It is allowed by the implicit "Self-Zone" allow rule.
The Self-Zone is a predefined security zone in the Prisma SD-WAN ZBFW that represents the ION device's own control plane and management traffic.
Default Rule: The security policy contains an implicit, uneditable default rule that Allows traffic originating from the Self-Zone to any destination zone (Internet, Private WAN, etc.).
Rationale: This ensures that the device can always perform essential critical functions-such as connecting to the Cloud Controller, resolving DNS, syncing time via NTP, and establishing VPN tunnels-without the administrator needing to manually create "Allow" rules for the device itself. If this traffic were blocked by a "Deny All" default, the device would become unmanageable (bricked) immediately after applying the policy.
NEW QUESTION # 77
Which IONs can support Branch Gateway?
  • A. 1200, 3200, 9200, 7108V1
  • B. 3104V, 1200S, 5200, 7108V
  • C. 3102V, 3200, 1200S, 5200
  • D. 9200, 3200, 5200, 7116V
In the Prisma SD-WAN ecosystem, ION (Instant-On Network) devices are categorized based on their performance capabilities, throughput, and their specific role within the network architecture-namely, whether they function as a Branch device or a Data Center (DC) device.2 The "Branch Gateway" designation typically refers to high-capacity hardware or virtual instances designed to handle complex routing, massive throughput, and high-density connectivity requirements found in large branch offices or regional hubs.
The devices listed in option D represent the high-performance tier of the ION family. The ION 9200 and ION
5200 are flagship hardware appliances designed for large-scale deployments, offering multi-gigabit throughput and extensive port density.3 The ION 3200 serves as a robust mid-to-high range branch solution.4 The ION 7116V is a high-capacity virtual appliance (part of the 7000 series) designed to provide flexible, software-defined gateway capabilities in virtualized environments or public clouds (like AWS, Azure, or GCP).
Specifically, these models support advanced features such as Layer 3 hardware forwarding, integrated switching (in certain sub-models), and the processing power required to run deep packet inspection (DPI) for application-based path selection at scale. While smaller units like the 1200 series are excellent for small-to- medium branches, the 9200, 3200, 5200, and 7116V are the primary workhorses for organizations requiring
"Gateway" class performance to manage heavy traffic loads and maintain high availability in a Prisma SD- WAN fabric.
NEW QUESTION # 78
Where is route leaking configured between VRFs?
  • A. Site configuration
  • B. VRF profile
  • C. VRF definition
  • D. BGP peer
In the Prisma SD-WAN solution, multi-tenancy and network isolation are achieved through the use of Virtual Routing and Forwarding (VRF) instances. However, there are many operational scenarios-such as providing shared access to a common service (e.g., DNS, NTP) or a central Internet gateway-where traffic must transition between these isolated routing domains. This process is known as route leaking.
In the Prisma SD-WAN management interface, route leaking is specifically configured within the VRF Profile. Unlike traditional CLI-based routers where route leaking might be configured under a global routing table or individual VRF definitions via import/export targets, Prisma SD-WAN utilizes a profile-based approach to ensure scalability and consistency across multiple sites. A VRF Profile acts as a template that defines the routing behavior for specific VRFs across the fabric.
When an administrator navigates to the VRF Profile settings, they can define "Leaking Rules." These rules specify the "From VRF" (source) and "To VRF" (destination) parameters, along with the specific prefixes or default routes that should be shared. By placing this configuration within the VRF Profile rather than a site- specific configuration, Palo Alto Networks allows for a "configure once, apply many" workflow. Once the VRF Profile is updated with the leaking rules, any ION device associated with that profile will automatically update its local routing table to allow the specified inter-VRF communication. This centralized orchestration simplifies the management of complex segmentation requirements in large-scale SD-WAN deployments.
NEW QUESTION # 79
A network engineer is troubleshooting a "Voice Quality" issue. They suspect that the DSCP markings are being stripped or altered by the ISP.
Which tool in the Prisma SD-WAN portal allows the engineer to capture live packets on the WAN interface and inspect the IP header ToS/DSCP field?
  • A. Flow Browser
  • B. Path Quality Monitor
  • C. Packet Capture (PCAP)
  • D. Event Logs
To validate specific packet-level details like DSCP (Differentiated Services Code Point) values, header checksums, or exact payload sizes, a Packet Capture (PCAP) is required.
PCAP Tool: Prisma SD-WAN provides a built-in PCAP utility accessible directly from the portal. The engineer can select the specific Interface (e.g., Internet 1), apply a Filter (e.g., port 5060 or host 1.2.3.4), and capture the traffic.
Analysis: The resulting .pcap file can be downloaded and opened in Wireshark. This allows the engineer to definitively see if the packets leaving the ION have DSCP EF (46) and if the packets arriving (if capturing on the other side) still retain that marking, or if the ISP has bleached it to CS0 (0).
Flow Browser (A): While it shows "Application" and metrics, the Flow Browser typically displays the assigned priority class, not necessarily the raw bit-level DSCP value present in the packet header on the wire.
NEW QUESTION # 80
Among all learning websites providing IT certification SD-WAN-Engineer dumps and training methods, whose SD-WAN-Engineer exam dumps and training materials are the most reliable? Of course, SD-WAN-Engineer exam dumps and certification training questions on DumpsReview site are the most reliable. Our DumpsReview have professional team, certification experts, technician and comprehensive language master, who always research the Latest SD-WAN-Engineer Exam Dumps and update SD-WAN-Engineer certification training material, so you can be fully sure that our SD-WAN-Engineer test training materials can help you pass the SD-WAN-Engineer exam.
Test SD-WAN-Engineer Free: https://www.dumpsreview.com/SD-WAN-Engineer-exam-dumps-review.html
Posted at 2/13/2026 18:45:38        Only Author  2#
Your article is exceptional, thank you for sharing it with us! I used the C_BCWME_2504 certification book torrent to get promoted and enjoy a salary raise. Now its free for everyone. Wishing you all a smooth promotion journey!
Posted at 2/17/2026 09:17:35        Only Author  3#
Thank you for sharing such an impactful article, it deeply impressed me. Boost your IT abilities with free Reliable study XSIAM-Engineer questions. Best wishes for success!
Posted at 2/17/2026 10:33:04        Only Author  4#
This article is truly eye-opening, thank you for sharing. Free Valid Mule-Arch-202 practice questions exam papers for you to download. Best of luck in your exams!
Posted at 3/7/2026 00:03:12        Only Author  5#
Your article really opened my eyes, Im so grateful for it. examcollection 300-725 offers great materials, and they're available to you free of charge.
