JN0-650 Exam Outline & JN0-650 PDF VCE
Posted at 2/2/2026 04:14:31
By doing this you can stay updated and competitive in the market and achieve your career objectives in a short time period. To do this you just need to pass the one Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) exam. Are you ready for this? If yes then enroll in Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) exam dumps and start this journey with ValidTorrent. The ValidTorrent offers real, valid, and updated JN0-650 Questions that surely will help you in exam preparation and enable you to pass the challenging Enterprise Routing and Switching, Professional (JNCIP-ENT) (JN0-650) exam with flying colors.
They are not forced to buy one format or the other to prepare for the Enterprise Routing and Switching, Professional (JNCIP-ENT) JN0-650 exam. ValidTorrent designed Juniper JN0-650 exam preparation material in Enterprise Routing and Switching, Professional (JNCIP-ENT) JN0-650 PDF and practice test. If you prefer PDF Dumps notes or practicing on the Enterprise Routing and Switching, Professional (JNCIP-ENT) JN0-650 practice test software, use either.
JN0-650 PDF VCE | Reliable JN0-650 DumpsWith the unemployment rising, large numbers of people are forced to live their job. It is hard to find a high salary job than before. Many people are immersed in updating their knowledge. So people are keen on taking part in the JN0-650 exam. As you know, the competition between candidates is fierce. If you want to win out, you must master the knowledge excellently. Now our JN0-650 Study Materials are your best choice. With the assistance of our study materials, you will advance quickly.
Juniper Enterprise Routing and Switching, Professional (JNCIP-ENT) Sample Questions (Q30-Q35):NEW QUESTION # 30
Exhibit.
Referring to the exhibit, which two statements are correct? (Choose two.)
- A. R1 will advertise the 203 0.113.0724 route as an OSPF Type 7 LSA into Area 0.
- B. R5 will advertise the 203 0.113 0/24 route as an OSPF Type 5 LSA into Area 1.
- C. R5 will advertise the 203 0.113.0/24 route as an OSPF Type 7 LSA into Area 1.
- D. R1 will advertise the 203 0.113.0/24 route as an OSPF Type 5 LSA into Area 0
The exhibit shows an OSPF network where Area 1 is configured as a Not-So-Stubby Area (NSSA). R5 is an Autonomous System Boundary Router (ASBR) injecting an External Route (203.0.113.0/24) into this area.
NSSA ASBR Behavior (Option D): Within an OSPF NSSA, external routes cannot be advertised as standard Type 5 LSAs because stubby areas do not support them. Instead, the ASBR (R5) advertises the external prefix using a Type 7 LSA (NSSA External LSA). This LSA is flooded throughout Area 1.
ABR Translation Behavior (Option C): When the Type 7 LSA reaches the Area Border Router (R1), the ABR is responsible for translating it into a Type 5 LSA (AS External LSA). This allows the external route to be propagated into the backbone (Area 0) and subsequently to the rest of the OSPF domain.
Incorrect Statements (A & B): Option A is incorrect because Type 7 LSAs are local to the NSSA and are never advertised into Area 0. Option B is incorrect because Type 5 LSAs are strictly prohibited within an NSSA.
NEW QUESTION # 31
Which two statements are true regarding Spanning Tree Protocol? (Choose two.)
- A. The switch with the lowest bridge priority is elected as the root bridge.
- B. The switch with the highest bridge priority is elected as the root bridge.
- C. If all switch ports are the same speed, the switch port with the highest port priority becomes the root port.
- D. If all switch ports are the same speed, the switch port with the lowest port priority becomes the root port.
NEW QUESTION # 32
How is MSDP used in conjunction with PIM-SM?
- A. To replace the need for an RP within a PIM-SM domain
- B. To exchange multicast source information between PIM-SM domains
- C. To enhance multicast traffic encryption
- D. To optimize the multicast routing table size
NEW QUESTION # 33
User A in the exhibit has authenticated using 802.1X.
Which 802.1X supplicant mode must you configure on switch S1 to prevent User B and User C from also accessing the network? Click the Exhibit to see a larger version.
- A. single
- B. secure-mode
- C. exclusive
- D. single-secure
NEW QUESTION # 34
Which statement is true regarding the community regular expression "
