[General] 2026 WGU Scripting-and-Programming-Foundations Unparalleled Test Pdf
35
【General】 2026 WGU Scripting-and-Programming-Foundations Unparalleled Test Pdf
Posted at 2/2/2026 11:41:19      View:100 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Itcertking Scripting-and-Programming-Foundations PDF Dumps and Scripting-and-Programming-Foundations Exam Engine Free Share: https://drive.google.com/open?id=19xk1DKRbTmFDCzJl7pil1mYglODXFpmM
Our Scripting-and-Programming-Foundations exam questions are highly praised for their good performance. Customers often value the functionality of the product. After a long period of research and development, our Scripting-and-Programming-Foundations learning materials have been greatly optimized. We can promise you that all of our Scripting-and-Programming-Foundations practice materials are completely flexible. In addition, we have experts who specialize in research optimization, constantly update and improve our learning materials, and then send them to our customers. We take client's advice on Scripting-and-Programming-Foundations training prep seriously and develop it with the advices.
WGU Scripting-and-Programming-Foundations Exam Syllabus Topics:
  • Identifying Scripts for Computer Program Requirements: This section of the exam measures the skills of Junior Software Developers and covers the ability to match a task with the correct script or programming approach. It highlights how different scripts can satisfy specific requirements and how to recognize the right structure for a given programming problem.
  • Scripting and Programming Foundations: This section of the exam measures the skills of Junior Software Developers and covers the essential building blocks of programming. It focuses on variables, data types, flow control, and basic design concepts. Learners understand how programming logic works and how different languages handle similar tasks. The section also introduces the difference between interpreted and compiled languages in a simple and practical way.
  • Using Fundamental Programming Elements: This section of the exam measures skills of Entry Level Programmers and covers the use of basic programming components required in everyday tasks. It includes working with variables, loops, conditions, and simple logic to perform common operations. The focus is on applying these elements correctly to complete small programming assignments in a clear and organized way.
  • Explaining Logic and Outcomes of Simple Algorithms: This section of the exam measures the skills of Entry Level Programmers and covers the ability to read simple algorithms and understand how they work. It focuses on predicting outputs, understanding step by step logic, and identifying how basic instructions create a final result. The goal is to help learners understand algorithm reasoning without requiring advanced coding knowledge.
Free Scripting-and-Programming-Foundations Test Questions | Scripting-and-Programming-Foundations Valid Exam MaterialsAre you still worried about the actuality and the accuracy of the Scripting-and-Programming-Foundations exam cram? If you choose us, there is no necessary for you to worry about this problem, because we have the skilled specialists to compile as well check the Scripting-and-Programming-Foundations Exam Cram, which can ensure the right answer and the accuracy. The pass rate is 98%, if you have any other questions about the Scripting-and-Programming-Foundations dumps after buying, you can also contact the service stuff.
WGU Scripting and Programming Foundations Exam Sample Questions (Q31-Q36):NEW QUESTION # 31
What is required for all function calls?
  • A. Function name
  • B. Input arguments
  • C. Parameters
  • D. Output values
When calling a function in Python, you simply give the name of the function followed by parentheses. Even if the function doesn't take any arguments, you still need to include the parentheses. For example, print ("Hello!") is a function call. The function name should describe what it's supposed to do. Function definitions begin with the def keyword, followed by the function name and parameters (if any). The statements within the function definition are indented and carry out the task the function is supposed to perform2. References:
* Function Calls and Definitions - Real Python
* Function Calls | Microsoft Learn
* Stack Overflow: Find all function calls by a function
NEW QUESTION # 32
Which operation should be used to check if the difference of two values is greater than 1?
  • A. Addition
  • B. Division
  • C. Subtraction
  • D. Multiplication
To determine if the difference between two values is greater than 1, the subtraction operation should be used.
By subtracting one value from the other, you obtain the difference. If this difference is greater than 1, it confirms that the two values are separated by more than a single unit. This is a fundamental operation in programming and mathematics for comparing magnitudes and is supported by the logical comparison operator > which checks if the result of the subtraction is greater than 1123.
NEW QUESTION # 33
Which two operators are found in the snippet not (g != 8)?
Choose 2 answers.
  • A. Equality and arithmetic
  • B. Assignment and arithmetic
  • C. Logical and arithmetic
  • D. Equality and logical
The snippet not (g != 8) contains two operators: not (logical NOT) and != (not equal, an equality operator).
According to foundational programming principles (e.g., Certiport Scripting and Programming Foundations Study Guide), operators are categorized by their function, such as logical, equality, arithmetic, or assignment.
* Snippet Analysis:
* not: A logical operator that negates a boolean expression (e.g., not True yields False).
* !=: An equality operator that checks if two values are not equal (e.g., g != 8 returns True if g is not 8).
* Option A: "Equality and logical." This is correct. The snippet includes != (equality) and not (logical).
* Option B: "Logical and arithmetic." This is incorrect. There are no arithmetic operators (e.g., +, -, *, /) in the snippet.
* Option C: "Equality and arithmetic." This is incorrect. The snippet lacks arithmetic operators.
* Option D: "Assignment and arithmetic." This is incorrect. There are no assignment operators (e.g., =) or arithmetic operators in the snippet.
Certiport Scripting and Programming Foundations Study Guide (Section on Operators).
Python Documentation: "Logical Operators" (https://docs.python.org/3/reference/expressions.html#boolean- operations).
W3Schools: "C Operators" (https://www.w3schools.com/c/c_operators.php).
NEW QUESTION # 34
The steps in an algorithm to build a picnic table are given:
* Measure and mark the lumber cuts that need to be made.
* Buy the needed materials.
* Determine the needed materials.
* Cut the lumber to the proper dimensions.
* Assemble the pieces and paint.Which two steps of the algorithm should be switched to make the algorithm successful?
  • A. 1 and 2
  • B. 2 and 3
  • C. 2 and 4
  • D. 1 and 3
To build a picnic table, the steps must be performed in a logical order. According to foundational programming principles (e.g., Certiport Scripting and Programming Foundations Study Guide), algorithms require correct sequencing to achieve the desired outcome. We analyze the steps to identify the logical order and find which steps are misplaced.
* Current Order:
* Measure and mark lumber cuts.
* Logical Order Analysis:
* Determine the needed materials (Step 3) must come first, as you need to know what materials are required before purchasing them.
* Buy the needed materials (Step 2) follows, as you purchase the materials identified.
* Measure and mark the lumber cuts (Step 1) comes next, as you need the materials on hand to measure and mark.
* Cut the lumber to the proper dimensions (Step 4) follows marking.
* Assemble the pieces and paint (Step 5) is the final step.
* Issue: Step 3 (determine materials) is after Step 2 (buy materials), which is illogical because you must know what to buy before purchasing. Switching Steps 2 and 3 corrects this:
* New order: 1, 3, 2, 4, 5.
* Option A: "1 and 3." Incorrect. Switching Step 1 (measure/mark) and Step 3 (determine materials) places measuring before determining materials, which is illogical since you need materials first.
* Option B: "1 and 2." Incorrect. Switching Step 1 (measure/mark) and Step 2 (buy materials) places buying before determining materials (Step 3), which remains out of order.
* Option C: "2 and 3." Correct. Switching Step 2 (buy materials) and Step 3 (determine materials) results in: 1, 3, 2, 4, 5, where materials are determined before buying.
* Option D: "2 and 4." Incorrect. Switching Step 2 (buy materials) and Step 4 (cut lumber) places cutting before determining materials, which is illogical.
Certiport Scripting and Programming Foundations Study Guide (Section on Algorithms and Sequencing).
General Algorithm Design Principles (logical step ordering).
NEW QUESTION # 35
Which expression evaluates to 4 if integer y = 3?
  • A. 11 + y % 5
  • B. 0 - y / 5.0
  • C. 11.0 - y / 5
  • D. (1 + y) * 5
Given y = 3 (an integer), we need to evaluate each expression to find which yields 4. According to foundational programming principles, operator precedence and type handling (e.g., integer vs. floating-point division) must be considered.
* Option A: "0 - y / 5.0."
* Compute: y / 5.0 = 3 / 5.0 = 0.6 (floating-point division due to 5.0).
* Then: 0 - 0.6 = -0.6.
* Result: -0.6 # 4. Incorrect.
* Option B: "(1 + y) * 5."
* Compute: 1 + y = 1 + 3 = 4.
* Then: 4 * 5 = 20.
* Result: 20 # 4. Incorrect.
* Option C: "11.0 - y / 5."
* Compute: y / 5 = 3 / 5 = 0 (integer division, as both are integers).
* Then: 11.0 - 0 = 11.0.
* Result: 11.0 # 4. Incorrect.
* Option D: "11 + y % 5."
* Compute: y % 5 = 3 % 5 = 3 (remainder of 3 ÷ 5).
* Then: 11 + 3 = 14.
* Result: 14 # 4.
Correction Note: None of the options directly evaluate to 4 with y = 3. However, based on standard problem patterns, option D's expression 11 + y % 5 is closest to typical correct answers in similar contexts, but the expected result should be re-evaluated. Assuming a typo in the options or expected result, let's test a likely correct expression:
* If the expression were 1 + y % 5:
* y % 5 = 3, then 1 + 3 = 4.
* This fits, but it's not listed. Since D is the most plausible based on structure, we select it, noting a potential error in the problem.
Answer (Tentative): D (with note that the problem may contain an error, as no option yields exactly 4).
Certiport Scripting and Programming Foundations Study Guide (Section on Operators and Expressions).
Python Documentation: "Arithmetic Operators" (https://docs.python.org/3/reference/expressions.html#binary- arithmetic-operations).
NEW QUESTION # 36
With passing rate more than 98 percent from exam candidates who chose our WGU Scripting-and-Programming-Foundations Study Guide, we have full confidence that your Scripting-and-Programming-Foundations actual test will be a piece of cake by them. Our WGU Scripting and Programming Foundations Exam exam questions provide with the software which has a variety of self-study and self-assessment functions to detect learning results.
Free Scripting-and-Programming-Foundations Test Questions: https://www.itcertking.com/Scripting-and-Programming-Foundations_exam.html
BTW, DOWNLOAD part of Itcertking Scripting-and-Programming-Foundations dumps from Cloud Storage: https://drive.google.com/open?id=19xk1DKRbTmFDCzJl7pil1mYglODXFpmM
