400-007 Reliable Test Question - 400-007 Exam Actual Questions
Posted at 2/3/2026 00:45:23      View:75 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest ExamTorrent 400-007 PDF Dumps and 400-007 Exam Engine Free Share: https://drive.google.com/open?id=1RKIArrxH7PAGRBndV8NvjbEZqDJ7kJ9P
ExamTorrent guarantee the best valid and high quality Cisco study guide which you won’t find any better one available. 400-007 training pdf will be the right study reference if you want to be 100% sure pass and get satisfying results. From our 400-007 free demo which allows you free download, you can see the validity of the questions and format of the 400-007 actual test. In addition, the price of the 400-007 dumps pdf is reasonable and affordable for all of you.
It is browser-based; therefore no need to install it, and you can start practicing for the Cisco 400-007 exam by creating the Cisco Certified Design Expert (CCDE) Written Exam (400-007) practice test. You don't need to install any separate software or plugin to use it on your system to practice for your actual Cisco Certified Design Expert (CCDE) Written Exam (400-007) exam. ExamTorrent 400-007 web-based practice software is supported by all well-known browsers like Chrome, Firefox, Opera, Internet Explorer, etc.
Providing You Perfect 400-007 Reliable Test Question with 100% Passing GuaranteeYou can also trust ExamTorrent Cisco 400-007 exam questions and start this journey with complete peace of mind and satisfaction. The Cisco Certified Design Expert (CCDE) Written Exam practice questions are designed and verified by experienced and qualified Cisco Certified Design Expert (CCDE) Written Exam (400-007) exam experts. They work collectively and put their expertise to ensure the top standard of ExamTorrent Cisco 400-007 Exam Dumps. So we can say that with the ExamTorrent Cisco 400-007 exam questions, you will get everything that you need to learn, prepare and pass the difficult Cisco 400-007 certification exam with good scores.
Cisco Certified Design Expert (CCDE) Written Exam Sample Questions (Q66-Q71):NEW QUESTION # 66
The General Bank of Greece plans to upgrade its legacy end-of-life WAN network with a new flexible, manageable, and scalable solution. The main requirements are ZTP support, end-to-end encryption, application awareness, and segmentation. The CTO states that the main goal of the bank is CAPEX reduction.
Which WAN technology should be used for the solution?
  • A. Managed SD-WAN
  • B. DMVPN with PfR
  • C. SD-branch
  • D. SD-WAN
In this case, the bank seeks a solution that addresses scalability, manageability, application visibility, security (encryption and segmentation), and operational simplicity while aiming to reduce capital expenses. All these characteristics point directly to an SD-WAN architecture.
A non-managed (self-hosted) SD-WAN deployment:
* Supports Zero Touch Provisioning (ZTP), reducing deployment time and operational burden.
* Provides application-level visibility and intelligent path control.
* Enables strong segmentation and end-to-end encryption via templates and policy engines.
* Helps reduce CAPEX through the use of lower-cost broadband and centralized management.
While a "managed SD-WAN" solution (Option C) might be suitable in some cases, it typically involves higher OPEX. The question emphasizes CAPEX reduction, favoring an in-house SD-WAN solution.
This approach aligns with CCDE v3.1's "Scenario-based Design Strategy Guidance" and "Technology Comparisons and Use Cases" topics that emphasize selecting technologies aligned to business objectives and architectural scalability.
NEW QUESTION # 67
Refer to the table.
A customer investigates connectivity options for a DCI between two production data centers to aid a large-scale migration project. The solution must provide a single 10G connection between locations and be able to run its own varying QoS profiles without service provider interaction based on the migration stages. All connectivity methods are at 10 Gbps. Which transport technology costs the least if the connectivity is required for just one year?
  • A. CWDM over dark fiber
  • B. Metro Ethernet
  • C. DWDM over dark fiber
  • D. MPLS wires only
NEW QUESTION # 68
Network operators have many options available, from fully centralized to fully distributed control planes, and each approach has its own set of characteristics. Drag and drop the characteristics from the left onto the corresponding approach on the right.
NEW QUESTION # 69
Which two protocols are used by SDN controllers to communicate with switches and routers? (Choose two.)
  • A. NetFlash
  • B. OpenFlash
  • C. NetFlow
  • D. OpenFlow
  • E. Open vSwitch Database
Answer: D,E
* B (OpenFlow):OpenFlow is a widely used SDN southbound protocol that enables controllers to directly manage forwarding tables of switches.
* D (Open vSwitch Database - OVSDB):OVSDB is used by SDN controllers (especially in virtualized environments) to manage configuration state and flow entries on Open vSwitch instances.
Other options explained:
* A/C: Non-existent protocols.
* E: NetFlow is a traffic monitoring protocol, not a control interface for SDN controllers.
NEW QUESTION # 70
You have been tasked with designing a data center interconnect as part of business continuity.
You want to use FCoE over this DCI to support synchronous replication.
Which two technologies allow for FCoE via lossless Ethernet or data center bridging? (Choose two.)
  • A. VPLS
  • B. Multichassis EtherChannel over Pseudowire
  • C. EoMPLS
  • D. SONET/SDH
  • E. DWDM
Answer: D,E
NEW QUESTION # 71
When you have a lot of eletronic devices, you definitly will figure out the way to study and prepare your 400-007 exam with them. It is so cool even to think about it. As we all know that the electronic equipment provides the convenience out of your imagination.With our APP online version of our 400-007practice materials, your attempt will come true. Our 400-007 exam dumps can be quickly downloaded to the eletronic devices.
400-007 Exam Actual Questions: https://www.examtorrent.com/400-007-valid-vce-dumps.html
If you are also planning to attempt the Cisco Certified Design Expert (CCDE) Written Exam (400-007) exam and are confused about where to prepare yourself for it then you are at the right place, Our 400-007 Exam Actual Questions - Cisco Certified Design Expert (CCDE) Written Exam updated study torrent can help you sharpen the skills you urgently need because the society is changing faster than we imagine, However the 400-007 Exam Actual Questions 400-007 Exam Actual Questions - Cisco Certified Design Expert (CCDE) Written Exam latest learning dumps can clear all these barriers for you.
Add Jane's domain account to the Server Operators Pdf 400-007 Files domain user group, However, we can take advantage of the way it makes a large network dividedinto many subnetworks look like a single large network 400-007 to reduce the vulnerability of the static default gateway definition on each end system.
Cisco 400-007 PDF Questions - Pass Your Exam With EaseIf you are also planning to attempt the Cisco Certified Design Expert (CCDE) Written Exam (400-007) exam and are confused about where to prepare yourself for it then you are at the rightplace, Our Cisco Certified Design Expert (CCDE) Written Exam updated study torrent can help 400-007 Exam Actual Questions you sharpen the skills you urgently need because the society is changing faster than we imagine.
However the CCDE v3.0 Cisco Certified Design Expert (CCDE) Written Exam latest learning dumps can clear all these barriers for you, Our 400-007 pdf cram is authorized and valid, focusing on solving the difficulties in the real exam.
With 100% Guaranteed of Success: ExamTorrent's promise is to get you a wonderful success in 400-007 certification exams.
P.S. Free & New 400-007 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1RKIArrxH7PAGRBndV8NvjbEZqDJ7kJ9P
