Try Before You Buy Free Microsoft DP-420 Exam Questions Demos
Posted at 2/3/2026 08:50:34
P.S. Free & New DP-420 dumps are available on Google Drive shared by TestKingIT: https://drive.google.com/open?id=1RzgOcE5VSCARqipjqYUIVirUhO1qW3Hp
We have three versions of our DP-420 certification guide, and they are PDF version, software version and online version. With the PDF version, you can print our materials onto paper and learn our DP-420 exam braindumps in a more handy way as you can take notes whenever you want to, and you can mark out whatever you need to review later. With the software version, you are allowed to install our Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB guide torrent in all computers that operate in windows system. Besides, the software version can simulate the real test environment, which is favorable for people to better adapt to the examination atmosphere. With the online version, you can study the Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB guide torrent wherever you like, and you still have access to the materials even if there is no internet available on the premise that you have studied the DP-420 Certification guide online once before.
To prepare for the Microsoft DP-420 Exam, candidates should have a solid understanding of Azure Cosmos DB, including its features and capabilities. They should also be familiar with cloud-native application development, including design patterns and best practices. Candidates should have practical experience in developing and implementing cloud-native applications using Azure Cosmos DB.
Exam DP-420 Materials, Relevant DP-420 AnswersOur team regularly modified it to provide you with the real and updated DP-420 pdf exam questions every time. The applicants are informed of these new changes till three months after purchase from the TestKingIT. The TestKingIT gives its applicants a Microsoft DP-420 web-based practice test software that doesn't require installation. Microsoft DP-420 Practice Test is compatible with all operating systems, including iOS, Mac, and Windows. You can use this Microsoft DP-420 practice test on any browser on any device anywhere. You need to sign in to a verified account on our website to use the entire premium Microsoft DP-420 practice test questions.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q68-Q73):NEW QUESTION # 68
You have an Azure Cosmos DB Core (SQL) API account named account1 that has the disableKeyBasedMetadataWriteAccess property enabled.
You are developing an app named App1 that will be used by a user named DevUser1 to create containers in account1. DevUser1 has a non-privileged user account in the Azure Active Directory (Azure AD) tenant.
You need to ensure that DevUser1 can use App1 to create containers in account1.
Box 1: Resource tokens
Resource tokens provide access to the application resources within a database. Resource tokens:
Provide access to specific containers, partition keys, documents, attachments, stored procedures, triggers, and UDFs.
Box 2: Azure Resource Manager API
You can use Azure Resource Manager to help deploy and manage your Azure Cosmos DB accounts, databases, and containers.
https://docs.microsoft.com/en-us ... cure-access-to-data
https://docs.microsoft.com/en-us/rest/api/resources/
NEW QUESTION # 69
You have an Azure Cosmos DB Core (SQL) account that has a single write region in West Europe.
database named db
Box 1: Yes
The Automatic failover option allows Azure Cosmos DB to failover to the region with the highest failover priority with no user action should a region become unavailable.
Box 2: No
West Europe is used for failover. Only North Europe is writable.
To Configure multi-region set UseMultipleWriteLocations to true.
Box 3: Yes
Provisioned throughput with single write region costs $0.008/hour per 100 RU/s and provisioned throughput with multiple writable regions costs $0.016/per hour per 100 RU/s.
https://docs.microsoft.com/en-us ... how-to-multi-master
https://docs.microsoft.com/en-us ... timize-cost-regions
NEW QUESTION # 70
You have a database named db1 in an Azure Cosmos DB for NoSQL
You are designing an application that will use dbl.
In db1, you are creating a new container named coll1 that will store in coll1.
The following is a sample of a document that will be stored in coll1.
The application will have the following characteristics:
* New orders will be created frequently by different customers.
* Customers will often view their past order history.
You need to select the partition key value for coll1 to support the application. The solution must minimize costs.
To what should you set the partition key?
- A. id
- B. customerId
- C. orderDate
- D. orderId
Based on the characteristics of the application and the provided document structure, the most suitable partition key value for coll1 in the given scenario would be the customerId, Option B.
The application frequently creates new orders by different customers and customers often view their past order history. Using customerId as the partition key would ensure that all orders associated with a particular customer are stored in the same partition. This enables efficient querying of past order history for a specific customer and reduces cross-partition queries, resulting in lower costs and improved performance.
a partition key is a JSON property (or path) within your documents that is used by Azure Cosmos DB to distribute data among multiple partitions3. A partition key should have a high cardinality, which means it should have many distinct values, such as hundreds or thousands1. A partition key should also align with the most common query patterns of your application, so that you can efficiently retrieve data by using the partition key value1.
Based on these criteria, one possible partition key that you could use for coll1 is B. customerId.
This partition key has the following advantages:
It has a high cardinality, as each customer will have a unique ID3.
It aligns with the query patterns of the application, as customers will often view their past order history3.
It minimizes costs, as it reduces the number of cross-partition queries and optimizes the storage and throughput utilization1.
This partition key also has some limitations, such as:
It may not be optimal for scenarios where orders need to be queried independently from customers or aggregated by date or other criteria3.
It may result in hot partitions or throttling if some customers create orders more frequently than others or have more data than others1.
It may not support transactions across multiple customers, as transactions are scoped to a single logical partition2.
Depending on your specific use case and requirements, you may need to adjust this partition key or choose a different one. For example, you could use a synthetic partition key that concatenates multiple properties of an item2, or you could use a partition key with a random or pre-calculated suffix to distribute the workload more evenly2.
NEW QUESTION # 71
You have an Azure subscription that contains a resource group named RG1. RG1 contains an Azure Cosmos DB for NoSQL account named account1.
You plan to audit changes to the control plane of account1.
You need to ensure that audit events include the details of the security principal that performs each control plane change.
How should you complete the az command? To answer select the appropriate options in the answer area.
NEW QUESTION # 72
You have an Apache Spark pool in Azure Synapse Analytics that runs the following Python code in a notebook.
New and updated orders will be added to contoso-erp.orders: Yes
The code performs bulk data ingestion from contoso-app: No
Both contoso-app and contoso-erp have Analytics store enabled: Yes
The code uses the spark.readStream method to read data from a container named orders in a database named contoso-app. The data is then filtered by a condition and written to another container named orders in a database named contoso-erp using the spark.writeStream method. The write mode is set to "append", which means that new and updated orders will be added to the destination container1.
The code does not perform bulk data ingestion from contoso-app, but rather stream processing. Bulk data ingestion is a process of loading large amounts of data into a data store in batches. Stream processing is a process of continuously processing data as it arrives in real-time2.
Both contoso-app and contoso-erp have Analytics store enabled, because they are both accessed by Spark pools using the spark.cosmos.oltp method. This method requires that the containers have Analytics store enabled, which is a feature that allows Spark pools to query data stored in Azure Cosmos DB containers using SQL APIs3.
NEW QUESTION # 73
Before clients purchase our Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB test torrent they can download and try out our product freely to see if it is worthy to buy our product. You can visit the pages of our product on the website which provides the demo of our DP-420 study torrent and you can see parts of the titles and the form of our software. On the pages of our DP-420 study tool, you can see the version of the product, the updated time, the quantity of the questions and answers, the characteristics and merits of the product, the price of our product, the discounts to the client, the details and the guarantee of our DP-420 study torrent, the methods to contact us, the evaluations of the client on our product, the related exams and other information about our Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB test torrent. Thus you could decide whether it is worthy to buy our product or not after you understand the features of details of our product carefully on the pages of our DP-420 study tool on the website.
Exam DP-420 Materials: https://www.testkingit.com/Microsoft/latest-DP-420-exam-dumps.html
- Free PDF Quiz 2026 The Best Microsoft DP-420 Test Online 🗺 Open ☀ [url]www.exam4labs.com ️☀️ enter ⏩ DP-420 ⏪ and obtain a free download 👦Trustworthy DP-420 Exam Content[/url]
- Splendid DP-420 Exam Braindumps are from High-quality Learning Quiz - Pdfvce 🏓 Search for “ DP-420 ” and download it for free immediately on ▛ [url]www.pdfvce.com ▟ 🤪Minimum DP-420 Pass Score[/url]
- Practice DP-420 Exam 🕓 Interactive DP-420 Course 🦳 DP-420 Exam Cram Pdf ☸ Search for ➡ DP-420 ️⬅️ and download exam materials for free through ✔ [url]www.practicevce.com ️✔️ 🏎Related DP-420 Certifications[/url]
- DP-420 Latest Exam Answers 🐣 DP-420 Exam Cram Pdf 🏦 Interactive DP-420 Course 🤛 Simply search for { DP-420 } for free download on ▷ [url]www.pdfvce.com ◁ 🛢DP-420 Test Voucher[/url]
- Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Reliable Exam Papers - DP-420 Study Pdf Vce - Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Online Practice Test 💹 Simply search for ▶ DP-420 ◀ for free download on 《 [url]www.pdfdumps.com 》 📃DP-420 Latest Exam Answers[/url]
- Practice DP-420 Exam 🗨 Trustworthy DP-420 Exam Content 🌭 DP-420 Valid Test Cram 🧽 Immediately open ⏩ [url]www.pdfvce.com ⏪ and search for 【 DP-420 】 to obtain a free download ◀DP-420 Practice Engine[/url]
- DP-420 Test Online - Valid Exam DP-420 Materials Bring you the Best Products for Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB 😂 Open { [url]www.prepawaypdf.com } and search for ( DP-420 ) to download exam materials for free 🐢DP-420 Latest Exam Answers[/url]
- DP-420 Top Exam Dumps 🚐 Test DP-420 Pattern 🐆 DP-420 Test Voucher 🛩 Easily obtain 【 DP-420 】 for free download through ▷ [url]www.pdfvce.com ◁ ☃DP-420 Relevant Questions[/url]
- Valid DP-420 Test Online - How to Download for Microsoft Exam DP-420 Materials ↘ Easily obtain ☀ DP-420 ️☀️ for free download through ✔ [url]www.testkingpass.com ️✔️ 🛸DP-420 Practice Engine[/url]
- Free PDF Quiz 2026 The Best Microsoft DP-420 Test Online 🍧 Copy URL ⇛ [url]www.pdfvce.com ⇚ open and search for ✔ DP-420 ️✔️ to download for free 🍧DP-420 Latest Exam Answers[/url]
- DP-420 Valid Test Cram 🔗 DP-420 Exam Cram Pdf 🔄 DP-420 Top Exam Dumps 🪁 Immediately open [ [url]www.pdfdumps.com ] and search for ⮆ DP-420 ⮄ to obtain a free download 🤐DP-420 Latest Exam Answers[/url]
What's more, part of that TestKingIT DP-420 dumps now are free: https://drive.google.com/open?id=1RzgOcE5VSCARqipjqYUIVirUhO1qW3Hp
