AZ-305 High Quality & AZ-305 Reliable Test Blueprint
44
Posted at 2/3/2026 08:59:17      View125 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft AZ-305 dumps are available on Google Drive shared by ITdumpsfree: https://drive.google.com/open?id=19d3wJxoxCvAAffrrAl-Txe9nxUE0P4Dy
The Microsoft AZ-305 exam offers a great opportunity for beginner and experienced to validate their expertise in a short time period. To do this they just need to pass the Designing Microsoft Azure Infrastructure Solutions AZ-305 Certification Exam which is not an easy task. And ITdumpsfree offfers latest AZ-305 exam practice, exam pattern and practice exam online.
The Microsoft AZ-305 exam consists of around 40-60 questions that need to be solved in 150 minutes. The questions are in different formats, including multiple-choice, drag and drop, and scenario-based questions. AZ-305 exam is aimed at individuals who have a solid understanding of cloud computing concepts and experience working with Azure. Candidates must have experience in designing and implementing Azure solutions and be familiar with Azure tools and services. Passing the AZ-305 Exam earns the candidate the Microsoft Certified: Azure Solutions Architect Expert certification.
AZ-305 Reliable Test Blueprint | Popular AZ-305 ExamsAs long as you are willing to exercise on a regular basis, the AZ-305 exam will be a piece of cake, because what our AZ-305 practice materials include is quintessential points about the exam. And our high pass rate as 98% to 100% are all proved data form our customers who had attended the AZ-305 Exam and got their success with the help of our AZ-305 study dumps. So just come on and join our success!
Microsoft AZ-305 certification exam is designed for Azure architects and engineers who are responsible for designing and implementing solutions in Microsoft Azure. AZ-305 exam is aimed at professionals who have experience with Azure technologies and services, and who have a good understanding of cloud computing concepts, including virtualization, storage, networking, and security. The AZ-305 Exam Tests your ability to design and implement solutions that meet the requirements of your organization, while also ensuring scalability, availability, and security.
Microsoft Designing Microsoft Azure Infrastructure Solutions Sample Questions (Q148-Q153):NEW QUESTION # 148
You have five .NET Core applications that run on 10 Azure virtual machines in the same subscription.
You need to recommend a solution to ensure that the applications can authenticate by using the same Azure Active Directory (Azure AD) identity. The solution must meet the following requirements:
Ensure that the applications can authenticate only when running on the 10 virtual machines.
Minimize administrative effort.
What should you include in the recommendation? To answer, select the appropriate options in the answer area.
NEW QUESTION # 149
You have an Azure subscription.
Your on-premises network contains a file server named Server1. Server 1 stores 5 TB of company files that are accessed rarely.
You plan to copy the files to Azure Storage.
You need to implement a storage solution for the files that meets the following requirements:
* The files must be available within 24 hours of being requested.
* Storage costs must be minimized.
Which two possible storage solutions achieve this goal? Each correct answer presents a complete solution. NOTE: Each correct selection is worth one point.
  • A. Create a general-purpose v2 storage account that is configured for the Hot default access tier. Create a blob container, copy the files to the blob container, and set each file to the Archive access tier.
  • B. Create an Azure Blob storage account that is configured for the Cool default access tier. Create a blob container, copy the files to the blob container, and set each file to the Archive access tier.
  • C. Create a general-purpose v1 storage account. Create a file share in the storage account and copy the files to the file share.
  • D. Create a general-purpose v1 storage account. Create a blob container and copy the files to the blob container.
  • E. Create a general-purpose v2 storage account that is configured for the Cool default access tier. Create a file share in the storage account and copy the files to the file share.
https://docs.microsoft.com/en-us ... ss-tier?tabs=portal
NEW QUESTION # 150
You need to recommend a notification solution for the IT Support distribution group.
  • A. Azure Network Watcher
  • B. an action group
  • C. a SendGrid account with advanced reporting
  • D. Azure AD Connect Health
https://docs.microsoft.com/en-us ... t-health-operations Case Study This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
Topic 3, Contoso
To start the case study
To display the first question in this case study, click the Next button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirements, existing environment, and problem statements. If the case study has an All Information tab, note that the information displayed is identical to the information displayed on the subsequent tabs. When you are ready to answer a question, click the Question button to return to the question.
Existing Environment: Technical Environment
The on-premises network contains a single Active Directory domain named contoso.com.
Contoso has a single Azure subscription.
Existing Environment: Business Partnerships
Contoso has a business partnership with Fabrikam, Inc. Fabrikam users access some Contoso applications over the internet by using Azure Active Directory (Azure AD) guest accounts.
Requirements: Planned Changes
Contoso plans to deploy two applications named App1 and App2 to Azure.
Requirements: App1
App1 will be a Python web app hosted in Azure App Service that requires a Linux runtime. Users from Contoso and Fabrikam will access App1.
App1 will access several services that require third-party credentials and access strings. The credentials and access strings are stored in Azure Key Vault.
App1 will have six instances: three in the East US Azure region and three in the West Europe Azure region.
App1 has the following data requirements:
Each instance will write data to a data store in the same availability zone as the instance.
Data written by any App1 instance must be visible to all App1 instances.
App1 will only be accessible from the internet. App1 has the following connection requirements:
Connections to App1 must pass through a web application firewall (WAF).
Connections to App1 must be active-active load balanced between instances.
All connections to App1 from North America must be directed to the East US region. All other connections must be directed to the West Europe region.
Every hour, you will run a maintenance task by invoking a PowerShell script that copies files from all the App1 instances. The PowerShell script will run from a central location.
Requirements: App2
App2 will be a NET app hosted in App Service that requires a Windows runtime. App2 has the following file storage requirements:
Save files to an Azure Storage account.
Replicate files to an on-premises location.
Ensure that on-premises clients can read the files over the LAN by using the SMB protocol.
You need to monitor App2 to analyze how long it takes to perform different transactions within the application. The solution must not require changes to the application code.
Application Development Requirements
Application developers will constantly develop new versions of App1 and App2. The development process must meet the following requirements:
A staging instance of a new application version must be deployed to the application host before the new version is used in production.
After testing the new version, the staging version of the application will replace the production version.
The switch to the new application version from staging to production must occur without any downtime of the application.
Identity Requirements
Contoso identifies the following requirements for managing Fabrikam access to resources:
Every month, an account manager at Fabrikam must review which Fabrikam users have access permissions to App1. Accounts that no longer need permissions must be removed as guests.
The solution must minimize development effort.
Security Requirement
All secrets used by Azure services must be stored in Azure Key Vault.
Services that require credentials must have the credentials tied to the service instance. The credentials must NOT be shared between services.
NEW QUESTION # 151
You configure OAuth2 authorization in API Management as shown in the following exhibit.
Box 1: Web applications
The Authorization Code Grant Type is used by both web apps and native apps to get an access token after a user authorizes an app.
Note: The Authorization Code grant type is used by confidential and public clients to exchange an authorization code for an access token.
After the user returns to the client via the redirect URL, the application will get the authorization code from the URL and use it to request an access token.
https://developer.okta.com/blog/ ... ion-code-grant-type
https://connect2id.com/products/ ... client-registration
NEW QUESTION # 152
You have the Azure resources shown in the following table.
You need to recommend a virtual network management solution that uses Azure Virtual Network Manager.
* Minimize the number of network managers.
* Minimize administrative effort when assigning the network group membership.
NEW QUESTION # 153
AZ-305 Reliable Test Blueprint: https://www.itdumpsfree.com/AZ-305-exam-passed.html
DOWNLOAD the newest ITdumpsfree AZ-305 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=19d3wJxoxCvAAffrrAl-Txe9nxUE0P4Dy
Posted at 2/21/2026 17:31:45        Only Author  2#
The article is written with great depth, and I have learned a lot of practical knowledge. This New test bootcamp CAMS materials helped me move up in my career. Now its free for everyone. Hope you all reach your promotions soon!
