DP-420 VCE Exam Simulator - DP-420 Valid Test Vce
Posted at 2/3/2026 10:19:13
View99
Replies0
2026 Latest PrepAwayPDF DP-420 PDF Dumps and DP-420 Exam Engine Free Share: https://drive.google.com/open?id=1p3Fk70HN0G_Fp0Vqc2ooh_3aHWQxYBFT
When you first contact our software, different people will have different problems. Maybe you are not comfortable with our DP-420 exam question and want to know more about our products and operations. As long as you have questions, you can send e-mail to us, we have online staff responsible for ensuring 24-hour service to help you solve all the problems about our DP-420 Test Prep. After you purchase our DP-420 quiz guide, we will still provide you with considerate services. Maybe you will ask whether we will charge additional service fees.
PrepAwayPDF provide high pass rate of the DP-420 exam materials that are compiled by experts with profound experiences according to the latest development in the theory and the practice so they are of great value. Please firstly try out our DP-420 training braindump before you decide to buy our DP-420 Study Guide as we have free demo on the web. It is worthy for you to buy our DP-420 exam preparation not only because it can help you pass the DP-420 exam successfully but also because it saves your time and energy.
DP-420 Valid Test Vce | DP-420 Reliable Dumps QuestionsThe APP online version of the DP-420 exam questions can provide you with exam simulation. And the good point is that you don't need to install any software or app. All you need is to click the link of the online DP-420 training material for one time, and then you can learn and practice offline. If our DP-420 Study Material is updated, you will receive an E-mail with a new link. You can follow the new link to keep up with the new trend of DP-420 exam.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q26-Q31):NEW QUESTION # 26
You have an Azure Cosmos DB account named account1.
You have several apps that connect to account1 by using the account's secondary key.
You then configure the apps to authenticate by using service principals.
You need to ensure that account1 will only allow apps to connect by using an Azure AD identity.
Which account property should you modify?
- A. userAssignedldentatxe
- B. disableKeyBasedMetadataWriteAccess ,
- C. allowedOrxgins
- D. disableLocalAuth
The disableLocalAuth property is a boolean flag that indicates whether local authentication methods such as primary/secondary keys are disabled for the Azure Cosmos DB account. Setting this property to true improves security by ensuring that Azure Cosmos DB accounts exclusively require Azure Active Directory identities for authentication1.
Topic 1, Litware, inc
Case Study
This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
To start the case study
To display the first question in this case study, click the Next button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirements, existing environment, and problem statements. If the case study has an All Information tab, note that the information displayed is identical to the information displayed on the subsequent tabs. When you are ready to answer a question, click the Question button to return to the question.
Overview
Litware, Inc. is a United States-based grocery retailer. Litware has a main office and a primary datacenter in Seattle. The company has 50 retail stores across the United States and an emerging online presence. Each store connects directly to the internet.
Existing environment. Cloud and Data Service Environments.
Litware has an Azure subscription that contains the resources shown in the following table.
Each container in productdb is configured for manual throughput.
The con-product container stores the company's product catalog data. Each document in con-product includes a con-productvendor value. Most queries targeting the data in con-product are in the following format.
SELECT * FROM con-product p WHERE p.con-productVendor - 'name'
Most queries targeting the data in the con-productVendor container are in the following format SELECT * FROM con-productVendor pv ORDER BY pv.creditRating, pv.yearFounded Existing environment. Current Problems.
Litware identifies the following issues:
Updates to product categories in the con-productVendor container do not propagate automatically to documents in the con-product container.
Application updates in con-product frequently cause HTTP status code 429 "Too many requests". You discover that the 429 status code relates to excessive request unit (RU) consumption during the updates.
Requirements. Planned Changes
Litware plans to implement a new Azure Cosmos DB Core (SQL) API account named account2 that will contain a database named iotdb. The iotdb database will contain two containers named con-iot1 and con-iot2.
Litware plans to make the following changes:
Store the telemetry data in account2.
Configure account1 to support multiple read-write regions.
Implement referential integrity for the con-product container.
Use Azure Functions to send notifications about product updates to different recipients.
Develop an app named App1 that will run from all locations and query the data in account1.
Develop an app named App2 that will run from the retail stores and query the data in account2. App2 must be limited to a single DNS endpoint when accessing account2.
Requirements. Business Requirements
Litware identifies the following business requirements:
Whenever there are multiple solutions for a requirement, select the solution that provides the best performance, as long as there are no additional costs associated.
Ensure that Azure Cosmos DB costs for IoT-related processing are predictable.
Minimize the number of firewall changes in the retail stores.
Requirements. Product Catalog Requirements
Litware identifies the following requirements for the product catalog:
Implement a custom conflict resolution policy for the product catalog data.
Minimize the frequency of errors during updates of the con-product container.
Once multi-region writes are configured, maximize the performance of App1 queries against the data in account1.
Trigger the execution of two Azure functions following every update to any document in the con-product container.
NEW QUESTION # 27
You have a container in an Azure Cosmos DB Core (SQL) API account.
You need to use the Azure Cosmos DB SDK to replace a document by using optimistic concurrency.
What should you include in the code? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... .itemrequestoptions
https://cosmosdb.github.io/labs/ ... rrency-control.html
NEW QUESTION # 28
The following is a sample of a document in orders.
The orders container uses customer as the partition key.
You need to provide a report of the total items ordered per month by item type. The solution must meet the following requirements:
Ensure that the report can run as quickly as possible.
Minimize the consumption of request units (RUs).
What should you do?
- A. Configure the report to query a new aggregate container. Populate the aggregates by using SQL queries that run daily.
- B. Configure the report to query orders by using a SQL query.
- C. Configure the report to query orders by using a SQL query through a dedicated gateway.
- D. Configure the report to query a new aggregate container. Populate the aggregates by using the change feed.
You can facilitate aggregate data by using Change Feed and Azure Functions, and then use it for reporting.
Reference: https://docs.microsoft.com/en-us/azure/cosmos-db/change-feed
NEW QUESTION # 29
You have an Azure Cosmos DB for NoSQL container. The container contains items that have the following properties.
You need to protect the data stored in the container by using Always Encrypted. For each property, you must use the strongest type of encryption and ensure that queries execute properly.
What is the strongest type of encryption that you can apply to each property? To answer, select the appropriate options in the answer area.
NEW QUESTION # 30
You have an Azure Cosmos DB Core (SQL) API account named account1 that has the disableKeyBasedMetadataWriteAccess property enabled.
You are developing an app named App1 that will be used by a user named DevUser1 to create containers in account1. DevUser1 has a non-privileged user account in the Azure Active Directory (Azure AD) tenant.
You need to ensure that DevUser1 can use App1 to create containers in account1.
https://docs.microsoft.com/en-us ... cure-access-to-data
https://docs.microsoft.com/en-us/rest/api/resources/
NEW QUESTION # 31
The world is changing rapidly and the requirements to the employees are higher than ever before. If you want to find an ideal job and earn a high income you must boost good working abilities and profound major knowledge. Passing DP-420 certification can help you realize your dreams. If you buy our product, we will provide you with the best Azure Cosmos DB Developer Specialty study materials and it can help you obtain DP-420certification. Our product is of high quality and our service is perfect.
DP-420 Valid Test Vce: https://www.prepawaypdf.com/Microsoft/DP-420-practice-exam-dumps.html
We boost a professional expert team to undertake the research and the production of our DP-420 study materials, There is an old saying goes like this:" Procrastination is the thief of time." It is quite clear that time is extremely valuable for those candidates who are preparing for the exam (DP-420 practice test), so our company has spared no effort to speed up the delivery speed in order to cater to the demands of our customers, DP-420 exam dumps are edited by professional experts, therefore the quality can be guaranteed.
You are advised to finish all exercises of our DP-420 study materials, For example, you might have a speed in miles per hour or an email address, We boost a professional expert team to undertake the research and the production of our DP-420 Study Materials.
Latest Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB pass review & DP-420 getfreedumps study materialsThere is an old saying goes like this:" Procrastination DP-420 Reliable Dumps Questions is the thief of time." It is quite clear that time is extremely valuable for those candidates who are preparing for the exam (DP-420 practice test), so our company has spared no effort to speed up the delivery speed in order to cater to the demands of our customers.
DP-420 exam dumps are edited by professional experts, therefore the quality can be guaranteed, More other humanism advantages are waiting for your experience.
Be supportive to offline exercise DP-420 on the condition that you practice it without mobile data.
- DP-420 Brain Dump Free 🦑 DP-420 Reliable Exam Answers 🥑 Valid DP-420 Exam Question 💌 Easily obtain { DP-420 } for free download through ☀ [url]www.pdfdumps.com ️☀️ 🌇DP-420 Valid Exam Forum[/url]
- New DP-420 Dumps Free 📿 Reliable DP-420 Test Vce 👊 DP-420 Latest Exam Online 🔸 Open website ☀ [url]www.pdfvce.com ️☀️ and search for ▷ DP-420 ◁ for free download 🐋DP-420 Latest Exam Online[/url]
- DP-420 Brain Dump Free 💸 DP-420 Latest Exam Online ✳ DP-420 Reliable Exam Answers 🏅 The page for free download of DP-420 on ⮆ [url]www.troytecdumps.com ⮄ will open immediately 🧸DP-420 Brain Dump Free[/url]
- New DP-420 Dumps Free 👺 New DP-420 Real Test 🐤 DP-420 Exam Materials 🤤 Search for DP-420 and download it for free immediately on ➥ [url]www.pdfvce.com 🡄 😄DP-420 Brain Dump Free[/url]
- Microsoft DP-420 VCE Exam Simulator Are Leading Materials with High Pass Rate 🐬 Download ➥ DP-420 🡄 for free by simply searching on ⏩ [url]www.prepawayete.com ⏪ 🎉Latest DP-420 Exam Practice[/url]
- Professional DP-420 VCE Exam Simulator to pass Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB - Recommend by Experts 🤴 Search for { DP-420 } and download it for free on [ [url]www.pdfvce.com ] website 🕚Valid DP-420 Exam Question[/url]
- Free PDF Microsoft - Newest DP-420 VCE Exam Simulator 🥦 ➥ [url]www.prep4sures.top 🡄 is best website to obtain DP-420 for free download 😺New DP-420 Exam Test[/url]
- Discount DP-420 Code 🔖 New DP-420 Exam Test 🤔 DP-420 Certification Exam 🌀 Open ⏩ [url]www.pdfvce.com ⏪ and search for ▛ DP-420 ▟ to download exam materials for free 🍑New DP-420 Exam Review[/url]
- New DP-420 Test Forum 🤒 DP-420 Latest Exam Book 🪀 DP-420 Brain Dump Free 🔬 The page for free download of ✔ DP-420 ️✔️ on ➥ [url]www.pdfdumps.com 🡄 will open immediately 🐕DP-420 Latest Test Cost[/url]
- DP-420 Certification Exam 🟢 Discount DP-420 Code 🐌 Discount DP-420 Code 🏌 Open [url]www.pdfvce.com and search for DP-420 to download exam materials for free ✈DP-420 Reliable Exam Answers[/url]
- New DP-420 Exam Review 🌜 New DP-420 Test Forum 🏣 DP-420 Latest Test Cost 🖐 Search for { DP-420 } on ➠ [url]www.prepawayete.com 🠰 immediately to obtain a free download 😊Reliable DP-420 Test Vce[/url]
DOWNLOAD the newest PrepAwayPDF DP-420 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1p3Fk70HN0G_Fp0Vqc2ooh_3aHWQxYBFT
