ATLASSIAN ACP-120 Valid Test Answers & Test ACP-120 Dumps Demo
Posted at 2/3/2026 11:33:09
BTW, DOWNLOAD part of Prep4sureExam ACP-120 dumps from Cloud Storage: https://drive.google.com/open?id=1brTI6s1b4HbKwvf1cdfQVglBXbxJl7IC
We has a long history of 10 years in designing the ACP-120 exam guide and enjoys a good reputation across the globe. There are so many features to show that our ACP-120 study engine surpasses others. We can confirm that the high quality is the guarantee to your success. At the same time, the prices of our ACP-120 practice materials are quite reasonable for no matter the staffs or the students to afford. What is more, usually we will give some discounts to our worthy customers.
Atlassian ACP-120 (Jira Cloud Administrator) Exam is a certification exam designed for IT professionals who work with JIRA Cloud. ACP-120 exam is intended to test the candidate's knowledge and skills in managing and administering JIRA Cloud. Jira Cloud Administrator certification is well recognized in the industry and can help candidates to stand out in the job market.
Test ACP-120 Dumps Demo & ACP-120 Valid TorrentUsing our products does not take you too much time but you can get a very high rate of return. Our ACP-120 quiz guide is of high quality, which mainly reflected in the passing rate. We can promise higher qualification rates for our ACP-120 exam question than materials of other institutions. Because our products are compiled by experts from various industries and they are based on the true problems of the past years and the development trend of the industry. What's more, according to the development of the time, we will send the updated materials of ACP-120 Test Prep to the customers soon if we update the products. Under the guidance of our study materials, you can gain unexpected knowledge. Finally, you will pass the exam and get a ATLASSIAN certification.
ATLASSIAN Jira Cloud Administrator Sample Questions (Q67-Q72):NEW QUESTION # 67
Billie needs to perform various restricted tasks in the system. You must decide whether to grant her site admin or organization admin privileges.
Identify two reasons why you must make her an organization admin (Choose two)
- A. Billie needs to enable other users to be site or product admins
- B. Billie needs to remove users from the site
- C. Billie needs to make changes to user's profiles
- D. Billie needs to log in as other users for troubleshooting user accounts
- E. Billie needs to enable other users to be organization admins
NEW QUESTION # 68
You need to make changes to the time tracking feature in Jira. What configuration can be controlled globally across all projects?
- A. The requirement of an original estimate when creating issues
- B. The ability to edit or delete their own or other users' worklogs for specific users
- C. The ability to log work on issues for specific groups
- D. The availability of time tracking fields on standard versus sub-task issue types
- E. The default tracking time unit, unless users explicitly specify one
Answer: E
Thetime trackingfeature in Jira Cloud allows logging work, tracking estimates, and managing time-related settings. The configuration that can be controlled globally across all projects isthe default tracking time unit, unless users explicitly specify one(Option C), as this is set in the global time tracking settings.
* Explanation of the Correct Answer (Option C):
* Thedefault tracking time unit(e.g., hours, days) is configured globally in Jira Cloud's time tracking settings and applies to all projects unless users specify a different unit when logging time or setting estimates. This setting determines how time is displayed and entered by default across the system.
* Exact Extract from Documentation:
Configure time tracking in Jira Cloud
Global time tracking settings apply to all projects and include:
* Default time unit: Sets the default unit for time tracking (e.g., hours, days).To configure:
* Go toSettings > Issues > Time tracking.
* Set theDefault unit for time tracking(e.g., Hour).Impact: The default unit is used across all projects unless users explicitly specify another unit (e.g., 2d for days).Note: Requires Jira administrator permissions.(Source: Atlassian Support Documentation, "Configure time tracking in Jira Cloud")
* Why This Fits: Thedefault tracking time unitis a global setting that applies to all projects, making Option C the correct answer.
* Why Other Options Are Incorrect:
* The ability to log work on issues for specific groups (Option A):
* The ability to log work is controlled by theWork On Issuespermission in each project's permission scheme, not globally. Permissions are project-specific, even if projects share a scheme, and cannot be set globally for specific groups across all projects.
* Extract from Documentation:
TheWork On Issuespermission is set in project permission schemes, not globally.
(Source: Atlassian Support Documentation, "Manage permissions in Jira Cloud")
* The ability to edit or delete their own or other users' worklogs for specific users (Option B):
* Permissions to edit or delete worklogs (e.g.,Edit Own Worklogs,Edit All Worklogs, Delete Own Worklogs,Delete All Worklogs) are also set in project permission schemes, not globally. These are project-specific settings.
Worklog permissions (Edit Own Worklogs,Delete All Worklogs) are configured in project permission schemes, not globally.
* The availability of time tracking fields on standard versus sub-task issue types (Option D):
* The availability of time tracking fields (e.g., Original Estimate, Remaining Estimate) is controlled byfield configurationsorscreens, which are project-specific or issue type- specific. There is no global setting to differentiate timetracking fields between standard and sub-task issue types.
Time tracking fields are managed by field configurations and screens, not global settings. Their availability depends on project or issue type configurations.
(Source: Atlassian Support Documentation, "Configure field settings")
* The requirement of an original estimate when creating issues (Option E):
* Requiring anOriginal Estimateis controlled byfield configurations(making the field required) orworkflow validators(enforcing a value during transitions). These are project- specific or issue type-specific, not global settings.
Requiring fields likeOriginal Estimateis set in field configurations or workflow validators, not globally.
* Additional Notes:
* Configuring global time tracking settings requiresJira administratorprivileges and is done in Settings > Issues > Time tracking.
* Other global time tracking settings include the format (e.g., hours per day, days per week) and whether time tracking is enabled.
* Project-specific settings (e.g., permissions, field requirements) override global defaults for specific use cases.
Atlassian Support Documentation:Configure time tracking in Jira Cloud
Atlassian Support Documentation:Manage permissions in Jira Cloud
Atlassian Support Documentation:Configure field settings
NEW QUESTION # 69
You are setting up Jira Software Cloud for an organization of 250 employees. Product access is already configured to grant new users access to Jira Software by default You now need to configure site access so that it meets these 3 conditions
1. Minimum administration overhead is required
2. Access is granted to the entire organization at the same time
3. Access is restricted only to your organization
Which solution meets these requirements? (Choose one)
- A. Enable existing users to send invitations to all current and future employees
- B. Create an invite link and share it with all current and future employees
- C. Approve any domain in the site access settings
- D. Add all your company's domains as approved domains
- E. Set the global mode to public and enable CAPTCHA on sign up
NEW QUESTION # 70
Max wants you to change the way the system fields Created or Updated are being displayed when viewing an issue.
How can this be achieved?
- A. Adjust the Complete Date/Time Format in the Jira Look and Feel configuration.
- B. Adjust the language and time zone preferences in Max's user profile.
- C. Adjust the Day Format in the Jira look and Feel configuration.
- D. Adjust the jira.date.time.picker.java.format in the advanced settings configuration.
- E. Adjust the jira.date.picker.java.format in the advanced settings configuration.
Reference: https://virginpulse.zendesk.com/ ... on-my-Max-is-wrong-
NEW QUESTION # 71
Jon needs to create groups and manage membership in groups. Which administrator privilege does Jon need?
- A. System administrator
- B. Project administrator
- C. Jira administrator
- D. Product Admin role for Jira
- E. Organization admin
Creating groups and managing group membership in Jira Software Cloud are system-level tasks that require theJira administratorprivilege. This privilege allows Jon to access user management settings and perform group-related actions.
* Explanation of the Correct Answer (Option D):
* TheJira administratorprivilege grants users the ability to manage global settings, including creating groups and managing their membership. This includes adding or removing users from groups, which is necessary for Jon's requirements.
Jira administrators can manage global settings, including:
* Creating and deleting groups.
* Adding or removing users from groups.
* Managing global permissions and user access.To create or manage groups:
* Go toSettings > User management > Groups.
* Create a new group or edit existing group membership.Note: Only Jira administrators or organization admins with user management permissions can perform these actions.(Source:
Atlassian Support Documentation, "Manage groups in Jira Cloud")
* Why This Fits: TheJira administratorprivilege directly enables Jon to create groups and manage their membership, making Option D the correct choice.
* Organization admin (Option A):
* Organization admins manage the Atlassian organization, including user access to products and billing. While they can manage users and groups at the organization level, creating groups specifically in Jira requiresJira administratorprivileges unless the organization admin also has this role.
Organization admins manage user access, billing, and security at the Atlassian organization level. Managing Jira-specific groups requires Jira administrator privileges.
(Source: Atlassian Support Documentation, "Manage your Atlassian organization")
* Product Admin role for Jira (Option B):
* TheProduct Adminrole for Jira grants access to manage product-specific settings, such as user access to Jira Software. However, creating and managing groups is a system-level task that requiresJira administratorprivileges.
Product admins manage user access to specific products (e.g., Jira Software). Group management requires Jira administrator or organization admin privileges.
(Source: Atlassian Support Documentation, "Manage product access")
* System administrator (Option C):
* The termsystem administratoris not a standard role in Jira Cloud. In some contexts, it may refer toJira administratorsororganization admins, but it is not a distinct privilege for group management.
Jira Cloud uses roles like Jira administrator and organization admin. There is no distinct "system administrator" role for group management.
(Source: Atlassian Support Documentation, "Manage users and groups")
* Project administrator (Option E):
* Project administrators manage settings for specific projects (e.g., permissions, components) but cannot create or manage groups, as these are global settings.
Project administrators manage project-specific settings but cannot access global settings like user or group management.
(Source: Atlassian Support Documentation, "Manage project permissions")
* Additional Notes:
* Jon's tasks require access toSettings > User management > Groups, which is restricted toJira administrators.
* If Jon is also an organization admin, he might have overlapping permissions, but theJira administratorrole is the most direct for group management in Jira.
Atlassian Support Documentation:Manage groups in Jira Cloud
Atlassian Support Documentation:Manage your Atlassian organization
Atlassian Support Documentation:Manage product access
Atlassian Support Documentation:Manage project permissions
NEW QUESTION # 72
We have three versions of ATLASSIAN ACP-120 guide materials available on our test platform, including PDF, Software and APP online. The most popular one is PDF version of our Jira Cloud Administrator ACP-120 exam questions and you can totally enjoy the convenience of this version, and this is mainly because there is a demo in it, therefore help you choose what kind of ACP-120 Practice Test are suitable to you and make the right choice.
Test ACP-120 Dumps Demo: https://www.prep4sureexam.com/ACP-120-dumps-torrent.html
- ACP-120 Actual Tests 🍞 Dumps ACP-120 PDF 🔵 Exam ACP-120 Answers 😎 Open website ☀ [url]www.prepawayete.com ️☀️ and search for 「 ACP-120 」 for free download 🙍Exam ACP-120 Answers[/url]
- ACP-120 Valid Dumps Files 💓 ACP-120 Valid Dumps Files 🎨 ACP-120 Reliable Study Materials 🚲 Easily obtain free download of ⮆ ACP-120 ⮄ by searching on ➽ [url]www.pdfvce.com 🢪 🎷ACP-120 Dumps Download[/url]
- ACP-120 Test Torrent is Very Easy for You to Save a Lot of Time to pass Jira Cloud Administrator exam - [url]www.prep4sures.top 🌈 Open ☀ www.prep4sures.top ️☀️ enter ✔ ACP-120 ️✔️ and obtain a free download 🌶Exam ACP-120 Answers[/url]
- ACP-120 Guide Torrent - ACP-120 Prep Guide -amp; ACP-120 Exam Torrent 💡 Open website ▛ [url]www.pdfvce.com ▟ and search for ( ACP-120 ) for free download 🌞Exam ACP-120 Answers[/url]
- ACP-120 Guide Torrent - ACP-120 Prep Guide -amp; ACP-120 Exam Torrent 🦖 Search for 《 ACP-120 》 and download it for free immediately on “ [url]www.practicevce.com ” 💺Regualer ACP-120 Update[/url]
- Free PDF ACP-120 - High Hit-Rate Jira Cloud Administrator Valid Test Answers 🕶 Go to website ( [url]www.pdfvce.com ) open and search for ⮆ ACP-120 ⮄ to download for free 🏤Regualer ACP-120 Update[/url]
- ACP-120 Valid Dumps Files 🔇 Test ACP-120 Questions Pdf 😸 ACP-120 New Practice Questions 🎄 Open { [url]www.prep4away.com } and search for 「 ACP-120 」 to download exam materials for free ‼ACP-120 Actual Tests[/url]
- ACP-120 free practice torrent - ACP-120 real pdf test 🟢 Copy URL “ [url]www.pdfvce.com ” open and search for { ACP-120 } to download for free 🏇ACP-120 Reliable Test Answers[/url]
- Pass Guaranteed Quiz 2026 The Best ATLASSIAN ACP-120 Valid Test Answers 🥉 Easily obtain free download of ⇛ ACP-120 ⇚ by searching on ▶ [url]www.practicevce.com ◀ 🕰ACP-120 Valid Dumps Files[/url]
- Useful ACP-120 Valid Test Answers | ACP-120 100% Free Test Dumps Demo 🤜 Easily obtain ▛ ACP-120 ▟ for free download through ➡ [url]www.pdfvce.com ️⬅️ 🔳ACP-120 Reliable Exam Voucher[/url]
- Useful ACP-120 Valid Test Answers | ACP-120 100% Free Test Dumps Demo 🆑 Search for ➥ ACP-120 🡄 and download it for free immediately on ⏩ [url]www.troytecdumps.com ⏪ 🚨ACP-120 Reliable Study Materials[/url]
- www.stes.tyc.edu.tw, blogfreely.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dl.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 ATLASSIAN ACP-120 dumps are available on Google Drive shared by Prep4sureExam: https://drive.google.com/open?id=1brTI6s1b4HbKwvf1cdfQVglBXbxJl7IC
