[General] Data-Cloud-Consultant Test Cram - Data-Cloud-Consultant Reliable Braindumps Ppt
85
【General】 Data-Cloud-Consultant Test Cram - Data-Cloud-Consultant Reliable Braindumps Ppt
Posted at 2/3/2026 12:30:42      View:159 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4training Data-Cloud-Consultant PDF Dumps and Data-Cloud-Consultant Exam Engine Free Share: https://drive.google.com/open?id=1fA4LLQ0A2DzBdRFkbLrub08mNHoPCn-0
Clients always wish that they can get immediate use after they buy our Data-Cloud-Consultant Test Questions because their time to get prepared for the exam is limited. Our Data-Cloud-Consultant test torrent won’t let the client wait for too much time and the client will receive the mails in 5-10 minutes sent by our system. Then the client can log in and use our software to learn immediately. It saves the client’s time.
Salesforce Data-Cloud-Consultant Exam Syllabus Topics:
  • Data Ingestion and Modeling: This topic covers the different transformation capabilities within Data Cloud. It includes describing processes and considerations for data ingestion from various sources, defining, mapping, and modeling data using best practices aligned with identity resolution. Lastly, it discusses using available tools to inspect and validate ingested and modeled data.
  • Data Cloud Setup and Administration: This topic includes applying Data Cloud permissions, permission sets, org-wide settings. It describes and configures data stream types, and data bundles. Moreover, it discusses use cases for data spaces, creating data spaces, managing and administering Data Cloud using reports, dashboards, flows, packaging, data kits, diagnosing and exploring data using Data Explorer, Profile Explorer, and APIs.
  • Segmentation and Insights: This topic defines basic concepts of segmentation and use cases, identifies scenarios for analyzing segment membership, configuring, refining, and maintaining segments within Data Cloud, and differentiating between calculated and streaming insights.
  • Act on Data: This topic defines activations and their basic use cases, using attributes and related attributes, identifying and analyzing timing dependencies affecting the Data Cloud lifecycle. Additionally it focuses on troubleshooting common problems with activations, and using data actions, including their requirements and intended use cases.
Topic 5
  • Data Cloud Overview: This topic covers Data Cloud's function, key terminology, business value, typical use cases, the Data Cloud lifecycle, dependencies, and principles of data ethics. These sub-topics provide an overview of Data Cloud's capabilities and applications.
Data-Cloud-Consultant Reliable Braindumps Ppt & Passing Data-Cloud-Consultant ScoreDue to busy routines, applicants of the Salesforce Certified Data Cloud Consultant (Data-Cloud-Consultant) exam need real Salesforce exam questions. When they don't study with updated Salesforce Data-Cloud-Consultant practice test questions, they fail and lose money. If you want to save your resources, choose updated and actual Data-Cloud-Consultant Exam Questions of Pass4training. At the Pass4training offer students Salesforce Data-Cloud-Consultant practice test questions, and 24/7 support to ensure they do comprehensive preparation for the Data-Cloud-Consultant exam.
Salesforce Certified Data Cloud Consultant Sample Questions (Q67-Q72):NEW QUESTION # 67
A consultant is planning the ingestion of a data stream that has profile information including a mobile phone number.
To ensure that the phone number can be used for future SMS campaigns, they need to confirm the phone number field is in the proper E164 Phone Number format. However, the phone numbers in the file appear to be in varying formats.
What is the most efficient way to guarantee that the various phone number formats are standardized?
  • A. Assign the PhoneNumber field type when creating the data stream.
  • B. Create a calculated insight after ingestion.
  • C. Edit and update the data in the source system prior to sending to Data Cloud.
  • D. Create a formula field to standardize the format.
The most efficient way to guarantee that the various phone number formats are standardized is to assign the PhoneNumber field type when creating the data stream. The PhoneNumber field type is a special field type that automatically converts phone numbers into the E164 format, which is the international standard for phone numbers. The E164 format consists of a plus sign (+), the country code, and the national number. For example,
+1-202-555-1234 is the E164 format for a US phone number. By using the PhoneNumber field type, the consultant can ensure that the phone numbers are consistent and can be used for future SMS campaigns. The other options are either more time-consuming, require manual intervention, or do not address the formatting issue. References: Data Stream Field Types, E164 Phone Number Format, Salesforce Data Cloud Exam Questions
NEW QUESTION # 68
What does the Ignore Empty Value option do in identity resolution?
  • A. Ignores empty fields when running any custom match rules
  • B. Ignores empty fields when running reconciliation rules
  • C. Ignores Individual object records with empty fields when running identity resolution rules
  • D. Ignores empty fields when running the standard match rules
The Ignore Empty Value option in identity resolution allows customers to ignore empty fields when running reconciliation rules. Reconciliation rules are used to determine the final value of an attribute for a unified individual profile, based on the values from different sources. The Ignore Empty Value option can be set to true or false for each attribute in a reconciliation rule. If set to true, the reconciliation rule will skip any source that has an empty value for that attribute and move on to the next source in the priority order. If set to false, the reconciliation rule will consider any source that has an empty value for that attribute as a valid source and use it to populate the attribute value for the unified individual profile.
The other options are not correct descriptions of what the Ignore Empty Value option does in identity resolution. The Ignore Empty Value option does not affect the custom match rules or the standard match rules, which are used to identify and link individuals across different sources based on their attributes. The Ignore Empty Value option also does not ignore individual object records with empty fields when running identity resolution rules, as identity resolution rules operate on the attribute level, not the record level.
Data Cloud Identity Resolution Reconciliation Rule Input
Configure Identity Resolution Rulesets
Data and Identity in Data Cloud
NEW QUESTION # 69
The leadership team at Cumulus Financial has determined that customers who deposited more than $250,000 in the last five years and are not using advisory services will be the central focus for all new campaigns in the next year.
Which features support this use case?
  • A. Calculated insight and data action
  • B. Calculated insight and segment
  • C. Streaming insight and data action
  • D. Streaming insight and segment
* Understanding the Use Case:
The leadership team wants to focus on customers who have deposited more than $250,000 in the last five years and are not using advisory services.
* Features Involved:
Calculated Insight: This feature helps derive metrics and values based on existing data. In this case, it can calculate total deposits over the last five years.
Segment: Segmentation allows targeting specific groups of customers based on defined criteria, such as total deposits and usage of advisory services.
* Steps to Implement:
Create a Calculated Insight:
Navigate to Visual Insights Builder in Salesforce Data Cloud.
Create a new calculated insight to sum deposits for each customer over the last five years.
Create a Segment:
Use the Segment Canvas to create a new segment.
Apply filters to include customers with deposits over $250,000 and exclude those using advisory services.
* Practical Application:
Example: Identify high-value customers who are not leveraging additional services and target them with personalized marketing campaigns to promote advisory services.
NEW QUESTION # 70
A Data Cloud consultant recently added a new data source and mapped some of the data to a new custom data model object (DMO) that they want to use for creating segments. However, they cannot view the newly created DMO when trying to create a new segment.
What is the cause of this issue?
  • A. The new DMO is not of category Profile.
  • B. Segmentation is only supported for the Individual and Unified Individual DMOs.
  • C. The new DMO does not have a relationship to the individual DMO
  • D. Data has not yes been ingested into the DMO.
The cause of this issue is that the new custom data model object (DMO) is not of category Profile. A category is a property of a DMO that defines its purpose and functionality in Data Cloud. There are three categories of DMOs: Profile, Event, and Other. Profile DMOs are used to store attributes of individuals or entities, such as name, email, address, etc. Event DMOs are used to store actions or interactions of individuals or entities, such as purchases, clicks, visits, etc. Other DMOs are used to store any other type of data that does not fit into the Profile or Event categories, such as products, locations, categories, etc. Only Profile DMOs can be used for creating segments in Data Cloud, as segments are based on the attributes of individuals or entities. Therefore, if the new custom DMO is not of category Profile, it will not appear in the segmentation canvas. The other options are not correct because they are not the cause of this issue. Data ingestion is not a prerequisite for creating segments, as segments can be created based on the data model schema without actual data. The new DMO does not need to have a relationship to the individual DMO, as segments can be created based on any Profile DMO, regardless of its relationship to other DMOs. Segmentation is not only supported for the Individual and Unified Individual DMOs, as segments can be created based on any Profile DMO, including custom ones. References: Create a Custom Data Model Object from an Existing Data Model Object, Create a Segment in Data Cloud, Data Model Object Category
NEW QUESTION # 71
A Data Cloud customer wants to adjust their identity resolution rules to increase their accuracy of matches. Rather than matching on email address, they want to review a rule that joins their CRM Contacts with their Marketing Contacts, where both use the CRM ID as their primary key.
Which two steps should the consultant take to address this new use case?
Choose 2 answers
  • A. Map the primary key from the two systems to Party Identification, using CRM ID as the identification name for both.
  • B. Map the primary key from the two systems to party identification, using CRM ID as the identification name for individuals coming from the CRM, and Marketing ID as the identification name for individuals coming from the marketing platform.
  • C. Create a matching rule based on party identification that matches on CRM ID as the party identification name.
  • D. Create a custom matching rule for an exact match on the Individual ID attribute.
To address this new use case, the consultant should map the primary key from the two systems to Party Identification, using CRM ID as the identification name for both, and create a matching rule based on party identification that matches on CRM ID as the party identification name. This way, the consultant can ensure that the CRM Contacts and Marketing Contacts are matched based on their CRM ID, which is a unique identifier for each individual. By using Party Identification, the consultant can also leverage the benefits of this attribute, such as being able to match across different entities and sources, and being able to handle multiple values for the same individual. The other options are incorrect because they either do not use the CRM ID as the primary key, or they do not use Party Identification as the attribute type. References: Configure Identity Resolution Rulesets, Identity Resolution Match Rules, Data Cloud Identity Resolution Ruleset, Data Cloud Identity Resolution Config Input
NEW QUESTION # 72
We will continue to pursue our passion for better performance and human-centric technology of latest Data-Cloud-Consultant quiz prep. And we guarantee you to pass the Data-Cloud-Consultant exam for we have confidence to make it with our technological strength. A good deal of researches has been made to figure out how to help different kinds of candidates to get the Data-Cloud-Consultant Certification. We have made classification to those faced with various difficulties, aiming at which we adopt corresponding methods. According to the statistics shown in the feedback chart, the general pass rate for latest Data-Cloud-Consultant test prep is 98%.
Data-Cloud-Consultant Reliable Braindumps Ppt: https://www.pass4training.com/Data-Cloud-Consultant-pass-exam-training.html
Posted at 2/18/2026 19:53:10        Only Author  2#
I’m really moved by this article, thanks for sharing! We’ve made Salesforce-MuleSoft-Associate Sample Exam freely available, packed with content to help you succeed.
