[Hardware] F5CAB4 Test Registration, F5CAB4 Actual Questions
【Hardware】 F5CAB4 Test Registration, F5CAB4 Actual Questions
Posted at 9 hour before      View:1 | Replies:0        Print      Only Author   [Copy Link] 1#
Among all substantial practice materials with similar themes, our F5CAB4 practice materials win a majority of credibility for promising customers who are willing to make progress in this line. With excellent quality at attractive price, our F5CAB4 Exam Questions get high demand of orders in this fierce market. You can just look at the data about the hot hit on the F5CAB4 study braindumps everyday, and you will know that how popular our F5CAB4 learning guide is.
All these three DumpsReview BIG-IP Administration Control Plane Administration (F5CAB4) exam questions formats are easy to use and perfectly work with all devices, operating systems, and the latest web browsers. So rest assured that with the DumpsReview F5CAB4 Exam Dumps you will get everything that you need to learn, prepare and pass the challenging BIG-IP Administration Control Plane Administration (F5CAB4) exam with good scores.
F5CAB4 Actual Questions, Vce F5CAB4 FileAs you know, we are now facing very great competitive pressure. We need to have more strength to get what we want, and F5CAB4 free exam guide may give you these things. After you use our study materials, you can get F5-CA certification, which will better show your ability, among many competitors, you will be very prominent. Using F5CAB4 practice files is an important step for you to improve your soft power. I hope that you can spend a little time understanding what our F5CAB4 study materials have to attract customers compared to other products in the industry.
F5 BIG-IP Administration Control Plane Administration Sample Questions (Q35-Q40):NEW QUESTION # 35
A BIG-IP Administrator needs to check the memory utilization on a BIG-IP system. Which two methods can the BIG-IP Administrator use? (Choose two.)
  • A. Run the tmsh show /sys traffic command
  • B. Go to Statistics > Module Statistics > Memory in the configuration utility
  • C. Run the tmsh show /sys memory command
  • D. Go to Statistics > Module Statistics > Traffic Summary in the configuration utility
Reporting device status includes monitoring physical resource exhaustion, such as memory. The Control Plane provides both a command-line method via TMSH (show /sys memory) and a graphical method under Statistics > Module Statistics > Memory to report on how memory is allocated across TMM and the Linux host494949494949494949. This is essential for identifying potential "Aggressive Mode" triggers or hardware performance bottlenecks50.
NEW QUESTION # 36
The BIG-IP Administrator suspects unauthorized SSH login attempts on the BIG-IP system.
Which log file would contain details of these attempts? (Choose one answer)
  • A. /var/log/secure
  • B. /var/log/audit
  • C. /var/log/ltm
  • D. /var/log/messages
On BIG-IP systems, authentication and authorization events are logged in /var/log/secure. This includes:
* Successful and failed SSH login attempts
* Invalid user authentication attempts
* PAM (Pluggable Authentication Module) authentication failures
* Access denials related to secure services
* /var/log/messages contains general system messages and service events, not detailed authentication failures.
* /var/log/audit records administrative configuration changes (who changed what and when), not login attempts.
* /var/log/ltm logs traffic-management (TMM) and application-related events.
Therefore, the correct log file for investigating unauthorized SSH login attempts is /var/log/secure.
NEW QUESTION # 37
As an organization grows, more people have to log into the BIG-IP. Instead of adding more local users, the BIG-IP Administrator is asked to configure remote authentication against a central authentication server.
Which two types of remote server can be used here? (Choose two answers)
  • A. OAUTH
  • B. RADIUS
  • C. SAML
  • D. LDAP
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents:
BIG-IP supports remote authentication by integrating with centralized authentication services through its AAA framework. The supported and commonly used remote authentication servers include:
LDAP (A)
Used to authenticate users against directory services such as Active Directory or other LDAP-compliant directories.
RADIUS (C)
Commonly used for centralized authentication, authorization, and accounting, especially in network and security environments.
OAUTH (B) is an authorization framework, not supported as a direct administrative authentication backend for BIG-IP management access.
SAML (D) is primarily used for single sign-on (SSO) in application authentication scenarios, not for BIG-IP administrative login authentication.
Thus, the correct remote authentication server types are LDAP and RADIUS.
NEW QUESTION # 38
A BIG-IP Administrator needs to restore a UCS file to an F5 device using the Configuration Utility. Which section of the Configuration Utility should the BIG-IP Administrator access to perform this task?
  • A. Local Traffic > Virtual Servers
  • B. System > Configuration
  • C. Local Traffic > Policies
  • D. System > Archives
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents: Managing the state of a device often involves restoring configuration backups known as User Configuration Set (UCS) files These archives contain the full system configuration, including licenses and SSL certificates. The Control Plane provides a dedicated management area for these files under System > Archives, where administrators can upload, create, and restore configuration snapshots
NEW QUESTION # 39
A BIG-IP Administrator needs to determine who changed a Virtual Server configuration.
In which log file would the BIG-IP Administrator find this data? (Choose one answer)
  • B. /var/log/ltm
  • C. /var/log/audit
The audit log (/var/log/audit) records configuration changes made on the BIG-IP system, including:
* Who made the change (user account)
* What was changed (for example, a virtual server modification)
* When the change occurred
* How it was performed (GUI, TMSH, or API)
* /var/log/secure logs authentication events such as login successes and failures, not configuration changes.
* /var/log/ltm logs traffic-management and runtime LTM events, not administrative configuration modifications.
Therefore, the correct log file for tracking who changed a virtual server is /var/log/audit.
NEW QUESTION # 40
The world is changing rapidly and the requirements to the employees are higher than ever before. If you want to find an ideal job and earn a high income you must boost good working abilities and profound major knowledge. Passing F5CAB4 certification can help you realize your dreams. If you buy our product, we will provide you with the best F5CAB4 Study Materials and it can help you obtain F5CAB4 certification. Our product is of high quality and our service is perfect.
F5CAB4 Actual Questions: https://www.dumpsreview.com/F5CAB4-exam-dumps-review.html
We guarantee our F5CAB4 test online files are the best save-time, save-energy and highly effective select for most candidates, If you are troubled with F5CAB4 exam, you can consider down our free demo, As most of customers have great liking for large amounts of information, F5CAB4 Actual Questions - BIG-IP Administration Control Plane Administration free pdf study provides free renewal in one year after purchase to cater to the demand of them, F5 F5CAB4 Test Registration We truly think of what you want and do the best.
in computer science from the University of Kent at Canterbury F5CAB4 Actual Questions in the United Kingdom, where his focus was on debugging tools and programmer psychology, Add and manage custom menus.
We guarantee our F5CAB4 Test Online files are the best save-time, save-energy and highly effective select for most candidates, If you are troubled with F5CAB4 exam, you can consider down our free demo.
Take Your F5 F5CAB4 Exam with Preparation Material Available in Three FormatsAs most of customers have great liking for large amounts of Vce F5CAB4 File information, BIG-IP Administration Control Plane Administration free pdf study provides free renewal in one year after purchase to cater to the demand of them.
We truly think of what you want and do the best, We insist to keep F5CAB4 our customers' information secret and never share the information to any other third part without the permission of the customer.
