[General] Reliable PDII-JPN Test Blueprint - Reliable PDII-JPN Test Pass4sure
【General】 Reliable PDII-JPN Test Blueprint - Reliable PDII-JPN Test Pass4sure
Posted at 2/3/2026 12:45:54      View:118 | Replies:4        Print      Only Author   [Copy Link] 1#
While attempting the exam, take heed of the clock ticking, so that you manage the Salesforce PDII-JPN Questions in a time-efficient way. Even if you are completely sure of the correct answer to a question, first eliminate the incorrect ones, so that you may prevent blunders due to human error.
With our PDII-JPN learning quiz, the exam will be a piece of cake. And PDII-JPN training materials serve as a breakthrough of your entire career. Meanwhile, PDII-JPN study guide provides you considerable solution through the exam and efficient acquaintance. By imparting the knowledge of the exam to those ardent exam candidates who are eager to succeed like you, our experts treat it as responsibility to offer help. So please prepare to get striking progress if you can get our PDII-JPN Study Guide with following traits for your information.
Excellent Reliable PDII-JPN Test Blueprint - Valid PDII-JPN Exam Tool Guarantee Purchasing SafetyWhen preparing to take the  (PDII-JPN) exam dumps, knowing where to start can be a little frustrating, but with ValidVCE Salesforce PDII-JPN practice questions, you will feel fully prepared. Using our Salesforce PDII-JPN practice test software, you can prepare for the increased difficulty on Salesforce PDII-JPN Exam day. Plus, we have various question types and difficulty levels so that you can tailor your  (PDII-JPN) exam dumps preparation to your requirements.
Salesforce  Sample Questions (Q156-Q161):NEW QUESTION # 156
リアルタイム通知が必要ない場合に、開発者がユーザが最後に Salesforce にログインした時期を確認できる Salesforce 機能はどれですか?
  • A. イベント監視ログ
  • B. 非同期データキャプチャイベント
  • C. カレンダーイベント
  • D. 開発者ログ
NEW QUESTION # 157
テスト クラスで Visualforce ページを初期化するためのベスト プラクティスは何ですか?
  • A. コントローラー、currentPage、setPage (MyTestPage) を使用
  • B. Test.setCurrentpage,MyTestPage を使用します。
  • C. Test.currentpage、getParameter、put (MyTestPage) を使用します。
  • D. テストを使用、setCurrentPage(Page.MyTestPage);
NEW QUESTION # 158
Universal Charities (UC) は、Salesforce を使用して個人や法人からクレジット カード引き落としの形で電子寄付を集めています。
カスタマー サービス エージェントがクレジット カード情報を入力すると、寄付が処理されるようにその情報が 8 つのサードパーティ決済プロセッサに送信される必要があります。UC は個人向けに 1 つの決済プロセッサを使用し、法人向けには別の決済プロセッサを使用します。
システム管理者が展開後に必要に応じて設定を変更できるように、開発者はさまざまな決済プロセッサの設定を保存するために何を使用する必要がありますか?
  • A. リストのカスタム設定
  • B. 階層カスタム設定
  • C. カスタムオブジェクト
  • D. カスタムメタデータ
NEW QUESTION # 159
ビジネスルールでは、新しいアカウントが作成されると必ず連絡先も作成されるように設定されています。連絡先の作成に失敗した場合、アカウントが作成されないようにするためのカスタム画面を開発する際に、どのような機能を使用できますか?
  • A. allOrNone を false に設定して Database.Insert メソッドを使用します。
  • B. try-catch ブロックで setSavePoint() と rollback() を使用します。
  • C. 連絡先の挿入に失敗した場合は、Database.Delete メソッドを使用します。
  • D. try-catch ブロックで Database Savepoint メソッドを使用します。
This requirement calls for "Transactional Atomicity," meaning either both database operations (Account creation and Contact creation) succeed, or neither is committed to the database. In Apex, each DML statement normally acts as its own individual transaction unless managed by Savepoints.
The correct approach is to use Database.setSavepoint() and Database.rollback() within a try-catch block (Option A). The developer sets a savepoint immediately before the Account is inserted. If the Account is created successfully but the subsequent Contact insertion fails (due to a validation rule, trigger error, or system exception), the code enters the catch block. Within the catch block, the developer executes Database.
rollback(sp), which reverts the database to the state it was in before the Account was ever inserted.
Option B is technically similar but "A" provides the standard programmatic pattern name. Option C (allOrNone=false) only applies to a single list of records in one DML call and cannot link the success of an Account to a Contact. Option D (manual deletion) is an unreliable "cleanup" strategy that fails if the system crashes or if there are secondary side effects from the initial insertion. Using Savepoints ensures the platform handles the rollback safely and completely.
NEW QUESTION # 160
"ageReference.setRedirect" Apex 関数が False に設定されている場合、どのタイプのリクエストが行われますか?
  • A. ポストバック リクエスト
  • B. 取得リクエスト
  • C. PageReference が同じコントローラーと拡張機能のサブセットを指している場合、ポストバック要求、そうでない場合は要求を取得
NEW QUESTION # 161
As is known to us, our company has promised that the PDII-JPN exam braindumps from our company will provide more than 99% pass guarantee for all people who try their best to prepare for the exam. If you are preparing for the exam by the guidance of the PDII-JPN study practice question from our company and take it into consideration seriously, you will absolutely pass the exam and get the related certification. So do not hesitate and hurry to buy our study materials.
Reliable PDII-JPN Test Pass4sure: https://www.validvce.com/PDII-JPN-exam-collection.html
You never will be regret for choosing our PDII-JPN study guide, it can do assist you pass the exam with certainty, Salesforce Reliable PDII-JPN Test Blueprint License and Site Access The Company grants you a limited time license to access this site, to purchase the products and use the services offered by this site only for personal use, All the necessary information about our complete range of PDII-JPN certification tests is given below.
Kelly lives in Littleton, Colorado, Where there is a will, there is a way, You never will be regret for choosing our PDII-JPN study guide, it can do assist you pass the exam with certainty.
License and Site Access The Company grants you a limited time PDII-JPN license to access this site, to purchase the products and use the services offered by this site only for personal use.
Quiz 2026 Professional Salesforce PDII-JPN: Reliable  Test BlueprintAll the necessary information about our complete range of PDII-JPN certification tests is given below,  certificate is a powerful support when you complete with other candidates.
In the IT industry, Salesforce's PDII-JPN exam certification is the essential certification of the IT industry.
Posted at 2/3/2026 21:19:07        Only Author  2#
Your article is breathtakingly good, thank you for sharing it! The Marketing-Cloud-Administrator latest test dumps free resources are top-quality and free to use.
Posted at 2/6/2026 19:05:20        Only Author  3#
That article was incredibly rich in knowledge. Reliable SAFe-Agilist exam collection file offers valuable resources, made available to you free of charge.
Posted at 2/6/2026 20:26:32        Only Author  4#
This article is exceptional, thank you so much for sharing. Latest real FCP_FSM_AN-7.2 test answers offers a wealth of material for free, designed to aid your learning.
Posted at 2/9/2026 01:17:26        Only Author  5#
The article is written with great depth, and I have learned a lot of practical knowledge. I earned my promotion and salary increase with the AI-201 valid soft simulations. Now, it's free for everyone. Wishing you all early promotions!
