[General] High Hit-Rate Workday - Workday-Prism-Analytics - Workday Pro Prism Analytics Ex
【General】 High Hit-Rate Workday - Workday-Prism-Analytics - Workday Pro Prism Analytics Ex
Posted at 2/3/2026 13:02:49      View:89 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that PrepAwayTest Workday-Prism-Analytics dumps now are free: https://drive.google.com/open?id=1XiT8VuuuqlgX0gsownF7WeCBnDchRJyI
We know that you have strong desire for success in your career, now, we recommend you to get the Workday-Prism-Analytics exam certification. PrepAwayTest will help you and provide you with the high quality Workday training material. Workday-Prism-Analytics questions are selected and edited from the original questions pool and verified by the professional experts. Besides, the updated of Workday-Prism-Analytics Pdf Torrent is checked every day by our experts and the new information can be added into the Workday-Prism-Analytics exam dumps immediately.
PrepAwayTest is website that can help a lot of IT people realize their dreams. If you have a IT dream, then quickly click the click of PrepAwayTest. It has the best training materials, which is PrepAwayTest;s Workday Workday-Prism-Analytics Exam Training materials. This training materials is what IT people are very wanted. Because it will make you pass the exam easily, since then rise higher and higher on your career path.
Workday-Prism-Analytics Reliable Exam Test, Exam Workday-Prism-Analytics DumpsSo we can say that the Workday-Prism-Analytics practice questions are the top-notch Workday Pro Prism Analytics Exam (Workday-Prism-Analytics) dumps that will provide you with everything that you must need for instant Workday Workday-Prism-Analytics exam preparation. Take the right decision regarding your quick Workday Pro Prism Analytics Exam (Workday-Prism-Analytics) exam questions preparation and download the real, valid, and updated Workday-Prism-Analytics exam dumps and start this journey.
Workday Pro Prism Analytics Exam Sample Questions (Q14-Q19):NEW QUESTION # 14
You want your derived dataset to only show rows that meet the following criteria: Agent ID is not null AND Location is Dallas OR Location is Montreal. How can you achieve this?
  • A. By using Simple Filter conditions.
  • B. By adding a Manage Fields stage.
  • C. By using Advanced Filter conditions.
  • D. By creating a Custom Example.
In Workday Prism Analytics, filtering a derived dataset to meet specific criteria involving multiple conditions with mixed logical operators (AND, OR) requires careful configuration. The criteria here are: Agent ID is not null AND (Location is Dallas OR Location is Montreal). According to the official Workday Prism Analytics study path documents, this can be achieved by using Advanced Filter conditions (option C).
A Simple Filter in Prism Analytics allows for basic conditions with a single operator ("If All" for AND, "If Any" for OR), but it cannot handle nested logic like AND combined with OR in a single filter. For example, a Simple Filter with "If All" would require all conditions to be true (Agent ID is not null AND Location is Dallas AND Location is Montreal), which is too restrictive. A Simple Filter with "If Any" would include rows where any condition is true (Agent ID is not null OR Location is Dallas OR Location is Montreal), which is too broad. The Advanced Filter, however, allows for complex expressions with nested logic, such as ISNOTNULL(Agent_ID) AND (Location = "Dallas" OR Location = "Montreal"), ensuring the correct rows are included.
The other options are incorrect:
* A. By adding a Manage Fields stage: The Manage Fields stage modifies field properties (e.g., type, visibility) but does not filter rows based on conditions.
* B. By using Simple Filter conditions: As explained, a Simple Filter cannot handle the combination of AND and OR logic required for this criteria.
* D. By creating a Custom Example: Custom Examples are used to provide sample data for testing, not to filter rows in a dataset.
Using Advanced Filter conditions allows for the precise application of the required logic to filter the dataset accurately.
Workday Prism Analytics Study Path Documents, Section: Data Prep and Transformation, Topic: Filtering Data in Derived Datasets Workday Prism Analytics Training Guide, Module: Data Prep and Transformation, Subtopic: Using Advanced Filters for Complex Conditions
NEW QUESTION # 15
What task or report should you access to view a Prism data source?
  • A. Edit Dataset Transformations task
  • B. View Prism Data Source report
  • C. View Dataset Details report
  • D. Edit Data Source Security task
In Workday Prism Analytics, a Prism data source represents the published dataset that is available for reporting and analytics within the Workday ecosystem. According to the official Workday Prism Analytics study path documents, the "View Prism Data Source" report is the specific task or report designed to allow users to view the details of a Prism data source. This report provides comprehensive information about the data source, including its metadata, structure, and associated attributes, enabling users to understand the data available for reporting purposes.
The other options do not serve this purpose. The "Edit Dataset Transformations task" is used to modify the transformation logic applied to a dataset, not to view a data source. The "Edit Data Source Security task" focuses on managing security settings for a data source, such as access permissions, rather than viewing its contents. Similarly, the "View Dataset Details report" provides information about a dataset (including its metadata and sample rows) but does not specifically address the published Prism data source, which is a distinct entity created after a dataset is published.
The "View Prism Data Source" report is the correct choice as it directly aligns with the need to inspect the properties and structure of a Prism data source, ensuring users can verify its suitability for reporting or integration with Workday reports.
Workday Prism Analytics Study Path Documents, Section: Datasets and Data Sources, Topic: Managing and Viewing Prism Data Sources Workday Prism Analytics Training Guide, Module: Publishing and Visualizing Data, Subtopic: Viewing and Validating Data Sources
NEW QUESTION # 16
You accidentally delete a Prism calculated field that is used in other Prism calculated fields or conditions.
What is a possible outcome?
  • A. The system will automatically adjust any dependencies accordingly.
  • B. Errors will result in any stage or calculated field that references the field.
  • C. Any calculated field referencing the deleted field defaults to zero.
  • D. The system will automatically reverse the deletion because the field is referenced elsewhere.
In Workday Prism Analytics, calculated fields are often interdependent, with one calculated field referencing another in its expression or being used in conditions within a dataset's transformation stages. According to the official Workday Prism Analytics study path documents, if a calculated field is deleted while other calculated fields or conditions depend on it, the system does not automatically handle the dependency. Instead, this deletion will cause errors in any stage or calculated field that references the deleted field. These errors occur because the dependent calculations or conditions can no longer resolve the reference to the deleted field, leading to failures in the dataset's transformation pipeline or when the dataset is processed or published.
A: The system will automatically reverse the deletion because the field is referenced elsewhere: Prism Analytics does not have an automatic reversal mechanism for deletions; users must manually restore the field if needed.
B: Any calculated field referencing the deleted field defaults to zero: The system does not default to zero; it will instead throw an error due to the unresolved reference.
D: The system will automatically adjust any dependencies accordingly: Prism does not automatically adjust dependencies; the user must manually update the dependent fields or conditions to resolve the issue.
The resulting errors highlight the importance of carefully managing dependencies when deleting calculated fields, ensuring that all references are updated or removed to avoid disruptions in the dataset's transformation logic.
Workday Prism Analytics Study Path Documents, Section: Data Prep and Transformation, Topic: Managing Calculated Fields and Dependencies Workday Prism Analytics Training Guide, Module: Data Prep and Transformation, Subtopic: Impact of Deleting Calculated Fields on Dataset Transformations
NEW QUESTION # 17
You created a derived dataset that imports data from a table, which will become your Stage 1. What can you add to this dataset?
  • A. Up to two Manage Fields transformation stages.
  • B. Up to five transformation stages.
  • C. As many transformation stages of any type as your scenario requires.
  • D. As many transformation stages of any type as long as they are in a particular order.
In Workday Prism Analytics, a derived dataset (DDS) allows users to transform data by adding various transformation stages after the initial import stage (Stage 1). According to the official Workday Prism Analytics study path documents, you can add as many transformation stages of any type as your scenario requires (option A). Prism Analytics supports a variety of transformation stages, such as Join, Union, Filter, Manage Fields, and Calculate Field, among others. There are no strict limits on the number of stages or their types, and they can be added in any order that makes sense for the data transformation logic, as long as the stages are configured correctly to produce the desired output. This flexibility allows users to build complex transformation pipelines tailored to their specific use case.
* B. As many transformation stages of any type as long as they are in a particular order: While the order of stages matters for the transformation logic (e.g., a Filter before a Join), there is no predefined order requirement for all stages; the order depends on the scenario.
* C. Up to five transformation stages: There is no limit of five transformation stages in Prism Analytics; you can add more as needed.
* D. Up to two Manage Fields transformation stages: There is no restriction to only two Manage Fields stages; you can add as many as required.
The ability to add as many transformation stages as needed provides maximum flexibility in shaping the data within a derived dataset.
Workday Prism Analytics Study Path Documents, Section: Data Prep and Transformation, Topic: Building Transformation Pipelines in Derived Datasets Workday Prism Analytics Training Guide, Module: Data Prep and Transformation, Subtopic: Adding and Configuring Transformation Stages
NEW QUESTION # 18
A Prism data writer has two pipelines of data that need to be joined together:
* The primary pipeline includes point of sale data by sales agent.
* The secondary pipeline includes performance rating by sales agent.
The requirement is to keep all of the point of sale data from the primary pipeline and blend in performance rating data for the agents from the secondary pipeline where it exists. What Join type should be used to blend the data together?
  • A. Right Outer Join
  • B. Full Outer Join
  • C. Left Outer Join
  • D. Inner Join
In Workday Prism Analytics, the requirement to keep all data from the primary pipeline (point of sale data by sales agent) and blend in matching data from the secondary pipeline (performance rating by sales agent) where it exists indicates the need for a specific type of join. According to the official Workday Prism Analytics study path documents, a Left Outer Join (option C) is the appropriate join type for this scenario. A Left Outer Join includes all rows from the primary pipeline and matches them with rows from the secondary pipeline based on the join condition (e.g., sales agent ID). If no match is found in the secondary pipeline, the fields from the secondary pipeline will have NULL values, but the primary pipeline's data is fully retained, meeting the requirement to keep all point of sale data while blending in performance ratings where available.
The other options do not meet the requirement:
* A. Inner Join: An Inner Join only includes rows where matches exist in both pipelines, which would exclude point of sale data for sales agents without performance ratings, violating the requirement to keep all primary pipeline data.
* B. Right Outer Join: A Right Outer Join includes all rows from the secondary pipeline and matching rows from the primary pipeline, which prioritizes the secondary pipeline and may exclude some point of sale data, not meeting the requirement.
* D. Full Outer Join: A Full Outer Join includes all rows from both pipelines, with NULLs for non- matching rows, but this is broader than the requirement, which only needs all data from the primary pipeline, not necessarily all data from the secondary pipeline.
A Left Outer Join ensures that all point of sale data is retained while blending in performance ratings where they exist, aligning with the stated requirement.
Workday Prism Analytics Study Path Documents, Section: Data Prep and Transformation, Topic: Join Types and Their Applications in Prism Analytics Workday Prism Analytics Training Guide, Module: Data Prep and Transformation, Subtopic: Blending Data Using Join Stages
NEW QUESTION # 19
The PrepAwayTest is offering real and updated Workday Workday-Prism-Analytics practice test questions. Very easy to use and perfectly assist you in Workday Workday-Prism-Analytics exam preparation. Workday Workday-Prism-Analytics Exams and will give you real-time Workday Workday-Prism-Analytics exam preparation environment all the time.
Workday-Prism-Analytics Reliable Exam Test: https://www.prepawaytest.com/Workday/Workday-Prism-Analytics-practice-exam-dumps.html
Workday Workday-Prism-Analytics VCE Exam Simulator Obtaining a certificate may be not an easy thing for some candidates, choose us, we will help you get the certificate easily, For many candidates who are striving for their exams and Workday certification, maybe our Workday-Prism-Analytics test cram: Workday Pro Prism Analytics Exam will be your best exam, Workday Workday-Prism-Analytics VCE Exam Simulator Your individual privacy is under our rigorous privacy protection.
A self-configuring system would configure itself according Workday-Prism-Analytics Reliable Exam Test to its intended function, I was also given a way to skip things without exiting completely—a very forgiving touch.
Obtaining a certificate may be not an easy thing Workday-Prism-Analytics for some candidates, choose us, we will help you get the certificate easily, For many candidates who are striving for their exams and Workday certification, maybe our Workday-Prism-Analytics test cram: Workday Pro Prism Analytics Exam will be your best exam.
Pass Guaranteed Quiz Workday - Newest Workday-Prism-Analytics - Workday Pro Prism Analytics Exam VCE Exam SimulatorYour individual privacy is under our rigorous privacy protection, So whatever you have learned from our Workday Workday-Prism-Analytics exam studying materials is actually related to what you are going to be tested.
Thus, the Workday-Prism-Analytics study information in your hands will keep updated, and you can grasp the Workday-Prism-Analytics exam dynamic in real time.
2026 Latest PrepAwayTest Workday-Prism-Analytics PDF Dumps and Workday-Prism-Analytics Exam Engine Free Share: https://drive.google.com/open?id=1XiT8VuuuqlgX0gsownF7WeCBnDchRJyI
Posted at 2/10/2026 19:22:32        Only Author  2#
The article gave me so much to think about. EX316 dump file gives you a wealth of free content, created to assist you.
