PT-AM-CPE Exam Prepare is a Stepping Stone for You to Pass PT-AM-CPE Exam - Test
Posted at 2/3/2026 13:07:53
Passing the Ping Identity PT-AM-CPE certification exam is not a tough thing to do but we make it so. The main reason is that we don't know how to study from the PT-AM-CPE exam questions we have. We assume that we can study one night and can easily take the Certified Professional - PingAM Exam PT-AM-CPE Exam the next morning. This was possible only when we were the school. Now, it is not possible.
In the process of using PT-AM-CPE study question if the clients encounter the difficulties, the obstacles and the doubts they could contact our online customer service staff in the whole day. Our service team will update the PT-AM-CPE certification file periodically and provide one-year free update. Have known these advantages you may be curious to further understand the detailed information about our PT-AM-CPE training braindump and we list the detailed characteristics and functions of our PT-AM-CPE exam questions on the web for you to know.
Quiz Trustable Ping Identity - PT-AM-CPE - Vce Certified Professional - PingAM Exam TorrentAnother version of Certified Professional - PingAM Exam (PT-AM-CPE) practice exams is also available at TestkingPass and that is web-based. It has all specifications we have discussed above in the section of the Ping Identity PT-AM-CPE desktop practice test software. But the only difference is that this web-based PT-AM-CPE practice exam software works online and needs no software installation. Furthermore, this PT-AM-CPE Practice Exam is supported by both Windows and iOS, Android, Mac, and Linux. Since it is the web-based PT-AM-CPE practice exam, you can take it from Opera, Chrome, Safari, Firefox, or any other popular browser.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q77-Q82):NEW QUESTION # 77
In an authentication tree process, considering best practice, where can the collected context data for mobile devices be persisted for subsequent risk analysis?
- A. In shared node state
- B. In a browser cookie
- C. In the session state
- D. With the user profile
In PingAM 8.0.2, the Intelligent Access engine (Authentication Trees) uses a specific data-passing mechanism to move information between individual nodes within a single journey. When a journey involves collecting context-such as device metadata (OS, version, screen resolution), location data (IP, geofencing), or risk signals-this information must be stored temporarily while the tree evaluates the next steps.
According to the "Authentication Node Development" and "Nodes and Trees" documentation, PingAM uses two primary transient storage objects during the authentication flow:
Shared State: This is the primary map used to share data between nodes in the same tree. Contextual data collected by nodes like the Device Profile Collector or Browser Capabilities nodes is stored here. It exists only for the duration of the authentication journey.
Transient State: Similar to shared state, but often used for sensitive data that should not be visible to certain types of nodes or scripts.
The documentation identifies Shared Node State (Option B) as the best practice for persisting collected context during the tree process.
Session State (Option A) is only available after the authentication is successful and a session has been created. It is not suitable for data needed by nodes within the tree to make a decision (like a risk engine node).
User Profile (Option C) is for long-term persistence (LDAP/PingDS). Storing transient device context there would cause unnecessary database write overhead and privacy concerns.
Browser Cookies (Option D) are limited in size and pose security risks if used to store raw device data that could be tampered with by the client.
Therefore, for real-time risk analysis within a journey, nodes write data to the shared state, where subsequent nodes (like a Scripted Decision Node or Adaptive Risk Node) can retrieve and analyze it.
NEW QUESTION # 78
What scope is required to be included in a client's request if you wish to utilize the OpenID Connect capabilities of PingAM's OAuth2 implementation?
- A. profile
- B. openid
- C. openid+connect
- D. id
PingAM 8.0.2 implements OpenID Connect (OIDC) 1.0 as an identity layer on top of the OAuth 2.0 protocol. While OAuth 2.0 is designed for authorization (accessing resources), OIDC is designed for authentication (verifying who the user is).
According to the "OpenID Connect 1.0" documentation in PingAM, the presence of a specific scope in the Authorization Request is what signals to the AM server that the request should be treated as an OIDC flow rather than a standard OAuth2 flow. This mandatory scope is openid.
When PingAM receives an /oauth2/authorize request containing the scope=openid parameter:
It triggers the OIDC processing logic.
It ensures that an ID Token (a signed JWT containing user identity information) is generated alongside (or instead of) the Access Token.
It allows the client to later access the UserInfo Endpoint to retrieve further claims about the authenticated user.
Other scopes like profile (Option A), email, or address are optional OIDC scopes used to request specific sets of user claims, but they do not "activate" OIDC on their own. openid+connect and id (Options B and D) are not recognized standard scopes in the OIDC specification. Therefore, openid is the fundamental requirement for any OIDC interaction in PingAM 8.0.2.
NEW QUESTION # 79
If there is a need to reset a registered device over the REST API, which one of the following statements is incorrect?
- A. Administrators can call the REST API to reset a user's device profile
- B. Only administrator accounts, not user accounts, have the ability to use the REST API for resetting a device profile
- C. Administrators can provide authenticated users with a self-service page to reset their devices via the REST API
- D. Administrators can call the REST API to reset a device that is out of sync, where the HOTP counter exceeds the HOTP threshold window and requires a reset
In PingAM 8.0.2, device management is a critical part of the Multi-Factor Authentication (MFA) lifecycle. When a user registers a device for Push, OATH, or WebAuthn, that information is stored as a part of their identity profile. There are many scenarios where a device might need to be reset-for example, if a phone is lost, if the ForgeRock/Ping Authenticator app is reinstalled, or if an HOTP (HMAC-based One-Time Password) counter becomes desynchronized beyond the allowed window.
According to the PingAM documentation on "Managing Devices for MFA" and the "REST API for Device Management":
Administrator Capabilities: Administrators have the authority to manage device profiles for any user. They can list, rename, or delete (reset) device profiles using the /json/realms/root/realms/[realm]/users/[username]/devices endpoint. This is vital for helpdesk scenarios (Option D and B).
User Self-Service (The Incorrect Statement C): Statement C is technically incorrect because PingAM's REST API specifically supports self-service device management. An authenticated end-user has the permission to manage their own devices. They can call the /json/realms/root/realms/[realm]/users/[username]/devices endpoint using their own valid SSO token to delete their own registered devices. This allows organizations to build self-service portals where users can "Unpair" a lost device without calling support (Option A).
The internal security of PingAM ensures that while a regular user can only access their own device sub-resource, an administrator with the appropriate amAdmin or Delegate Admin privileges can access the resources of all users. Therefore, the claim that only administrator accounts can use the REST API for these actions is false and contradicts the "User Self-Service" philosophy built into the PingAM 8 API architecture.
NEW QUESTION # 80
During the PingAM startup process, what is the location and name of the file that the PingAM bootstrap process uses to connect to the configuration Directory Services repository?
- A. <user-home>/<am-instance-dir>/boot.json
- B. /path/to/tomcat/<tomcat-instance-dir>/webapps/<am-instance-dir>/boot.json
- C. <user-home-dir>/<am-instance-dir>/config/boot.json
- D. <user-home-dir>/.openam/config/boot.json
In PingAM 8.0.2, especially when utilizing File-Based Configuration (FBC), the startup sequence relies on a "bootstrap" phase to locate the system's configuration. According to the "Installation Guide" and "Configuration Directory Structure," the primary file involved in this process is named boot.json.
The boot.json file contains the essential connection details required for the AM binaries to find and unlock the configuration store (usually PingDS). This includes the LDAP host, port, bind DN, and references to the secret stores needed to decrypt the configuration.
The location of this file is determined by the Configuration Directory path specified during the initial setup. By default, PingAM creates its configuration directory in the home directory of the user running the web container. The standard path structure is <user-home>/<am-instance-dir>/. Therefore, the boot.json file is located at the root of this instance directory: <user-home>/<am-instance-dir>/boot.json.
Options A and D are incorrect because they place the file inside a /config subdirectory; while AM has many config files in subdirectories, the boot.json sits at the root to be accessible as the first point of entry.
Option B is incorrect because it suggests the file is stored within the Tomcat webapps folder. PingAM specifically avoids storing configuration data within the web application binaries to ensure that configuration persists even if the .war file is deleted or redeployed.
Understanding the location of boot.json is vital for DevOps engineers who need to automate the deployment of PingAM using tools like Amster or when troubleshooting a "Failed to connect to the configuration store" error during server startup.
NEW QUESTION # 81
Which area of PingAM does affinity mode relate to?
- A. Self-service
- B. Authentication
- C. Authorization
- D. Load balancing
In PingAM 8.0.2, the term Affinity Mode (or session affinity) is strictly related to Load Balancing (Option B). It describes a configuration where a load balancer ensures that all requests belonging to a specific user session are consistently routed to the same PingAM server instance in a cluster.
According to the "Load Balancing" and "Deployment Planning" documentation:
Affinity is critical for performance in stateful deployments. While PingAM can operate in a "stateless" manner by retrieving sessions from the Core Token Service (CTS) on every request, this creates unnecessary overhead. Affinity Mode allows the AM server to satisfy requests using its local "In-memory" session cache.
There are two primary levels of affinity discussed in PingAM documentation:
Client-to-AM Affinity: Usually handled by the load balancer using a cookie (like the AMLB cookie) to keep the user on the same AM node.
AM-to-DS Affinity: Used when AM connects to the CTS (PingDS). This ensures that an AM server always talks to the same directory server node to avoid "replication lag" where a session might be written to one DS node but not yet visible on another.
Without affinity, the system remains functional due to the CTS, but performance decreases as every request requires a cross-network database lookup. Therefore, affinity is a core concept of the Load Balancing and high-availability architecture.
NEW QUESTION # 82
You can become more competitive force in the job hunting market and you can also improve your ability in the process of getting a certificate. PT-AM-CPE study materials of us will help you get the certificate successfully. With experienced experts to compile PT-AM-CPE study materials, they are high-quality and accuracy, and you can pass the exam just one time. Moreover, we offer you free demo, and you can have a try before buying PT-AM-CPE Exam Dumps, so that you can have a better understanding of what you are going to buy.
PT-AM-CPE Reliable Test Cost: https://www.testkingpass.com/PT-AM-CPE-testking-dumps.html
The Ping Identity is one of the leading platforms that are committed to ace the Certified Professional - PingAM Exam PT-AM-CPE exam preparation with the Ping Identity PT-AM-CPE valid dumps, Ping Identity Vce PT-AM-CPE Torrent There is an old saying; nothing in the world is difficult for one who set his mind to it, NO need of second chances, Clear PT-AM-CPE Exam in first attempt, Users can customize the time and Certified Professional - PingAM Exam (PT-AM-CPE) questions of Ping Identity PT-AM-CPE practice tests according to their needs.
But in this newest book, I did find that I Vce PT-AM-CPE Torrent couldn't be specific enough without using the Scrum language, The wording of this sentence is so concise that it is almost PT-AM-CPE certainly impossible to understand unless you understand it from a clearer area.
Quiz 2026 Useful Ping Identity PT-AM-CPE: Vce Certified Professional - PingAM Exam TorrentThe Ping Identity is one of the leading platforms that are committed to ace the Certified Professional - PingAM Exam PT-AM-CPE Exam Preparation with the Ping Identity PT-AM-CPE valid dumps, There is an old saying; nothing in the world is difficult for one who set his mind to it.
Besides for the high quality by our Ping Identity masters team, they are also checking about the PT-AM-CPE update condition everyday.
- Vce PT-AM-CPE Torrent - Latest Ping Identity Certified Professional - PingAM Exam - PT-AM-CPE Reliable Test Cost 🦖 Go to website ☀ [url]www.examcollectionpass.com ️☀️ open and search for ✔ PT-AM-CPE ️✔️ to download for free 🥡Reliable PT-AM-CPE Test Objectives[/url]
- PT-AM-CPE Latest Exam Pass4sure 🥬 Exam PT-AM-CPE Question ⚓ Exam PT-AM-CPE Question 🏤 Simply search for ⇛ PT-AM-CPE ⇚ for free download on ⇛ [url]www.pdfvce.com ⇚ 📅
T-AM-CPE Certification Dumps[/url] - Free PDF Accurate Ping Identity - Vce PT-AM-CPE Torrent 😓 Search for ⇛ PT-AM-CPE ⇚ and download exam materials for free through ⏩ [url]www.troytecdumps.com ⏪ 🚰
T-AM-CPE Latest Dumps Ppt[/url] - 100% Pass Ping Identity - Efficient Vce PT-AM-CPE Torrent 🐟 ➠ [url]www.pdfvce.com 🠰 is best website to obtain ( PT-AM-CPE ) for free download 🐁Test PT-AM-CPE Question[/url]
- Vce PT-AM-CPE Torrent - Latest Ping Identity Certified Professional - PingAM Exam - PT-AM-CPE Reliable Test Cost 📥 Search for ▶ PT-AM-CPE ◀ and download it for free on ☀ [url]www.exam4labs.com ️☀️ website 🛀
T-AM-CPE Latest Exam Online[/url] - Vce PT-AM-CPE Torrent - Latest Ping Identity Certified Professional - PingAM Exam - PT-AM-CPE Reliable Test Cost 🔭 Easily obtain 「 PT-AM-CPE 」 for free download through ⮆ [url]www.pdfvce.com ⮄ 🌊Test PT-AM-CPE Question[/url]
- Pass Leader PT-AM-CPE Dumps ☮ PT-AM-CPE Latest Dumps Ppt 🪕 PT-AM-CPE New Exam Bootcamp 🆘 Easily obtain ⏩ PT-AM-CPE ⏪ for free download through ⏩ [url]www.pdfdumps.com ⏪ ✨Test PT-AM-CPE Question[/url]
- Free PDF Accurate Ping Identity - Vce PT-AM-CPE Torrent 🖌 Easily obtain free download of ⇛ PT-AM-CPE ⇚ by searching on ▛ [url]www.pdfvce.com ▟ 🌠
T-AM-CPE Certification Dumps[/url] - Free PDF Quiz PT-AM-CPE - Unparalleled Vce Certified Professional - PingAM Exam Torrent 🌭 Search for ☀ PT-AM-CPE ️☀️ and download it for free on 「 [url]www.practicevce.com 」 website 📏Real PT-AM-CPE Exam Answers[/url]
- Real PT-AM-CPE Exam Answers 🔜 Pass Leader PT-AM-CPE Dumps 📣 Detailed PT-AM-CPE Study Dumps ↕ Download ➠ PT-AM-CPE 🠰 for free by simply searching on ➡ [url]www.pdfvce.com ️⬅️ 🛰
T-AM-CPE Latest Test Format[/url] - Validate Your Skills with Ping Identity PT-AM-CPE Certified Professional - PingAM Exam Exam Dumps 📦 Search on ✔ [url]www.vce4dumps.com ️✔️ for ☀ PT-AM-CPE ️☀️ to obtain exam materials for free download 🎂Exam PT-AM-CPE Question[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.bandlab.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
